3 Replies Latest reply on Feb 12, 2011 9:29 AM by John T Smith
    What's hardware should upgrade for Using Premiere CS4 to editing (AVCHD)m2ts file?
    freda_yeo
      What's hardware or software should upgrade for Using Premiere CS4 to editing (AVCHD)m2ts file?
      1st question: when i try to do editing by using Premiere CS4 AVCHD sequence timeline, the edting monitor seems not smooth (like wearing goggles) & delay, and when i use AME to encode m2ts file (which not yet edit) to AVI file (about 1 hour), it take 2h 13min to finish, is it normal?
      2nd question: i use mpeg2 HD 1440 file to do eding, the edting monitor also not very smooth but better than using m2ts file, after editing done, i try to encode these mpeg2 HD 1440 file (which edited about long 1 hr) to a New file mpeg2 1440 X 1080i HQ or even mpeg2 Pal DV HQ file, the encoding was not runthe encoding after wait for half an hour. How many hours it take usually????
      3rd question: i use m2ts file video file to export as a Bitmap, 1 frame 1 picture bitmap, it take long time too, about 1 or 2min to finish encoding, if i export more than 1 picture, it take even more time, i have experienced it, 3 or 4 pictures need about 10 or 15 min to finish encoding. i used to using mpeg2 HD 1440 file (which edited file) to export frame as picture, it not run the encoding at all. WHY ????
      i'm new in Premiere CS4,so i got many question about Premiere CS4, usually i use Premiere Pro 1.5 version
      my computer is: Intel (R) Core (TM) 2 Duo CPU
                               E7400 @ 2.80 GHz
                               2.80 GHz, 2.00 GB RAM
                               Graphic Card: ATI Radeon X1650 series
                              2 Hard Disks in my computer (C Drive is 300 GB (not sata) , D Drive is 500 GB sata)
      4th Question: Premiere CS5 & Premiere CS4 which one is better ???
      5th Question: What's different ATI Radeon and NVIDIA Card, which is better, which u suggest to. What is different Graphic Card and Video Card ?? Should i install HD Video Card ????
