1 Reply Latest reply on Feb 12, 2011 11:12 AM by George_Johnson
    Filling out forms?
    KF6MHL
      I have Reader 9.  I want a product that will let me fill out pdf forms.  I'm 76 and it's getting harder to write.  Especialy in small form boxes.  If I could enter data directly into a pdf form it would be a great help.
      What options do i have?
      Joe
        • 1. Re: Filling out forms?
          George_Johnson MVP & Adobe Community Professional
          If the creator of the PDF "form" did not make it interactive by taking the additional step of adding form fields, there's not a lot you can do with Reader unless they enabled the Typewriter tool, which is probably unikely as well.
          There are some non-Adobe PDF viewers that allow you to add text, such as FoxIt Reader. But this won't work if the document has security settings that prevent it.
          So to summarize, Adobe Reader will work if the PDF contains form fields, or you can use it to add text if it has the necessary usage rights that allow the Typewriter tool to be enabled.
          Some non-Adobe PDF viewers will let you add text, but not if security settings prevent it.
