4 Replies Latest reply on Feb 13, 2011 3:35 PM by George_Johnson
    Scripting a textbox value change.
    Mr Paneser
      I thought I was doing really well with this, any ideas why this isn't working?
      I've got a combo box and an invisble text field with a pre-set value.  there are 5 choices in the combo.  If it is not changed then I do nothing.  If the first choice is picked I change the value in the text box and display it.  If any other value is picked I simple make the text box visible
      I've added the code which should be OK.  No errors are thrown up, but I haven't got a watch set up to check the values in "section"
      function add_verification_notice()
          if (event.willCommit) return;
          // Get the value selected in the combo box
          var section = event.changeEx;
          // set a change message if required
          var message = "this message is good";
          // Exit if "Pick one" is selected
          if (section == 0) {
              return;
          // Display the fields for the selected section
          if (section == 1) {
      getField("VerificationBox").value = message;
        • 1. Re: Scripting a textbox value change.
          I would use the 'custom keystroke script' and the 'changeEx' property of the 'event.' object. You may want to set the 'commit selection immediately'.
          • 2. Re: Scripting a textbox value change.
            I think it more likely that the changeEx value is a string, not a number.
            • 3. Re: Scripting a textbox value change.
              Mr Paneser Level 1
              Apologies guys, but a newbe to programming in this lang
              Can you clarify points please
              • 4. Re: Scripting a textbox value change.
                George_Johnson MVP & Adobe Community Professional
                If that script is what you have for the custom Keystroke script of the combo box, it needs to be changed to:
                // Keystroke script for combo box
                (function () {
                    if (section == 0) {
                        return;
                    // Display themessage
                    if (section == 1) {
                If that function is defined in a document-level JavaScript, the Keystroke script for the combo box would be:
                // Call the function
                add_verification_notice();
                The first option sets up an anonymous function that calls itself. If you just define a function without calling it, nothing will happen.
