7 Replies Latest reply on Jul 3, 2007 2:26 PM by ntsiii
    uanble to bind to property
      I cannot figure out why I am getting this error. I have a datagrid component with a XML data provider.
      warning: unable to bind to property 'memory' on class 'XML' (class is not an IEventDispatcher)
      warning: unable to bind to property 'value' on class 'XMLList' (class is not an IEventDispatcher)
      warning: unable to bind to property 'disks' on class 'XML' (class is not an IEventDispatcher)
      Everything is working correctly so why am I getting these warnings? My application is very simple but the warning comes up when I click on my datagrid item. This is the basic code:
      [Bindable]
      private var _data:XML;
      private function resultHandler(event:ResultEvent):void {
      _data = new XML(event.result);
      My datagrid dataProvider="{_data.file}"...........The code when I select an item is:
      <mx:Label text="{dg.selectedItem.memory}"/>
      <mx:Label text="{dg.selectedItem.memory.@value}"/>
      I am new to Flex and this is driving me crazy.
        • 1. Re: uanble to bind to property
          Confused still.
          • 2. Re: uanble to bind to property
            AwesomeDigital3
            I get the same warning, but it works for me too.
            Is this something we can fix, or should we just ignore the warning?
            Mathias
            • 3. Re: uanble to bind to property
              AwesomeDigital3 Level 1
              poisonver
              I just solved my issue
              Is the dataprovider for your datagrid an array that is defined in a class?
              Mine is. When I made the class bindable, the warnings went away.
              e.g.
              [Bindable]
              public class Individual
              If your set up is the same, give that a try.
              Mathias
              • 4. Re: uanble to bind to property
                Nope I am using xml as a dataprovider from an HTTP service call.
                I think that it is binding to the xml file but I have attributes inside that are not binding and I believe that is the problem. So I still don't have an answer and it still is driving me nuts.
                • 5. Re: uanble to bind to property
                  gjastrab
                  Is this resultHandler being called from an HTTPService? If so, try the following:
                  <mx:HTTPService id="srv" ... />
                  <mx:DataGrid dataProvider="{srv.lastResult.file}" />
                  • 6. uanble to bind to property
                    Yeah I tried that too I get the warning only when I click on the datagrid row I use
                    {dg.selectedItem.os}
                    {dg.selectedItem.os.@value}
                    As stated it is binding the xml class but not any attributes inside the xml meaning that it is setup like:
                    <files>
                    <file fileName="foobar" firstName="foo">
                    <os value="pass">Windows XP Professional</os>
                    etc.......
                    </file>
                    etc...
                    </files>
                    • 7. Re: uanble to bind to property
                      ntsiii Level 3
                      selectedItem is an Object and so is not recognized as XML. Cast the reference:
                      <mx:Label text="{XML(dg.selectedItem).memory.@value}"/> (technically not a cast, but a top-level function call)
                      If you don't need binding, consider directly assigning the value"
                      <mx:Label id="lbl1" initialize="lbl1.text=dg.selectedItem.memory.@value" ../>
                      Much lower overhead and avoids the binding warning without the cast.
                      Tracy
