0 Replies Latest reply on Feb 11, 2011 6:32 AM by m1kal_
    maybe bug : ListCollectionView.addAll with a filter function
    m1kal_ Level 2
      I think I found a bug in the flex SDK. I've checked in JIRA and it seems that it is not yet reported.
      This simple code raise a "out of bouds exception" (flex SDK 4.1) :
      var list:ArrayCollection = new ArrayCollection();
      list.filterFunction = filter;
      list.refresh();
      var items:ArrayList = new ArrayList([1,2,3,4,5]);
      list.addAll(items);
      function filter(obj:Object) : Boolean {
           var n:Number = obj as Number;
           return n<2;
      I've checked the code in mx.collections.ListCollectionView and it's obvious : addAll is calling addAllAt. "addAllAt" is calling by looping over the list to add and calling addItemAt for each item, but it increments the index arguments even if the previous item was not really added (due to a filter restriction), and the "out of bounds exception occurs". In my opinion, addAllAt has to be changed as folowing :
      current version :
      public function addAllAt(addList:IList, index:int):void {
           var length:int = addList.length;
           for (var i:int=0; i < length; i++)
                this.addItemAt(addList.getItemAt(i), i+index);
      proposed version :
                var at:int = i+index;
                if(at>length) {
                     at = length;
                this.addItemAt(addList.getItemAt(i), at);
      Should I open a bug? Or am I missing something?
      M1kal
