1 Reply Latest reply on Feb 10, 2011 10:29 PM by Linda Nicholls
    Replacing image when over slice
      I have an image in Fireworks which is divided into several slices. Is it possible if the user hovers over a slice to replace the rest of the image.
      For example
      In the piture in Fireworks, the hotspot covers the power supply, being covered (http://img42.imageshack.us/i/pcinsideunedited.jpg/) in an hotspot. Once the hotspot is hovered over, is it possible to replace the image with this one (http://img600.imageshack.us/i/insidepcbw.png/) ?
      Also, if it is not possible in Fireworks, would it work in DreamWeaver.
        • 1. Re: Replacing image when over slice
          Linda Nicholls Level 4
          Sure it can be done in Fireworks! Create a second state and place the image you want to switch to on it. Select the slice you want to use as the trigger (the one that causes the image swap) and click on it. You'll see a little target icon pop up.  Drag the icon to each slice you want to swap and chose State 2 when prompted.
