9 Replies Latest reply on Feb 23, 2011 8:31 AM by HelcioCarvalhoBrazil
    Flash Builder - Exit Code: 6  - 0 fatal error(s), 6 error(s), 4 warning(s)
    Gary Boulter
      Hello,
      I can’t install Flash Builder or Catalyst. They are both part of CS5.
      I've had a look at the forum and tried a couple of things
      ·         Run as administrator, re-installed Flash Builder or Catalyst
      ·         restarted computer in a minimised state, done a system scan etc
      Both of these methods have not worked for me and I keep getting the same message:
      Exit Code: 6
      -------------------------------------- Summary --------------------------------------
      WARNING: Warning: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
      WARNING: Warning: {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
      ERROR: Custom Action for payload {177E1CA1-14CC-4398-AB15-A5746EFE8F22} Adobe Flash Builder returned error. Failing this payload.
      ERROR: Custom Action for payload {E8815668-95B0-443D-AC92-2BFD7DD8F16A} Adobe Flash Catalyst CS5 returned error. Failing this payload.
      ERROR: The following payload errors were found during install:
      ERROR:  - Adobe Flash Builder: Install failed
      ERROR:  - Adobe Flash Player 10 ActiveX: Install failed
      ERROR:  - Adobe Flash Catalyst CS5: Install failed
      I’m running Windows 7, x64 (home premium) with 8 gig memory and a terabyte hard drive.
      I’m new to all of this I must confess so any help or advice would be greatly appreciated.
      Cheers J
        • 1. Re: Flash Builder - Exit Code: 6  - 0 fatal error(s), 6 error(s), 4 warning(s)
          C. Agruss (Adobe) Level 3
          Based on those Custom Action errors in the log, the problem could stem from installing into a path containing one or more unsupported characters.
          Are you installing to the default location, or using a custom path?
          -Chris
          • 2. Re: Flash Builder - Exit Code: 6  - 0 fatal error(s), 6 error(s), 4 warning(s)
            Gary Boulter Level 1
            Hi Chris and thank you so much for your response.
            I'm just instaling into the defualt location.
            - cheers,
            Gary.
            • 3. Re: Flash Builder - Exit Code: 6  - 0 fatal error(s), 6 error(s), 4 warning(s)
              That same error can sometimes mean there's a character it can't handle in the path to your user home folder.
              If you send me the full install log, I can probably spot the cause. More info here on where to find the full log:
              http://kb2.adobe.com/cps/844/cpsid_84451.html
              -Chris
              • 4. Re: Flash Builder - Exit Code: 6  - 0 fatal error(s), 6 error(s), 4 warning(s)
                Hi Chris,
                I hopefully I've done this right and found what you need to have a look at.
                Apologies if I've got it wrong
                [    6204] Sun Feb 13 12:52:24 2011  INFO
                Visit http://www.adobe.com/go/loganalyzer/ for more information
                START - Installer Session
                RIBS version: 3.0.122.0
                Win OS version: 6.1.0.0 64 bit Type: 1
                ::START TIMER:: [Total Timer]
                CHECK: Single instance running
                CHECK : Credentials
                Load Deployment File
                Create Required Folders
                Assuming install mode
                ::START TIMER:: [Bootstrap]
                Perform Bootstrapping ...
                :: END TIMER :: [Bootstrap] took 11758 miliseconds (11.758 seconds) DTR = 131.996 KBPS (0.128902 MBPS)
                Looking up install source path
                Sync Media DB ...
                ::START TIMER:: [Sync Media DB]
                Pre check media db sync
                End of Pre check media db sync. Exit code: 1
                Media db sync skipped as session is already installed
                :: END TIMER :: [Sync Media DB] took 125.649 miliseconds (0.125649 seconds)
                Ready to initialize session to start with ...
                ::START TIMER:: [CreatePayloadSession]
                -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
                Updated source path: E:\Adobe CS5
                Updating media info for: {01367616-4132-4311-911F-49D2EA82F7C2}
                  Type: 1, Volume Order: 1, Media Name: CS5 Master Coll1
                  Path: E:\Adobe CS5\payloads\AdobeOnLocation5RoyaltyWrapperAll\Install.db
                Updating media info for: {02731921-5711-4E7A-A898-D6BCF0F2A1CD}
                  Path: E:\Adobe CS5\payloads\AdobeCSXSInfrastructure2-mul\Install.db
                Updating media info for: {033E378E-6AD3-4AD5-BDEB-CBD69B31046C}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86\Microsoft_VC90_ATL_x86.msi
                Updating media info for: {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A}
                  Path: E:\Adobe CS5\payloads\AdobeAMP1.8-mul\AdobeAIRInstaller.exe
                Updating media info for: {03EEF3DA-71F9-4FE5-92AD-D10142E26459}
                  Path: E:\Adobe CS5\payloads\SiteCatalystNetAverages1-mul\Install.db
                Updating media info for: {04D84E18-23ED-46EA-9B41-789433E34D03}
                  Path: E:\Adobe CS5\payloads\AdobeContribute6-FFPlugin\Install.db
                Updating media info for: {0669F23C-1B69-41B4-A3ED-4F54A5986D66}
                  Path: E:\Adobe CS5\payloads\AdobeLinguisticsAll_x64\Install.db
                Updating media info for: {08D2E121-7F6A-43EB-97FD-629B44903403}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi
                Updating media info for: {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A}
                  Path: E:\Adobe CS5\payloads\AdobePhotoshop12-Support\Install.db
                Updating media info for: {0A9AAB1E-0FEA-1033-851A-888C0B8E78B5}
                  Type: 1, Volume Order: 2, Media Name: CS5 Master Coll2
                  Path: E:\Adobe CS5\payloads\AdobeInDesign7CommonLang-en_US\AdobeInDesign7CommonLang-en_US.msi
                Updating media info for: {0B754B55-6F63-461E-BB75-E8C883BDF88F}
                  Path: E:\Adobe CS5\payloads\AdobePremierePro5AllRetail\AdobePremierePro5AllRetail.msi
                Updating media info for: {0D067D13-C3D7-4EA6-B346-740CD91FD547}
                  Path: E:\Adobe CS5\payloads\AdobeBridge4-mul\Install.db
                Updating media info for: {0E3C6C75-872D-4B0D-B0B2-31C717250691}
                  Path: E:\Adobe CS5\payloads\AdobeEncore5RoyaltyAll\AdobeEncore5RoyaltyAll.msi
                Updating media info for: {0E659C1D-7686-4322-A501-58E3FEB4E743}
                  Path: E:\Adobe CS5\payloads\AdobeAfterEffects10AllRetail\AdobeAfterEffects10AllRetail.msi
                Updating media info for: {0EDAD58E-71F3-4D0E-9D32-A205533FC0E9}
                  Path: E:\Adobe CS5\payloads\AdobeKoreanSpeechAnalysisModels2All\AdobeKoreanSpeechAnalysisModels2All.msi
                Updating media info for: {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC80_ATL_x86\Microsoft_VC80_ATL_x86.msi
                Updating media info for: {11C0657F-2BD4-4CBC-87F3-9455DC91886E}
                  Path: E:\Adobe CS5\payloads\AdobeFontsRecommended_x64-mul\Install.db
                Updating media info for: {14A2CC02-4638-405D-8190-ECD7BFD32D6E}
                  Path: E:\Adobe CS5\payloads\AdobeFlash11-en_USLanguagePack\AdobeFlash11-en_USLanguagePack.msi
                Updating media info for: {157D044B-C60D-1015-B0DB-A40823CC0F49}
                  Path: E:\Adobe CS5\payloads\AdobeToolhints-mul\Install.db
                Updating media info for: {164965E8-4BB0-4EEB-AFBA-75785A2A2A7F}
                  Path: E:\Adobe CS5\payloads\AdobeFireworks11All\AdobeFireworks11All.msi
                Updating media info for: {177E1CA1-14CC-4398-AB15-A5746EFE8F22}
                  Path: E:\Adobe CS5\payloads\AdobeFlashBuilder-mul\AdobeFlashBuilder-mul.msi
                Updating media info for: {17C6080E-F475-4B49-A30C-EEB85673E999}
                  Path: E:\Adobe CS5\payloads\AdobePDFL9.9_x64-mul\Install.db
                Updating media info for: {1A48007B-34D2-44BD-8708-B570F5339C14}
                  Path: E:\Adobe CS5\payloads\AdobeEncore5RoyaltyWrapperAll\Install.db
                Updating media info for: {1D809D80-28A4-11DF-A816-0024E8692489}
                  Path: E:\Adobe CS5\payloads\DeviceCentral3LP-en_US\Install.db
                Updating media info for: {1D830E80-28A4-11DF-A025-0024E8692489}
                  Path: E:\Adobe CS5\payloads\DeviceCentral3LP-en_GB\Install.db
                Updating media info for: {1E9FC118-651D-4934-97BE-E53CAE5C7D45}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86_x64\Microsoft_VC80_MFCLOC_x86_x64.msi
                Updating media info for: {20F72893-AEC7-4954-9EAA-F07FD6184781}
                  Path: E:\Adobe CS5\payloads\AdobeAfterEffects10RoyaltyWrapperAll\Install.db
                Updating media info for: {22F41D72-2E97-46AE-B8C4-EF66876C7838}
                  Path: E:\Adobe CS5\payloads\AdobePremierePro5ProtectedWrapperAll\AdobePremierePro5ProtectedWrapperAll.ms i
                Updating media info for: {234A555C-70F5-48FB-A7E2-32410EB5AF64}
                  Path: E:\Adobe CS5\payloads\AdobeItalianSpeechAnalysisModels2All\AdobeItalianSpeechAnalysisModels2All.ms i
                Updating media info for: {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655}
                  Path: E:\Adobe CS5\payloads\AdobeMobileExtension_Flash11-en_US\AdobeMobileExtension_Flash11-en_US.msi
                Updating media info for: {26B63C3A-0BFF-1033-B389-A7ACEC31657E}
                  Path: E:\Adobe CS5\payloads\AdobeInDesign7AppLang-en_GB\AdobeInDesign7AppLang-en_GB.msi
                Updating media info for: {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA}
                  Path: E:\Adobe CS5\payloads\AdobeXMPPanelsAll\Install.db
                Updating media info for: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5}
                  Path: E:\Adobe CS5\payloads\AdobeAPE3-mul\Install.db
                Updating media info for: {30221E3E-4C47-4560-A296-DD9ABB500C21}
                  Path: E:\Adobe CS5\payloads\AIR2_Flash11-mul\Install.db
                Updating media info for: {33A3F995-8333-4676-8D6F-AB7674BB52EA}
                  Path: E:\Adobe CS5\payloads\AMEPCIWrapper5All\Install.db
                Updating media info for: {34F82E6B-8096-45CA-B604-ACACAC22E553}
                  Path: E:\Adobe CS5\payloads\AdobePremierePro5en_USLanguagePack\AdobePremierePro5en_USLanguagePack.msi
                Updating media info for: {36D02DA9-35F2-4686-A2FE-EF3014D2E226}
                  Path: E:\Adobe CS5\payloads\AdobeSpanishSpeechAnalysisModels2All\AdobeSpanishSpeechAnalysisModels2All.ms i
                Updating media info for: {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3}
                  Path: E:\Adobe CS5\payloads\AdobeCameraRaw6.0All\Install.db
                Updating media info for: {39CB2E53-5326-4939-8B5A-0402C6EFBFE3}
                  Path: E:\Adobe CS5\payloads\AdobeColorCommonSetCMYK3-mul\Install.db
                Updating media info for: {3A8C7CB3-2A2E-4EB9-99C9-DF08C324BA70}
                  Path: E:\Adobe CS5\payloads\AdobeFireworks11en_USLanguagePack\AdobeFireworks11en_USLanguagePack.msi
                Updating media info for: {3BF96AC2-0CA1-11DF-B07B-459956D89593}
                  Path: E:\Adobe CS5\payloads\AdobeHelp\AIRInstallerRunner.exe
                Updating media info for: {3F023875-4A52-4605-9DB6-A88D4A813E8D}
                  Path: E:\Adobe CS5\payloads\AdobeCameraRawProfile6.0All\Install.db
                Updating media info for: {3F6B5CAC-733F-1029-B5BD-C0F5E35809F0}
                  Path: E:\Adobe CS5\payloads\AdobeBuzzword-mul\Install.db
                Updating media info for: {406D22BD-7910-479B-96AA-0DB8A36C694B}
                  Path: E:\Adobe CS5\payloads\AdobeAfterEffects10ProtectedWrapperAll\Install.db
                Updating media info for: {40F95A03-885A-45fb-9A14-486BEFEDDF34}
                  Path: E:\Adobe CS5\payloads\AdobeFlashPlayer10_plRel_mul\AdobeFlashPlayer10_plRel_mul.msi
                Updating media info for: {414BDCF9-DE14-4083-BE96-2F4193CE8BBA}
                  Path: E:\Adobe CS5\payloads\AdobeContribute6en_USLanguagePack\AdobeContribute6en_USLanguagePack.msi
                Updating media info for: {4355EE3F-2FDD-4EF4-83EA-2465FBF95B16}
                  Path: E:\Adobe CS5\payloads\AdobeGermanSpeechAnalysisModels2All\Install.db
                Updating media info for: {4438C826-1FD0-4D04-A70B-24FE1580AB21}
                  Path: E:\Adobe CS5\payloads\AdobeMiniBridge1-mul\Install.db
                Updating media info for: {4569AD91-47F4-4D9E-8FC9-717EC32D7AE1}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86_x64\Microsoft_VC80_CRT_x86_x64.msi
                Updating media info for: {479C08E9-FACF-4190-A37A-81D65B4C8D4E}
                  Path: E:\Adobe CS5\payloads\AdobeContribute6-IEPlugin\Install.db
                Updating media info for: {4BE1791F-1D8A-4B8E-B803-D97C5D7CB245}
                  Path: E:\Adobe CS5\payloads\AdobeSoundbooth3ProtectedWrapperAll\Install.db
                Updating media info for: {4C08199E-0D93-4227-8325-F024E71CA7A1}
                  Path: E:\Adobe CS5\payloads\AdobeSING3-mul\Install.db
                Updating media info for: {50A16F0B-47DA-4583-B4FE-E026719A2024}
                  Path: E:\Adobe CS5\payloads\AdobePhotoshop12-en_US_x64\AdobePhotoshop12-en_US_x64.msi
                Updating media info for: {54F4466A-091A-46DA-B697-43D55CEF9DF6}
                  Path: E:\Adobe CS5\payloads\AdobeColorJA_ExtraSettings3-mul\Install.db
                Updating media info for: {56540320-C921-1029-83D9-FE864D1FC1DF}
                  Path: E:\Adobe CS5\payloads\AdobeReviewPanel2-mul\Install.db
                Updating media info for: {5658F35F-15B9-1033-8337-97B78F2D0BE0}
                  Path: E:\Adobe CS5\payloads\AdobeInDesign7IconHandler64-mul\AdobeInDesign7IconHandler64-mul.msi
                Updating media info for: {565DE707-5798-4FC3-8DF6-0F58A348A9B0}
                  Path: E:\Adobe CS5\payloads\AdobePremierePro5RoyaltyAll\AdobePremierePro5RoyaltyAll.msi
                Updating media info for: {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD}
                  Path: E:\Adobe CS5\payloads\AdobeMobileExtension_Flash11-mul\AdobeMobileExtension_Flash11-mul.msi
                Updating media info for: {5DDABB74-A879-4BE7-A4C6-FD41793942DB}
                  Path: E:\Adobe CS5\payloads\AMEDolby5All_x64\AMEDolby5All_x64.msi
                Updating media info for: {5E08533A-2C1B-469D-AFD5-953C9D00031F}
                  Path: E:\Adobe CS5\payloads\BrowserLabCSLive-mul\Install.db
                Updating media info for: {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41}
                  Path: E:\Adobe CS5\payloads\AdobeCameraRaw6.0All-x64\Install.db
                Updating media info for: {635DCFA5-3A47-4452-AEC7-D3B23FFE929D}
                  Path: E:\Adobe CS5\payloads\iPhone_Flash11-mul\iPhone_Flash11-mul.msi
                Updating media info for: {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86\Microsoft_VC90_MFC_x86.msi
                Updating media info for: {64D991B0-4E64-47AC-8A35-291DA2E7D02F}
                  Path: E:\Adobe CS5\payloads\AdobeAfterEffects10SupportAll\Install.db
                Updating media info for: {66173EC7-974E-4652-9468-4A93D2481BF0}
                  Path: E:\Adobe CS5\payloads\AdobeStoryExtension-mul\Install.db
                Updating media info for: {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}
                  Path: E:\Adobe CS5\payloads\AdobePhotoshop12-Core_x64\AdobePhotoshop12-Core_x64.msi
                Updating media info for: {681DE732-3F3A-42F2-91C9-84B1CC9B8535}
                  Path: E:\Adobe CS5\payloads\AdobeContribute6en_GBLanguagePack\AdobeContribute6en_GBLanguagePack.msi
                Updating media info for: {68CEA5C9-2964-4ECB-84A4-D77C511332BC}
                  Path: E:\Adobe CS5\payloads\AMECore5All_x64\Install.db
                Updating media info for: {694213D7-1E0E-4C8F-B822-E2E3680C0FCE}
                  Path: E:\Adobe CS5\payloads\AMECore5All\Install.db
                Updating media info for: {69582206-7E5D-4476-A8F4-ECF90E9C8A69}
                  Path: E:\Adobe CS5\payloads\AdobePhotoshop12-en_US\AdobePhotoshop12-en_US.msi
                Updating media info for: {6ACDB89B-63FB-4C7D-8490-7528E248F25B}
                  Path: E:\Adobe CS5\payloads\AdobeAfterEffects10en_USLanguagePack\AdobeAfterEffects10en_USLanguagePack.ms i
                Updating media info for: {6B485102-4593-43F6-BA45-F14D690B0C64}
                  Path: E:\Adobe CS5\payloads\AdobeSuiteSharedConfiguration-mul\Install.db
                Updating media info for: {6BA6F6D7-1D30-482A-B9B8-20E79D6DB4F9}
                  Path: E:\Adobe CS5\payloads\AdobePremierePro5RoyaltyWrapperAll\AdobePremierePro5RoyaltyWrapperAll.msi
                Updating media info for: {6C7D437A-D2E9-4FE9-A4D9-A6329860835C}
                  Path: E:\Adobe CS5\payloads\AdobeLinguisticsAll\Install.db
                Updating media info for: {6D96660C-1444-410E-9A84-681C0AFB8937}
                  Path: E:\Adobe CS5\payloads\AdobePDFSettings10-mul\AdobePDFSettings10-mul.msi
                Updating media info for: {6E505C8F-2896-11DF-9B64-0013724DD917}
                  Path: E:\Adobe CS5\payloads\AdobeDeviceCentral3-all\Install.db
                Updating media info for: {6F29BE46-E5F3-4146-8A84-20301E5C985A}
                  Path: E:\Adobe CS5\payloads\AdobeColorEU_ExtraSettings3-mul\Install.db
                Updating media info for: {6F3A624B-1B72-4081-96E8-23261F389C5C}
                  Path: E:\Adobe CS5\payloads\AdobeTypeSupport10-mul\Install.db
                Updating media info for: {73A4DC5E-226E-42BA-8ECA-2822592AC044}
                  Path: E:\Adobe CS5\payloads\AdobeVideoProfilesCS3-mul\Install.db
                Updating media info for: {771C9F59-3F22-4610-A23E-321A98ECA264}
                  Path: E:\Adobe CS5\payloads\AdobeOnLocation5en_USLanguagePack\AdobeOnLocation5en_USLanguagePack.msi
                Updating media info for: {7745F18B-FD8A-4011-BE16-588900C503D0}
                  Path: E:\Adobe CS5\payloads\AdobeFlashFonts1-mul\Install.db
                Updating media info for: {7816FDDE-40D4-482D-AD7D-97858985DB3E}
                  Path: E:\Adobe CS5\payloads\AdobeOnLocation5RoyaltyAll\AdobeOnLocation5RoyaltyAll.msi
                Updating media info for: {78A53622-CDBA-49D1-A3D0-D563FB398D0C}
                  Path: E:\Adobe CS5\payloads\AdobeColorCommonSetRGB3-mul\Install.db
                Updating media info for: {7A33510F-1580-42C2-877E-8C5502566292}
                  Path: E:\Adobe CS5\payloads\AdobeAPE3_x64-mul\Install.db
                Updating media info for: {7B7DE224-2ACA-41E2-A94D-5A6C6D75106D}
                  Path: E:\Adobe CS5\payloads\AdobeContribute6-OfficePlugin\AdobeContribute6-OfficePlugin.msi
                Updating media info for: {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E}
                  Path: E:\Adobe CS5\payloads\AdobePhotoshop12-Core\AdobePhotoshop12-Core.msi
                Updating media info for: {7E5AA19B-0B85-4f44-BA26-728851489200}
                  Path: E:\Adobe CS5\payloads\AdobeFlashPlayer10_axRel_mul\AdobeFlashPlayer10_axRel_mul.msi
                Updating media info for: {7EB208EE-0C2B-1033-A6DC-E1BD0289A1F4}
                  Path: E:\Adobe CS5\payloads\AdobeInDesign7AppLang-en_US\AdobeInDesign7AppLang-en_US.msi
                Updating media info for: {7F9C94CD-0BAC-4F8F-8990-6A5886F4D550}
                  Path: E:\Adobe CS5\payloads\AdobeFontsRequired_x64-mul\Install.db
                Updating media info for: {805ABF27-1582-1033-B4AC-82A1DE0DD827}
                  Path: E:\Adobe CS5\payloads\AdobeInDesign7CommonBase-mul\Install.db
                Updating media info for: {8557397C-A42D-486F-97B3-A2CBC2372593}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\Microsoft_VC90_ATL_x86_x64.msi
                Updating media info for: {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B}
                  Path: E:\Adobe CS5\payloads\AdobePhotoshop12-en_GB\AdobePhotoshop12-en_GB.msi
                Updating media info for: {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}
                  Path: E:\Adobe CS5\payloads\AdobeCSXSExtensions2-mul\Install.db
                Updating media info for: {925D058B-564A-443A-B4B2-7E90C6432E55}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC80_ATL_x86_x64\Microsoft_VC80_ATL_x86_x64.msi
                Updating media info for: {925ED7E4-E1B6-4544-8141-1C98A18D2E2E}
                  Path: E:\Adobe CS5\payloads\AdobeOutputModuleAll\Install.db
                Updating media info for: {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\Microsoft_VC90_CRT_x86_x64.msi
                Updating media info for: {92D4A929-78F1-4EC3-B626-08B3CF5B784F}
                  Path: E:\Adobe CS5\payloads\AMEPCI5All\AMEPCI5All.msi
                Updating media info for: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
                Updating media info for: {955EB78F-C938-4EA8-8470-C6EA71685834}
                  Path: E:\Adobe CS5\payloads\AIR2_Flash11-en_US\Install.db
                Updating media info for: {966B69F2-0FBD-1033-B01C-D13C02FFF33F}
                  Path: E:\Adobe CS5\payloads\AdobeInDesign7CommonLang-en_GB\AdobeInDesign7CommonLang-en_GB.msi
                Updating media info for: {98DD55B6-C58C-462F-B8A4-F0585BFEBB15}
                  Path: E:\Adobe CS5\payloads\AdobeCMaps3_x64-mul\Install.db
                Updating media info for: {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7}
                  Path: E:\Adobe CS5\payloads\AdobeTypeSupport10_x64-mul\Install.db
                Updating media info for: {9B97EC91-B3FD-4BFF-88FC-5345A26AC2E7}
                  Path: E:\Adobe CS5\payloads\AdobeIllustrator15-mul\AdobeIllustrator15-mul.msi
                Updating media info for: {A013B68A-B1D9-470F-BB0F-816752F096A3}
                  Path: E:\Adobe CS5\payloads\AMEPCIWrapper5All_x64\Install.db
                Updating media info for: {A1E0C87F-BFE5-490A-898E-05BD4DD2BADF}
                  Path: E:\Adobe CS5\payloads\AdobeInternationalEnglishSpeechAnalysisModels2All\AdobeInternationalEnglishS peechAnalysisModels2All.msi
                Updating media info for: {A32910E5-4084-4A0E-9FFF-D2E9C1B1C134}
                  Path: E:\Adobe CS5\payloads\AdobeEncoreFunctionalContent5All\Install.db
                Updating media info for: {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\Microsoft_VC90_MFC_x86_x64.msi
                Updating media info for: {A47C8AE9-D51B-4A58-A051-396158FC3012}
                  Path: E:\Adobe CS5\payloads\AdobePhotoshop12-en_GB_x64\AdobePhotoshop12-en_GB_x64.msi
                Updating media info for: {A5A8E72E-1B9D-4F99-ADED-F3595CB3D03E}
                  Path: E:\Adobe CS5\payloads\AdobeVideoProfilesAE3-mul\Install.db
                Updating media info for: {A8798E04-96FF-4564-9157-0D4C89CB794C}
                  Path: E:\Adobe CS5\payloads\AdobeDynamiclinkSupport5All\Install.db
                Updating media info for: {AAE6F374-91CB-45FB-9282-4CFA0DED2088}
                  Path: E:\Adobe CS5\payloads\AMEDolbyWrapper5All\Install.db
                Updating media info for: {ABDC1F61-2C50-4BB1-ACDA-66D412D72582}
                  Path: E:\Adobe CS5\payloads\AdobeOnLocation5All\AdobeOnLocation5All.msi
                Updating media info for: {ADAF6949-4547-4B3D-97C5-6FB4D0C08A1E}
                  Path: E:\Adobe CS5\payloads\AdobeSoundbooth3RoyaltyWrapperAll\Install.db
                Updating media info for: {AE9B837F-D135-42FC-BE03-33545B5DCBDC}
                  Path: E:\Adobe CS5\payloads\AdobeWinSoftLinguisticsPluginAll\Install.db
                Updating media info for: {B55FDCCB-8A45-4943-8D90-585C3490A032}
                  Path: E:\Adobe CS5\payloads\AdobeWinSoftLinguisticsPluginAll_x64\Install.db
                Updating media info for: {B60B8713-F828-44F9-BEEE-7596F814E540}
                  Path: E:\Adobe CS5\payloads\AdobeColorEU_Recommended3-mul\Install.db
                Updating media info for: {B842A584-A0BF-4870-A850-9C0E52FD6A20}
                  Path: E:\Adobe CS5\payloads\AdobeEncore5en_USLanguagePack\AdobeEncore5en_USLanguagePack.msi
                Updating media info for: {B8D286BC-A68D-4E74-9F68-8756A49896D8}
                  Path: E:\Adobe CS5\payloads\AdobePremierePro5ProtectedAll\AdobePremierePro5ProtectedAll.msi
                Updating media info for: {BAE5212B-6651-4AD8-B26A-1B284D2665C6}
                  Path: E:\Adobe CS5\payloads\AdobePDFL9.9-mul\Install.db
                Updating media info for: {BB024724-14D5-4AB6-B21C-74EDA63A0A39}
                  Path: E:\Adobe CS5\payloads\HIL_Help_Search\Install.db
                Updating media info for: {BD0D6363-E961-410F-8BF4-ECD8795F3923}
                  Path: E:\Adobe CS5\payloads\AdobeCMaps3-mul\Install.db
                Updating media info for: {BEC5B482-32A1-43E0-B7F7-9BF9592A1069}
                  Path: E:\Adobe CS5\payloads\AdobeColorNA_ExtraSettings3-mul\Install.db
                Updating media info for: {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}
                  Path: E:\Adobe CS5\payloads\AdobeAfterEffects10ProtectedAll\AdobeAfterEffects10ProtectedAll.msi
                Updating media info for: {C79312BD-3E76-4474-A10C-1435D1856A4B}
                  Path: E:\Adobe CS5\payloads\AdobeDreamweaver11-mul\AdobeDreamweaver11-mul.msi
                Updating media info for: {C8C1BAD5-54E6-4146-AD07-3A8AD36569C3}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC80_MFC_x86_x64\Microsoft_VC80_MFC_x86_x64.msi
                Updating media info for: {C925A34A-01B9-42C3-BB88-C7A78835F0EC}
                  Path: E:\Adobe CS5\payloads\ph\ph.msi
                Updating media info for: {CBDD7465-CE11-4A58-9497-C370B65923F1}
                  Path: E:\Adobe CS5\payloads\AdobeFontsRequired-mul\Install.db
                Updating media info for: {CBE4F6C3-788E-4CAC-BA25-26FE39A3BC8C}
                  Path: E:\Adobe CS5\payloads\AdobeSoundbooth3AllTrial\AdobeSoundbooth3AllTrial.msi
                Updating media info for: {CC0EF75D-9336-4E4F-B4A2-99E2E60E161F}
                  Path: E:\Adobe CS5\payloads\AdobeAfterEffectsPresets10All\Install.db
                Updating media info for: {CD29B5CA-4727-4114-9AD9-25CCCE6E4014}
                  Path: E:\Adobe CS5\payloads\AdobeAfterEffects10RoyaltyAll\AdobeAfterEffects10RoyaltyAll.msi
                Updating media info for: {CD693E49-C5EF-4FA6-9037-9B636931C02B}
                  Path: E:\Adobe CS5\payloads\AdobeAmericanEnglishSpeechAnalysisModels2All\Install.db
                Updating media info for: {CFA46C39-C539-4BE9-9364-495003C714AD}
                  Path: E:\Adobe CS5\payloads\SwitchBoard2.0All\Install.db
                Updating media info for: {CFC9F871-7C40-40B6-BE4A-B98A5B309716}
                  Path: E:\Adobe CS5\payloads\AdobeFlash11-mul\AdobeFlash11-mul.msi
                Updating media info for: {D0DAEA50-AD52-4BF9-AD5F-3E09564A8692}
                  Path: E:\Adobe CS5\payloads\AdobeIllustrator15en_GBLanguagePack\AdobeIllustrator15en_GBLanguagePack.msi
                Updating media info for: {D1A19B02-817E-4296-A45B-07853FD74D57}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC80_MFC_x86\Microsoft_VC80_MFC_x86.msi
                Updating media info for: {D26EEF95-420A-4726-B85D-AFBE752EF526}
                  Path: E:\Adobe CS5\payloads\AdobeColorNA_Recommended3-mul\Install.db
                Updating media info for: {D31D91FE-F0E8-4DF1-812C-9400BE92A386}
                  Path: E:\Adobe CS5\payloads\AdobeColorPhotoshop3-mul\Install.db
                Updating media info for: {D3598CAC-AEB3-4234-A1E0-16F47D5F38CC}
                  Path: E:\Adobe CS5\payloads\AMEDolby5All\AMEDolby5All.msi
                Updating media info for: {D3A8C87E-ED6A-41DB-8B21-C29EDA65B154}
                  Path: E:\Adobe CS5\payloads\AdobeIllustrator15en_USLanguagePack\AdobeIllustrator15en_USLanguagePack.msi
                Updating media info for: {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C}
                  Path: E:\Adobe CS5\payloads\aifsdk-win\Install.db
                Updating media info for: {D5E7D8B9-9B8F-4DA0-9B2C-167DC889B0E1}
                  Path: E:\Adobe CS5\payloads\AdobeAfterEffectsFunctionalContent10All\Install.db
                Updating media info for: {D8465547-5D5B-4856-A93A-8AC0A05C5D4D}
                  Path: E:\Adobe CS5\payloads\AdobeEncore5AllRetail\AdobeEncore5AllRetail.msi
                Updating media info for: {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\Microsoft_VC80_MFCLOC_x86.msi
                Updating media info for: {DE5DE662-2ECB-4D93-967B-221FBCC8A736}
                  Path: E:\Adobe CS5\payloads\AdobeSoundbooth3ProtectedAll\AdobeSoundbooth3ProtectedAll.msi
                Updating media info for: {DE60F0DE-469A-42DC-A678-978313210057}
                  Path: E:\Adobe CS5\payloads\AdobeContribute6-mul\AdobeContribute6-mul.msi
                Updating media info for: {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3}
                  Path: E:\Adobe CS5\payloads\AdobePDFSettings10-ja_JP\AdobePDFSettings10-ja_JP.msi
                Updating media info for: {DEC9BB26-1381-1033-A965-E3BD5F2EF8BC}
                  Path: E:\Adobe CS5\payloads\AdobeInDesign7AppBase2-mul\Install.db
                Updating media info for: {E319B9F9-4DE6-462C-970B-77D06C7807EE}
                  Path: E:\Adobe CS5\payloads\Players_Flash11-mul\Players_Flash11-mul.msi
                Updating media info for: {E39A5ABD-516B-46F9-A042-694BBA6A4E08}
                  Path: E:\Adobe CS5\payloads\AdobeFontsRecommended-mul\Install.db
                Updating media info for: {E3E040E8-4CCD-4C71-8BAF-80BB2AD5DA04}
                  Path: E:\Adobe CS5\payloads\AdobeDreamweaver11en_USLanguagePack\AdobeDreamweaver11en_USLanguagePack.msi
                Updating media info for: {E4CB336B-159D-1033-B84D-B9A01A0BE4A9}
                  Path: E:\Adobe CS5\payloads\AdobeInDesign7IconHandler-mul\Install.db
                Updating media info for: {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6}
                  Path: E:\Adobe CS5\payloads\AdobeExtensionManager5.0All\Install.db
                Updating media info for: {E5087BCA-6496-47A7-B9C4-B85D1CF062AE}
                  Path: E:\Adobe CS5\payloads\AdobeColorJA_Recommended3-mul\Install.db
                Updating media info for: {E5DD149F-8370-48F9-A32C-2E3DC776CFFB}
                  Path: E:\Adobe CS5\payloads\AdobeJRECS5-mul\Install.db
                Updating media info for: {E6F68811-F702-492C-A7DA-D22CA670BC22}
                  Path: E:\Adobe CS5\payloads\AdobeSoundbooth3en_USLanguagePack\AdobeSoundbooth3en_USLanguagePack.msi
                Updating media info for: {E7F2C606-8529-4028-B26E-8407DB43DD45}
                  Path: E:\Adobe CS5\payloads\AdobeFrenchSpeechAnalysisModels2All\Install.db
                Updating media info for: {E8815668-95B0-443D-AC92-2BFD7DD8F16A}
                  Path: E:\Adobe CS5\payloads\AdobeFlashCatalyst-mul\AdobeFlashCatalyst-mul.msi
                Updating media info for: {E995AC53-954A-48D2-A861-613B8D42A9BE}
                  Path: E:\Adobe CS5\payloads\AdobeExtendScriptToolkit3.5.0-mul\Install.db
                Updating media info for: {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345}
                  Path: E:\Adobe CS5\payloads\TLF_Flash11-mul\TLF_Flash11-mul.msi
                Updating media info for: {F319804F-E3A4-4C02-8AEC-CB39A4F6447E}
                  Path: E:\Adobe CS5\payloads\AdobeSoundbooth3RoyaltyAll\AdobeSoundbooth3RoyaltyAll.msi
                Updating media info for: {F3ECF5C7-9A9D-460A-B3D6-C7E4C1DFD040}
                  Path: E:\Adobe CS5\payloads\AdobeMotionPicture3-mul\Install.db
                Updating media info for: {F46A4C18-2EAD-49F0-A244-994226F93B39}
                  Path: E:\Adobe CS5\payloads\AdobeJapaneseSpeechAnalysisModels2All\AdobeJapaneseSpeechAnalysisModels2All. msi
                Updating media info for: {F4EC52C6-1223-4EA9-8C48-F4E6AB2EEC19}
                  Path: E:\Adobe CS5\payloads\AdobePremiereProFunctionalContent5All\Install.db
                Updating media info for: {F6CCA85F-7527-4AFF-82B6-26532A74A244}
                  Path: E:\Adobe CS5\payloads\AdobeFireworks11en_GBLanguagePack\AdobeFireworks11en_GBLanguagePack.msi
                Updating media info for: {F6FA54C9-3E8F-4416-905C-DA5398DF9640}
                  Path: E:\Adobe CS5\payloads\AdobeAIR1.5.3-mul\AdobeAIRInstaller.exe
                Updating media info for: {F77882B9-A94F-44F4-A739-8370749255B6}
                  Path: E:\Adobe CS5\payloads\AdobePremierePro5SupportAll\Install.db
                Updating media info for: {F8F0792D-8A6B-44F6-B2AF-AD1A40DF1BFD}
                  Path: E:\Adobe CS5\payloads\AMEDolbyWrapper5All_x64\Install.db
                Updating media info for: {F9766AC1-1461-1033-B862-DF8FE1C033BE}
                  Path: E:\Adobe CS5\payloads\AdobeInDesign7AppBase-mul\AdobeInDesign7AppBase-mul.msi
                Updating media info for: {F9C71630-0EE3-475C-9E2B-ED95AE197DBD}
                  Path: E:\Adobe CS5\payloads\AMEPCI5All_x64\AMEPCI5All_x64.msi
                Updating media info for: {FBB02B04-C034-4382-A3F6-57416E2752C4}
                  Path: E:\Adobe CS5\payloads\AdobeMasterCollection5-mul\AdobeMasterCollection5-mul.msi
                Updating media info for: {FD5603A3-1375-1033-872D-8F09140FFDB2}
                  Path: E:\Adobe CS5\payloads\AdobeInDesign7AppFSet-Roman\Install.db
                --------------------  END  - Updating Media Sources -  END  --------------------
                Supported RIBS version range: [0.0.66.0,3.0.122.0]
                ----------------- CreatePayloadSession: machine is x64 ---------------
                [    6204] Sun Feb 13 12:52:30 2011  INFO
                ______ Verify Dependency Subscribers ______
                Setting property "INSTALLDIR" to: C:\Program Files\Adobe
                Setting property "installLanguage" to: en_GB
                Attempting to find the selected language in the set of available payload languages
                Setting property "installSourcePath" to: E:\Adobe CS5
                Overwrite property "userASUPath" to: C:\Users\GARY&S~1\AppData\Local\Adobe\OOBE\PDApp\
                Found payload actions:
                Deciding what installer mode to use...
                BEGIN Setting requested payload actions
                Value returned on lookup of payload: {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 is: true
                Action string for  {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86  is none
                Value returned on lookup of payload: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86 is: true
                Action string for  {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86  is none
                Value returned on lookup of payload: {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86 is: true
                Action string for  {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86  is none
                Value returned on lookup of payload: {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86 is: true
                Action string for  {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86  is none
                Value returned on lookup of payload: {55516693-25E2-4620-BF94-6BA66B00419F} Adobe Player for Embedding_3.1_AdobeAPE3-mul is: true
                Action string for  {55516693-25E2-4620-BF94-6BA66B00419F} Adobe Player for Embedding_3.1_AdobeAPE3-mul  is none
                Payload {55516693-25E2-4620-BF94-6BA66B00419F} Adobe Player for Embedding_3.1_AdobeAPE3-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding is: true
                Action string for  {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding  is none
                Value returned on lookup of payload: {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 is: true
                Action string for  {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86  is none
                Value returned on lookup of payload: {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86 is: true
                Action string for  {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86  is none
                Value returned on lookup of payload: {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE is: true
                Action string for  {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE  is none
                Value returned on lookup of payload: {A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All is: true
                Action string for  {A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All  is none
                Payload {A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer is: true
                Action string for  {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer  is none
                Value returned on lookup of payload: {6B485102-4593-43F6-BA45-F14D690B0C64} Suite Shared Configuration CS5 is: true
                Action string for  {6B485102-4593-43F6-BA45-F14D690B0C64} Suite Shared Configuration CS5  is none
                Value returned on lookup of payload: {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 is: true
                Action string for  {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5  is none
                Value returned on lookup of payload: {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 is: true
                Action string for  {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5  is none
                Value returned on lookup of payload: {FA2A2592-3F40-456D-ACEC-166CB79D4F98} Adobe CSXS Infrastructure CS5_2.0.1_AdobeCSXSInfrastructure2-mul is: true
                Action string for  {FA2A2592-3F40-456D-ACEC-166CB79D4F98} Adobe CSXS Infrastructure CS5_2.0.1_AdobeCSXSInfrastructure2-mul  is none
                Payload {FA2A2592-3F40-456D-ACEC-166CB79D4F98} Adobe CSXS Infrastructure CS5_2.0.1_AdobeCSXSInfrastructure2-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5 is: true
                Action string for  {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5  is none
                Value returned on lookup of payload: {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86 is: true
                Action string for  {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86  is none
                Value returned on lookup of payload: {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 is: true
                Action string for  {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5  is none
                Value returned on lookup of payload: {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport is: true
                Action string for  {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport  is none
                Value returned on lookup of payload: {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule is: true
                Action string for  {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule  is none
                Value returned on lookup of payload: {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0 is: true
                Action string for  {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0  is none
                Value returned on lookup of payload: {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64 is: true
                Action string for  {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64  is none
                Value returned on lookup of payload: {4569AD91-47F4-4D9E-8FC9-717EC32D7AE1} Microsoft_VC80_CRT_x86_x64 is: true
                Action string for  {4569AD91-47F4-4D9E-8FC9-717EC32D7AE1} Microsoft_VC80_CRT_x86_x64  is none
                Value returned on lookup of payload: {1E9FC118-651D-4934-97BE-E53CAE5C7D45} Microsoft_VC80_MFCLOC_x86_x64 is: true
                Action string for  {1E9FC118-651D-4934-97BE-E53CAE5C7D45} Microsoft_VC80_MFCLOC_x86_x64  is none
                Value returned on lookup of payload: {C8C1BAD5-54E6-4146-AD07-3A8AD36569C3} Microsoft_VC80_MFC_x86_x64 is: true
                Action string for  {C8C1BAD5-54E6-4146-AD07-3A8AD36569C3} Microsoft_VC80_MFC_x86_x64  is none
                Value returned on lookup of payload: {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64 is: true
                Action string for  {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64  is none
                Value returned on lookup of payload: {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64 is: true
                Action string for  {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64  is none
                Value returned on lookup of payload: {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp is: true
                Action string for  {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp  is none
                Value returned on lookup of payload: {0061DED1-0204-44C5-B6E0-FAD6AA00E320} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll is: true
                Action string for  {0061DED1-0204-44C5-B6E0-FAD6AA00E320} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll  is none
                Payload {0061DED1-0204-44C5-B6E0-FAD6AA00E320} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 is: true
                Action string for  {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5  is none
                Value returned on lookup of payload: {187A7A38-6DD4-4549-AECD-22BA6BC2F002} Adobe ExtendScript Toolkit CS5_3.5.0_AdobeExtendScriptToolkit3.5.0-mul is: true
                Action string for  {187A7A38-6DD4-4549-AECD-22BA6BC2F002} Adobe ExtendScript Toolkit CS5_3.5.0_AdobeExtendScriptToolkit3.5.0-mul  is none
                Payload {187A7A38-6DD4-4549-AECD-22BA6BC2F002} Adobe ExtendScript Toolkit CS5_3.5.0_AdobeExtendScriptToolkit3.5.0-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5 is: true
                Action string for  {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5  is none
                Value returned on lookup of payload: {9AF7B703-B806-4C74-94E5-82963EFC0188} Adobe Extension Manager CS5_5.0.1_AdobeExtensionManager5.0All is: true
                Action string for  {9AF7B703-B806-4C74-94E5-82963EFC0188} Adobe Extension Manager CS5_5.0.1_AdobeExtensionManager5.0All  is none
                Payload {9AF7B703-B806-4C74-94E5-82963EFC0188} Adobe Extension Manager CS5_5.0.1_AdobeExtensionManager5.0All is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5 is: true
                Action string for  {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5  is none
                Value returned on lookup of payload: {FD58D99B-9927-4226-8E00-959A4F76BD89} Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All is: true
                Action string for  {FD58D99B-9927-4226-8E00-959A4F76BD89} Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All  is none
                Payload {FD58D99B-9927-4226-8E00-959A4F76BD89} Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw is: true
                Action string for  {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw  is none
                Value returned on lookup of payload: {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5 is: true
                Action string for  {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5  is none
                Value returned on lookup of payload: {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB is: true
                Action string for  {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB  is none
                Value returned on lookup of payload: {D8676884-2C59-41BB-B315-486D98A20867} Adobe Media Encoder CS5 X64_5.0.1_AMECore5All_x64 is: true
                Action string for  {D8676884-2C59-41BB-B315-486D98A20867} Adobe Media Encoder CS5 X64_5.0.1_AMECore5All_x64  is none
                Payload {D8676884-2C59-41BB-B315-486D98A20867} Adobe Media Encoder CS5 X64_5.0.1_AMECore5All_x64 is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 is: true
                Action string for  {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64  is none
                Value returned on lookup of payload: {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK is: true
                Action string for  {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK  is none
                Value returned on lookup of payload: {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5 is: false
                Action string for  {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5  is none
                Value returned on lookup of payload: {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5 is: true
                Action string for  {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5  is none
                Value returned on lookup of payload: {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5 is: true
                Action string for  {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5  is none
                Value returned on lookup of payload: {E5087BCA-6496-47A7-B9C4-B85D1CF062AE} AdobeColorJA CS5 is: false
                Action string for  {E5087BCA-6496-47A7-B9C4-B85D1CF062AE} AdobeColorJA CS5  is none
                Value returned on lookup of payload: {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5 is: true
                Action string for  {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5  is none
                Value returned on lookup of payload: {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5 is: false
                Action string for  {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5  is none
                Value returned on lookup of payload: {F9997A85-B21A-48E4-9C8A-7E1352AB1C62} Adobe Player for Embedding x64_3.1_AdobeAPE3_x64-mul is: true
                Action string for  {F9997A85-B21A-48E4-9C8A-7E1352AB1C62} Adobe Player for Embedding x64_3.1_AdobeAPE3_x64-mul  is none
                Payload {F9997A85-B21A-48E4-9C8A-7E1352AB1C62} Adobe Player for Embedding x64_3.1_AdobeAPE3_x64-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {7A33510F-1580-42C2-877E-8C5502566292} Adobe Player for Embedding x64 is: true
                Action string for  {7A33510F-1580-42C2-877E-8C5502566292} Adobe Player for Embedding x64  is none
                Value returned on lookup of payload: {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5 is: true
                Action string for  {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5  is none
                Value returned on lookup of payload: {98DD55B6-C58C-462F-B8A4-F0585BFEBB15} AdobeCMaps x64 CS5 is: true
                Action string for  {98DD55B6-C58C-462F-B8A4-F0585BFEBB15} AdobeCMaps x64 CS5  is none
                Value returned on lookup of payload: {17C6080E-F475-4B49-A30C-EEB85673E999} AdobePDFL x64 CS5 is: true
                Action string for  {17C6080E-F475-4B49-A30C-EEB85673E999} AdobePDFL x64 CS5  is none
                Value returned on lookup of payload: {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7} AdobeTypeSupport x64 CS5 is: true
                Action string for  {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7} AdobeTypeSupport x64 CS5  is none
                Value returned on lookup of payload: {5056CCD0-DDD6-47D1-9D46-612FA03FF82E} Adobe Media Encoder CS5 PCI WRAPPER X64_5.0.1_AMEPCIWrapper5All_x64 is: true
                Action string for  {5056CCD0-DDD6-47D1-9D46-612FA03FF82E} Adobe Media Encoder CS5 PCI WRAPPER X64_5.0.1_AMEPCIWrapper5All_x64  is none
                Payload {5056CCD0-DDD6-47D1-9D46-612FA03FF82E} Adobe Media Encoder CS5 PCI WRAPPER X64_5.0.1_AMEPCIWrapper5All_x64 is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {A013B68A-B1D9-470F-BB0F-816752F096A3} Adobe Media Encoder CS5 PCI WRAPPER X64 is: true
                Action string for  {A013B68A-B1D9-470F-BB0F-816752F096A3} Adobe Media Encoder CS5 PCI WRAPPER X64  is none
                Value returned on lookup of payload: {7F9C94CD-0BAC-4F8F-8990-6A5886F4D550} Required Common Fonts Installation x64 is: true
                Action string for  {7F9C94CD-0BAC-4F8F-8990-6A5886F4D550} Required Common Fonts Installation x64  is none
                Value returned on lookup of payload: {5C6A2D6E-4C4B-40AC-998A-B09B24DB631F} Adobe Media Encoder CS5 Dolby WRAPPER X64_5.0.1_AMEDolbyWrapper5All_x64 is: true
                Action string for  {5C6A2D6E-4C4B-40AC-998A-B09B24DB631F} Adobe Media Encoder CS5 Dolby WRAPPER X64_5.0.1_AMEDolbyWrapper5All_x64  is none
                Payload {5C6A2D6E-4C4B-40AC-998A-B09B24DB631F} Adobe Media Encoder CS5 Dolby WRAPPER X64_5.0.1_AMEDolbyWrapper5All_x64 is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {F8F0792D-8A6B-44F6-B2AF-AD1A40DF1BFD} Adobe Media Encoder CS5 Dolby WRAPPER X64 is: true
                Action string for  {F8F0792D-8A6B-44F6-B2AF-AD1A40DF1BFD} Adobe Media Encoder CS5 Dolby WRAPPER X64  is none
                Value returned on lookup of payload: {010B3947-C8F7-4F18-BF03-49A8662CC4A9} Adobe Photoshop CS5 Support_12.0.3_AdobePhotoshop12-Support is: true
                Action string for  {010B3947-C8F7-4F18-BF03-49A8662CC4A9} Adobe Photoshop CS5 Support_12.0.3_AdobePhotoshop12-Support  is none
                Payload {010B3947-C8F7-4F18-BF03-49A8662CC4A9} Adobe Photoshop CS5 Support_12.0.3_AdobePhotoshop12-Support is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A} Adobe Photoshop CS5 Support is: true
                Action string for  {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A} Adobe Photoshop CS5 Support  is none
                Value returned on lookup of payload: {A1CABA8D-CF84-402F-8948-D2567915D40C} Pixel Bender Toolkit_2.5_aifsdk-win is: true
                Action string for  {A1CABA8D-CF84-402F-8948-D2567915D40C} Pixel Bender Toolkit_2.5_aifsdk-win  is none
                Payload {A1CABA8D-CF84-402F-8948-D2567915D40C} Pixel Bender Toolkit_2.5_aifsdk-win is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C} Pixel Bender Toolkit is: true
                Action string for  {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C} Pixel Bender Toolkit  is none
                Value returned on lookup of payload: {3FE9B5F2-1ABD-1027-89E7-AA1204825831} Adobe InDesign CS5 Application Base Files2_7.0.3.535_AdobeInDesign7AppBase2-mul is: true
                Action string for  {3FE9B5F2-1ABD-1027-89E7-AA1204825831} Adobe InDesign CS5 Application Base Files2_7.0.3.535_AdobeInDesign7AppBase2-mul  is none
                Payload {3FE9B5F2-1ABD-1027-89E7-AA1204825831} Adobe InDesign CS5 Application Base Files2_7.0.3.535_AdobeInDesign7AppBase2-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {DEC9BB26-1381-1033-A965-E3BD5F2EF8BC} Adobe InDesign CS5 Application Base Files2 is: true
                Action string for  {DEC9BB26-1381-1033-A965-E3BD5F2EF8BC} Adobe InDesign CS5 Application Base Files2  is none
                Value returned on lookup of payload: {FD5603A3-1375-1033-872D-8F09140FFDB2} Adobe InDesign CS5 Application Feature Set Files is: true
                Action string for  {FD5603A3-1375-1033-872D-8F09140FFDB2} Adobe InDesign CS5 Application Feature Set Files  is none
                Value returned on lookup of payload: {805ABF27-1582-1033-B4AC-82A1DE0DD827} Adobe InDesign CS5 Common Base Files is: true
                Action string for  {805ABF27-1582-1033-B4AC-82A1DE0DD827} Adobe InDesign CS5 Common Base Files  is none
                Value returned on lookup of payload: {925D058B-564A-443A-B4B2-7E90C6432E55} Microsoft_VC80_ATL_x86_x64 is: true
                Action string for  {925D058B-564A-443A-B4B2-7E90C6432E55} Microsoft_VC80_ATL_x86_x64  is none
                Value returned on lookup of payload: {C925A34A-01B9-42C3-BB88-C7A78835F0EC} ph is: true
                Action string for  {C925A34A-01B9-42C3-BB88-C7A78835F0EC} ph  is none
                Value returned on lookup of payload: {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR is: true
                Action string for  {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR  is none
                Value returned on lookup of payload: {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player is: true
                Action string for  {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player  is none
                Value returned on lookup of payload: {03AA8100-8A65-11DF-9F66-0013724DD917} DeviceCentral_3.0.1_AdobeDeviceCentral3-all is: true
                Action string for  {03AA8100-8A65-11DF-9F66-0013724DD917} DeviceCentral_3.0.1_AdobeDeviceCentral3-all  is none
                Payload {03AA8100-8A65-11DF-9F66-0013724DD917} DeviceCentral_3.0.1_AdobeDeviceCentral3-all is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral is: true
                Action string for  {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral  is none
                Value returned on lookup of payload: {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US is: false
                Action string for  {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US  is none
                Payload {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {AD3268E2-8A6B-11DF-8A38-0024E8692489} DeviceCentral_3.0.1_DeviceCentral3LP-en_GB is: true
                Action string for  {AD3268E2-8A6B-11DF-8A38-0024E8692489} DeviceCentral_3.0.1_DeviceCentral3LP-en_GB  is none
                Payload {AD3268E2-8A6B-11DF-8A38-0024E8692489} DeviceCentral_3.0.1_DeviceCentral3LP-en_GB is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB is: true
                Action string for  {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB  is none
                Payload {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {123ABCFA-AE86-4B1C-A4D8-A732BEF9C86B} Adobe Bridge CS5_4.0.4_AdobeBridge4-mul is: true
                Action string for  {123ABCFA-AE86-4B1C-A4D8-A732BEF9C86B} Adobe Bridge CS5_4.0.4_AdobeBridge4-mul  is none
                Payload {123ABCFA-AE86-4B1C-A4D8-A732BEF9C86B} Adobe Bridge CS5_4.0.4_AdobeBridge4-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5 is: true
                Action string for  {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5  is none
                Value returned on lookup of payload: {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5 is: true
                Action string for  {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5  is none
                Value returned on lookup of payload: {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5 is: true
                Action string for  {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5  is none
                Value returned on lookup of payload: {66173EC7-974E-4652-9468-4A93D2481BF0} CSXS Story Extension is: true
                Action string for  {66173EC7-974E-4652-9468-4A93D2481BF0} CSXS Story Extension  is none
                Value returned on lookup of payload: {BB024724-14D5-4AB6-B21C-74EDA63A0A39} HIL Help Search is: true
                Action string for  {BB024724-14D5-4AB6-B21C-74EDA63A0A39} HIL Help Search  is none
                Value returned on lookup of payload: {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5 is: true
                Action string for  {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5  is none
                Value returned on lookup of payload: {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3} PDF Settings CS5 is: false
                Action string for  {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3} PDF Settings CS5  is none
                Value returned on lookup of payload: {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation is: true
                Action string for  {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation  is none
                Value returned on lookup of payload: {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation is: true
                Action string for  {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation  is none
                Value returned on lookup of payload: {03EEF3DA-71F9-4FE5-92AD-D10142E26459} SiteCatalyst NetAverages is: true
                Action string for  {03EEF3DA-71F9-4FE5-92AD-D10142E26459} SiteCatalyst NetAverages  is none
                Value returned on lookup of payload: {5E08533A-2C1B-469D-AFD5-953C9D00031F} Adobe BrowserLab CS Live is: true
                Action string for  {5E08533A-2C1B-469D-AFD5-953C9D00031F} Adobe BrowserLab CS Live  is none
                Value returned on lookup of payload: {32841ECE-EC28-42CD-A4DD-6CE832A7EA8D} Photoshop Camera Raw (64 bit)_6.3_AdobeCameraRaw6.0All-x64 is: true
                Action string for  {32841ECE-EC28-42CD-A4DD-6CE832A7EA8D} Photoshop Camera Raw (64 bit)_6.3_AdobeCameraRaw6.0All-x64  is none
                Payload {32841ECE-EC28-42CD-A4DD-6CE832A7EA8D} Photoshop Camera Raw (64 bit)_6.3_AdobeCameraRaw6.0All-x64 is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41} Photoshop Camera Raw (64 bit) is: true
                Action string for  {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41} Photoshop Camera Raw (64 bit)  is none
                Value returned on lookup of payload: {4438C826-1FD0-4D04-A70B-24FE1580AB21} Adobe Mini Bridge CS5 is: true
                Action string for  {4438C826-1FD0-4D04-A70B-24FE1580AB21} Adobe Mini Bridge CS5  is none
                Value returned on lookup of payload: {694213D7-1E0E-4C8F-B822-E2E3680C0FCE} Adobe Media Encoder CS5 is: false
                Action string for  {694213D7-1E0E-4C8F-B822-E2E3680C0FCE} Adobe Media Encoder CS5  is donotinstall
                Selection of payload {694213D7-1E0E-4C8F-B822-E2E3680C0FCE} Adobe Media Encoder CS5 is allowed but the user has marked it for not to install
                Value returned on lookup of payload: {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX is: true
                Action string for  {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX  is none
                Value returned on lookup of payload: {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin is: false
                Action string for  {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin  is none
                Value returned on lookup of payload: {11C0657F-2BD4-4CBC-87F3-9455DC91886E} Recommended Common Fonts Installation x64 is: true
                Action string for  {11C0657F-2BD4-4CBC-87F3-9455DC91886E} Recommended Common Fonts Installation x64  is none
                Value returned on lookup of payload: {B55FDCCB-8A45-4943-8D90-585C3490A032} Adobe WinSoft Linguistics Plugin CS5 x64 is: true
                Action string for  {B55FDCCB-8A45-4943-8D90-585C3490A032} Adobe WinSoft Linguistics Plugin CS5 x64  is none
                Value returned on lookup of payload: {D31D91FE-F0E8-4DF1-812C-9400BE92A386} AdobeColorPhotoshop CS5 is: true
                Action string for  {D31D91FE-F0E8-4DF1-812C-9400BE92A386} AdobeColorPhotoshop CS5  is none
                Value returned on lookup of payload: {73A4DC5E-226E-42BA-8ECA-2822592AC044} AdobeColorVideoProfilesCS CS5 is: true
                Action string for  {73A4DC5E-226E-42BA-8ECA-2822592AC044} AdobeColorVideoProfilesCS CS5  is none
                Value returned on lookup of payload: {CD693E49-C5EF-4FA6-9037-9B636931C02B} AmericanEnglishSpeechAnalysisModels is: true
                Action string for  {CD693E49-C5EF-4FA6-9037-9B636931C02B} AmericanEnglishSpeechAnalysisModels  is none
                Value returned on lookup of payload: {0669F23C-1B69-41B4-A3ED-4F54A5986D66} Adobe Linguistics CS5 x64 is: true
                Action string for  {0669F23C-1B69-41B4-A3ED-4F54A5986D66} Adobe Linguistics CS5 x64  is none
                Value returned on lookup of payload: {88BE801D-C8EC-46A4-92AC-06CE56FE0E0A} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-mul is: true
                Action string for  {88BE801D-C8EC-46A4-92AC-06CE56FE0E0A} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-mul  is none
                Payload {88BE801D-C8EC-46A4-92AC-06CE56FE0E0A} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {30221E3E-4C47-4560-A296-DD9ABB500C21} AIR2 For Adobe Flash Pro is: true
                Action string for  {30221E3E-4C47-4560-A296-DD9ABB500C21} AIR2 For Adobe Flash Pro  is none
                Value returned on lookup of payload: {A69CC698-119E-450F-9AEC-2F377C03B33B} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-en_US is: true
                Action string for  {A69CC698-119E-450F-9AEC-2F377C03B33B} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-en_US  is none
                Payload {A69CC698-119E-450F-9AEC-2F377C03B33B} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-en_US is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US is: true
                Action string for  {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US  is none
                Payload {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {CC0EF75D-9336-4E4F-B4A2-99E2E60E161F} Adobe After Effects CS5 Presets is: true
                Action string for  {CC0EF75D-9336-4E4F-B4A2-99E2E60E161F} Adobe After Effects CS5 Presets  is none
                Value returned on lookup of payload: {64D991B0-4E64-47AC-8A35-291DA2E7D02F} Adobe After Effects CS5 Support is: true
                Action string for  {64D991B0-4E64-47AC-8A35-291DA2E7D02F} Adobe After Effects CS5 Support  is none
                Value returned on lookup of payload: {D5E7D8B9-9B8F-4DA0-9B2C-167DC889B0E1} Adobe After Effects CS5 Template Projects & Footage is: true
                Action string for  {D5E7D8B9-9B8F-4DA0-9B2C-167DC889B0E1} Adobe After Effects CS5 Template Projects & Footage  is none
                Value returned on lookup of payload: {AAC33035-8CD9-4089-900B-10F4350AE81E} Adobe After Effects CS5 Third Party Content Wrapper_10.0.1_AdobeAfterEffects10ProtectedWrapperAll is: true
                Action string for  {AAC33035-8CD9-4089-900B-10F4350AE81E} Adobe After Effects CS5 Third Party Content Wrapper_10.0.1_AdobeAfterEffects10ProtectedWrapperAll  is none
                Payload {AAC33035-8CD9-4089-900B-10F4350AE81E} Adobe After Effects CS5 Third Party Content Wrapper_10.0.1_AdobeAfterEffects10ProtectedWrapperAll is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {406D22BD-7910-479B-96AA-0DB8A36C694B} Adobe After Effects CS5 Third Party Content Wrapper is: true
                Action string for  {406D22BD-7910-479B-96AA-0DB8A36C694B} Adobe After Effects CS5 Third Party Content Wrapper  is none
                Value returned on lookup of payload: {A8573435-DB08-4E7E-8E19-D16BD9A04736} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper_10.0.1_AdobeAfterEffects10RoyaltyWrapperAll is: true
                Action string for  {A8573435-DB08-4E7E-8E19-D16BD9A04736} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper_10.0.1_AdobeAfterEffects10RoyaltyWrapperAll  is none
                Payload {A8573435-DB08-4E7E-8E19-D16BD9A04736} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper_10.0.1_AdobeAfterEffects10RoyaltyWrapperAll is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {20F72893-AEC7-4954-9EAA-F07FD6184781} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper is: true
                Action string for  {20F72893-AEC7-4954-9EAA-F07FD6184781} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper  is none
                Value returned on lookup of payload: {DF2B2B91-F938-1051-88C6-AE7C8C5B3B23} Adobe Buzzword CS5_1.0_AdobeBuzzword-mul is: true
                Action string for  {DF2B2B91-F938-1051-88C6-AE7C8C5B3B23} Adobe Buzzword CS5_1.0_AdobeBuzzword-mul  is none
                Payload {DF2B2B91-F938-1051-88C6-AE7C8C5B3B23} Adobe Buzzword CS5_1.0_AdobeBuzzword-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {3F6B5CAC-733F-1029-B5BD-C0F5E35809F0} Adobe Buzzword CS5 is: true
                Action string for  {3F6B5CAC-733F-1029-B5BD-C0F5E35809F0} Adobe Buzzword CS5  is none
                Value returned on lookup of payload: {A32910E5-4084-4A0E-9FFF-D2E9C1B1C134} Adobe Encore CS5 Library is: true
                Action string for  {A32910E5-4084-4A0E-9FFF-D2E9C1B1C134} Adobe Encore CS5 Library  is none
                Value returned on lookup of payload: {1A48007B-34D2-44BD-8708-B570F5339C14} Adobe Encore CS5 Royalty Codecs Installer Wrapper is: true
                Action string for  {1A48007B-34D2-44BD-8708-B570F5339C14} Adobe Encore CS5 Royalty Codecs Installer Wrapper  is none
                Value returned on lookup of payload: {7745F18B-FD8A-4011-BE16-588900C503D0} Adobe Flash Fonts1 is: true
                Action string for  {7745F18B-FD8A-4011-BE16-588900C503D0} Adobe Flash Fonts1  is none
                Value returned on lookup of payload: {E4CB336B-159D-1033-B84D-B9A01A0BE4A9} Adobe InDesign CS5 Icon Handler is: true
                Action string for  {E4CB336B-159D-1033-B84D-B9A01A0BE4A9} Adobe InDesign CS5 Icon Handler  is none
                Value returned on lookup of payload: {AAE6F374-91CB-45FB-9282-4CFA0DED2088} Adobe Media Encoder CS5 Dolby WRAPPER is: false
                Action string for  {AAE6F374-91CB-45FB-9282-4CFA0DED2088} Adobe Media Encoder CS5 Dolby WRAPPER  is donotinstall
                Selection of payload {AAE6F374-91CB-45FB-9282-4CFA0DED2088} Adobe Media Encoder CS5 Dolby WRAPPER is not allowed therefore shall be re-checking later
                Value returned on lookup of payload: {33A3F995-8333-4676-8D6F-AB7674BB52EA} Adobe Media Encoder CS5 PCI WRAPPER is: false
                Action string for  {33A3F995-8333-4676-8D6F-AB7674BB52EA} Adobe Media Encoder CS5 PCI WRAPPER  is donotinstall
                Selection of payload {33A3F995-8333-4676-8D6F-AB7674BB52EA} Adobe Media Encoder CS5 PCI WRAPPER is not allowed therefore shall be re-checking later
                Value returned on lookup of payload: {6C6D990F-FC88-4F07-912C-DA37468D9A3C} Adobe OnLocation CS5 Royalty Content Wrapper_5.0.1_AdobeOnLocation5RoyaltyWrapperAll is: true
                Action string for  {6C6D990F-FC88-4F07-912C-DA37468D9A3C} Adobe OnLocation CS5 Royalty Content Wrapper_5.0.1_AdobeOnLocation5RoyaltyWrapperAll  is none
                Payload {6C6D990F-FC88-4F07-912C-DA37468D9A3C} Adobe OnLocation CS5 Royalty Content Wrapper_5.0.1_AdobeOnLocation5RoyaltyWrapperAll is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {01367616-4132-4311-911F-49D2EA82F7C2} Adobe OnLocation CS5 Royalty Content Wrapper is: true
                Action string for  {01367616-4132-4311-911F-49D2EA82F7C2} Adobe OnLocation CS5 Royalty Content Wrapper  is none
                Value returned on lookup of payload: {F4EC52C6-1223-4EA9-8C48-F4E6AB2EEC19} Adobe Premiere Pro CS5 Functional Content is: true
                Action string for  {F4EC52C6-1223-4EA9-8C48-F4E6AB2EEC19} Adobe Premiere Pro CS5 Functional Content  is none
                Value returned on lookup of payload: {F77882B9-A94F-44F4-A739-8370749255B6} Adobe Premiere Pro CS5 Support is: true
                Action string for  {F77882B9-A94F-44F4-A739-8370749255B6} Adobe Premiere Pro CS5 Support  is none
                Value returned on lookup of payload: {4C08199E-0D93-4227-8325-F024E71CA7A1} Adobe SING CS5 is: true
                Action string for  {4C08199E-0D93-4227-8325-F024E71CA7A1} Adobe SING CS5  is none
                Value returned on lookup of payload: {4BE1791F-1D8A-4B8E-B803-D97C5D7CB245} Adobe Soundbooth CS5 Codecs Wrapper is: true
                Action string for  {4BE1791F-1D8A-4B8E-B803-D97C5D7CB245} Adobe Soundbooth CS5 Codecs Wrapper  is none
                Value returned on lookup of payload: {ADAF6949-4547-4B3D-97C5-6FB4D0C08A1E} Adobe Soundbooth CS5 Royalty Codecs Wrapper is: true
                Action string for  {ADAF6949-4547-4B3D-97C5-6FB4D0C08A1E} Adobe Soundbooth CS5 Royalty Codecs Wrapper  is none
                Value returned on lookup of payload: {157D044B-C60D-1015-B0DB-A40823CC0F49} Adobe Toolhints CS5 is: true
                Action string for  {157D044B-C60D-1015-B0DB-A40823CC0F49} Adobe Toolhints CS5  is none
                Value returned on lookup of payload: {A5A8E72E-1B9D-4F99-ADED-F3595CB3D03E} AdobeColorVideoProfilesAE CS5 is: true
                Action string for  {A5A8E72E-1B9D-4F99-ADED-F3595CB3D03E} AdobeColorVideoProfilesAE CS5  is none
                Value returned on lookup of payload: {F3ECF5C7-9A9D-460A-B3D6-C7E4C1DFD040} AdobeMotionPicture CS5 is: true
                Action string for  {F3ECF5C7-9A9D-460A-B3D6-C7E4C1DFD040} AdobeMotionPicture CS5  is none
                Value returned on lookup of payload: {04D84E18-23ED-46EA-9B41-789433E34D03} Firefox Plugin CS5 is: true
                Action string for  {04D84E18-23ED-46EA-9B41-789433E34D03} Firefox Plugin CS5  is none
                Value returned on lookup of payload: {E7F2C606-8529-4028-B26E-8407DB43DD45} FrenchSpeechAnalysisModels is: true
                Action string for  {E7F2C606-8529-4028-B26E-8407DB43DD45} FrenchSpeechAnalysisModels  is none
                Value returned on lookup of payload: {4355EE3F-2FDD-4EF4-83EA-2465FBF95B16} GermanSpeechAnalysisModels is: true
                Action string for  {4355EE3F-2FDD-4EF4-83EA-2465FBF95B16} GermanSpeechAnalysisModels  is none
                Value returned on lookup of payload: {479C08E9-FACF-4190-A37A-81D65B4C8D4E} IE Plugin CS5 is: true
                Action string for  {479C08E9-FACF-4190-A37A-81D65B4C8D4E} IE Plugin CS5  is none
                Value returned on lookup of payload: {A1E0C87F-BFE5-490A-898E-05BD4DD2BADF} InternationalEnglishSpeechAnalysisModels is: true
                Action string for  {A1E0C87F-BFE5-490A-898E-05BD4DD2BADF} InternationalEnglishSpeechAnalysisModels  is none
                Value returned on lookup of payload: {234A555C-70F5-48FB-A7E2-32410EB5AF64} ItalianSpeechAnalysisModels is: true
                Action string for  {234A555C-70F5-48FB-A7E2-32410EB5AF64} ItalianSpeechAnalysisModels  is none
                Value returned on lookup of payload: {F46A4C18-2EAD-49F0-A244-994226F93B39} JapaneseSpeechAnalysisModels is: true
                Action string for  {F46A4C18-2EAD-49F0-A244-994226F93B39} JapaneseSpeechAnalysisModels  is none
                Value returned on lookup of payload: {0EDAD58E-71F3-4D0E-9D32-A205533FC0E9} KoreanSpeechAnalysisModels is: true
                Action string for  {0EDAD58E-71F3-4D0E-9D32-A205533FC0E9} KoreanSpeechAnalysisModels  is none
                Value returned on lookup of payload: {7B7DE224-2ACA-41E2-A94D-5A6C6D75106D} Office Plugin CS5 is: true
                Action string for  {7B7DE224-2ACA-41E2-A94D-5A6C6D75106D} Office Plugin CS5  is none
                Value returned on lookup of payload: {E319B9F9-4DE6-462C-970B-77D06C7807EE} Players For Adobe Flash Pro is: true
                Action string for  {E319B9F9-4DE6-462C-970B-77D06C7807EE} Players For Adobe Flash Pro  is none
                Value returned on lookup of payload: {36D02DA9-35F2-4686-A2FE-EF3014D2E226} SpanishSpeechAnalysisModels is: true
                Action string for  {36D02DA9-35F2-4686-A2FE-EF3014D2E226} SpanishSpeechAnalysisModels  is none
                Value returned on lookup of payload: {22C1290B-8DC3-4C8B-93E2-4373B9AAB1CC} TLF For Adobe Flash Pro_1.0.1_TLF_Flash11-mul is: true
                Action string for  {22C1290B-8DC3-4C8B-93E2-4373B9AAB1CC} TLF For Adobe Flash Pro_1.0.1_TLF_Flash11-mul  is none
                Payload {22C1290B-8DC3-4C8B-93E2-4373B9AAB1CC} TLF For Adobe Flash Pro_1.0.1_TLF_Flash11-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345} TLF For Adobe Flash Pro is: true
                Action string for  {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345} TLF For Adobe Flash Pro  is none
                Value returned on lookup of payload: {62466A6D-1130-4D66-9D65-ED3E1A988E12} iPhone Publishing_1.0.1_iPhone_Flash11-mul is: true
                Action string for  {62466A6D-1130-4D66-9D65-ED3E1A988E12} iPhone Publishing_1.0.1_iPhone_Flash11-mul  is none
                Payload {62466A6D-1130-4D66-9D65-ED3E1A988E12} iPhone Publishing_1.0.1_iPhone_Flash11-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {635DCFA5-3A47-4452-AEC7-D3B23FFE929D} iPhone Publishing is: true
                Action string for  {635DCFA5-3A47-4452-AEC7-D3B23FFE929D} iPhone Publishing  is none
                Value returned on lookup of payload: {5658F35F-15B9-1033-8337-97B78F2D0BE0} Adobe InDesign CS5 Icon Handler x64 is: true
                Action string for  {5658F35F-15B9-1033-8337-97B78F2D0BE0} Adobe InDesign CS5 Icon Handler x64  is none
                Value returned on lookup of payload: {AAA45CA1-CEF2-45A9-9162-6774CFFF8260} Adobe Premiere Pro CS5 Third Party Content Wrapper_5.0.3_AdobePremierePro5ProtectedWrapperAll is: true
                Action string for  {AAA45CA1-CEF2-45A9-9162-6774CFFF8260} Adobe Premiere Pro CS5 Third Party Content Wrapper_5.0.3_AdobePremierePro5ProtectedWrapperAll  is none
                Payload {AAA45CA1-CEF2-45A9-9162-6774CFFF8260} Adobe Premiere Pro CS5 Third Party Content Wrapper_5.0.3_AdobePremierePro5ProtectedWrapperAll is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {22F41D72-2E97-46AE-B8C4-EF66876C7838} Adobe Premiere Pro CS5 Third Party Content Wrapper is: true
                Action string for  {22F41D72-2E97-46AE-B8C4-EF66876C7838} Adobe Premiere Pro CS5 Third Party Content Wrapper  is none
                Value returned on lookup of payload: {CB8BB160-EC13-4D89-8990-F15F01E74961} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper_5.0.3_AdobePremierePro5RoyaltyWrapperAll is: true
                Action string for  {CB8BB160-EC13-4D89-8990-F15F01E74961} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper_5.0.3_AdobePremierePro5RoyaltyWrapperAll  is none
                Payload {CB8BB160-EC13-4D89-8990-F15F01E74961} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper_5.0.3_AdobePremierePro5RoyaltyWrapperAll is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {6BA6F6D7-1D30-482A-B9B8-20E79D6DB4F9} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper is: true
                Action string for  {6BA6F6D7-1D30-482A-B9B8-20E79D6DB4F9} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper  is none
                Value returned on lookup of payload: {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1} Adobe After Effects CS5 Third Party Content is: true
                Action string for  {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1} Adobe After Effects CS5 Third Party Content  is install
                Selection of payload {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1} Adobe After Effects CS5 Third Party Content is forbidden by the policy.
                Value returned on lookup of payload: {CD29B5CA-4727-4114-9AD9-25CCCE6E4014} Adobe After Effects CS5 Third Party Royalty Content is: true
                Action string for  {CD29B5CA-4727-4114-9AD9-25CCCE6E4014} Adobe After Effects CS5 Third Party Royalty Content  is install
                Selection of payload {CD29B5CA-4727-4114-9AD9-25CCCE6E4014} Adobe After Effects CS5 Third Party Royalty Content is forbidden by the policy.
                Value returned on lookup of payload: {0E3C6C75-872D-4B0D-B0B2-31C717250691} Adobe Encore CS5 Third Party Royalty Content is: true
                Action string for  {0E3C6C75-872D-4B0D-B0B2-31C717250691} Adobe Encore CS5 Third Party Royalty Content  is install
                Selection of payload {0E3C6C75-872D-4B0D-B0B2-31C717250691} Adobe Encore CS5 Third Party Royalty Content is forbidden by the policy.
                Value returned on lookup of payload: {D3598CAC-AEB3-4234-A1E0-16F47D5F38CC} Adobe Media Encoder CS5 Dolby is: false
                Action string for  {D3598CAC-AEB3-4234-A1E0-16F47D5F38CC} Adobe Media Encoder CS5 Dolby  is none
                Value returned on lookup of payload: {5DDABB74-A879-4BE7-A4C6-FD41793942DB} Adobe Media Encoder CS5 Dolby X64 is: true
                Action string for  {5DDABB74-A879-4BE7-A4C6-FD41793942DB} Adobe Media Encoder CS5 Dolby X64  is install
                Selection of payload {5DDABB74-A879-4BE7-A4C6-FD41793942DB} Adobe Media Encoder CS5 Dolby X64 is forbidden by the policy.
                Value returned on lookup of payload: {92D4A929-78F1-4EC3-B626-08B3CF5B784F} Adobe Media Encoder CS5 PCI is: false
                Action string for  {92D4A929-78F1-4EC3-B626-08B3CF5B784F} Adobe Media Encoder CS5 PCI  is none
                Value returned on lookup of payload: {F9C71630-0EE3-475C-9E2B-ED95AE197DBD} Adobe Media Encoder CS5 PCI X64 is: true
                Action string for  {F9C71630-0EE3-475C-9E2B-ED95AE197DBD} Adobe Media Encoder CS5 PCI X64  is install
                Selection of payload {F9C71630-0EE3-475C-9E2B-ED95AE197DBD} Adobe Media Encoder CS5 PCI X64 is forbidden by the policy.
                Value returned on lookup of payload: {7816FDDE-40D4-482D-AD7D-97858985DB3E} Adobe OnLocation CS5 Royalty Content is: true
                Action string for  {7816FDDE-40D4-482D-AD7D-97858985DB3E} Adobe OnLocation CS5 Royalty Content  is install
                Selection of payload {7816FDDE-40D4-482D-AD7D-97858985DB3E} Adobe OnLocation CS5 Royalty Content is forbidden by the policy.
                Value returned on lookup of payload: {B8D286BC-A68D-4E74-9F68-8756A49896D8} Adobe Premiere Pro CS5 Third Party Content is: true
                Action string for  {B8D286BC-A68D-4E74-9F68-8756A49896D8} Adobe Premiere Pro CS5 Third Party Content  is install
                Selection of payload {B8D286BC-A68D-4E74-9F68-8756A49896D8} Adobe Premiere Pro CS5 Third Party Content is forbidden by the policy.
                Value returned on lookup of payload: {565DE707-5798-4FC3-8DF6-0F58A348A9B0} Adobe Premiere Pro CS5 Third Party Royalty Content is: true
                Action string for  {565DE707-5798-4FC3-8DF6-0F58A348A9B0} Adobe Premiere Pro CS5 Third Party Royalty Content  is install
                Selection of payload {565DE707-5798-4FC3-8DF6-0F58A348A9B0} Adobe Premiere Pro CS5 Third Party Royalty Content is forbidden by the policy.
                Value returned on lookup of payload: {DE5DE662-2ECB-4D93-967B-221FBCC8A736} Adobe Soundbooth CS5 Codecs is: true
                Action string for  {DE5DE662-2ECB-4D93-967B-221FBCC8A736} Adobe Soundbooth CS5 Codecs  is install
                Selection of payload {DE5DE662-2ECB-4D93-967B-221FBCC8A736} Adobe Soundbooth CS5 Codecs is forbidden by the policy.
                Value returned on lookup of payload: {F319804F-E3A4-4C02-8AEC-CB39A4F6447E} Adobe Soundbooth CS5 Royalty Codecs is: true
                Action string for  {F319804F-E3A4-4C02-8AEC-CB39A4F6447E} Adobe Soundbooth CS5 Royalty Codecs  is install
                Selection of payload {F319804F-E3A4-4C02-8AEC-CB39A4F6447E} Adobe Soundbooth CS5 Royalty Codecs is forbidden by the policy.
                Value returned on lookup of payload: {FBB02B04-C034-4382-A3F6-57416E2752C4} Creative Suite 5 Master Collection is: true
                Action string for  {FBB02B04-C034-4382-A3F6-57416E2752C4} Creative Suite 5 Master Collection  is install
                Value returned on lookup of payload: {CBE4F6C3-788E-4CAC-BA25-26FE39A3BC8C} Adobe Soundbooth is: true
                Action string for  {CBE4F6C3-788E-4CAC-BA25-26FE39A3BC8C} Adobe Soundbooth  is none
                Value returned on lookup of payload: {E6F68811-F702-492C-A7DA-D22CA670BC22} Adobe Soundbooth_AdobeSoundbooth3en_USLanguagePack is: true
                Action string for  {E6F68811-F702-492C-A7DA-D22CA670BC22} Adobe Soundbooth_AdobeSoundbooth3en_USLanguagePack  is none
                Payload {E6F68811-F702-492C-A7DA-D22CA670BC22} Adobe Soundbooth_AdobeSoundbooth3en_USLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {64C19EC0-24A3-4F6F-A0AD-C701C8C48700} Adobe OnLocation CS5_5.0.1_AdobeOnLocation5All is: true
                Action string for  {64C19EC0-24A3-4F6F-A0AD-C701C8C48700} Adobe OnLocation CS5_5.0.1_AdobeOnLocation5All  is none
                Payload {64C19EC0-24A3-4F6F-A0AD-C701C8C48700} Adobe OnLocation CS5_5.0.1_AdobeOnLocation5All is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {ABDC1F61-2C50-4BB1-ACDA-66D412D72582} Adobe OnLocation CS5 is: true
                Action string for  {ABDC1F61-2C50-4BB1-ACDA-66D412D72582} Adobe OnLocation CS5  is none
                Value returned on lookup of payload: {771C9F59-3F22-4610-A23E-321A98ECA264} Adobe OnLocation CS5_AdobeOnLocation5en_USLanguagePack is: true
                Action string for  {771C9F59-3F22-4610-A23E-321A98ECA264} Adobe OnLocation CS5_AdobeOnLocation5en_USLanguagePack  is none
                Payload {771C9F59-3F22-4610-A23E-321A98ECA264} Adobe OnLocation CS5_AdobeOnLocation5en_USLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {177E1CA1-14CC-4398-AB15-A5746EFE8F22} Adobe Flash Builder is: false
                Action string for  {177E1CA1-14CC-4398-AB15-A5746EFE8F22} Adobe Flash Builder  is install
                Value returned on lookup of payload: {4FC4B869-AD0D-4A56-B626-2926EB2C48D0} Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11-mul is: true
                Action string for  {4FC4B869-AD0D-4A56-B626-2926EB2C48D0} Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11-mul  is none
                Payload {4FC4B869-AD0D-4A56-B626-2926EB2C48D0} Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {C79312BD-3E76-4474-A10C-1435D1856A4B} Adobe Dreamweaver CS5 is: true
                Action string for  {C79312BD-3E76-4474-A10C-1435D1856A4B} Adobe Dreamweaver CS5  is none
                Value returned on lookup of payload: {F19DAA62-588A-46D3-A092-C808F565D633} Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11en_USLanguagePack is: true
                Action string for  {F19DAA62-588A-46D3-A092-C808F565D633} Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11en_USLanguagePack  is none
                Payload {F19DAA62-588A-46D3-A092-C808F565D633} Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11en_USLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {E3E040E8-4CCD-4C71-8BAF-80BB2AD5DA04} Adobe Dreamweaver CS5_AdobeDreamweaver11en_USLanguagePack is: true
                Action string for  {E3E040E8-4CCD-4C71-8BAF-80BB2AD5DA04} Adobe Dreamweaver CS5_AdobeDreamweaver11en_USLanguagePack  is none
                Payload {E3E040E8-4CCD-4C71-8BAF-80BB2AD5DA04} Adobe Dreamweaver CS5_AdobeDreamweaver11en_USLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {DE60F0DE-469A-42DC-A678-978313210057} Adobe Contribute CS5 is: true
                Action string for  {DE60F0DE-469A-42DC-A678-978313210057} Adobe Contribute CS5  is none
                Value returned on lookup of payload: {414BDCF9-DE14-4083-BE96-2F4193CE8BBA} Adobe Contribute CS5_AdobeContribute6en_USLanguagePack is: false
                Action string for  {414BDCF9-DE14-4083-BE96-2F4193CE8BBA} Adobe Contribute CS5_AdobeContribute6en_USLanguagePack  is none
                Payload {414BDCF9-DE14-4083-BE96-2F4193CE8BBA} Adobe Contribute CS5_AdobeContribute6en_USLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {681DE732-3F3A-42F2-91C9-84B1CC9B8535} Adobe Contribute CS5_AdobeContribute6en_GBLanguagePack is: true
                Action string for  {681DE732-3F3A-42F2-91C9-84B1CC9B8535} Adobe Contribute CS5_AdobeContribute6en_GBLanguagePack  is none
                Payload {681DE732-3F3A-42F2-91C9-84B1CC9B8535} Adobe Contribute CS5_AdobeContribute6en_GBLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {E8815668-95B0-443D-AC92-2BFD7DD8F16A} Adobe Flash Catalyst CS5 is: false
                Action string for  {E8815668-95B0-443D-AC92-2BFD7DD8F16A} Adobe Flash Catalyst CS5  is install
                Value returned on lookup of payload: {164965E8-4BB0-4EEB-AFBA-75785A2A2A7F} Adobe Fireworks CS5 is: true
                Action string for  {164965E8-4BB0-4EEB-AFBA-75785A2A2A7F} Adobe Fireworks CS5  is none
                Value returned on lookup of payload: {3A8C7CB3-2A2E-4EB9-99C9-DF08C324BA70} Adobe Fireworks CS5_AdobeFireworks11en_USLanguagePack is: false
                Action string for  {3A8C7CB3-2A2E-4EB9-99C9-DF08C324BA70} Adobe Fireworks CS5_AdobeFireworks11en_USLanguagePack  is none
                Payload {3A8C7CB3-2A2E-4EB9-99C9-DF08C324BA70} Adobe Fireworks CS5_AdobeFireworks11en_USLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {F6CCA85F-7527-4AFF-82B6-26532A74A244} Adobe Fireworks CS5_AdobeFireworks11en_GBLanguagePack is: true
                Action string for  {F6CCA85F-7527-4AFF-82B6-26532A74A244} Adobe Fireworks CS5_AdobeFireworks11en_GBLanguagePack  is none
                Payload {F6CCA85F-7527-4AFF-82B6-26532A74A244} Adobe Fireworks CS5_AdobeFireworks11en_GBLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {D8465547-5D5B-4856-A93A-8AC0A05C5D4D} Adobe Encore CS5 is: true
                Action string for  {D8465547-5D5B-4856-A93A-8AC0A05C5D4D} Adobe Encore CS5  is none
                Value returned on lookup of payload: {B842A584-A0BF-4870-A850-9C0E52FD6A20} Adobe Encore CS5_AdobeEncore5en_USLanguagePack is: true
                Action string for  {B842A584-A0BF-4870-A850-9C0E52FD6A20} Adobe Encore CS5_AdobeEncore5en_USLanguagePack  is none
                Payload {B842A584-A0BF-4870-A850-9C0E52FD6A20} Adobe Encore CS5_AdobeEncore5en_USLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {EA4B7009-6FAC-41b1-BBB6-E76680C924DC} Adobe Illustrator CS5_15.0.2_AdobeIllustrator15-mul is: true
                Action string for  {EA4B7009-6FAC-41b1-BBB6-E76680C924DC} Adobe Illustrator CS5_15.0.2_AdobeIllustrator15-mul  is none
                Payload {EA4B7009-6FAC-41b1-BBB6-E76680C924DC} Adobe Illustrator CS5_15.0.2_AdobeIllustrator15-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {9B97EC91-B3FD-4BFF-88FC-5345A26AC2E7} Adobe Illustrator CS5 is: true
                Action string for  {9B97EC91-B3FD-4BFF-88FC-5345A26AC2E7} Adobe Illustrator CS5  is none
                Value returned on lookup of payload: {D3A8C87E-ED6A-41DB-8B21-C29EDA65B154} Adobe Illustrator CS5_AdobeIllustrator15en_USLanguagePack is: false
                Action string for  {D3A8C87E-ED6A-41DB-8B21-C29EDA65B154} Adobe Illustrator CS5_AdobeIllustrator15en_USLanguagePack  is none
                Payload {D3A8C87E-ED6A-41DB-8B21-C29EDA65B154} Adobe Illustrator CS5_AdobeIllustrator15en_USLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {D0DAEA50-AD52-4BF9-AD5F-3E09564A8692} Adobe Illustrator CS5_AdobeIllustrator15en_GBLanguagePack is: true
                Action string for  {D0DAEA50-AD52-4BF9-AD5F-3E09564A8692} Adobe Illustrator CS5_AdobeIllustrator15en_GBLanguagePack  is none
                Payload {D0DAEA50-AD52-4BF9-AD5F-3E09564A8692} Adobe Illustrator CS5_AdobeIllustrator15en_GBLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {5733850A-FF54-431F-A935-71A96AE80F95} Adobe Photoshop CS5 Core_12.0.3_AdobePhotoshop12-Core is: true
                Action string for  {5733850A-FF54-431F-A935-71A96AE80F95} Adobe Photoshop CS5 Core_12.0.3_AdobePhotoshop12-Core  is none
                Payload {5733850A-FF54-431F-A935-71A96AE80F95} Adobe Photoshop CS5 Core_12.0.3_AdobePhotoshop12-Core is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} Adobe Photoshop CS5 Core is: true
                Action string for  {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} Adobe Photoshop CS5 Core  is none
                Value returned on lookup of payload: {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US is: false
                Action string for  {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US  is none
                Payload {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B} Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB is: true
                Action string for  {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B} Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB  is none
                Payload {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B} Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {FA5686B7-A305-4A41-93CD-48BAC929C313} Adobe Photoshop CS5 Core_x64_12.0.3_AdobePhotoshop12-Core_x64 is: true
                Action string for  {FA5686B7-A305-4A41-93CD-48BAC929C313} Adobe Photoshop CS5 Core_x64_12.0.3_AdobePhotoshop12-Core_x64  is none
                Payload {FA5686B7-A305-4A41-93CD-48BAC929C313} Adobe Photoshop CS5 Core_x64_12.0.3_AdobePhotoshop12-Core_x64 is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84} Adobe Photoshop CS5 Core_x64 is: true
                Action string for  {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84} Adobe Photoshop CS5 Core_x64  is none
                Value returned on lookup of payload: {50A16F0B-47DA-4583-B4FE-E026719A2024} Adobe Photoshop CS5 English Language Pack_x64_AdobePhotoshop12-en_US_x64 is: false
                Action string for  {50A16F0B-47DA-4583-B4FE-E026719A2024} Adobe Photoshop CS5 English Language Pack_x64_AdobePhotoshop12-en_US_x64  is none
                Payload {50A16F0B-47DA-4583-B4FE-E026719A2024} Adobe Photoshop CS5 English Language Pack_x64_AdobePhotoshop12-en_US_x64 is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {A47C8AE9-D51B-4A58-A051-396158FC3012} Adobe Photoshop CS5 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64 is: true
                Action string for  {A47C8AE9-D51B-4A58-A051-396158FC3012} Adobe Photoshop CS5 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64  is none
                Payload {A47C8AE9-D51B-4A58-A051-396158FC3012} Adobe Photoshop CS5 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64 is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {D20D27DB-B598-4142-8B7E-BE1342BA77C9} Adobe After Effects CS5_10.0.1_AdobeAfterEffects10AllRetail is: true
                Action string for  {D20D27DB-B598-4142-8B7E-BE1342BA77C9} Adobe After Effects CS5_10.0.1_AdobeAfterEffects10AllRetail  is none
                Payload {D20D27DB-B598-4142-8B7E-BE1342BA77C9} Adobe After Effects CS5_10.0.1_AdobeAfterEffects10AllRetail is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {0E659C1D-7686-4322-A501-58E3FEB4E743} Adobe After Effects CS5 is: true
                Action string for  {0E659C1D-7686-4322-A501-58E3FEB4E743} Adobe After Effects CS5  is none
                Value returned on lookup of payload: {6ACDB89B-63FB-4C7D-8490-7528E248F25B} Adobe After Effects CS5_AdobeAfterEffects10en_USLanguagePack is: true
                Action string for  {6ACDB89B-63FB-4C7D-8490-7528E248F25B} Adobe After Effects CS5_AdobeAfterEffects10en_USLanguagePack  is none
                Payload {6ACDB89B-63FB-4C7D-8490-7528E248F25B} Adobe After Effects CS5_AdobeAfterEffects10en_USLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {7E0C3ACA-19FA-1027-8580-84E7230B548F} Adobe InDesign CS5 Application Base Files_7.0.3.535_AdobeInDesign7AppBase-mul is: true
                Action string for  {7E0C3ACA-19FA-1027-8580-84E7230B548F} Adobe InDesign CS5 Application Base Files_7.0.3.535_AdobeInDesign7AppBase-mul  is none
                Payload {7E0C3ACA-19FA-1027-8580-84E7230B548F} Adobe InDesign CS5 Application Base Files_7.0.3.535_AdobeInDesign7AppBase-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {F9766AC1-1461-1033-B862-DF8FE1C033BE} Adobe InDesign CS5 Application Base Files is: true
                Action string for  {F9766AC1-1461-1033-B862-DF8FE1C033BE} Adobe InDesign CS5 Application Base Files  is none
                Value returned on lookup of payload: {7EB208EE-0C2B-1033-A6DC-E1BD0289A1F4} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_US is: false
                Action string for  {7EB208EE-0C2B-1033-A6DC-E1BD0289A1F4} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_US  is none
                Payload {7EB208EE-0C2B-1033-A6DC-E1BD0289A1F4} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_US is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {966B69F2-0FBD-1033-B01C-D13C02FFF33F} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_GB is: true
                Action string for  {966B69F2-0FBD-1033-B01C-D13C02FFF33F} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_GB  is none
                Payload {966B69F2-0FBD-1033-B01C-D13C02FFF33F} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_GB is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {05BAD153-18C5-1027-8235-EC70CC150594} Adobe InDesign CS5 Application Language Files_7.0.3.535_AdobeInDesign7AppLang-en_GB is: true
                Action string for  {05BAD153-18C5-1027-8235-EC70CC150594} Adobe InDesign CS5 Application Language Files_7.0.3.535_AdobeInDesign7AppLang-en_GB  is none
                Payload {05BAD153-18C5-1027-8235-EC70CC150594} Adobe InDesign CS5 Application Language Files_7.0.3.535_AdobeInDesign7AppLang-en_GB is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {26B63C3A-0BFF-1033-B389-A7ACEC31657E} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_GB is: true
                Action string for  {26B63C3A-0BFF-1033-B389-A7ACEC31657E} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_GB  is none
                Payload {26B63C3A-0BFF-1033-B389-A7ACEC31657E} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_GB is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {0A9AAB1E-0FEA-1033-851A-888C0B8E78B5} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_US is: true
                Action string for  {0A9AAB1E-0FEA-1033-851A-888C0B8E78B5} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_US  is none
                Payload {0A9AAB1E-0FEA-1033-851A-888C0B8E78B5} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_US is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {FDE4CB87-FDB7-40CE-A6D9-189E09FCABE8} Adobe Premiere Pro CS5_5.0.3_AdobePremierePro5AllRetail is: true
                Action string for  {FDE4CB87-FDB7-40CE-A6D9-189E09FCABE8} Adobe Premiere Pro CS5_5.0.3_AdobePremierePro5AllRetail  is none
                Payload {FDE4CB87-FDB7-40CE-A6D9-189E09FCABE8} Adobe Premiere Pro CS5_5.0.3_AdobePremierePro5AllRetail is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {0B754B55-6F63-461E-BB75-E8C883BDF88F} Adobe Premiere Pro CS5 is: true
                Action string for  {0B754B55-6F63-461E-BB75-E8C883BDF88F} Adobe Premiere Pro CS5  is none
                Value returned on lookup of payload: {B61DD7DA-4942-40A2-AF16-14957DFFEF09} Adobe Premiere Pro CS5_5.0.3_AdobePremierePro5en_USLanguagePack is: true
                Action string for  {B61DD7DA-4942-40A2-AF16-14957DFFEF09} Adobe Premiere Pro CS5_5.0.3_AdobePremierePro5en_USLanguagePack  is none
                Payload {B61DD7DA-4942-40A2-AF16-14957DFFEF09} Adobe Premiere Pro CS5_5.0.3_AdobePremierePro5en_USLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {34F82E6B-8096-45CA-B604-ACACAC22E553} Adobe Premiere Pro CS5_AdobePremierePro5en_USLanguagePack is: true
                Action string for  {34F82E6B-8096-45CA-B604-ACACAC22E553} Adobe Premiere Pro CS5_AdobePremierePro5en_USLanguagePack  is none
                Payload {34F82E6B-8096-45CA-B604-ACACAC22E553} Adobe Premiere Pro CS5_AdobePremierePro5en_USLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {70CAC073-3CDD-498C-80F7-79B76A61D7E6} Adobe Flash CS5_11.0.2_AdobeFlash11-mul is: true
                Action string for  {70CAC073-3CDD-498C-80F7-79B76A61D7E6} Adobe Flash CS5_11.0.2_AdobeFlash11-mul  is none
                Payload {70CAC073-3CDD-498C-80F7-79B76A61D7E6} Adobe Flash CS5_11.0.2_AdobeFlash11-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {CFC9F871-7C40-40B6-BE4A-B98A5B309716} Adobe Flash CS5 is: true
                Action string for  {CFC9F871-7C40-40B6-BE4A-B98A5B309716} Adobe Flash CS5  is none
                Value returned on lookup of payload: {F637969B-336C-4533-9D4D-D0163A39C42F} Adobe Flash CS5_11.0.2_AdobeFlash11-en_USLanguagePack is: true
                Action string for  {F637969B-336C-4533-9D4D-D0163A39C42F} Adobe Flash CS5_11.0.2_AdobeFlash11-en_USLanguagePack  is none
                Payload {F637969B-336C-4533-9D4D-D0163A39C42F} Adobe Flash CS5_11.0.2_AdobeFlash11-en_USLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack is: true
                Action string for  {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack  is none
                Payload {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul is: true
                Action string for  {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul  is none
                Payload {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US is: true
                Action string for  {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US  is none
                Payload {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US is extension payload. Aligning its action according to parent.
                Selection of payload {AAE6F374-91CB-45FB-9282-4CFA0DED2088} Adobe Media Encoder CS5 Dolby WRAPPER is allowed but the user has marked it for not to install
                Selection of payload {33A3F995-8333-4676-8D6F-AB7674BB52EA} Adobe Media Encoder CS5 PCI WRAPPER is allowed but the user has marked it for not to install
                END Setting requested payload actions
                Collected advanced path check information for INSTALLDIR
                INSTALLDIR is a well-formed path
                INSTALLDIR is not the root path
                INSTALLDIR is on a local volume
                INSTALLDIR is on a writable volume
                INSTALLDIR is not on a case sensitive volume
                INSTALLDIR passed path basic path validation: C:\Program Files (x86)\Adobe
                [    6204] Sun Feb 13 12:52:44 2011  INFO
                ::START TIMER:: [System check :{02731921-5711-4E7A-A898-D6BCF0F2A1CD}]
                In InstallPreSystemCheckProc
                Custom action return code: 0
                :: END TIMER :: [System check :{02731921-5711-4E7A-A898-D6BCF0F2A1CD}] took 15.9435 miliseconds (0.0159435 seconds)
                ::START TIMER:: [System check :{8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}]
                :: END TIMER :: [System check :{8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}] took 14.9719 miliseconds (0.0149719 seconds)
                [    6204] Sun Feb 13 12:52:45 2011  INFO
                ::START TIMER:: [System check :{7F9C94CD-0BAC-4F8F-8990-6A5886F4D550}]
                Font Installer: Fonts STI Custom Hook 1.6 Release
                :: END TIMER :: [System check :{7F9C94CD-0BAC-4F8F-8990-6A5886F4D550}] took 21.0319 miliseconds (0.0210319 seconds)
                ::START TIMER:: [System check :{0D067D13-C3D7-4EA6-B346-740CD91FD547}]
                CustomHooksTester -> In InstallPreSystemCheckProc
                :: END TIMER :: [System check :{0D067D13-C3D7-4EA6-B346-740CD91FD547}] took 14.565 miliseconds (0.014565 seconds)
                ::START TIMER:: [System check :{E39A5ABD-516B-46F9-A042-694BBA6A4E08}]
                :: END TIMER :: [System check :{E39A5ABD-516B-46F9-A042-694BBA6A4E08}] took 21.1709 miliseconds (0.0211709 seconds)
                ::START TIMER:: [System check :{CBDD7465-CE11-4A58-9497-C370B65923F1}]
                :: END TIMER :: [System check :{CBDD7465-CE11-4A58-9497-C370B65923F1}] took 21.0037 miliseconds (0.0210037 seconds)
                ::START TIMER:: [System check :{11C0657F-2BD4-4CBC-87F3-9455DC91886E}]
                :: END TIMER :: [System check :{11C0657F-2BD4-4CBC-87F3-9455DC91886E}] took 29.4713 miliseconds (0.0294713 seconds)
                [    6204] Sun Feb 13 12:52:46 2011  INFO
                ::START TIMER:: [System check :{7745F18B-FD8A-4011-BE16-588900C503D0}]
                :: END TIMER :: [System check :{7745F18B-FD8A-4011-BE16-588900C503D0}] took 21.3443 miliseconds (0.0213443 seconds)
                ::START TIMER:: [System check :{04D84E18-23ED-46EA-9B41-789433E34D03}]
                :: END TIMER :: [System check :{04D84E18-23ED-46EA-9B41-789433E34D03}] took 24.5427 miliseconds (0.0245427 seconds)
                ::START TIMER:: [System check :{177E1CA1-14CC-4398-AB15-A5746EFE8F22}]
                :: END TIMER :: [System check :{177E1CA1-14CC-4398-AB15-A5746EFE8F22}] took 15.8478 miliseconds (0.0158478 seconds)
                ::START TIMER:: [System check :{DE60F0DE-469A-42DC-A678-978313210057}]
                :: END TIMER :: [System check :{DE60F0DE-469A-42DC-A678-978313210057}] took 15.0508 miliseconds (0.0150508 seconds)
                ::START TIMER:: [System check :{E8815668-95B0-443D-AC92-2BFD7DD8F16A}]
                :: END TIMER :: [System check :{E8815668-95B0-443D-AC92-2BFD7DD8F16A}] took 24.1043 miliseconds (0.0241043 seconds)
                [    6204] Sun Feb 13 12:52:47 2011  INFO
                ::START TIMER:: [System check :{164965E8-4BB0-4EEB-AFBA-75785A2A2A7F}]
                :: END TIMER :: [System check :{164965E8-4BB0-4EEB-AFBA-75785A2A2A7F}] took 36.7976 miliseconds (0.0367976 seconds)
                [    6204] Sun Feb 13 12:52:47 2011  WARN
                Warning: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
                Warning: {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
                [    6204] Sun Feb 13 12:52:48 2011  INFO
                Payloads passed preflight validation.
                Call PreSession Custom Hook
                Calling the custom action code for pre-repair for payload {08D2E121-7F6A-43EB-97FD-629B44903403}
                ::START TIMER:: [Payload Operation :{08D2E121-7F6A-43EB-97FD-629B44903403}]
                [    4776] Sun Feb 13 12:52:48 2011  INFO
                Installer Operation: ModifyThirdPartyPayloadOperation
                Modify Thirdparty payload
                Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi
                MsiSourceListAddSource for  E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi is 0
                MsiSourceListSetInfo with updated name: Microsoft_VC90_CRT_x86.msi, Result: 0
                Payload exists on removable media: E:\
                [    4776] Sun Feb 13 12:52:49 2011  INFO
                Updating Media for package
                Added volume name: CS5 Master Coll1 for diskID: 1 with result: 0
                MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC90_CRT_x86\, Result: 0
                Configuring MSI ProductCode: {08D2E121-7F6A-43EB-97FD-629B44903403}
                Setting AFLPath C:\Program Files (x86)\Common Files\Adobe\Installers\{FBB02B04-C034-4382-A3F6-57416E2752C4}
                MsiConfigureProductEx command line:
                ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress   REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adb3F22.tmp"
                1: 0 2: 1033 3: 1252
                [    4776] Sun Feb 13 12:52:50 2011  INFO
                === Logging started: 13/02/2011  12:52:50 ===
                Message type: 0, Argument: 1033
                Message type: 1, Argument: Microsoft_VC90_CRT_x86
                Action 12:52:50: INSTALL.
                Action start 12:52:50: INSTALL.
                Action 12:52:50: SystemFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7.
                Action start 12:52:50: SystemFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7.
                Action ended 12:52:50: SystemFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7. Return value 1.
                Action 12:52:50: AppSearch. Searching for installed applications
                Action start 12:52:50: AppSearch.
                Action ended 12:52:50: AppSearch. Return value 0.
                Action 12:52:50: FindRelatedProducts. Searching for related applications
                Action start 12:52:50: FindRelatedProducts.
                Action ended 12:52:50: FindRelatedProducts. Return value 0.
                Action 12:52:50: ValidateProductID.
                Action start 12:52:50: ValidateProductID.
                Action ended 12:52:50: ValidateProductID. Return value 1.
                Action 12:52:50: WindowsFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7.
                Action start 12:52:50: WindowsFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7.
                Action ended 12:52:50: WindowsFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7. Return value 1.
                Action 12:52:50: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_75 44A81A5FCF.
                Action start 12:52:50: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_75 44A81A5FCF.
                Action ended 12:52:50: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_75 44A81A5FCF. Return value 1.
                Action 12:52:50: CostInitialize. Computing space requirements
                Action start 12:52:50: CostInitialize.
                [    4776] Sun Feb 13 12:52:56 2011  INFO
                Action ended 12:52:56: CostInitialize. Return value 1.
                Action 12:52:56: FileCost. Computing space requirements
                Action start 12:52:56: FileCost.
                Action ended 12:52:56: FileCost. Return value 1.
                Action 12:52:56: IsolateComponents.
                Action start 12:52:56: IsolateComponents.
                Action ended 12:52:56: IsolateComponents. Return value 0.
                Action 12:52:56: CostFinalize. Computing space requirements
                Action start 12:52:56: CostFinalize.
                Action ended 12:52:56: CostFinalize. Return value 1.
                Action 12:52:56: SetODBCFolders. Initializing ODBC directories
                Action start 12:52:56: SetODBCFolders.
                Action ended 12:52:56: SetODBCFolders. Return value 0.
                Action 12:52:56: MigrateFeatureStates. Migrating feature states from related applications
                Action start 12:52:56: MigrateFeatureStates.
                Action ended 12:52:56: MigrateFeatureStates. Return value 0.
                Action 12:52:56: InstallValidate. Validating install
                Action start 12:52:56: InstallValidate.
                Action ended 12:52:56: InstallValidate. Return value 1.
                Action 12:52:56: RemoveExistingProducts. Removing applications
                Action start 12:52:56: RemoveExistingProducts.
                Action ended 12:52:56: RemoveExistingProducts. Return value 0.
                Action 12:52:56: InstallInitialize.
                Action start 12:52:56: InstallInitialize.
                Action ended 12:52:56: InstallInitialize. Return value 1.
                Action 12:52:56: ProcessComponents. Updating component registration
                Action start 12:52:56: ProcessComponents.
                Action 12:52:56: GenerateScript. Generating script operations for action:
                Action ended 12:52:56: ProcessComponents. Return value 1.
                Action 12:52:56: UnpublishComponents. Unpublishing Qualified Components
                Action start 12:52:56: UnpublishComponents.
                Action ended 12:52:56: UnpublishComponents. Return value 0.
                Action 12:52:56: MsiUnpublishAssemblies. Unpublishing assembly information
                Action start 12:52:56: MsiUnpublishAssemblies.
                Action ended 12:52:56: MsiUnpublishAssemblies. Return value 1.
                Action 12:52:56: UnpublishFeatures. Unpublishing product features
                Action start 12:52:56: UnpublishFeatures.
                Action ended 12:52:56: UnpublishFeatures. Return value 1.
                Action 12:52:56: StopServices. Stopping services
                Action start 12:52:56: StopServices.
                Action ended 12:52:56: StopServices. Return value 1.
                Action 12:52:56: DeleteServices. Deleting services
                Action start 12:52:56: DeleteServices.
                Action ended 12:52:56: DeleteServices. Return value 1.
                Action 12:52:56: UnregisterComPlus. Unregistering COM+ Applications and Components
                Action start 12:52:56: UnregisterComPlus.
                Action ended 12:52:56: UnregisterComPlus. Return value 0.
                Action 12:52:56: SelfUnregModules. Unregistering modules
                Action start 12:52:56: SelfUnregModules.
                Action ended 12:52:56: SelfUnregModules. Return value 1.
                Action 12:52:56: UnregisterTypeLibraries. Unregistering type libraries
                Action start 12:52:56: UnregisterTypeLibraries.
                Action ended 12:52:56: UnregisterTypeLibraries. Return value 0.
                Action 12:52:56: RemoveODBC. Removing ODBC components
                Action start 12:52:56: RemoveODBC.
                Action ended 12:52:56: RemoveODBC. Return value 1.
                Action 12:52:56: UnregisterFonts. Unregistering fonts
                Action start 12:52:56: UnregisterFonts.
                Action ended 12:52:56: UnregisterFonts. Return value 1.
                Action 12:52:56: RemoveRegistryValues. Removing system registry values
                Action start 12:52:56: RemoveRegistryValues.
                Action ended 12:52:56: RemoveRegistryValues. Return value 1.
                Action 12:52:56: UnregisterClassInfo. Unregister class servers
                Action start 12:52:56: UnregisterClassInfo.
                Action ended 12:52:56: UnregisterClassInfo. Return value 0.
                Action 12:52:56: UnregisterExtensionInfo. Unregistering extension servers
                Action start 12:52:56: UnregisterExtensionInfo.
                Action ended 12:52:56: UnregisterExtensionInfo. Return value 0.
                Action 12:52:56: UnregisterProgIdInfo. Unregistering program identifiers
                Action start 12:52:56: UnregisterProgIdInfo.
                Action ended 12:52:56: UnregisterProgIdInfo. Return value 0.
                Action 12:52:56: UnregisterMIMEInfo. Unregistering MIME info
                Action start 12:52:56: UnregisterMIMEInfo.
                Action ended 12:52:56: UnregisterMIMEInfo. Return value 0.
                Action 12:52:56: RemoveIniValues. Removing INI file entries
                Action start 12:52:56: RemoveIniValues.
                Action ended 12:52:56: RemoveIniValues. Return value 1.
                Action 12:52:56: RemoveShortcuts. Removing shortcuts
                Action start 12:52:56: RemoveShortcuts.
                Action ended 12:52:56: RemoveShortcuts. Return value 0.
                Action 12:52:56: RemoveEnvironmentStrings. Updating environment strings
                Action start 12:52:56: RemoveEnvironmentStrings.
                Action ended 12:52:56: RemoveEnvironmentStrings. Return value 1.
                Action 12:52:56: RemoveDuplicateFiles. Removing duplicated files
                Action start 12:52:56: RemoveDuplicateFiles.
                Action ended 12:52:56: RemoveDuplicateFiles. Return value 1.
                Action 12:52:56: RemoveFiles. Removing files
                Action start 12:52:56: RemoveFiles.
                Action ended 12:52:56: RemoveFiles. Return value 0.
                Action 12:52:56: RemoveFolders. Removing folders
                Action start 12:52:56: RemoveFolders.
                Action ended 12:52:56: RemoveFolders. Return value 0.
                Action 12:52:56: CreateFolders. Creating folders
                Action start 12:52:56: CreateFolders.
                Action ended 12:52:56: CreateFolders. Return value 0.
                Action 12:52:56: MoveFiles. Moving files
                Action start 12:52:56: MoveFiles.
                Action ended 12:52:56: MoveFiles. Return value 1.
                Action 12:52:56: InstallFiles. Copying new files
                Action start 12:52:56: InstallFiles.
                File: Copying new files,  Directory: ,  Size:
                Action ended 12:52:56: InstallFiles. Return value 1.
                Action 12:52:56: PatchFiles. Patching files
                Action start 12:52:56: PatchFiles.
                Action ended 12:52:56: PatchFiles. Return value 0.
                Action 12:52:56: DuplicateFiles. Creating duplicate files
                Action start 12:52:56: DuplicateFiles.
                Action ended 12:52:56: DuplicateFiles. Return value 1.
                Action 12:52:56: BindImage. Binding executables
                Action start 12:52:56: BindImage.
                Action ended 12:52:56: BindImage. Return value 1.
                Action 12:52:56: CreateShortcuts. Creating shortcuts
                Action start 12:52:56: CreateShortcuts.
                Shortcut: Creating shortcuts
                Action ended 12:52:56: CreateShortcuts. Return value 0.
                Action 12:52:56: RegisterClassInfo. Registering class servers
                Action start 12:52:56: RegisterClassInfo.
                Action ended 12:52:56: RegisterClassInfo. Return value 0.
                Action 12:52:56: RegisterExtensionInfo. Registering extension servers
                Action start 12:52:56: RegisterExtensionInfo.
                Action ended 12:52:56: RegisterExtensionInfo. Return value 0.
                Action 12:52:56: RegisterProgIdInfo. Registering program identifiers
                Action start 12:52:56: RegisterProgIdInfo.
                Action ended 12:52:56: RegisterProgIdInfo. Return value 0.
                Action 12:52:56: RegisterMIMEInfo. Registering MIME info
                Action start 12:52:56: RegisterMIMEInfo.
                Action ended 12:52:56: RegisterMIMEInfo. Return value 0.
                Action 12:52:56: WriteRegistryValues. Writing system registry values
                Action start 12:52:56: WriteRegistryValues.
                Action ended 12:52:56: WriteRegistryValues. Return value 1.
                Action 12:52:56: WriteIniValues. Writing INI file values
                Action start 12:52:56: WriteIniValues.
                Action ended 12:52:56: WriteIniValues. Return value 1.
                Action 12:52:56: WriteEnvironmentStrings. Updating environment strings
                Action start 12:52:56: WriteEnvironmentStrings.
                Action ended 12:52:56: WriteEnvironmentStrings. Return value 1.
                Action 12:52:56: RegisterFonts. Registering fonts
                Action start 12:52:56: RegisterFonts.
                Action ended 12:52:56: RegisterFonts. Return value 1.
                Action 12:52:56: InstallODBC. Installing ODBC components
                Action start 12:52:56: InstallODBC.
                Action ended 12:52:56: InstallODBC. Return value 0.
                Action 12:52:56: RegisterTypeLibraries. Registering type libraries
                Action start 12:52:56: RegisterTypeLibraries.
                Action ended 12:52:56: RegisterTypeLibraries. Return value 0.
                Action 12:52:56: SelfRegModules. Registering modules
                Action start 12:52:56: SelfRegModules.
                Action ended 12:52:56: SelfRegModules. Return value 1.
                Action 12:52:56: RegisterComPlus. Registering COM+ Applications and Components
                Action start 12:52:56: RegisterComPlus.
                Action ended 12:52:56: RegisterComPlus. Return value 0.
                Action 12:52:56: InstallServices. Installing new services
                Action start 12:52:56: InstallServices.
                Action ended 12:52:56: InstallServices. Return value 1.
                Action 12:52:56: StartServices. Starting services
                Action start 12:52:56: StartServices.
                Action ended 12:52:56: StartServices. Return value 1.
                Action 12:52:56: RegisterUser. Registering user
                Action start 12:52:56: RegisterUser.
                Action ended 12:52:56: RegisterUser. Return value 0.
                Action 12:52:56: RegisterProduct. Registering product
                Action start 12:52:56: RegisterProduct.
                Registering product
                Action ended 12:52:56: RegisterProduct. Return value 1.
                Action 12:52:56: PublishComponents. Publishing qualified components
                Action start 12:52:56: PublishComponents.
                Action ended 12:52:56: PublishComponents. Return value 0.
                Action 12:52:56: MsiPublishAssemblies. Publishing assembly information
                Action start 12:52:56: MsiPublishAssemblies.
                Application Context:Publishing assembly information, Assembly Name:
                Action ended 12:52:56: MsiPublishAssemblies. Return value 1.
                Action 12:52:56: PublishFeatures. Publishing product features
                Action start 12:52:56: PublishFeatures.
                Feature: Publishing product features
                Action ended 12:52:56: PublishFeatures. Return value 1.
                Action 12:52:56: PublishProduct. Publishing product information
                Action start 12:52:56: PublishProduct.
                Action ended 12:52:56: PublishProduct. Return value 1.
                Action 12:52:56: InstallFinalize.
                Action start 12:52:56: InstallFinalize.
                Shortcut: ARPPRODUCTICON.exe
                40d50.msi
                Application Context:Global, Assembly Name:Microsoft.VC90.CRT,version="9.0.30729.4137",publicKeyToken="1fc8b3b9a1e18e3b",proces sorArchitecture="x86",type="win32"
                Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.CRT,version="9.0.30729.4137",publicKeyToken="1fc8b3b9a1e18 e3b",processorArchitecture="x86",type="win32-policy"
                Feature: Microsoft_VC90_CRT_x86_
                Message type: 2, Argument: 0
                Action 12:52:56: RollbackCleanup. Removing backup files
                File: C:\Config.Msi\354041.rbf
                File: C:\Config.Msi\354042.rbf
                Message type: 2, Argument: 1
                [    4776] Sun Feb 13 12:52:57 2011  INFO
                Action ended 12:52:57: InstallFinalize. Return value 1.
                Action ended 12:52:57: INSTALL. Return value 1.
                Property(S): DiskPrompt = [1]
                Property(S): UpgradeCode = {0FD62DF3-05EA-44F2-9C45-98FA04CF85DE}
                Property(S): SourcedirProduct = {08D2E121-7F6A-43EB-97FD-629B44903403}
                Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\
                Property(S): Installed = 2009/07/28 04:12:16
                Property(S): PrimaryVolumeSpaceRemaining = 0
                Property(S): PrimaryVolumeSpaceRequired = 0
                Property(S): PrimaryVolumeSpaceAvailable = 0
                Property(S): OutOfNoRbDiskSpace = 0
                Property(S): OutOfDiskSpace = 0
                Property(S): CostingComplete = 1
                Property(S): ROOTDRIVE = F:\
                Property(S): ACTION = INSTALL
                Property(S): Preselected = 1
                Property(S): QFEUpgrade = 1
                Property(S): UILevel = 2
                Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi
                Property(S): DATABASE = C:\Windows\Installer\35403b.msi
                Property(S): Privileged = 1
                Property(S): MsiRunningElevated = 1
                Property(S): RedirectedDllSupport = 2
                Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
                Property(S): MsiNetAssemblySupport = 4.0.30319.1
                Property(S): Date = 13/02/2011
                Property(S): Time = 12:52:57
                Property(S): TTCSupport = 1
                Property(S): ColorBits = 32
                Property(S): TextInternalLeading = 3
                Property(S): TextHeight = 16
                Property(S): BorderSide = 1
                Property(S): BorderTop = 1
                Property(S): CaptionHeight = 22
                Property(S): ScreenY = 768
                Property(S): ScreenX = 1024
                Property(S): SystemLanguageID = 3081
                Property(S): ComputerName = PC
                Property(S): UserLanguageID = 3081
                Property(S): UserSID = S-1-5-21-618155685-1063480468-518450737-1000
                Property(S): LogonUser = Gary & Susan
                Property(S): MsiTrueAdminUser = 1
                Property(S): AdminUser = 1
                Property(S): VirtualMemory = 14381
                Property(S): PhysicalMemory = 8151
                Property(S): Intel = 6
                Property(S): Msix64 = 6
                Property(S): MsiAMD64 = 6
                Property(S): ShellAdvtSupport = 1
                Property(S): OLEAdvtSupport = 1
                Property(S): GPTSupport = 1
                Property(S): RecentFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Recent\
                Property(S): VersionNT = 601
                Property(S): ProgramFilesFolder = C:\Program Files (x86)\
                Property(S): ADOBE = C:\Program Files (x86)\Adobe\
                Property(S): TARGETDIR = F:\
                Property(S): ALLUSERSPROFILE = F:\
                Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
                Property(S): AppDataFolder = C:\Users\Gary & Susan\AppData\Roaming\
                Property(S): CommonAppDataFolder = C:\ProgramData\
                Property(S): CommonFiles64Folder = C:\Program Files (x86)\Common Files\
                Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
                Property(S): ISYourDataBaseDir = C:\Program Files (x86)\Adobe\My Product Name\Database\
                Property(S): DATABASEDIR = C:\Program Files (x86)\Adobe\My Product Name\Database\
                Property(S): DesktopFolder = C:\Users\Public\Desktop\
                Property(S): FavoritesFolder = C:\Users\Gary & Susan\Favorites\
                Property(S): FontsFolder = C:\Windows\Fonts\
                Property(S): GlobalAssemblyCache = F:\
                Property(S): MY_PRODUCT_NAME = C:\Program Files (x86)\Adobe\My Product Name\
                Property(S): INSTALLDIR = C:\Program Files (x86)\Adobe\My Product Name\
                Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
                Property(S): ISMyCompanyDir = C:\Program Files (x86)\My Company Name\
                Property(S): ISMyProductDir = C:\Program Files (x86)\My Company Name\My Product Name\
                Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
                Property(S): LocalAppDataFolder = C:\Users\Gary & Susan\AppData\Local\
                Property(S): MyPicturesFolder = C:\Users\Gary & Susan\Pictures\
                Property(S): PersonalFolder = C:\Users\Gary & Susan\Documents\
                Property(S): PrimaryVolumePath = F:\
                Property(S): ProgramFiles64Folder = C:\Program Files (x86)\
                Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
                Property(S): SendToFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\SendTo\
                Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
                Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
                Property(S): System16Folder = F:\
                Property(S): System64Folder = C:\Windows\SysWOW64\
                Property(S): SystemFolder = C:\Windows\SysWOW64\
                Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\
                Property(S): TempFolder = C:\Users\GARY&S~1\AppData\Local\Temp\
                Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
                Property(S): USERPROFILE = F:\
                Property(S): WindowsFolder = C:\Windows\
                Property(S): WindowsVolume = C:\
                Property(S): WindowsFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\
                Property(S): SystemFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\SysWOW64\
                Property(S): WinSxsDirectory.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B 7 = C:\Windows\winsxs\
                Property(S): payload_ul.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4137_none_508fc1d4bcb b3eca\
                Property(S): payload.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.4137_x-ww_d494ac0e\
                Property(S): WinSxsManifests.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B 7 = C:\Windows\winsxs\Manifests\
                Property(S): WinSxsPolicies.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\Policies\
                Property(S): policydir.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\Policies\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_1742743b\
                Property(S): policydir_ul.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_1742743b\
                Property(S): ALLUSERS = 1
                Property(S): WinSxsDirectory.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_ 7544A81A5FCF = C:\Windows\winsxs\
                Property(S): payload_ul.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_7544A 81A5FCF = C:\Windows\winsxs\x86_policy.9.0.microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4137_none_ f47d3254f657e518\
                Property(S): WinSxsPolicies.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_7 544A81A5FCF = C:\Windows\winsxs\Policies\
                Property(S): policydir.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_7544A8 1A5FCF = C:\Windows\winsxs\Policies\x86_policy.9.0.Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_b7353f 75\
                Property(S): WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_75 44A81A5FCF = C:\Windows\
                Property(S): PrintHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
                Property(S): NetHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
                Property(S): RemoteAdminTS = 1
                Property(S): MsiNTSuitePersonal = 1
                Property(S): MsiNTProductType = 1
                Property(S): ServicePackLevelMinor = 0
                Property(S): ServicePackLevel = 0
                Property(S): WindowsBuild = 7600
                Property(S): VersionNT64 = 601
                Property(S): VersionMsi = 5.00
                Property(S): ISCHECKFORPRODUCTUPDATES = 1
                Property(S): ApplicationUsers = AllUsers
                Property(S): AgreeToLicense = No
                Property(S): _IsMaintenance = Change
                Property(S): SetupType = Typical
                Property(S): _IsSetupTypeMin = Typical
                Property(S): IS_SQLSERVER_USERNAME = sa
                Property(S): IS_SQLSERVER_AUTHENTICATION = 0
                Property(S): RestartManagerOption = CloseRestart
                Property(S): Display_IsBitmapDlg = 1
                Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
                Property(S): DefaultUIFont = Tahoma8
                Property(S): DialogCaption = InstallShield for Windows Installer
                Property(S): DisplayNameCustom = Custom
                Property(S): DisplayNameMinimal = Minimal
                Property(S): DisplayNameTypical = Typical
                Property(S): DWUSINTERVAL = 30
                Property(S): ErrorDialog = SetupError
                Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
                Property(S): InstallChoice = AR
                Property(S): INSTALLLEVEL = 100
                Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
                Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
                Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
                Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
                Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
                Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
                Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
                Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
                Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
                Property(S): ISVROOT_PORT_NO = 0
                Property(S): Manufacturer = Adobe
                Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
                Property(S): ProductCode = {08D2E121-7F6A-43EB-97FD-629B44903403}
                Property(S): ProductID = none
                Property(S): ProductLanguage = 1033
                Property(S): ProductName = Microsoft_VC90_CRT_x86
                Property(S): ProductVersion = 1.00.0000
                Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
                Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
                Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
                Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
                Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
                Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
                Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
                Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
                Property(S): ProgressType0 = install
                Property(S): ProgressType1 = Installing
                Property(S): ProgressType2 = installed
                Property(S): ProgressType3 = installs
                Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
                Property(S): RebootYesNo = Yes
                Property(S): ReinstallModeText = omus
                Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
                Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
                Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
                Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
                Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
                Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
                Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
                Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
                Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
                Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
                Property(S): DWUSLINK = CEBCC75FFEEBF7C8BEACA0F8D9CB978FB9FB078FDE8CE0E8CE2BC08F9EAB5058BEDCD0A8FEAC
                Property(S): ARPURLINFOABOUT = http://www.Adobe.com
                Property(S): SHOWLAUNCHPROGRAM = 0
                Property(S): REBOOT = ReallySuppress
                Property(S): ARPSYSTEMCOMPONENT = 1
                Property(S): VersionDatabase = 200
                Property(S): PRODUCTLANGUAGE = 1033
                Property(S): MsiSystemRebootPending = 1
                Property(S): CURRENTMEDIAVOLUMELABEL = CS5 Master Coll1
                Property(S): CLIENTPROCESSID = 5888
                Property(S): MSICLIENTUSESEXTERNALUI = 1
                Property(S): CLIENTUILEVEL = 3
                Property(S): CURRENTDIRECTORY = C:\Users\Gary & Susan\AppData\Local\Adobe\OOBE\PDApp\DWA
                Property(S): ADDLOCAL = ALL
                Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adb3F22.tmp
                Property(S): REINSTALLMODE = pvoums
                Property(S): REINSTALL = ALL
                Property(S): MSIRESTARTMANAGERCONTROL = Disable
                Property(S): ADOBE_SETUP = 1
                Property(S): ProductToBeRegistered = 1
                Property(S): USERNAME = Gary & Susan
                Property(S): ProductState = 5
                Property(S): PackageCode = {5DB7D0CC-71CB-4DD2-993F-C9E909FA78F0}
                === Logging stopped: 13/02/2011  12:52:57 ===
                1: 2 2: 0
                1: 2 2: 1
                [    6204] Sun Feb 13 12:52:57 2011  INFO
                *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
                :: END TIMER :: [Payload Operation :{08D2E121-7F6A-43EB-97FD-629B44903403}] took 9017.99 miliseconds (9.01799 seconds) DTR = 5.3227 KBPS (0.00519795 MBPS)
                Updating driver data - Action: Add driver entry
                Updating driver data successful. Driver entry was added. ARP estimated size 0KB
                User specified overrideFile:
                Calling the custom action code for post-repair for payload {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86
                Calling the custom action code for pre-repair for payload {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
                ::START TIMER:: [Payload Operation :{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}]
                [    2916] Sun Feb 13 12:52:57 2011  INFO
                Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
                MsiSourceListAddSource for  E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi is 0
                MsiSourceListSetInfo with updated name: Microsoft_VC80_CRT_x86.msi, Result: 0
                MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC80_CRT_x86\, Result: 0
                Configuring MSI ProductCode: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
                ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress   REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adb604B.tmp"
                [    2916] Sun Feb 13 12:52:58 2011  INFO
                === Logging started: 13/02/2011  12:52:58 ===
                Message type: 1, Argument: Microsoft_VC80_CRT_x86
                Action 12:52:58: INSTALL.
                Action start 12:52:58: INSTALL.
                Action 12:52:58: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
                Action start 12:52:58: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
                Action ended 12:52:58: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E. Return value 1.
                Action 12:52:58: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
                Action start 12:52:58: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
                Action ended 12:52:58: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E. Return value 1.
                Action 12:52:58: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
                Action start 12:52:58: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
                Action ended 12:52:58: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E. Return value 1.
                Action 12:52:58: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
                Action start 12:52:58: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
                Action ended 12:52:58: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E. Return value 1.
                Action 12:52:58: AppSearch. Searching for installed applications
                Action start 12:52:58: AppSearch.
                Action ended 12:52:58: AppSearch. Return value 0.
                Action 12:52:58: FindRelatedProducts. Searching for related applications
                Action start 12:52:58: FindRelatedProducts.
                Action ended 12:52:58: FindRelatedProducts. Return value 0.
                Action 12:52:58: ValidateProductID.
                Action start 12:52:58: ValidateProductID.
                Action ended 12:52:58: ValidateProductID. Return value 1.
                Action 12:52:58: CostInitialize. Computing space requirements
                Action start 12:52:58: CostInitialize.
                Action ended 12:52:58: CostInitialize. Return value 1.
                Action 12:52:58: FileCost. Computing space requirements
                Action start 12:52:58: FileCost.
                Action ended 12:52:58: FileCost. Return value 1.
                Action 12:52:58: IsolateComponents.
                Action start 12:52:58: IsolateComponents.
                Action ended 12:52:58: IsolateComponents. Return value 0.
                Action 12:52:58: CostFinalize. Computing space requirements
                Action start 12:52:58: CostFinalize.
                Action ended 12:52:58: CostFinalize. Return value 1.
                Action 12:52:58: SetODBCFolders. Initializing ODBC directories
                Action start 12:52:58: SetODBCFolders.
                Action ended 12:52:58: SetODBCFolders. Return value 0.
                Action 12:52:58: MigrateFeatureStates. Migrating feature states from related applications
                Action start 12:52:58: MigrateFeatureStates.
                Action ended 12:52:58: MigrateFeatureStates. Return value 0.
                Action 12:52:58: InstallValidate. Validating install
                Action start 12:52:58: InstallValidate.
                Action ended 12:52:58: InstallValidate. Return value 1.
                Action 12:52:58: RemoveExistingProducts. Removing applications
                Action start 12:52:58: RemoveExistingProducts.
                Action ended 12:52:58: RemoveExistingProducts. Return value 0.
                Action 12:52:58: InstallInitialize.
                Action start 12:52:58: InstallInitialize.
                Action ended 12:52:58: InstallInitialize. Return value 1.
                Action 12:52:58: SxsInstallCA.
                Action start 12:52:58: SxsInstallCA.
                [    2916] Sun Feb 13 12:52:59 2011  INFO
                1: sxsdelca 2: traceop 3: 1256 4: 0
                1: sxsdelca 2: traceop 3: 1257 4: 0
                1: sxsdelca 2: traceop 3: 1258 4: 0
                1: sxsdelca 2: traceop 3: 1284 4: 0
                1: sxsdelca 2: traceop 3: 1288 4: 0
                1: sxsdelca 2: traceop 3: 1289 4: 0
                1: sxsdelca 2: traceop 3: 1290 4: 0
                1: sxsdelca 2: traceop 3: 1292 4: 0
                1: sxsdelca 2: traceop 3: 1318 4: 0
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: uplevel.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: uplevel.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca 2: traceop 3: 1284 4: 259
                1: sxsdelca 2: SxsMsmInstall completed 3: 0 4: 0
                Action ended 12:52:59: SxsInstallCA. Return value 1.
                Action 12:52:59: ProcessComponents. Updating component registration
                Action start 12:52:59: ProcessComponents.
                Action 12:52:59: GenerateScript. Generating script operations for action:
                Action ended 12:52:59: ProcessComponents. Return value 1.
                Action 12:52:59: UnpublishComponents. Unpublishing Qualified Components
                Action start 12:52:59: UnpublishComponents.
                Action ended 12:52:59: UnpublishComponents. Return value 0.
                Action 12:52:59: MsiUnpublishAssemblies. Unpublishing assembly information
                Action start 12:52:59: MsiUnpublishAssemblies.
                Action ended 12:52:59: MsiUnpublishAssemblies. Return value 1.
                Action 12:52:59: UnpublishFeatures. Unpublishing product features
                Action start 12:52:59: UnpublishFeatures.
                Action ended 12:52:59: UnpublishFeatures. Return value 1.
                Action 12:52:59: StopServices. Stopping services
                Action start 12:52:59: StopServices.
                Action ended 12:52:59: StopServices. Return value 1.
                Action 12:52:59: DeleteServices. Deleting services
                Action start 12:52:59: DeleteServices.
                Action ended 12:52:59: DeleteServices. Return value 1.
                Action 12:52:59: UnregisterComPlus. Unregistering COM+ Applications and Components
                Action start 12:52:59: UnregisterComPlus.
                Action ended 12:52:59: UnregisterComPlus. Return value 0.
                Action 12:52:59: SelfUnregModules. Unregistering modules
                Action start 12:52:59: SelfUnregModules.
                Action ended 12:52:59: SelfUnregModules. Return value 1.
                Action 12:52:59: UnregisterTypeLibraries. Unregistering type libraries
                Action start 12:52:59: UnregisterTypeLibraries.
                Action ended 12:52:59: UnregisterTypeLibraries. Return value 0.
                Action 12:52:59: RemoveODBC. Removing ODBC components
                Action start 12:52:59: RemoveODBC.
                Action ended 12:52:59: RemoveODBC. Return value 1.
                Action 12:52:59: UnregisterFonts. Unregistering fonts
                Action start 12:52:59: UnregisterFonts.
                Action ended 12:52:59: UnregisterFonts. Return value 1.
                Action 12:52:59: RemoveRegistryValues. Removing system registry values
                Action start 12:52:59: RemoveRegistryValues.
                Action ended 12:52:59: RemoveRegistryValues. Return value 1.
                Action 12:52:59: UnregisterClassInfo. Unregister class servers
                Action start 12:52:59: UnregisterClassInfo.
                Action ended 12:52:59: UnregisterClassInfo. Return value 0.
                Action 12:52:59: UnregisterExtensionInfo. Unregistering extension servers
                Action start 12:52:59: UnregisterExtensionInfo.
                Action ended 12:52:59: UnregisterExtensionInfo. Return value 0.
                Action 12:52:59: UnregisterProgIdInfo. Unregistering program identifiers
                Action start 12:52:59: UnregisterProgIdInfo.
                Action ended 12:52:59: UnregisterProgIdInfo. Return value 0.
                Action 12:52:59: UnregisterMIMEInfo. Unregistering MIME info
                Action start 12:52:59: UnregisterMIMEInfo.
                Action ended 12:52:59: UnregisterMIMEInfo. Return value 0.
                Action 12:52:59: RemoveIniValues. Removing INI file entries
                Action start 12:52:59: RemoveIniValues.
                Action ended 12:52:59: RemoveIniValues. Return value 1.
                Action 12:52:59: RemoveShortcuts. Removing shortcuts
                Action start 12:52:59: RemoveShortcuts.
                Action ended 12:52:59: RemoveShortcuts. Return value 0.
                Action 12:52:59: RemoveEnvironmentStrings. Updating environment strings
                Action start 12:52:59: RemoveEnvironmentStrings.
                Action ended 12:52:59: RemoveEnvironmentStrings. Return value 1.
                Action 12:52:59: RemoveDuplicateFiles. Removing duplicated files
                Action start 12:52:59: RemoveDuplicateFiles.
                Action ended 12:52:59: RemoveDuplicateFiles. Return value 1.
                Action 12:52:59: RemoveFiles. Removing files
                Action start 12:52:59: RemoveFiles.
                Action ended 12:52:59: RemoveFiles. Return value 0.
                Action 12:52:59: RemoveFolders. Removing folders
                Action start 12:52:59: RemoveFolders.
                Action ended 12:52:59: RemoveFolders. Return value 0.
                Action 12:52:59: CreateFolders. Creating folders
                Action start 12:52:59: CreateFolders.
                Action ended 12:52:59: CreateFolders. Return value 0.
                Action 12:52:59: MoveFiles. Moving files
                Action start 12:52:59: MoveFiles.
                Action ended 12:52:59: MoveFiles. Return value 1.
                Action 12:52:59: InstallFiles. Copying new files
                Action start 12:52:59: InstallFiles.
                [    2916] Sun Feb 13 12:53:01 2011  INFO
                [    2916] Sun Feb 13 12:53:07 2011  INFO
                Action ended 12:53:07: InstallFiles. Return value 1.
                Action 12:53:07: PatchFiles. Patching files
                Action start 12:53:07: PatchFiles.
                Action ended 12:53:07: PatchFiles. Return value 0.
                Action 12:53:07: DuplicateFiles. Creating duplicate files
                Action start 12:53:07: DuplicateFiles.
                Action ended 12:53:07: DuplicateFiles. Return value 1.
                Action 12:53:07: BindImage. Binding executables
                Action start 12:53:07: BindImage.
                Action ended 12:53:07: BindImage. Return value 1.
                Action 12:53:07: CreateShortcuts. Creating shortcuts
                Action start 12:53:07: CreateShortcuts.
                Action ended 12:53:07: CreateShortcuts. Return value 0.
                Action 12:53:07: RegisterClassInfo. Registering class servers
                Action start 12:53:07: RegisterClassInfo.
                Action ended 12:53:07: RegisterClassInfo. Return value 0.
                Action 12:53:07: RegisterExtensionInfo. Registering extension servers
                Action start 12:53:07: RegisterExtensionInfo.
                Action ended 12:53:07: RegisterExtensionInfo. Return value 0.
                Action 12:53:07: RegisterProgIdInfo. Registering program identifiers
                Action start 12:53:07: RegisterProgIdInfo.
                Action ended 12:53:07: RegisterProgIdInfo. Return value 0.
                Action 12:53:07: RegisterMIMEInfo. Registering MIME info
                Action start 12:53:07: RegisterMIMEInfo.
                Action ended 12:53:07: RegisterMIMEInfo. Return value 0.
                Action 12:53:07: WriteRegistryValues. Writing system registry values
                Action start 12:53:07: WriteRegistryValues.
                Action ended 12:53:07: WriteRegistryValues. Return value 1.
                Action 12:53:07: WriteIniValues. Writing INI file values
                Action start 12:53:07: WriteIniValues.
                Action ended 12:53:07: WriteIniValues. Return value 1.
                Action 12:53:07: WriteEnvironmentStrings. Updating environment strings
                Action start 12:53:07: WriteEnvironmentStrings.
                Action ended 12:53:07: WriteEnvironmentStrings. Return value 1.
                Action 12:53:07: RegisterFonts. Registering fonts
                Action start 12:53:07: RegisterFonts.
                Action ended 12:53:07: RegisterFonts. Return value 1.
                Action 12:53:07: InstallODBC. Installing ODBC components
                Action start 12:53:07: InstallODBC.
                Action ended 12:53:07: InstallODBC. Return value 0.
                Action 12:53:07: RegisterTypeLibraries. Registering type libraries
                Action start 12:53:07: RegisterTypeLibraries.
                Action ended 12:53:07: RegisterTypeLibraries. Return value 0.
                Action 12:53:07: SelfRegModules. Registering modules
                Action start 12:53:07: SelfRegModules.
                Action ended 12:53:07: SelfRegModules. Return value 1.
                Action 12:53:07: RegisterComPlus. Registering COM+ Applications and Components
                Action start 12:53:07: RegisterComPlus.
                Action ended 12:53:07: RegisterComPlus. Return value 0.
                Action 12:53:07: InstallServices. Installing new services
                Action start 12:53:07: InstallServices.
                Action ended 12:53:07: InstallServices. Return value 1.
                Action 12:53:07: StartServices. Starting services
                Action start 12:53:07: StartServices.
                Action ended 12:53:07: StartServices. Return value 1.
                Action 12:53:07: RegisterUser. Registering user
                Action start 12:53:07: RegisterUser.
                Action ended 12:53:07: RegisterUser. Return value 0.
                Action 12:53:07: RegisterProduct. Registering product
                Action start 12:53:07: RegisterProduct.
                Registering product
                Action ended 12:53:07: RegisterProduct. Return value 1.
                Action 12:53:07: PublishComponents. Publishing qualified components
                Action start 12:53:07: PublishComponents.
                Action ended 12:53:07: PublishComponents. Return value 0.
                Action 12:53:07: MsiPublishAssemblies. Publishing assembly information
                Action start 12:53:07: MsiPublishAssemblies.
                Action ended 12:53:07: MsiPublishAssemblies. Return value 1.
                Action 12:53:07: PublishFeatures. Publishing product features
                Action start 12:53:07: PublishFeatures.
                Action ended 12:53:07: PublishFeatures. Return value 1.
                Action 12:53:07: PublishProduct. Publishing product information
                Action start 12:53:07: PublishProduct.
                Action ended 12:53:07: PublishProduct. Return value 1.
                Action 12:53:07: InstallFinalize.
                Action start 12:53:07: InstallFinalize.
                Action 12:53:07: ProcessComponents. Updating component registration
                Action 12:53:07: RemoveODBC. Removing ODBC components
                Action 12:53:07: InstallFiles. Copying new files
                40d59.msi
                Application Context:Global, Assembly Name:Microsoft.VC80.CRT,version="8.0.50727.4053",type="win32",publicKeyToken="1fc8b3b9a1e 18e3b",processorArchitecture="x86"
                Application Context:Global, Assembly Name:policy.8.0.Microsoft.VC80.CRT,version="8.0.50727.4053",type="win32-policy",publicKey Token="1fc8b3b9a1e18e3b",processorArchitecture="x86"
                Feature: Microsoft_VC80_CRT_x86_
                Action 12:53:07: RollbackCleanup. Removing backup files
                File: C:\Config.Msi\35404a.rbf
                File: C:\Config.Msi\35404b.rbf
                Action ended 12:53:07: InstallFinalize. Return value 1.
                Action ended 12:53:07: INSTALL. Return value 1.
                Property(S): SourcedirProduct = {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
                Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\
                Property(S): UpgradeCode = {662366D8-8FF7-4EA3-92A8-C7FEA8AC8032}
                Property(S): Installed = 2009/11/13 21:21:16
                Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
                Property(S): DATABASE = C:\Windows\Installer\354044.msi
                Property(S): Time = 12:53:07
                Property(S): VirtualMemory = 14373
                Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\
                Property(S): WinSxsDirectory.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
                Property(S): payload_ul.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_d08d7da0442 a985d\
                Property(S): payload.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_0de06acd\
                Property(S): WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\
                Property(S): SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
                Property(S): WinSxsManifests.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
                Property(S): WinSxsPolicies.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
                Property(S): policydir.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): policydir_ul.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989\
                Property(S): policydir.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): policydir.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): policydir.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): policydir.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): policydir.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): policydir.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): payload.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_0de46bd0\
                Property(S): policydir.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): policydir.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): policydir.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): policydir.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): payload.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_0de56c0a\
                Property(S): payload.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_0de56c09\
                Property(S): policydir.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): policydir.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): payload.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_0de56c0b\
                Property(S): payload.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_0de56c0c\
                Property(S): policydir.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): policydir.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): payload.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_0de56c0d\
                Property(S): policydir.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): payload.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_0de56c0e\
                Property(S): payload.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_0de56c0f\
                Property(S): policydir.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): policydir.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): payload.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_6818287e\
                Property(S): policydir.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): payload.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_6818287f\
                Property(S): payload.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_68182881\
                Property(S): policydir.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): payload.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_68182882\
                Property(S): payload.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_68212ab8\
                Property(S): policydir.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): payload.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_689938c4\
                Property(S): policydir.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): payload.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_b80ea88c\
                Property(S): policydir.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): payload.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_b80fa8c8\
                Property(S): policydir.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): payload.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_b810a90f\
                Property(S): payload.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_5ef082d6\
                Property(S): payload.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_e69378d0\
                Property(S): policydir.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): payload.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_e69378d1\
                Property(S): payload.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_e69378d2\
                Property(S): payload.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_e695794c\
                Property(S): payload.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_e6967988\
                Property(S): payload.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989\
                Property(S): WinSxsDirectory.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
                Property(S): payload_ul.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_ 516e2e610f48bda6\
                Property(S): WinSxsPolicies.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
                Property(S): policydir.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\
                Property(S): SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
                Property(S): WinSxsManifests.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
                Property(S): payload.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_51 e427d4\
                Property(S): policydir.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): policydir.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): policydir_ul.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_ 2a9a3690\
                Property(S): policydir.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): policydir.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): policydir.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): policydir.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): policydir.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): payload.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_51 e92911\
                Property(S): policydir.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): policydir.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): payload.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_51 e828d7\
                Property(S): policydir.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): payload.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_51 e92910\
                Property(S): policydir.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): policydir.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): policydir.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): policydir.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): payload.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_51 e92912\
                Property(S): policydir.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): payload.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_51 e92913\
                Property(S): policydir.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): payload.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_51 e92914\
                Property(S): policydir.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): payload.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_51 e92915\
                Property(S): policydir.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): payload.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_51 e92916\
                Property(S): policydir.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): payload.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_a c1be585\
                Property(S): payload.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_a c1be586\
                Property(S): policydir.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): payload.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_a c1be588\
                Property(S): payload.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_a c1be589\
                Property(S): policydir.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): policydir.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): payload.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_a c24e7bf\
                Property(S): policydir.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): policydir.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): payload.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_a c9cf5cb\
                Property(S): payload.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_ fc126593\
                Property(S): payload.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_ fc1365cf\
                Property(S): payload.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_ fc146616\
                Property(S): payload.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_ a2f43fdd\
                Property(S): payload.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_ 2a9735d7\
                Property(S): payload.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_ 2a9735d8\
                Property(S): payload.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_ 2a9735d9\
                Property(S): payload.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_ 2a993653\
                Property(S): payload.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_ 2a9a368f\
                Property(S): payload.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_ 2a9a3690\
                Property(S): ProductCode = {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
                Property(S): ProductName = Microsoft_VC80_CRT_x86
                Property(S): ProductVersion = 8.0.50727.4053
                Property(S): RebootYesNo = No
                Property(S): DWUSLINK = CE2BC78F6EACC0E8D9AC408FEEFC978F8EBCE78FCE9CA7F8CE4B878F7EBC2738E98CA7A8F9AC
                Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adb604B.tmp
                Property(S): PackageCode = {FA041436-73B8-40C4-97F3-249E037C89EE}
                === Logging stopped: 13/02/2011  12:53:07 ===
                1: 2 2: 0
                1: 2 2: 1
                [    6204] Sun Feb 13 12:53:08 2011  INFO
                :: END TIMER :: [Payload Operation :{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}] took 11039.9 miliseconds (11.0399 seconds) DTR = 115.218 KBPS (0.112518 MBPS)
                Calling the custom action code for post-repair for payload {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86
                Calling the custom action code for pre-repair for payload {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
                ::START TIMER:: [Payload Operation :{D92BBB52-82FF-42ED-8A3C-4E062F944AB7}]
                [    3300] Sun Feb 13 12:53:08 2011  INFO
                Installer Operation: ModifyThirdPartyPayloadOperation
                Modify Thirdparty payload
                Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\Microsoft_VC80_MFCLOC_x86.msi
                MsiSourceListAddSource for  E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\Microsoft_VC80_MFCLOC_x86.msi is 0
                MsiSourceListSetInfo with updated name: Microsoft_VC80_MFCLOC_x86.msi, Result: 0
                Payload exists on removable media: E:\
                [    3300] Sun Feb 13 12:53:09 2011  INFO
                Updating Media for package
                Added volume name: CS5 Master Coll1 for diskID: 1 with result: 0
                MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\, Result: 0
                Configuring MSI ProductCode: {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
                Setting AFLPath C:\Program Files (x86)\Common Files\Adobe\Installers\{FBB02B04-C034-4382-A3F6-57416E2752C4}
                MsiConfigureProductEx command line:
                ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress   REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adb8BDF.tmp"
                1: 0 2: 1033 3: 1252
                === Logging started: 13/02/2011  12:53:09 ===
                Message type: 0, Argument: 1033
                Message type: 1, Argument: Microsoft_VC80_MFCLOC_x86
                Action 12:53:09: INSTALL.
                Action start 12:53:09: INSTALL.
                Action 12:53:09: WindowsFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E.
                Action start 12:53:09: WindowsFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E.
                Action ended 12:53:09: WindowsFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E. Return value 1.
                Action 12:53:09: SystemFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E.
                Action start 12:53:09: SystemFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E.
                Action ended 12:53:09: SystemFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E. Return value 1.
                Action 12:53:09: WindowsFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E.
                Action start 12:53:09: WindowsFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E.
                Action ended 12:53:09: WindowsFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E. Return value 1.
                Action 12:53:09: SystemFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E.
                Action start 12:53:09: SystemFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E.
                Action ended 12:53:09: SystemFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E. Return value 1.
                Action 12:53:09: AppSearch. Searching for installed applications
                Action start 12:53:09: AppSearch.
                Action ended 12:53:09: AppSearch. Return value 0.
                Action 12:53:09: FindRelatedProducts. Searching for related applications
                Action start 12:53:09: FindRelatedProducts.
                Action ended 12:53:09: FindRelatedProducts. Return value 0.
                Action 12:53:09: ValidateProductID.
                Action start 12:53:09: ValidateProductID.
                Action ended 12:53:09: ValidateProductID. Return value 1.
                Action 12:53:09: CostInitialize. Computing space requirements
                Action start 12:53:09: CostInitialize.
                Action ended 12:53:09: CostInitialize. Return value 1.
                Action 12:53:09: FileCost. Computing space requirements
                Action start 12:53:09: FileCost.
                Action ended 12:53:09: FileCost. Return value 1.
                Action 12:53:09: IsolateComponents.
                Action start 12:53:09: IsolateComponents.
                Action ended 12:53:09: IsolateComponents. Return value 0.
                Action 12:53:09: CostFinalize. Computing space requirements
                Action start 12:53:09: CostFinalize.
                Action ended 12:53:09: CostFinalize. Return value 1.
                Action 12:53:09: SetODBCFolders. Initializing ODBC directories
                Action start 12:53:09: SetODBCFolders.
                Action ended 12:53:09: SetODBCFolders. Return value 0.
                Action 12:53:09: MigrateFeatureStates. Migrating feature states from related applications
                Action start 12:53:09: MigrateFeatureStates.
                Action ended 12:53:09: MigrateFeatureStates. Return value 0.
                Action 12:53:09: InstallValidate. Validating install
                Action start 12:53:09: InstallValidate.
                Action ended 12:53:09: InstallValidate. Return value 1.
                Action 12:53:09: RemoveExistingProducts. Removing applications
                Action start 12:53:09: RemoveExistingProducts.
                Action ended 12:53:09: RemoveExistingProducts. Return value 0.
                Action 12:53:09: InstallInitialize.
                Action start 12:53:09: InstallInitialize.
                Action ended 12:53:09: InstallInitialize. Return value 1.
                Action 12:53:09: SxsInstallCA.
                Action start 12:53:09: SxsInstallCA.
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4053.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: uplevel.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.89.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.93.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.94.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.95.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.96.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.97.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.98.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.99.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.100.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.101.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.103.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.104.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.193.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.238.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3044.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3051.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3069.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.1833.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4027.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4028.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4029.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4045.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4052.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: uplevel.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                Action ended 12:53:09: SxsInstallCA. Return value 1.
                Action 12:53:09: ProcessComponents. Updating component registration
                Action start 12:53:09: ProcessComponents.
                Action 12:53:09: GenerateScript. Generating script operations for action:
                Action ended 12:53:09: ProcessComponents. Return value 1.
                Action 12:53:09: UnpublishComponents. Unpublishing Qualified Components
                Action start 12:53:09: UnpublishComponents.
                Action ended 12:53:09: UnpublishComponents. Return value 0.
                Action 12:53:09: MsiUnpublishAssemblies. Unpublishing assembly information
                Action start 12:53:09: MsiUnpublishAssemblies.
                Action ended 12:53:09: MsiUnpublishAssemblies. Return value 1.
                Action 12:53:09: UnpublishFeatures. Unpublishing product features
                Action start 12:53:09: UnpublishFeatures.
                Action ended 12:53:09: UnpublishFeatures. Return value 1.
                Action 12:53:09: StopServices. Stopping services
                Action start 12:53:09: StopServices.
                Action ended 12:53:09: StopServices. Return value 1.
                Action 12:53:09: DeleteServices. Deleting services
                Action start 12:53:09: DeleteServices.
                Action ended 12:53:09: DeleteServices. Return value 1.
                Action 12:53:09: UnregisterComPlus. Unregistering COM+ Applications and Components
                Action start 12:53:09: UnregisterComPlus.
                Action ended 12:53:09: UnregisterComPlus. Return value 0.
                Action 12:53:09: SelfUnregModules. Unregistering modules
                Action start 12:53:09: SelfUnregModules.
                Action ended 12:53:09: SelfUnregModules. Return value 1.
                Action 12:53:09: UnregisterTypeLibraries. Unregistering type libraries
                Action start 12:53:09: UnregisterTypeLibraries.
                Action ended 12:53:09: UnregisterTypeLibraries. Return value 0.
                Action 12:53:09: RemoveODBC. Removing ODBC components
                Action start 12:53:09: RemoveODBC.
                Action ended 12:53:09: RemoveODBC. Return value 1.
                Action 12:53:09: UnregisterFonts. Unregistering fonts
                Action start 12:53:09: UnregisterFonts.
                Action ended 12:53:09: UnregisterFonts. Return value 1.
                Action 12:53:09: RemoveRegistryValues. Removing system registry values
                Action start 12:53:09: RemoveRegistryValues.
                Action ended 12:53:09: RemoveRegistryValues. Return value 1.
                Action 12:53:09: UnregisterClassInfo. Unregister class servers
                Action start 12:53:09: UnregisterClassInfo.
                Action ended 12:53:09: UnregisterClassInfo. Return value 0.
                Action 12:53:09: UnregisterExtensionInfo. Unregistering extension servers
                Action start 12:53:09: UnregisterExtensionInfo.
                Action ended 12:53:09: UnregisterExtensionInfo. Return value 0.
                Action 12:53:09: UnregisterProgIdInfo. Unregistering program identifiers
                Action start 12:53:09: UnregisterProgIdInfo.
                Action ended 12:53:09: UnregisterProgIdInfo. Return value 0.
                Action 12:53:09: UnregisterMIMEInfo. Unregistering MIME info
                Action start 12:53:09: UnregisterMIMEInfo.
                Action ended 12:53:09: UnregisterMIMEInfo. Return value 0.
                Action 12:53:09: RemoveIniValues. Removing INI file entries
                Action start 12:53:09: RemoveIniValues.
                Action ended 12:53:09: RemoveIniValues. Return value 1.
                Action 12:53:09: RemoveShortcuts. Removing shortcuts
                Action start 12:53:09: RemoveShortcuts.
                Action ended 12:53:09: RemoveShortcuts. Return value 0.
                Action 12:53:09: RemoveEnvironmentStrings. Updating environment strings
                Action start 12:53:09: RemoveEnvironmentStrings.
                Action ended 12:53:09: RemoveEnvironmentStrings. Return value 1.
                Action 12:53:09: RemoveDuplicateFiles. Removing duplicated files
                Action start 12:53:09: RemoveDuplicateFiles.
                Action ended 12:53:09: RemoveDuplicateFiles. Return value 1.
                Action 12:53:09: RemoveFiles. Removing files
                Action start 12:53:09: RemoveFiles.
                Action ended 12:53:09: RemoveFiles. Return value 0.
                Action 12:53:09: RemoveFolders. Removing folders
                Action start 12:53:09: RemoveFolders.
                Action ended 12:53:09: RemoveFolders. Return value 0.
                Action 12:53:09: CreateFolders. Creating folders
                Action start 12:53:09: CreateFolders.
                Action ended 12:53:09: CreateFolders. Return value 0.
                Action 12:53:09: MoveFiles. Moving files
                Action start 12:53:09: MoveFiles.
                Action ended 12:53:09: MoveFiles. Return value 1.
                Action 12:53:09: InstallFiles. Copying new files
                Action start 12:53:09: InstallFiles.
                File: Copying new files,  Directory: ,  Size:
                Action ended 12:53:09: InstallFiles. Return value 1.
                Action 12:53:09: PatchFiles. Patching files
                Action start 12:53:09: PatchFiles.
                Action ended 12:53:09: PatchFiles. Return value 0.
                Action 12:53:09: DuplicateFiles. Creating duplicate files
                Action start 12:53:09: DuplicateFiles.
                Action ended 12:53:09: DuplicateFiles. Return value 1.
                Action 12:53:09: BindImage. Binding executables
                Action start 12:53:09: BindImage.
                Action ended 12:53:09: BindImage. Return value 1.
                Action 12:53:09: CreateShortcuts. Creating shortcuts
                Action start 12:53:09: CreateShortcuts.
                Shortcut: Creating shortcuts
                Action ended 12:53:09: CreateShortcuts. Return value 0.
                Action 12:53:09: RegisterClassInfo. Registering class servers
                Action start 12:53:09: RegisterClassInfo.
                Action ended 12:53:09: RegisterClassInfo. Return value 0.
                Action 12:53:09: RegisterExtensionInfo. Registering extension servers
                Action start 12:53:09: RegisterExtensionInfo.
                Action ended 12:53:09: RegisterExtensionInfo. Return value 0.
                Action 12:53:09: RegisterProgIdInfo. Registering program identifiers
                Action start 12:53:09: RegisterProgIdInfo.
                Action ended 12:53:09: RegisterProgIdInfo. Return value 0.
                Action 12:53:09: RegisterMIMEInfo. Registering MIME info
                Action start 12:53:09: RegisterMIMEInfo.
                Action ended 12:53:09: RegisterMIMEInfo. Return value 0.
                Action 12:53:09: WriteRegistryValues. Writing system registry values
                Action start 12:53:09: WriteRegistryValues.
                Action ended 12:53:09: WriteRegistryValues. Return value 1.
                Action 12:53:09: WriteIniValues. Writing INI file values
                Action start 12:53:09: WriteIniValues.
                Action ended 12:53:09: WriteIniValues. Return value 1.
                Action 12:53:09: WriteEnvironmentStrings. Updating environment strings
                Action start 12:53:09: WriteEnvironmentStrings.
                Action ended 12:53:09: WriteEnvironmentStrings. Return value 1.
                Action 12:53:09: RegisterFonts. Registering fonts
                Action start 12:53:09: RegisterFonts.
                Action ended 12:53:09: RegisterFonts. Return value 1.
                Action 12:53:09: InstallODBC. Installing ODBC components
                Action start 12:53:09: InstallODBC.
                Action ended 12:53:09: InstallODBC. Return value 0.
                Action 12:53:09: RegisterTypeLibraries. Registering type libraries
                Action start 12:53:09: RegisterTypeLibraries.
                Action ended 12:53:09: RegisterTypeLibraries. Return value 0.
                Action 12:53:09: SelfRegModules. Registering modules
                Action start 12:53:09: SelfRegModules.
                Action ended 12:53:09: SelfRegModules. Return value 1.
                Action 12:53:09: RegisterComPlus. Registering COM+ Applications and Components
                Action start 12:53:09: RegisterComPlus.
                Action ended 12:53:09: RegisterComPlus. Return value 0.
                Action 12:53:09: InstallServices. Installing new services
                Action start 12:53:09: InstallServices.
                Action ended 12:53:09: InstallServices. Return value 1.
                Action 12:53:09: StartServices. Starting services
                Action start 12:53:09: StartServices.
                Action ended 12:53:09: StartServices. Return value 1.
                Action 12:53:09: RegisterUser. Registering user
                Action start 12:53:09: RegisterUser.
                Action ended 12:53:09: RegisterUser. Return value 0.
                Action 12:53:09: RegisterProduct. Registering product
                Action start 12:53:09: RegisterProduct.
                Registering product
                Action ended 12:53:09: RegisterProduct. Return value 1.
                Action 12:53:09: PublishComponents. Publishing qualified components
                Action start 12:53:09: PublishComponents.
                Action ended 12:53:09: PublishComponents. Return value 0.
                Action 12:53:09: MsiPublishAssemblies. Publishing assembly information
                Action start 12:53:09: MsiPublishAssemblies.
                Application Context:Publishing assembly information, Assembly Name:
                Action ended 12:53:09: MsiPublishAssemblies. Return value 1.
                Action 12:53:09: PublishFeatures. Publishing product features
                Action start 12:53:09: PublishFeatures.
                Feature: Publishing product features
                Action ended 12:53:09: PublishFeatures. Return value 1.
                Action 12:53:09: PublishProduct. Publishing product information
                Action start 12:53:09: PublishProduct.
                Action ended 12:53:09: PublishProduct. Return value 1.
                Action 12:53:09: InstallFinalize.
                Action start 12:53:09: InstallFinalize.
                [    3300] Sun Feb 13 12:53:10 2011  INFO
                Action 12:53:10: CreateShortcuts. Creating shortcuts
                Shortcut: ARPPRODUCTICON.exe
                Action 12:53:10: RegisterProduct. Registering product
                40d62.msi
                Action 12:53:10: MsiPublishAssemblies. Publishing assembly information
                Application Context:Global, Assembly Name:Microsoft.VC80.MFCLOC,publicKeyToken="1fc8b3b9a1e18e3b",version="8.0.50727.4053",typ e="win32",processorArchitecture="x86"
                Application Context:Global, Assembly Name:policy.8.0.Microsoft.VC80.MFCLOC,publicKeyToken="1fc8b3b9a1e18e3b",version="8.0.5072 7.4053",type="win32-policy",processorArchitecture="x86"
                Action 12:53:10: PublishFeatures. Publishing product features
                Feature: Microsoft_VC80_MFCLOC_x
                Action 12:53:10: PublishProduct. Publishing product information
                Message type: 2, Argument: 0
                Action 12:53:10: RollbackCleanup. Removing backup files
                File: C:\Config.Msi\354053.rbf
                File: C:\Config.Msi\354054.rbf
                Message type: 2, Argument: 1
                Action ended 12:53:10: InstallFinalize. Return value 1.
                Action ended 12:53:10: INSTALL. Return value 1.
                Property(S): DiskPrompt = [1]
                Property(S): UpgradeCode = {DBBF67A0-1BA6-4CF4-A1EF-007F1FD45598}
                Property(S): SourcedirProduct = {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
                Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\
                Property(S): PrimaryVolumeSpaceRemaining = 0
                Property(S): PrimaryVolumeSpaceRequired = 0
                Property(S): PrimaryVolumeSpaceAvailable = 0
                Property(S): OutOfNoRbDiskSpace = 0
                Property(S): OutOfDiskSpace = 0
                Property(S): Installed = 2009/11/13 21:27:58
                Property(S): CostingComplete = 1
                Property(S): ROOTDRIVE = F:\
                Property(S): ACTION = INSTALL
                Property(S): Preselected = 1
                Property(S): QFEUpgrade = 1
                Property(S): UILevel = 2
                Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\Microsoft_VC80_MFCLOC_x86.msi
                Property(S): DATABASE = C:\Windows\Installer\35404d.msi
                Property(S): Privileged = 1
                Property(S): MsiRunningElevated = 1
                Property(S): RedirectedDllSupport = 2
                Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
                Property(S): MsiNetAssemblySupport = 4.0.30319.1
                Property(S): Date = 13/02/2011
                Property(S): Time = 12:53:10
                Property(S): TTCSupport = 1
                Property(S): ColorBits = 32
                Property(S): TextInternalLeading = 3
                Property(S): TextHeight = 16
                Property(S): BorderSide = 1
                Property(S): BorderTop = 1
                Property(S): CaptionHeight = 22
                Property(S): ScreenY = 768
                Property(S): ScreenX = 1024
                Property(S): SystemLanguageID = 3081
                Property(S): ComputerName = PC
                Property(S): UserLanguageID = 3081
                Property(S): UserSID = S-1-5-21-618155685-1063480468-518450737-1000
                Property(S): LogonUser = Gary & Susan
                Property(S): MsiTrueAdminUser = 1
                Property(S): AdminUser = 1
                Property(S): VirtualMemory = 14364
                Property(S): PhysicalMemory = 8151
                Property(S): Intel = 6
                Property(S): Msix64 = 6
                Property(S): MsiAMD64 = 6
                Property(S): ShellAdvtSupport = 1
                Property(S): OLEAdvtSupport = 1
                Property(S): GPTSupport = 1
                Property(S): VersionNT = 601
                Property(S): ProgramFilesFolder = C:\Program Files (x86)\
                Property(S): ADOBE = C:\Program Files (x86)\Adobe\
                Property(S): TARGETDIR = F:\
                Property(S): ALLUSERSPROFILE = F:\
                Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
                Property(S): AppDataFolder = C:\Users\Gary & Susan\AppData\Roaming\
                Property(S): CommonAppDataFolder = C:\ProgramData\
                Property(S): CommonFiles64Folder = C:\Program Files (x86)\Common Files\
                Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
                Property(S): ISYourDataBaseDir = C:\Program Files (x86)\Adobe\My Product Name\Database\
                Property(S): DATABASEDIR = C:\Program Files (x86)\Adobe\My Product Name\Database\
                Property(S): DesktopFolder = C:\Users\Public\Desktop\
                Property(S): FavoritesFolder = C:\Users\Gary & Susan\Favorites\
                Property(S): FontsFolder = C:\Windows\Fonts\
                Property(S): GlobalAssemblyCache = F:\
                Property(S): MY_PRODUCT_NAME = C:\Program Files (x86)\Adobe\My Product Name\
                Property(S): INSTALLDIR = C:\Program Files (x86)\Adobe\My Product Name\
                Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
                Property(S): ISMyCompanyDir = C:\Program Files (x86)\My Company Name\
                Property(S): ISMyProductDir = C:\Program Files (x86)\My Company Name\My Product Name\
                Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
                Property(S): LocalAppDataFolder = C:\Users\Gary & Susan\AppData\Local\
                Property(S): MyPicturesFolder = C:\Users\Gary & Susan\Pictures\
                Property(S): PersonalFolder = C:\Users\Gary & Susan\Documents\
                Property(S): PrimaryVolumePath = F:\
                Property(S): ProgramFiles64Folder = C:\Program Files (x86)\
                Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
                Property(S): SendToFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\SendTo\
                Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
                Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
                Property(S): System16Folder = F:\
                Property(S): System64Folder = C:\Windows\SysWOW64\
                Property(S): SystemFolder = C:\Windows\SysWOW64\
                Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\
                Property(S): TempFolder = C:\Users\GARY&S~1\AppData\Local\Temp\
                Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
                Property(S): USERPROFILE = F:\
                Property(S): WindowsFolder = C:\Windows\
                Property(S): WindowsVolume = C:\
                Property(S): WinSxsDirectory.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
                Property(S): payload_ul.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.4053_none_03ca5532 205cb096\
                Property(S): payload.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_3415f6d0\
                Property(S): WindowsFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\
                Property(S): SystemFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
                Property(S): WinSxsManifests.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
                Property(S): WinSxsPolicies.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
                Property(S): policydir.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): policydir_ul.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_0ccc058c \
                Property(S): policydir.8.0.50727.89.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): policydir.8.0.50727.94.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.89.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_3419f7d3\
                Property(S): policydir.8.0.50727.95.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): policydir.8.0.50727.93.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.93.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_341af80c\
                Property(S): payload.8.0.50727.94.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_341af80d\
                Property(S): policydir.8.0.50727.96.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): policydir.8.0.50727.97.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.95.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_341af80e\
                Property(S): policydir.8.0.50727.99.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.96.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_341af80f\
                Property(S): policydir.8.0.50727.98.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): policydir.8.0.50727.101.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.97.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_341af810\
                Property(S): payload.8.0.50727.98.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_341af811\
                Property(S): policydir.8.0.50727.100.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.99.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_341af812\
                Property(S): payload.8.0.50727.100.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_8e4db481\
                Property(S): policydir.8.0.50727.103.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): policydir.8.0.50727.104.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): policydir.8.0.50727.238.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.101.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_8e4db482\
                Property(S): policydir.8.0.50727.193.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.103.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_8e4db484\
                Property(S): payload.8.0.50727.104.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_8e4db485\
                Property(S): policydir.8.0.50727.3044.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.193.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_8e56b6bb\
                Property(S): policydir.8.0.50727.3069.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.238.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_8ecec4c7\
                Property(S): policydir.8.0.50727.3051.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.3044.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_de44348f \
                Property(S): payload.8.0.50727.3051.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_de4534cb \
                Property(S): policydir.8.0.50727.1833.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): policydir.8.0.50727.4027.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.3069.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_de463512 \
                Property(S): payload.8.0.50727.1833.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_85260ed9 \
                Property(S): policydir.8.0.50727.4028.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): policydir.8.0.50727.4029.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.4027.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_0cc904d3 \
                Property(S): payload.8.0.50727.4028.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_0cc904d4 \
                Property(S): policydir.8.0.50727.4045.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): policydir.8.0.50727.4052.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.4029.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_0cc904d5 \
                Property(S): payload.8.0.50727.4045.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_0ccb054f \
                Property(S): policydir.8.0.50727.4053.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.4052.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_0ccc058b \
                Property(S): payload.8.0.50727.4053.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_0ccc058c \
                Property(S): ALLUSERS = 1
                Property(S): RecentFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Recent\
                Property(S): WinSxsDirectory.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
                Property(S): payload_ul.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.4053_no ne_4db266e67dd280ef\
                Property(S): WinSxsPolicies.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
                Property(S): policydir.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): WindowsFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\
                Property(S): SystemFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
                Property(S): WinSxsManifests.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
                Property(S): payload.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww _63bb0537\
                Property(S): policydir.8.0.50727.103.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): policydir.8.0.50727.96.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): policydir_ul.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4053_x- ww_3c7113f3\
                Property(S): policydir.8.0.50727.94.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): policydir.8.0.50727.89.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): policydir.8.0.50727.95.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): policydir.8.0.50727.100.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): policydir.8.0.50727.93.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): payload.8.0.50727.94.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww _63c00674\
                Property(S): policydir.8.0.50727.193.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): policydir.8.0.50727.98.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): payload.8.0.50727.89.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww _63bf063a\
                Property(S): policydir.8.0.50727.104.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): payload.8.0.50727.93.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww _63c00673\
                Property(S): policydir.8.0.50727.99.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): policydir.8.0.50727.101.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): policydir.8.0.50727.97.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): policydir.8.0.50727.4028.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): payload.8.0.50727.95.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww _63c00675\
                Property(S): policydir.8.0.50727.3044.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): payload.8.0.50727.96.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww _63c00676\
                Property(S): policydir.8.0.50727.238.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): payload.8.0.50727.97.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww _63c00677\
                Property(S): policydir.8.0.50727.4052.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): payload.8.0.50727.98.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww _63c00678\
                Property(S): policydir.8.0.50727.1833.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): payload.8.0.50727.99.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww _63c00679\
                Property(S): policydir.8.0.50727.3051.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): payload.8.0.50727.100.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.100_x-w w_bdf2c2e8\
                Property(S): payload.8.0.50727.101.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.101_x-w w_bdf2c2e9\
                Property(S): policydir.8.0.50727.4029.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): payload.8.0.50727.103.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.103_x-w w_bdf2c2eb\
                Property(S): payload.8.0.50727.104.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.104_x-w w_bdf2c2ec\
                Property(S): policydir.8.0.50727.4045.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): policydir.8.0.50727.4027.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): payload.8.0.50727.193.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.193_x-w w_bdfbc522\
                Property(S): policydir.8.0.50727.3069.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): policydir.8.0.50727.4053.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): payload.8.0.50727.238.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.238_x-w w_be73d32e\
                Property(S): payload.8.0.50727.3044.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.3044_x- ww_0de942f6\
                Property(S): payload.8.0.50727.3051.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.3051_x- ww_0dea4332\
                Property(S): payload.8.0.50727.3069.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.3069_x- ww_0deb4379\
                Property(S): payload.8.0.50727.1833.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.1833_x- ww_b4cb1d40\
                Property(S): payload.8.0.50727.4027.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4027_x- ww_3c6e133a\
                Property(S): payload.8.0.50727.4028.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4028_x- ww_3c6e133b\
                Property(S): payload.8.0.50727.4029.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4029_x- ww_3c6e133c\
                Property(S): payload.8.0.50727.4045.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4045_x- ww_3c7013b6\
                Property(S): payload.8.0.50727.4052.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4052_x- ww_3c7113f2\
                Property(S): payload.8.0.50727.4053.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4053_x- ww_3c7113f3\
                Property(S): PrintHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
                Property(S): NetHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
                Property(S): RemoteAdminTS = 1
                Property(S): MsiNTSuitePersonal = 1
                Property(S): MsiNTProductType = 1
                Property(S): ServicePackLevelMinor = 0
                Property(S): ServicePackLevel = 0
                Property(S): WindowsBuild = 7600
                Property(S): VersionNT64 = 601
                Property(S): VersionMsi = 5.00
                Property(S): ISCHECKFORPRODUCTUPDATES = 1
                Property(S): ApplicationUsers = AllUsers
                Property(S): AgreeToLicense = No
                Property(S): _IsMaintenance = Change
                Property(S): SetupType = Typical
                Property(S): _IsSetupTypeMin = Typical
                Property(S): IS_SQLSERVER_USERNAME = sa
                Property(S): IS_SQLSERVER_AUTHENTICATION = 0
                Property(S): RestartManagerOption = CloseRestart
                Property(S): Display_IsBitmapDlg = 1
                Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
                Property(S): DefaultUIFont = Tahoma8
                Property(S): DialogCaption = InstallShield for Windows Installer
                Property(S): DisplayNameCustom = Custom
                Property(S): DisplayNameMinimal = Minimal
                Property(S): DisplayNameTypical = Typical
                Property(S): DWUSINTERVAL = 30
                Property(S): ErrorDialog = SetupError
                Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
                Property(S): InstallChoice = AR
                Property(S): INSTALLLEVEL = 100
                Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
                Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
                Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
                Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
                Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
                Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
                Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
                Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
                Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
                Property(S): ISVROOT_PORT_NO = 0
                Property(S): Manufacturer = Adobe
                Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
                Property(S): ProductCode = {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
                Property(S): ProductID = none
                Property(S): ProductLanguage = 1033
                Property(S): ProductName = Microsoft_VC80_MFCLOC_x86
                Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
                Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
                Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
                Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
                Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
                Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
                Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
                Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
                Property(S): ProgressType0 = install
                Property(S): ProgressType1 = Installing
                Property(S): ProgressType2 = installed
                Property(S): ProgressType3 = installs
                Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
                Property(S): ReinstallModeText = omus
                Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
                Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
                Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
                Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
                Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
                Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
                Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
                Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
                Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
                Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
                Property(S): DWUSLINK = CE0BC0C8E9CBE7B86EACE7CFDEDC978F99CC678F49ABA0E8CE6BC7C8BEDB9088F9ACF798D9AC
                Property(S): ARPURLINFOABOUT = http://www.Adobe.com
                Property(S): SHOWLAUNCHPROGRAM = 0
                Property(S): ARPSYSTEMCOMPONENT = 1
                Property(S): REBOOT = ReallySuppress
                Property(S): VersionDatabase = 200
                Property(S): PRODUCTLANGUAGE = 1033
                Property(S): MsiSystemRebootPending = 1
                Property(S): CURRENTMEDIAVOLUMELABEL = CS5 Master Coll1
                Property(S): CLIENTPROCESSID = 5888
                Property(S): MSICLIENTUSESEXTERNALUI = 1
                Property(S): CLIENTUILEVEL = 3
                Property(S): CURRENTDIRECTORY = C:\Users\Gary & Susan\AppData\Local\Adobe\OOBE\PDApp\DWA
                Property(S): ADDLOCAL = ALL
                Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adb8BDF.tmp
                Property(S): REINSTALLMODE = pvoums
                Property(S): REINSTALL = ALL
                Property(S): MSIRESTARTMANAGERCONTROL = Disable
                Property(S): ADOBE_SETUP = 1
                Property(S): USERNAME = Gary & Susan
                Property(S): ProductToBeRegistered = 1
                Property(S): ProductState = 5
                Property(S): PackageCode = {AF8EF662-EF5A-426A-AA7B-B83C3A5FFFBB}
                === Logging stopped: 13/02/2011  12:53:10 ===
                1: 2 2: 0
                1: 2 2: 1
                [    6204] Sun Feb 13 12:53:10 2011  INFO
                *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
                :: END TIMER :: [Payload Operation :{D92BBB52-82FF-42ED-8A3C-4E062F944AB7}] took 2031.14 miliseconds (2.03114 seconds) DTR = 289.492 KBPS (0.282707 MBPS)
                User specified overrideFile:
                Calling the custom action code for post-repair for payload {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86
                Calling the custom action code for pre-repair for payload {D1A19B02-817E-4296-A45B-07853FD74D57}
                ::START TIMER:: [Payload Operation :{D1A19B02-817E-4296-A45B-07853FD74D57}]
                [    4528] Sun Feb 13 12:53:10 2011  INFO
                Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC80_MFC_x86\Microsoft_VC80_MFC_x86.msi
                MsiSourceListAddSource for  E:\Adobe CS5\payloads\Microsoft_VC80_MFC_x86\Microsoft_VC80_MFC_x86.msi is 0
                MsiSourceListSetInfo with updated name: Microsoft_VC80_MFC_x86.msi, Result: 0
                [    4528] Sun Feb 13 12:53:11 2011  INFO
                MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC80_MFC_x86\, Result: 0
                Configuring MSI ProductCode: {D1A19B02-817E-4296-A45B-07853FD74D57}
                ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress   REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adb93CD.tmp"
                [    4528] Sun Feb 13 12:53:12 2011  INFO
                === Logging started: 13/02/2011  12:53:12 ===
                Message type: 1, Argument: Microsoft_VC80_MFC_x86
                Action 12:53:12: INSTALL.
                Action start 12:53:12: INSTALL.
                Action 12:53:12: WindowsFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E.
                Action start 12:53:12: WindowsFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E.
                Action ended 12:53:12: WindowsFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E. Return value 1.
                Action 12:53:12: SystemFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E.
                Action start 12:53:12: SystemFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E.
                Action ended 12:53:12: SystemFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E. Return value 1.
                Action 12:53:12: WindowsFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E.
                Action start 12:53:12: WindowsFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E.
                Action ended 12:53:12: WindowsFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E. Return value 1.
                Action 12:53:12: SystemFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E.
                Action start 12:53:12: SystemFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E.
                Action ended 12:53:12: SystemFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E. Return value 1.
                Action 12:53:12: AppSearch. Searching for installed applications
                Action start 12:53:12: AppSearch.
                Action ended 12:53:12: AppSearch. Return value 0.
                Action 12:53:12: FindRelatedProducts. Searching for related applications
                Action start 12:53:12: FindRelatedProducts.
                Action ended 12:53:12: FindRelatedProducts. Return value 0.
                Action 12:53:12: ValidateProductID.
                Action start 12:53:12: ValidateProductID.
                Action ended 12:53:12: ValidateProductID. Return value 1.
                Action 12:53:12: CostInitialize. Computing space requirements
                Action start 12:53:12: CostInitialize.
                Action ended 12:53:12: CostInitialize. Return value 1.
                Action 12:53:12: FileCost. Computing space requirements
                Action start 12:53:12: FileCost.
                Action ended 12:53:12: FileCost. Return value 1.
                Action 12:53:12: IsolateComponents.
                Action start 12:53:12: IsolateComponents.
                Action ended 12:53:12: IsolateComponents. Return value 0.
                Action 12:53:12: CostFinalize. Computing space requirements
                Action start 12:53:12: CostFinalize.
                Action ended 12:53:12: CostFinalize. Return value 1.
                Action 12:53:12: SetODBCFolders. Initializing ODBC directories
                Action start 12:53:12: SetODBCFolders.
                Action ended 12:53:12: SetODBCFolders. Return value 0.
                Action 12:53:12: MigrateFeatureStates. Migrating feature states from related applications
                Action start 12:53:12: MigrateFeatureStates.
                Action ended 12:53:12: MigrateFeatureStates. Return value 0.
                Action 12:53:12: InstallValidate. Validating install
                Action start 12:53:12: InstallValidate.
                Action ended 12:53:12: InstallValidate. Return value 1.
                Action 12:53:12: RemoveExistingProducts. Removing applications
                Action start 12:53:12: RemoveExistingProducts.
                Action ended 12:53:12: RemoveExistingProducts. Return value 0.
                Action 12:53:12: InstallInitialize.
                Action start 12:53:12: InstallInitialize.
                Action ended 12:53:12: InstallInitialize. Return value 1.
                Action 12:53:12: SxsInstallCA.
                Action start 12:53:12: SxsInstallCA.
                1: sxsdelca 2: traceop 3: 1256 4: 0
                1: sxsdelca 2: traceop 3: 1257 4: 0
                1: sxsdelca 2: traceop 3: 1258 4: 0
                1: sxsdelca 2: traceop 3: 1284 4: 0
                1: sxsdelca 2: traceop 3: 1288 4: 0
                1: sxsdelca 2: traceop 3: 1289 4: 0
                1: sxsdelca 2: traceop 3: 1290 4: 0
                1: sxsdelca 2: traceop 3: 1292 4: 0
                1: sxsdelca 2: traceop 3: 1318 4: 0
                1: sxsdelca: Skipping component  2: uplevel.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4053.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.89.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.94.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.93.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.95.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.96.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.97.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.98.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.99.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.100.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.101.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.103.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.104.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.193.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.238.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3044.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3051.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3069.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.1833.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4027.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4028.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4029.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4045.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4052.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: uplevel.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
                1: sxsdelca 2: traceop 3: 1284 4: 259
                1: sxsdelca 2: SxsMsmInstall completed 3: 0 4: 0
                Action ended 12:53:12: SxsInstallCA. Return value 1.
                Action 12:53:12: ProcessComponents. Updating component registration
                Action start 12:53:12: ProcessComponents.
                Action 12:53:12: GenerateScript. Generating script operations for action:
                Action ended 12:53:12: ProcessComponents. Return value 1.
                Action 12:53:12: UnpublishComponents. Unpublishing Qualified Components
                Action start 12:53:12: UnpublishComponents.
                Action ended 12:53:12: UnpublishComponents. Return value 0.
                Action 12:53:12: MsiUnpublishAssemblies. Unpublishing assembly information
                Action start 12:53:12: MsiUnpublishAssemblies.
                Action ended 12:53:12: MsiUnpublishAssemblies. Return value 1.
                Action 12:53:12: UnpublishFeatures. Unpublishing product features
                Action start 12:53:12: UnpublishFeatures.
                Action ended 12:53:12: UnpublishFeatures. Return value 1.
                Action 12:53:12: StopServices. Stopping services
                Action start 12:53:12: StopServices.
                Action ended 12:53:12: StopServices. Return value 1.
                Action 12:53:12: DeleteServices. Deleting services
                Action start 12:53:12: DeleteServices.
                Action ended 12:53:12: DeleteServices. Return value 1.
                Action 12:53:12: UnregisterComPlus. Unregistering COM+ Applications and Components
                Action start 12:53:12: UnregisterComPlus.
                Action ended 12:53:12: UnregisterComPlus. Return value 0.
                Action 12:53:12: SelfUnregModules. Unregistering modules
                Action start 12:53:12: SelfUnregModules.
                Action ended 12:53:12: SelfUnregModules. Return value 1.
                Action 12:53:12: UnregisterTypeLibraries. Unregistering type libraries
                Action start 12:53:12: UnregisterTypeLibraries.
                Action ended 12:53:12: UnregisterTypeLibraries. Return value 0.
                Action 12:53:12: RemoveODBC. Removing ODBC components
                Action start 12:53:12: RemoveODBC.
                Action ended 12:53:12: RemoveODBC. Return value 1.
                Action 12:53:12: UnregisterFonts. Unregistering fonts
                Action start 12:53:12: UnregisterFonts.
                Action ended 12:53:12: UnregisterFonts. Return value 1.
                Action 12:53:12: RemoveRegistryValues. Removing system registry values
                Action start 12:53:12: RemoveRegistryValues.
                Action ended 12:53:12: RemoveRegistryValues. Return value 1.
                Action 12:53:12: UnregisterClassInfo. Unregister class servers
                Action start 12:53:12: UnregisterClassInfo.
                Action ended 12:53:12: UnregisterClassInfo. Return value 0.
                Action 12:53:12: UnregisterExtensionInfo. Unregistering extension servers
                Action start 12:53:12: UnregisterExtensionInfo.
                Action ended 12:53:12: UnregisterExtensionInfo. Return value 0.
                Action 12:53:12: UnregisterProgIdInfo. Unregistering program identifiers
                Action start 12:53:12: UnregisterProgIdInfo.
                Action ended 12:53:12: UnregisterProgIdInfo. Return value 0.
                Action 12:53:12: UnregisterMIMEInfo. Unregistering MIME info
                Action start 12:53:12: UnregisterMIMEInfo.
                Action ended 12:53:12: UnregisterMIMEInfo. Return value 0.
                Action 12:53:12: RemoveIniValues. Removing INI file entries
                Action start 12:53:12: RemoveIniValues.
                Action ended 12:53:12: RemoveIniValues. Return value 1.
                Action 12:53:12: RemoveShortcuts. Removing shortcuts
                Action start 12:53:12: RemoveShortcuts.
                Action ended 12:53:12: RemoveShortcuts. Return value 0.
                Action 12:53:12: RemoveEnvironmentStrings. Updating environment strings
                Action start 12:53:12: RemoveEnvironmentStrings.
                Action ended 12:53:12: RemoveEnvironmentStrings. Return value 1.
                Action 12:53:12: RemoveDuplicateFiles. Removing duplicated files
                Action start 12:53:12: RemoveDuplicateFiles.
                Action ended 12:53:12: RemoveDuplicateFiles. Return value 1.
                Action 12:53:12: RemoveFiles. Removing files
                Action start 12:53:12: RemoveFiles.
                Action ended 12:53:12: RemoveFiles. Return value 0.
                Action 12:53:12: RemoveFolders. Removing folders
                Action start 12:53:12: RemoveFolders.
                Action ended 12:53:12: RemoveFolders. Return value 0.
                Action 12:53:12: CreateFolders. Creating folders
                Action start 12:53:12: CreateFolders.
                Action ended 12:53:12: CreateFolders. Return value 0.
                Action 12:53:12: MoveFiles. Moving files
                Action start 12:53:12: MoveFiles.
                Action ended 12:53:12: MoveFiles. Return value 1.
                Action 12:53:12: InstallFiles. Copying new files
                Action start 12:53:12: InstallFiles.
                Action ended 12:53:12: InstallFiles. Return value 1.
                Action 12:53:12: PatchFiles. Patching files
                Action start 12:53:12: PatchFiles.
                Action ended 12:53:12: PatchFiles. Return value 0.
                Action 12:53:12: DuplicateFiles. Creating duplicate files
                Action start 12:53:12: DuplicateFiles.
                Action ended 12:53:12: DuplicateFiles. Return value 1.
                Action 12:53:12: BindImage. Binding executables
                Action start 12:53:12: BindImage.
                Action ended 12:53:12: BindImage. Return value 1.
                Action 12:53:12: CreateShortcuts. Creating shortcuts
                Action start 12:53:12: CreateShortcuts.
                Action ended 12:53:12: CreateShortcuts. Return value 0.
                Action 12:53:12: RegisterClassInfo. Registering class servers
                Action start 12:53:12: RegisterClassInfo.
                Action ended 12:53:12: RegisterClassInfo. Return value 0.
                Action 12:53:12: RegisterExtensionInfo. Registering extension servers
                Action start 12:53:12: RegisterExtensionInfo.
                Action ended 12:53:12: RegisterExtensionInfo. Return value 0.
                Action 12:53:12: RegisterProgIdInfo. Registering program identifiers
                Action start 12:53:12: RegisterProgIdInfo.
                Action ended 12:53:12: RegisterProgIdInfo. Return value 0.
                Action 12:53:12: RegisterMIMEInfo. Registering MIME info
                Action start 12:53:12: RegisterMIMEInfo.
                Action ended 12:53:12: RegisterMIMEInfo. Return value 0.
                Action 12:53:12: WriteRegistryValues. Writing system registry values
                Action start 12:53:12: WriteRegistryValues.
                Action ended 12:53:12: WriteRegistryValues. Return value 1.
                Action 12:53:12: WriteIniValues. Writing INI file values
                Action start 12:53:12: WriteIniValues.
                Action ended 12:53:12: WriteIniValues. Return value 1.
                Action 12:53:12: WriteEnvironmentStrings. Updating environment strings
                Action start 12:53:12: WriteEnvironmentStrings.
                Action ended 12:53:12: WriteEnvironmentStrings. Return value 1.
                Action 12:53:12: RegisterFonts. Registering fonts
                Action start 12:53:12: RegisterFonts.
                Action ended 12:53:12: RegisterFonts. Return value 1.
                Action 12:53:12: InstallODBC. Installing ODBC components
                Action start 12:53:12: InstallODBC.
                Action ended 12:53:12: InstallODBC. Return value 0.
                Action 12:53:12: RegisterTypeLibraries. Registering type libraries
                Action start 12:53:12: RegisterTypeLibraries.
                Action ended 12:53:12: RegisterTypeLibraries. Return value 0.
                Action 12:53:12: SelfRegModules. Registering modules
                Action start 12:53:12: SelfRegModules.
                Action ended 12:53:12: SelfRegModules. Return value 1.
                Action 12:53:12: RegisterComPlus. Registering COM+ Applications and Components
                Action start 12:53:12: RegisterComPlus.
                Action ended 12:53:12: RegisterComPlus. Return value 0.
                Action 12:53:12: InstallServices. Installing new services
                Action start 12:53:12: InstallServices.
                Action ended 12:53:12: InstallServices. Return value 1.
                Action 12:53:12: StartServices. Starting services
                Action start 12:53:12: StartServices.
                Action ended 12:53:12: StartServices. Return value 1.
                Action 12:53:12: RegisterUser. Registering user
                Action start 12:53:12: RegisterUser.
                Action ended 12:53:12: RegisterUser. Return value 0.
                Action 12:53:12: RegisterProduct. Registering product
                Action start 12:53:12: RegisterProduct.
                Registering product
                Action ended 12:53:12: RegisterProduct. Return value 1.
                Action 12:53:12: PublishComponents. Publishing qualified components
                Action start 12:53:12: PublishComponents.
                Action ended 12:53:12: PublishComponents. Return value 0.
                Action 12:53:12: MsiPublishAssemblies. Publishing assembly information
                Action start 12:53:12: MsiPublishAssemblies.
                Action ended 12:53:12: MsiPublishAssemblies. Return value 1.
                Action 12:53:12: PublishFeatures. Publishing product features
                Action start 12:53:12: PublishFeatures.
                Action ended 12:53:12: PublishFeatures. Return value 1.
                Action 12:53:12: PublishProduct. Publishing product information
                Action start 12:53:12: PublishProduct.
                Action ended 12:53:12: PublishProduct. Return value 1.
                Action 12:53:12: InstallFinalize.
                Action start 12:53:12: InstallFinalize.
                Message type: 0, Argument: 1033
                40d6b.msi
                [    4528] Sun Feb 13 12:53:13 2011  INFO
                Action 12:53:13: MsiPublishAssemblies. Publishing assembly information
                Application Context:Global, Assembly Name:Microsoft.VC80.MFC,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",ver sion="8.0.50727.4053",type="win32"
                Application Context:Global, Assembly Name:policy.8.0.Microsoft.VC80.MFC,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1 e18e3b",version="8.0.50727.4053",type="win32-policy"
                Action 12:53:13: PublishFeatures. Publishing product features
                Feature: Microsoft_VC80_MFC_x86_
                Action 12:53:13: PublishProduct. Publishing product information
                Action 12:53:13: RollbackCleanup. Removing backup files
                File: C:\Config.Msi\35405c.rbf
                File: C:\Config.Msi\35405d.rbf
                Action ended 12:53:13: InstallFinalize. Return value 1.
                Action ended 12:53:13: INSTALL. Return value 1.
                Property(S): SourcedirProduct = {D1A19B02-817E-4296-A45B-07853FD74D57}
                Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC80_MFC_x86\
                Property(S): UpgradeCode = {BA8F3080-8370-4EB2-8827-F83E97A7A343}
                Property(S): Installed = 2009/11/13 21:25:22
                Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC80_MFC_x86\Microsoft_VC80_MFC_x86.msi
                Property(S): DATABASE = C:\Windows\Installer\354056.msi
                Property(S): Time = 12:53:13
                Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC80_MFC_x86\
                Property(S): WinSxsDirectory.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
                Property(S): payload_ul.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_microsoft.vc80.mfc_1fc8b3b9a1e18e3b_8.0.50727.4053_none_cbf21254470 d8752\
                Property(S): payload.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_dec6ddd2\
                Property(S): WindowsFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\
                Property(S): SystemFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
                Property(S): WinSxsManifests.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
                Property(S): WinSxsPolicies.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
                Property(S): policydir.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
                Property(S): policydir_ul.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_b77cec8e\
                Property(S): policydir.8.0.50727.4027.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
                Property(S): policydir.8.0.50727.89.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
                Property(S): policydir.8.0.50727.104.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
                Property(S): policydir.8.0.50727.94.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
                Property(S): policydir.8.0.50727.4052.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
                Property(S): policydir.8.0.50727.95.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
                Property(S): policydir.8.0.50727.99.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
                Property(S): payload.8.0.50727.89.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_decaded5\
                Property(S): policydir.8.0.50727.100.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
                Property(S): policydir.8.0.50727.93.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
                Property(S): policydir.8.0.50727.97.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
                Property(S): policydir.8.0.50727.96.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
                Property(S): policydir.8.0.50727.98.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
                Property(S): payload.8.0.50727.93.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_decbdf0e\
                Property(S): payload.8.0.50727.94.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_decbdf0f\
                Property(S): policydir.8.0.50727.101.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
                Property(S): policydir.8.0.50727.3051.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
                Property(S): payload.8.0.50727.95.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_decbdf10\
                Property(S): payload.8.0.50727.96.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_decbdf11\
                Property(S): policydir.8.0.50727.103.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
                Property(S): payload.8.0.50727.97.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_decbdf12\
                Property(S): payload.8.0.50727.98.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_decbdf13\
                Property(S): policydir.8.0.50727.193.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
                Property(S): payload.8.0.50727.99.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_decbdf14\
                Property(S): policydir.8.0.50727.238.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
                Property(S): payload.8.0.50727.100.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_38fe9b83\
                Property(S): payload.8.0.50727.101.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_38fe9b84\
                Property(S): policydir.8.0.50727.3044.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
                Property(S): payload.8.0.50727.103.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_38fe9b86\
                Property(S): payload.8.0.50727.104.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_38fe9b87\
                Property(S): payload.8.0.50727.193.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_39079dbd\
                Property(S): policydir.8.0.50727.3069.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
                Property(S): payload.8.0.50727.238.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_397fabc9\
                Property(S): policydir.8.0.50727.1833.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
                Property(S): policydir.8.0.50727.4029.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
                Property(S): payload.8.0.50727.3044.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_88f51b91\
                Property(S): policydir.8.0.50727.4028.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
                Property(S): payload.8.0.50727.3051.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_88f61bcd\
                Property(S): policydir.8.0.50727.4053.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
                Property(S): payload.8.0.50727.3069.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_88f71c14\
                Property(S): policydir.8.0.50727.4045.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
                Property(S): payload.8.0.50727.1833.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_2fd6f5db\
                Property(S): payload.8.0.50727.4027.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_b779ebd5\
                Property(S): payload.8.0.50727.4028.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_b779ebd6\
                Property(S): payload.8.0.50727.4029.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_b779ebd7\
                Property(S): payload.8.0.50727.4045.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_b77bec51\
                Property(S): payload.8.0.50727.4052.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_b77cec8d\
                Property(S): payload.8.0.50727.4053.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_b77cec8e\
                Property(S): WinSxsDirectory.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
                Property(S): payload_ul.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.mfc_1fc8b3b9a1e18e3b_8.0.50727.4053_none_ 49ef489714173a89\
                Property(S): WinSxsPolicies.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
                Property(S): policydir.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c3 2e\
                Property(S): WindowsFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\
                Property(S): SystemFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
                Property(S): WinSxsManifests.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
                Property(S): payload.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_22 ca9ad9\
                Property(S): policydir.8.0.50727.103.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c3 2e\
                Property(S): policydir.8.0.50727.96.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c3 2e\
                Property(S): policydir_ul.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_ fb80a995\
                Property(S): policydir.8.0.50727.94.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c3 2e\
                Property(S): policydir.8.0.50727.89.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c3 2e\
                Property(S): policydir.8.0.50727.95.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c3 2e\
                Property(S): policydir.8.0.50727.100.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c3 2e\
                Property(S): policydir.8.0.50727.93.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c3 2e\
                Property(S): payload.8.0.50727.94.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_22 cf9c16\
                Property(S): policydir.8.0.50727.193.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c3 2e\
                Property(S): policydir.8.0.50727.98.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c3 2e\
                Property(S): payload.8.0.50727.89.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_22 ce9bdc\
                Property(S): policydir.8.0.50727.104.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c3 2e\
                Property(S): payload.8.0.50727.93.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_22 cf9c15\
                Property(S): policydir.8.0.50727.99.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c3 2e\
                Property(S): policydir.8.0.50727.101.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c3 2e\
                Property(S): policydir.8.0.50727.97.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c3 2e\
                Property(S): policydir.8.0.50727.4028.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c3 2e\
                Property(S): payload.8.0.50727.95.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_22 cf9c17\
                Property(S): policydir.8.0.50727.3044.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c3 2e\
                Property(S): payload.8.0.50727.96.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_22 cf9c18\
                Property(S): policydir.8.0.50727.238.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c3 2e\
                Property(S): payload.8.0.50727.97.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_22 cf9c19\
                Property(S): policydir.8.0.50727.4052.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c3 2e\
                Property(S): payload.8.0.50727.98.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_22 cf9c1a\
                Property(S): policydir.8.0.50727.1833.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c3 2e\
                Property(S): payload.8.0.50727.99.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_22 cf9c1b\
                Property(S): policydir.8.0.50727.3051.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c3 2e\
                Property(S): payload.8.0.50727.100.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_7 d02588a\
                Property(S): payload.8.0.50727.101.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_7 d02588b\
                Property(S): policydir.8.0.50727.4029.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c3 2e\
                Property(S): payload.8.0.50727.103.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_7 d02588d\
                Property(S): payload.8.0.50727.104.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_7 d02588e\
                Property(S): policydir.8.0.50727.4045.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c3 2e\
                Property(S): policydir.8.0.50727.4027.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c3 2e\
                Property(S): payload.8.0.50727.193.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_7 d0b5ac4\
                Property(S): policydir.8.0.50727.3069.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c3 2e\
                Property(S): policydir.8.0.50727.4053.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c3 2e\
                Property(S): payload.8.0.50727.238.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_7 d8368d0\
                Property(S): payload.8.0.50727.3044.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_ ccf8d898\
                Property(S): payload.8.0.50727.3051.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_ ccf9d8d4\
                Property(S): payload.8.0.50727.3069.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_ ccfad91b\
                Property(S): payload.8.0.50727.1833.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_ 73dab2e2\
                Property(S): payload.8.0.50727.4027.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_ fb7da8dc\
                Property(S): payload.8.0.50727.4028.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_ fb7da8dd\
                Property(S): payload.8.0.50727.4029.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_ fb7da8de\
                Property(S): payload.8.0.50727.4045.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_ fb7fa958\
                Property(S): payload.8.0.50727.4052.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_ fb80a994\
                Property(S): payload.8.0.50727.4053.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_ fb80a995\
                Property(S): ProductCode = {D1A19B02-817E-4296-A45B-07853FD74D57}
                Property(S): ProductName = Microsoft_VC80_MFC_x86
                Property(S): ProductVersion = 8.0.50727.4053
                Property(S): RebootYesNo = No
                Property(S): DWUSLINK = CE8C979FAE7BF06819ACF728AE3C978F3EBCC78FFEEB4798CE8CE7EF9EDBA75FF9ABA7E8FEAC
                Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adb93CD.tmp
                Property(S): PackageCode = {032B02B2-4D8D-45FF-BB1E-864B26F4ADDC}
                === Logging stopped: 13/02/2011  12:53:13 ===
                1: 2 2: 0
                1: 2 2: 1
                [    6204] Sun Feb 13 12:53:13 2011  INFO
                :: END TIMER :: [Payload Operation :{D1A19B02-817E-4296-A45B-07853FD74D57}] took 3031.97 miliseconds (3.03197 seconds) DTR = 23.747 KBPS (0.0231904 MBPS)
                [    6204] Sun Feb 13 12:53:14 2011  INFO
                Calling the custom action code for post-repair for payload {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86
                [    6204] Sun Feb 13 12:53:14 2011  WARN
                Warning: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
                Calling the custom action code for pre-repair for payload {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}
                ::START TIMER:: [Payload Operation :{635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}]
                [    5528] Sun Feb 13 12:53:14 2011  INFO
                Installer Operation: ModifyThirdPartyPayloadOperation
                Modify Thirdparty payload
                Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86\Microsoft_VC90_MFC_x86.msi
                MsiSourceListAddSource for  E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86\Microsoft_VC90_MFC_x86.msi is 0
                MsiSourceListSetInfo with updated name: Microsoft_VC90_MFC_x86.msi, Result: 0
                Payload exists on removable media: E:\
                Updating Media for package
                Added volume name: CS5 Master Coll1 for diskID: 1 with result: 0
                MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC90_MFC_x86\, Result: 0
                Configuring MSI ProductCode: {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}
                Setting AFLPath C:\Program Files (x86)\Common Files\Adobe\Installers\{FBB02B04-C034-4382-A3F6-57416E2752C4}
                MsiConfigureProductEx command line:
                ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress   REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adbA108.tmp"
                1: 0 2: 1033 3: 1252
                [    5528] Sun Feb 13 12:53:17 2011  INFO
                === Logging started: 13/02/2011  12:53:17 ===
                Message type: 1, Argument: Microsoft_VC90_MFC_x86
                Action 12:53:17: INSTALL.
                Action start 12:53:17: INSTALL.
                Action 12:53:17: SystemFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D.
                Action start 12:53:17: SystemFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D.
                Action ended 12:53:17: SystemFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D. Return value 1.
                Action 12:53:17: AppSearch. Searching for installed applications
                Action start 12:53:17: AppSearch.
                Action ended 12:53:17: AppSearch. Return value 0.
                Action 12:53:17: FindRelatedProducts. Searching for related applications
                Action start 12:53:17: FindRelatedProducts.
                Action ended 12:53:17: FindRelatedProducts. Return value 0.
                Action 12:53:17: ValidateProductID.
                Action start 12:53:17: ValidateProductID.
                Action ended 12:53:17: ValidateProductID. Return value 1.
                Action 12:53:17: WindowsFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D.
                Action start 12:53:17: WindowsFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D.
                Action ended 12:53:17: WindowsFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D. Return value 1.
                Action 12:53:17: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0F1_7C00_33DE_BBF5_55 39993CCCBF.
                Action start 12:53:17: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0F1_7C00_33DE_BBF5_55 39993CCCBF.
                Action ended 12:53:17: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0F1_7C00_33DE_BBF5_55 39993CCCBF. Return value 1.
                Action 12:53:17: CostInitialize. Computing space requirements
                Action start 12:53:17: CostInitialize.
                Action ended 12:53:17: CostInitialize. Return value 1.
                Action 12:53:17: FileCost. Computing space requirements
                Action start 12:53:17: FileCost.
                Action ended 12:53:17: FileCost. Return value 1.
                Action 12:53:17: IsolateComponents.
                Action start 12:53:17: IsolateComponents.
                Action ended 12:53:17: IsolateComponents. Return value 0.
                Action 12:53:17: CostFinalize. Computing space requirements
                Action start 12:53:17: CostFinalize.
                Action ended 12:53:17: CostFinalize. Return value 1.
                Action 12:53:17: SetODBCFolders. Initializing ODBC directories
                Action start 12:53:17: SetODBCFolders.
                Action ended 12:53:17: SetODBCFolders. Return value 0.
                Action 12:53:17: MigrateFeatureStates. Migrating feature states from related applications
                Action start 12:53:17: MigrateFeatureStates.
                Action ended 12:53:17: MigrateFeatureStates. Return value 0.
                Action 12:53:17: InstallValidate. Validating install
                Action start 12:53:17: InstallValidate.
                Action ended 12:53:17: InstallValidate. Return value 1.
                Action 12:53:17: RemoveExistingProducts. Removing applications
                Action start 12:53:17: RemoveExistingProducts.
                Action ended 12:53:17: RemoveExistingProducts. Return value 0.
                Action 12:53:17: InstallInitialize.
                Action start 12:53:17: InstallInitialize.
                Action ended 12:53:17: InstallInitialize. Return value 1.
                Action 12:53:17: ProcessComponents. Updating component registration
                Action start 12:53:17: ProcessComponents.
                Action 12:53:17: GenerateScript. Generating script operations for action:
                Action ended 12:53:17: ProcessComponents. Return value 1.
                Action 12:53:17: UnpublishComponents. Unpublishing Qualified Components
                Action start 12:53:17: UnpublishComponents.
                Action ended 12:53:17: UnpublishComponents. Return value 0.
                Action 12:53:17: MsiUnpublishAssemblies. Unpublishing assembly information
                Action start 12:53:17: MsiUnpublishAssemblies.
                Action ended 12:53:17: MsiUnpublishAssemblies. Return value 1.
                Action 12:53:17: UnpublishFeatures. Unpublishing product features
                Action start 12:53:17: UnpublishFeatures.
                Action ended 12:53:17: UnpublishFeatures. Return value 1.
                Action 12:53:17: StopServices. Stopping services
                Action start 12:53:17: StopServices.
                Action ended 12:53:17: StopServices. Return value 1.
                Action 12:53:17: DeleteServices. Deleting services
                Action start 12:53:17: DeleteServices.
                Action ended 12:53:17: DeleteServices. Return value 1.
                Action 12:53:17: UnregisterComPlus. Unregistering COM+ Applications and Components
                Action start 12:53:17: UnregisterComPlus.
                Action ended 12:53:17: UnregisterComPlus. Return value 0.
                Action 12:53:17: SelfUnregModules. Unregistering modules
                Action start 12:53:17: SelfUnregModules.
                Action ended 12:53:17: SelfUnregModules. Return value 1.
                Action 12:53:17: UnregisterTypeLibraries. Unregistering type libraries
                Action start 12:53:17: UnregisterTypeLibraries.
                Action ended 12:53:17: UnregisterTypeLibraries. Return value 0.
                Action 12:53:17: RemoveODBC. Removing ODBC components
                Action start 12:53:17: RemoveODBC.
                Action ended 12:53:17: RemoveODBC. Return value 1.
                Action 12:53:17: UnregisterFonts. Unregistering fonts
                Action start 12:53:17: UnregisterFonts.
                Action ended 12:53:17: UnregisterFonts. Return value 1.
                Action 12:53:17: RemoveRegistryValues. Removing system registry values
                Action start 12:53:17: RemoveRegistryValues.
                Action ended 12:53:17: RemoveRegistryValues. Return value 1.
                Action 12:53:17: UnregisterClassInfo. Unregister class servers
                Action start 12:53:17: UnregisterClassInfo.
                Action ended 12:53:17: UnregisterClassInfo. Return value 0.
                Action 12:53:17: UnregisterExtensionInfo. Unregistering extension servers
                Action start 12:53:17: UnregisterExtensionInfo.
                Action ended 12:53:17: UnregisterExtensionInfo. Return value 0.
                Action 12:53:17: UnregisterProgIdInfo. Unregistering program identifiers
                Action start 12:53:17: UnregisterProgIdInfo.
                Action ended 12:53:17: UnregisterProgIdInfo. Return value 0.
                Action 12:53:17: UnregisterMIMEInfo. Unregistering MIME info
                Action start 12:53:17: UnregisterMIMEInfo.
                Action ended 12:53:17: UnregisterMIMEInfo. Return value 0.
                Action 12:53:17: RemoveIniValues. Removing INI file entries
                Action start 12:53:17: RemoveIniValues.
                Action ended 12:53:17: RemoveIniValues. Return value 1.
                Action 12:53:17: RemoveShortcuts. Removing shortcuts
                Action start 12:53:17: RemoveShortcuts.
                Action ended 12:53:17: RemoveShortcuts. Return value 0.
                Action 12:53:17: RemoveEnvironmentStrings. Updating environment strings
                Action start 12:53:17: RemoveEnvironmentStrings.
                Action ended 12:53:17: RemoveEnvironmentStrings. Return value 1.
                Action 12:53:17: RemoveDuplicateFiles. Removing duplicated files
                Action start 12:53:17: RemoveDuplicateFiles.
                Action ended 12:53:17: RemoveDuplicateFiles. Return value 1.
                Action 12:53:17: RemoveFiles. Removing files
                Action start 12:53:17: RemoveFiles.
                Action ended 12:53:17: RemoveFiles. Return value 0.
                Action 12:53:17: RemoveFolders. Removing folders
                Action start 12:53:17: RemoveFolders.
                Action ended 12:53:17: RemoveFolders. Return value 0.
                Action 12:53:17: CreateFolders. Creating folders
                Action start 12:53:17: CreateFolders.
                Action ended 12:53:17: CreateFolders. Return value 0.
                Action 12:53:17: MoveFiles. Moving files
                Action start 12:53:17: MoveFiles.
                Action ended 12:53:17: MoveFiles. Return value 1.
                Action 12:53:17: InstallFiles. Copying new files
                Action start 12:53:17: InstallFiles.
                File: Copying new files,  Directory: ,  Size:
                Action ended 12:53:17: InstallFiles. Return value 1.
                Action 12:53:17: PatchFiles. Patching files
                Action start 12:53:17: PatchFiles.
                Action ended 12:53:17: PatchFiles. Return value 0.
                Action 12:53:17: DuplicateFiles. Creating duplicate files
                Action start 12:53:17: DuplicateFiles.
                Action ended 12:53:17: DuplicateFiles. Return value 1.
                Action 12:53:17: BindImage. Binding executables
                Action start 12:53:17: BindImage.
                Action ended 12:53:17: BindImage. Return value 1.
                Action 12:53:17: CreateShortcuts. Creating shortcuts
                Action start 12:53:17: CreateShortcuts.
                Shortcut: Creating shortcuts
                Action ended 12:53:17: CreateShortcuts. Return value 0.
                Action 12:53:17: RegisterClassInfo. Registering class servers
                Action start 12:53:17: RegisterClassInfo.
                Action ended 12:53:17: RegisterClassInfo. Return value 0.
                Action 12:53:17: RegisterExtensionInfo. Registering extension servers
                Action start 12:53:17: RegisterExtensionInfo.
                Action ended 12:53:17: RegisterExtensionInfo. Return value 0.
                Action 12:53:17: RegisterProgIdInfo. Registering program identifiers
                Action start 12:53:17: RegisterProgIdInfo.
                Action ended 12:53:17: RegisterProgIdInfo. Return value 0.
                Action 12:53:17: RegisterMIMEInfo. Registering MIME info
                Action start 12:53:17: RegisterMIMEInfo.
                Action ended 12:53:17: RegisterMIMEInfo. Return value 0.
                Action 12:53:17: WriteRegistryValues. Writing system registry values
                Action start 12:53:17: WriteRegistryValues.
                Action ended 12:53:17: WriteRegistryValues. Return value 1.
                Action 12:53:17: WriteIniValues. Writing INI file values
                Action start 12:53:17: WriteIniValues.
                Action ended 12:53:17: WriteIniValues. Return value 1.
                Action 12:53:17: WriteEnvironmentStrings. Updating environment strings
                Action start 12:53:17: WriteEnvironmentStrings.
                Action ended 12:53:17: WriteEnvironmentStrings. Return value 1.
                Action 12:53:17: RegisterFonts. Registering fonts
                Action start 12:53:17: RegisterFonts.
                Action ended 12:53:17: RegisterFonts. Return value 1.
                Action 12:53:17: InstallODBC. Installing ODBC components
                Action start 12:53:17: InstallODBC.
                Action ended 12:53:17: InstallODBC. Return value 0.
                Action 12:53:17: RegisterTypeLibraries. Registering type libraries
                Action start 12:53:17: RegisterTypeLibraries.
                Action ended 12:53:17: RegisterTypeLibraries. Return value 0.
                Action 12:53:17: SelfRegModules. Registering modules
                Action start 12:53:17: SelfRegModules.
                Action ended 12:53:17: SelfRegModules. Return value 1.
                Action 12:53:17: RegisterComPlus. Registering COM+ Applications and Components
                Action start 12:53:17: RegisterComPlus.
                Action ended 12:53:17: RegisterComPlus. Return value 0.
                Action 12:53:17: InstallServices. Installing new services
                Action start 12:53:17: InstallServices.
                Action ended 12:53:17: InstallServices. Return value 1.
                Action 12:53:17: StartServices. Starting services
                Action start 12:53:17: StartServices.
                Action ended 12:53:17: StartServices. Return value 1.
                Action 12:53:17: RegisterUser. Registering user
                Action start 12:53:17: RegisterUser.
                Action ended 12:53:17: RegisterUser. Return value 0.
                Action 12:53:17: RegisterProduct. Registering product
                Action start 12:53:17: RegisterProduct.
                Registering product
                Action ended 12:53:17: RegisterProduct. Return value 1.
                Action 12:53:17: PublishComponents. Publishing qualified components
                Action start 12:53:17: PublishComponents.
                Action ended 12:53:17: PublishComponents. Return value 0.
                Action 12:53:17: MsiPublishAssemblies. Publishing assembly information
                Action start 12:53:17: MsiPublishAssemblies.
                Application Context:Publishing assembly information, Assembly Name:
                Action ended 12:53:17: MsiPublishAssemblies. Return value 1.
                Action 12:53:17: PublishFeatures. Publishing product features
                Action start 12:53:17: PublishFeatures.
                Feature: Publishing product features
                Action ended 12:53:17: PublishFeatures. Return value 1.
                Action 12:53:17: PublishProduct. Publishing product information
                Action start 12:53:17: PublishProduct.
                Action ended 12:53:17: PublishProduct. Return value 1.
                Action 12:53:17: InstallFinalize.
                Action start 12:53:17: InstallFinalize.
                Shortcut: ARPPRODUCTICON.exe
                40d74.msi
                Application Context:Global, Assembly Name:Microsoft.VC90.MFC,version="9.0.30729.4137",publicKeyToken="1fc8b3b9a1e18e3b",proces sorArchitecture="x86",type="win32"
                Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.MFC,version="9.0.30729.4137",publicKeyToken="1fc8b3b9a1e18 e3b",processorArchitecture="x86",type="win32-policy"
                Feature: Microsoft_VC90_MFC_x86_
                Message type: 2, Argument: 0
                Action 12:53:17: RollbackCleanup. Removing backup files
                File: C:\Config.Msi\354065.rbf
                File: C:\Config.Msi\354066.rbf
                Message type: 2, Argument: 1
                Action ended 12:53:17: InstallFinalize. Return value 1.
                Action ended 12:53:17: INSTALL. Return value 1.
                Property(S): DiskPrompt = [1]
                Property(S): UpgradeCode = {7534F528-4E84-4BFB-A8F2-BBD75974F28F}
                Property(S): SourcedirProduct = {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}
                Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86\
                Property(S): Installed = 2009/07/28 04:13:22
                Property(S): PrimaryVolumeSpaceRemaining = 0
                Property(S): PrimaryVolumeSpaceRequired = 0
                Property(S): PrimaryVolumeSpaceAvailable = 0
                Property(S): OutOfNoRbDiskSpace = 0
                Property(S): OutOfDiskSpace = 0
                Property(S): CostingComplete = 1
                Property(S): ROOTDRIVE = F:\
                Property(S): ACTION = INSTALL
                Property(S): Preselected = 1
                Property(S): QFEUpgrade = 1
                Property(S): UILevel = 2
                Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86\Microsoft_VC90_MFC_x86.msi
                Property(S): DATABASE = C:\Windows\Installer\35405f.msi
                Property(S): Privileged = 1
                Property(S): MsiRunningElevated = 1
                Property(S): RedirectedDllSupport = 2
                Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
                Property(S): MsiNetAssemblySupport = 4.0.30319.1
                Property(S): Date = 13/02/2011
                Property(S): Time = 12:53:17
                Property(S): TTCSupport = 1
                Property(S): ColorBits = 32
                Property(S): TextInternalLeading = 3
                Property(S): TextHeight = 16
                Property(S): BorderSide = 1
                Property(S): BorderTop = 1
                Property(S): CaptionHeight = 22
                Property(S): ScreenY = 768
                Property(S): ScreenX = 1024
                Property(S): SystemLanguageID = 3081
                Property(S): ComputerName = PC
                Property(S): UserLanguageID = 3081
                Property(S): UserSID = S-1-5-21-618155685-1063480468-518450737-1000
                Property(S): LogonUser = Gary & Susan
                Property(S): MsiTrueAdminUser = 1
                Property(S): AdminUser = 1
                Property(S): VirtualMemory = 14364
                Property(S): PhysicalMemory = 8151
                Property(S): Intel = 6
                Property(S): Msix64 = 6
                Property(S): MsiAMD64 = 6
                Property(S): ShellAdvtSupport = 1
                Property(S): OLEAdvtSupport = 1
                Property(S): GPTSupport = 1
                Property(S): RecentFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Recent\
                Property(S): VersionNT = 601
                Property(S): ProgramFilesFolder = C:\Program Files (x86)\
                Property(S): ADOBE = C:\Program Files (x86)\Adobe\
                Property(S): TARGETDIR = F:\
                Property(S): ALLUSERSPROFILE = F:\
                Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
                Property(S): AppDataFolder = C:\Users\Gary & Susan\AppData\Roaming\
                Property(S): CommonAppDataFolder = C:\ProgramData\
                Property(S): CommonFiles64Folder = C:\Program Files (x86)\Common Files\
                Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
                Property(S): ISYourDataBaseDir = C:\Program Files (x86)\Adobe\My Product Name\Database\
                Property(S): DATABASEDIR = C:\Program Files (x86)\Adobe\My Product Name\Database\
                Property(S): DesktopFolder = C:\Users\Public\Desktop\
                Property(S): FavoritesFolder = C:\Users\Gary & Susan\Favorites\
                Property(S): FontsFolder = C:\Windows\Fonts\
                Property(S): GlobalAssemblyCache = F:\
                Property(S): MY_PRODUCT_NAME = C:\Program Files (x86)\Adobe\My Product Name\
                Property(S): INSTALLDIR = C:\Program Files (x86)\Adobe\My Product Name\
                Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
                Property(S): ISMyCompanyDir = C:\Program Files (x86)\My Company Name\
                Property(S): ISMyProductDir = C:\Program Files (x86)\My Company Name\My Product Name\
                Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
                Property(S): LocalAppDataFolder = C:\Users\Gary & Susan\AppData\Local\
                Property(S): MyPicturesFolder = C:\Users\Gary & Susan\Pictures\
                Property(S): PersonalFolder = C:\Users\Gary & Susan\Documents\
                Property(S): PrimaryVolumePath = F:\
                Property(S): ProgramFiles64Folder = C:\Program Files (x86)\
                Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
                Property(S): SendToFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\SendTo\
                Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
                Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
                Property(S): System16Folder = F:\
                Property(S): System64Folder = C:\Windows\SysWOW64\
                Property(S): SystemFolder = C:\Windows\SysWOW64\
                Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86\
                Property(S): TempFolder = C:\Users\GARY&S~1\AppData\Local\Temp\
                Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
                Property(S): USERPROFILE = F:\
                Property(S): WindowsFolder = C:\Windows\
                Property(S): WindowsVolume = C:\
                Property(S): WindowsFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D = C:\Windows\
                Property(S): SystemFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D = C:\Windows\SysWOW64\
                Property(S): WinSxsDirectory.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2 D = C:\Windows\winsxs\
                Property(S): payload_ul.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D = C:\Windows\winsxs\x86_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.4137_none_4bf45688bf9 e2dbf\
                Property(S): payload.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D = C:\Windows\winsxs\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.30729.4137_x-ww_a57b1f13\
                Property(S): WinSxsManifests.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2 D = C:\Windows\winsxs\Manifests\
                Property(S): WinSxsPolicies.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D = C:\Windows\winsxs\Policies\
                Property(S): policydir.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D = C:\Windows\winsxs\Policies\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_x-ww_aef5eff6\
                Property(S): policydir_ul.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D = C:\Windows\winsxs\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_x-ww_aef5eff6\
                Property(S): ALLUSERS = 1
                Property(S): WinSxsDirectory.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0F1_7C00_33DE_BBF5_ 5539993CCCBF = C:\Windows\winsxs\
                Property(S): payload_ul.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0F1_7C00_33DE_BBF5_55399 93CCCBF = C:\Windows\winsxs\x86_policy.9.0.microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.4137_none_ ecfe4c8afb2661fb\
                Property(S): WinSxsPolicies.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0F1_7C00_33DE_BBF5_5 539993CCCBF = C:\Windows\winsxs\Policies\
                Property(S): policydir.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0F1_7C00_33DE_BBF5_553999 3CCCBF = C:\Windows\winsxs\Policies\x86_policy.9.0.Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_x-ww_4ee8bb 30\
                Property(S): WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0F1_7C00_33DE_BBF5_55 39993CCCBF = C:\Windows\
                Property(S): PrintHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
                Property(S): NetHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
                Property(S): RemoteAdminTS = 1
                Property(S): MsiNTSuitePersonal = 1
                Property(S): MsiNTProductType = 1
                Property(S): ServicePackLevelMinor = 0
                Property(S): ServicePackLevel = 0
                Property(S): WindowsBuild = 7600
                Property(S): VersionNT64 = 601
                Property(S): VersionMsi = 5.00
                Property(S): ISCHECKFORPRODUCTUPDATES = 1
                Property(S): ApplicationUsers = AllUsers
                Property(S): AgreeToLicense = No
                Property(S): _IsMaintenance = Change
                Property(S): SetupType = Typical
                Property(S): _IsSetupTypeMin = Typical
                Property(S): IS_SQLSERVER_USERNAME = sa
                Property(S): IS_SQLSERVER_AUTHENTICATION = 0
                Property(S): RestartManagerOption = CloseRestart
                Property(S): Display_IsBitmapDlg = 1
                Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
                Property(S): DefaultUIFont = Tahoma8
                Property(S): DialogCaption = InstallShield for Windows Installer
                Property(S): DisplayNameCustom = Custom
                Property(S): DisplayNameMinimal = Minimal
                Property(S): DisplayNameTypical = Typical
                Property(S): DWUSINTERVAL = 30
                Property(S): ErrorDialog = SetupError
                Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
                Property(S): InstallChoice = AR
                Property(S): INSTALLLEVEL = 100
                Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
                Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
                Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
                Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
                Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
                Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
                Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
                Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
                Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
                Property(S): ISVROOT_PORT_NO = 0
                Property(S): Manufacturer = Adobe
                Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
                Property(S): ProductCode = {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}
                Property(S): ProductID = none
                Property(S): ProductLanguage = 1033
                Property(S): ProductName = Microsoft_VC90_MFC_x86
                Property(S): ProductVersion = 1.00.0000
                Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
                Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
                Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
                Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
                Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
                Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
                Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
                Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
                Property(S): ProgressType0 = install
                Property(S): ProgressType1 = Installing
                Property(S): ProgressType2 = installed
                Property(S): ProgressType3 = installs
                Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
                Property(S): RebootYesNo = Yes
                Property(S): ReinstallModeText = omus
                Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
                Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
                Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
                Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
                Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
                Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
                Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
                Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
                Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
                Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
                Property(S): DWUSLINK = CEDCD08F9EDBA7DF5EAC87CFDEDB978F8EABA08FCEECA7AFCEFCA0AFF9DBF78FB9ABA7F819AC
                Property(S): ARPURLINFOABOUT = http://www.Adobe.com
                Property(S): SHOWLAUNCHPROGRAM = 0
                Property(S): ARPSYSTEMCOMPONENT = 1
                Property(S): REBOOT = ReallySuppress
                Property(S): VersionDatabase = 200
                Property(S): PRODUCTLANGUAGE = 1033
                Property(S): MsiSystemRebootPending = 1
                Property(S): CURRENTMEDIAVOLUMELABEL = CS5 Master Coll1
                Property(S): CLIENTPROCESSID = 5888
                Property(S): MSICLIENTUSESEXTERNALUI = 1
                Property(S): CLIENTUILEVEL = 3
                Property(S): CURRENTDIRECTORY = C:\Users\Gary & Susan\AppData\Local\Adobe\OOBE\PDApp\DWA
                Property(S): ADDLOCAL = ALL
                Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adbA108.tmp
                Property(S): REINSTALLMODE = pvoums
                Property(S): REINSTALL = ALL
                Property(S): MSIRESTARTMANAGERCONTROL = Disable
                Property(S): ADOBE_SETUP = 1
                Property(S): ProductToBeRegistered = 1
                Property(S): USERNAME = Gary & Susan
                Property(S): ProductState = 5
                Property(S): PackageCode = {FCC5DFDD-8D3B-457A-9232-4D938A966CD6}
                === Logging stopped: 13/02/2011  12:53:17 ===
                1: 2 2: 0
                1: 2 2: 1
                [    6204] Sun Feb 13 12:53:18 2011  INFO
                *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
                :: END TIMER :: [Payload Operation :{635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}] took 4027.41 miliseconds (4.02741 seconds)
                User specified overrideFile:
                Calling the custom action code for post-repair for payload {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86
                Calling the custom action code for pre-repair for payload {033E378E-6AD3-4AD5-BDEB-CBD69B31046C}
                ::START TIMER:: [Payload Operation :{033E378E-6AD3-4AD5-BDEB-CBD69B31046C}]
                [    5640] Sun Feb 13 12:53:18 2011  INFO
                Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86\Microsoft_VC90_ATL_x86.msi
                MsiSourceListAddSource for  E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86\Microsoft_VC90_ATL_x86.msi is 0
                MsiSourceListSetInfo with updated name: Microsoft_VC90_ATL_x86.msi, Result: 0
                MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC90_ATL_x86\, Result: 0
                Configuring MSI ProductCode: {033E378E-6AD3-4AD5-BDEB-CBD69B31046C}
                ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress   REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adbB0D2.tmp"
                === Logging started: 13/02/2011  12:53:18 ===
                Message type: 1, Argument: Microsoft_VC90_ATL_x86
                Action 12:53:18: INSTALL.
                Action start 12:53:18: INSTALL.
                Action 12:53:18: SystemFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A.
                Action start 12:53:18: SystemFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A.
                Action ended 12:53:18: SystemFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A. Return value 1.
                Action 12:53:18: AppSearch. Searching for installed applications
                Action start 12:53:18: AppSearch.
                Action ended 12:53:18: AppSearch. Return value 0.
                Action 12:53:18: FindRelatedProducts. Searching for related applications
                Action start 12:53:18: FindRelatedProducts.
                Action ended 12:53:18: FindRelatedProducts. Return value 0.
                Action 12:53:18: ValidateProductID.
                Action start 12:53:18: ValidateProductID.
                Action ended 12:53:18: ValidateProductID. Return value 1.
                Action 12:53:18: WindowsFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A.
                Action start 12:53:18: WindowsFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A.
                Action ended 12:53:18: WindowsFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A. Return value 1.
                Action 12:53:18: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37E4_C37F_3B9C_8A4D_0B 4F390FB6DC.
                Action start 12:53:18: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37E4_C37F_3B9C_8A4D_0B 4F390FB6DC.
                Action ended 12:53:18: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37E4_C37F_3B9C_8A4D_0B 4F390FB6DC. Return value 1.
                Action 12:53:18: CostInitialize. Computing space requirements
                Action start 12:53:18: CostInitialize.
                Action ended 12:53:18: CostInitialize. Return value 1.
                Action 12:53:18: FileCost. Computing space requirements
                Action start 12:53:18: FileCost.
                Action ended 12:53:18: FileCost. Return value 1.
                Action 12:53:18: IsolateComponents.
                Action start 12:53:18: IsolateComponents.
                Action ended 12:53:18: IsolateComponents. Return value 0.
                Action 12:53:18: CostFinalize. Computing space requirements
                Action start 12:53:18: CostFinalize.
                Action ended 12:53:18: CostFinalize. Return value 1.
                Action 12:53:18: SetODBCFolders. Initializing ODBC directories
                Action start 12:53:18: SetODBCFolders.
                Action ended 12:53:18: SetODBCFolders. Return value 0.
                Action 12:53:18: MigrateFeatureStates. Migrating feature states from related applications
                Action start 12:53:18: MigrateFeatureStates.
                Action ended 12:53:18: MigrateFeatureStates. Return value 0.
                Action 12:53:18: InstallValidate. Validating install
                Action start 12:53:18: InstallValidate.
                Action ended 12:53:18: InstallValidate. Return value 1.
                Action 12:53:18: RemoveExistingProducts. Removing applications
                Action start 12:53:18: RemoveExistingProducts.
                Action ended 12:53:18: RemoveExistingProducts. Return value 0.
                Action 12:53:18: InstallInitialize.
                Action start 12:53:18: InstallInitialize.
                [    5640] Sun Feb 13 12:53:19 2011  INFO
                Action ended 12:53:19: InstallInitialize. Return value 1.
                Action 12:53:19: ProcessComponents. Updating component registration
                Action start 12:53:19: ProcessComponents.
                Action 12:53:19: GenerateScript. Generating script operations for action:
                Action ended 12:53:19: ProcessComponents. Return value 1.
                Action 12:53:19: UnpublishComponents. Unpublishing Qualified Components
                Action start 12:53:19: UnpublishComponents.
                Action ended 12:53:19: UnpublishComponents. Return value 0.
                Action 12:53:19: MsiUnpublishAssemblies. Unpublishing assembly information
                Action start 12:53:19: MsiUnpublishAssemblies.
                Action ended 12:53:19: MsiUnpublishAssemblies. Return value 1.
                Action 12:53:19: UnpublishFeatures. Unpublishing product features
                Action start 12:53:19: UnpublishFeatures.
                Action ended 12:53:19: UnpublishFeatures. Return value 1.
                Action 12:53:19: StopServices. Stopping services
                Action start 12:53:19: StopServices.
                Action ended 12:53:19: StopServices. Return value 1.
                Action 12:53:19: DeleteServices. Deleting services
                Action start 12:53:19: DeleteServices.
                Action ended 12:53:19: DeleteServices. Return value 1.
                Action 12:53:19: UnregisterComPlus. Unregistering COM+ Applications and Components
                Action start 12:53:19: UnregisterComPlus.
                Action ended 12:53:19: UnregisterComPlus. Return value 0.
                Action 12:53:19: SelfUnregModules. Unregistering modules
                Action start 12:53:19: SelfUnregModules.
                Action ended 12:53:19: SelfUnregModules. Return value 1.
                Action 12:53:19: UnregisterTypeLibraries. Unregistering type libraries
                Action start 12:53:19: UnregisterTypeLibraries.
                Action ended 12:53:19: UnregisterTypeLibraries. Return value 0.
                Action 12:53:19: RemoveODBC. Removing ODBC components
                Action start 12:53:19: RemoveODBC.
                Action ended 12:53:19: RemoveODBC. Return value 1.
                Action 12:53:19: UnregisterFonts. Unregistering fonts
                Action start 12:53:19: UnregisterFonts.
                Action ended 12:53:19: UnregisterFonts. Return value 1.
                Action 12:53:19: RemoveRegistryValues. Removing system registry values
                Action start 12:53:19: RemoveRegistryValues.
                Action ended 12:53:19: RemoveRegistryValues. Return value 1.
                Action 12:53:19: UnregisterClassInfo. Unregister class servers
                Action start 12:53:19: UnregisterClassInfo.
                Action ended 12:53:19: UnregisterClassInfo. Return value 0.
                Action 12:53:19: UnregisterExtensionInfo. Unregistering extension servers
                Action start 12:53:19: UnregisterExtensionInfo.
                Action ended 12:53:19: UnregisterExtensionInfo. Return value 0.
                Action 12:53:19: UnregisterProgIdInfo. Unregistering program identifiers
                Action start 12:53:19: UnregisterProgIdInfo.
                Action ended 12:53:19: UnregisterProgIdInfo. Return value 0.
                Action 12:53:19: UnregisterMIMEInfo. Unregistering MIME info
                Action start 12:53:19: UnregisterMIMEInfo.
                Action ended 12:53:19: UnregisterMIMEInfo. Return value 0.
                Action 12:53:19: RemoveIniValues. Removing INI file entries
                Action start 12:53:19: RemoveIniValues.
                Action ended 12:53:19: RemoveIniValues. Return value 1.
                Action 12:53:19: RemoveShortcuts. Removing shortcuts
                Action start 12:53:19: RemoveShortcuts.
                Action ended 12:53:19: RemoveShortcuts. Return value 0.
                Action 12:53:19: RemoveEnvironmentStrings. Updating environment strings
                Action start 12:53:19: RemoveEnvironmentStrings.
                Action ended 12:53:19: RemoveEnvironmentStrings. Return value 1.
                Action 12:53:19: RemoveDuplicateFiles. Removing duplicated files
                Action start 12:53:19: RemoveDuplicateFiles.
                Action ended 12:53:19: RemoveDuplicateFiles. Return value 1.
                Action 12:53:19: RemoveFiles. Removing files
                Action start 12:53:19: RemoveFiles.
                Action ended 12:53:19: RemoveFiles. Return value 0.
                Action 12:53:19: RemoveFolders. Removing folders
                Action start 12:53:19: RemoveFolders.
                Action ended 12:53:19: RemoveFolders. Return value 0.
                Action 12:53:19: CreateFolders. Creating folders
                Action start 12:53:19: CreateFolders.
                Action ended 12:53:19: CreateFolders. Return value 0.
                Action 12:53:19: MoveFiles. Moving files
                Action start 12:53:19: MoveFiles.
                Action ended 12:53:19: MoveFiles. Return value 1.
                Action 12:53:19: InstallFiles. Copying new files
                Action start 12:53:19: InstallFiles.
                Action ended 12:53:19: InstallFiles. Return value 1.
                Action 12:53:19: PatchFiles. Patching files
                Action start 12:53:19: PatchFiles.
                Action ended 12:53:19: PatchFiles. Return value 0.
                Action 12:53:19: DuplicateFiles. Creating duplicate files
                Action start 12:53:19: DuplicateFiles.
                Action ended 12:53:19: DuplicateFiles. Return value 1.
                Action 12:53:19: BindImage. Binding executables
                Action start 12:53:19: BindImage.
                Action ended 12:53:19: BindImage. Return value 1.
                Action 12:53:19: CreateShortcuts. Creating shortcuts
                Action start 12:53:19: CreateShortcuts.
                Action ended 12:53:19: CreateShortcuts. Return value 0.
                Action 12:53:19: RegisterClassInfo. Registering class servers
                Action start 12:53:19: RegisterClassInfo.
                Action ended 12:53:19: RegisterClassInfo. Return value 0.
                Action 12:53:19: RegisterExtensionInfo. Registering extension servers
                Action start 12:53:19: RegisterExtensionInfo.
                Action ended 12:53:19: RegisterExtensionInfo. Return value 0.
                Action 12:53:19: RegisterProgIdInfo. Registering program identifiers
                Action start 12:53:19: RegisterProgIdInfo.
                Action ended 12:53:19: RegisterProgIdInfo. Return value 0.
                Action 12:53:19: RegisterMIMEInfo. Registering MIME info
                Action start 12:53:19: RegisterMIMEInfo.
                Action ended 12:53:19: RegisterMIMEInfo. Return value 0.
                Action 12:53:19: WriteRegistryValues. Writing system registry values
                Action start 12:53:19: WriteRegistryValues.
                Action ended 12:53:19: WriteRegistryValues. Return value 1.
                Action 12:53:19: WriteIniValues. Writing INI file values
                Action start 12:53:19: WriteIniValues.
                Action ended 12:53:19: WriteIniValues. Return value 1.
                Action 12:53:19: WriteEnvironmentStrings. Updating environment strings
                Action start 12:53:19: WriteEnvironmentStrings.
                Action ended 12:53:19: WriteEnvironmentStrings. Return value 1.
                Action 12:53:19: RegisterFonts. Registering fonts
                Action start 12:53:19: RegisterFonts.
                Action ended 12:53:19: RegisterFonts. Return value 1.
                Action 12:53:19: InstallODBC. Installing ODBC components
                Action start 12:53:19: InstallODBC.
                Action ended 12:53:19: InstallODBC. Return value 0.
                Action 12:53:19: RegisterTypeLibraries. Registering type libraries
                Action start 12:53:19: RegisterTypeLibraries.
                Action ended 12:53:19: RegisterTypeLibraries. Return value 0.
                Action 12:53:19: SelfRegModules. Registering modules
                Action start 12:53:19: SelfRegModules.
                Action ended 12:53:19: SelfRegModules. Return value 1.
                Action 12:53:19: RegisterComPlus. Registering COM+ Applications and Components
                Action start 12:53:19: RegisterComPlus.
                Action ended 12:53:19: RegisterComPlus. Return value 0.
                Action 12:53:19: InstallServices. Installing new services
                Action start 12:53:19: InstallServices.
                Action ended 12:53:19: InstallServices. Return value 1.
                Action 12:53:19: StartServices. Starting services
                Action start 12:53:19: StartServices.
                Action ended 12:53:19: StartServices. Return value 1.
                Action 12:53:19: RegisterUser. Registering user
                Action start 12:53:19: RegisterUser.
                Action ended 12:53:19: RegisterUser. Return value 0.
                Action 12:53:19: RegisterProduct. Registering product
                Action start 12:53:19: RegisterProduct.
                Registering product
                Action ended 12:53:19: RegisterProduct. Return value 1.
                Action 12:53:19: PublishComponents. Publishing qualified components
                Action start 12:53:19: PublishComponents.
                Action ended 12:53:19: PublishComponents. Return value 0.
                Action 12:53:19: MsiPublishAssemblies. Publishing assembly information
                Action start 12:53:19: MsiPublishAssemblies.
                Action ended 12:53:19: MsiPublishAssemblies. Return value 1.
                Action 12:53:19: PublishFeatures. Publishing product features
                Action start 12:53:19: PublishFeatures.
                Action ended 12:53:19: PublishFeatures. Return value 1.
                Action 12:53:19: PublishProduct. Publishing product information
                Action start 12:53:19: PublishProduct.
                Action ended 12:53:19: PublishProduct. Return value 1.
                Action 12:53:19: InstallFinalize.
                Action start 12:53:19: InstallFinalize.
                40d7d.msi
                Application Context:Global, Assembly Name:Microsoft.VC90.ATL,version="9.0.30729.4137",publicKeyToken="1fc8b3b9a1e18e3b",proces sorArchitecture="x86",type="win32"
                Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.ATL,version="9.0.30729.4137",publicKeyToken="1fc8b3b9a1e18 e3b",processorArchitecture="x86",type="win32-policy"
                Feature: Microsoft_VC90_ATL_x86_
                Action 12:53:19: RollbackCleanup. Removing backup files
                File: C:\Config.Msi\35406e.rbf
                File: C:\Config.Msi\35406f.rbf
                Action ended 12:53:19: InstallFinalize. Return value 1.
                Action ended 12:53:19: INSTALL. Return value 1.
                Property(S): UpgradeCode = {F31F95D5-E2B6-4984-A9D1-CA5E8CF1BFFE}
                Property(S): SourcedirProduct = {033E378E-6AD3-4AD5-BDEB-CBD69B31046C}
                Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86\
                Property(S): Installed = 2009/07/28 04:07:38
                Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86\Microsoft_VC90_ATL_x86.msi
                Property(S): DATABASE = C:\Windows\Installer\354068.msi
                Property(S): Time = 12:53:19
                Property(S): VirtualMemory = 14362
                Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86\
                Property(S): WindowsFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A = C:\Windows\
                Property(S): SystemFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A = C:\Windows\SysWOW64\
                Property(S): WinSxsDirectory.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2 A = C:\Windows\winsxs\
                Property(S): payload_ul.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A = C:\Windows\winsxs\x86_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.4137_none_51c97d20bbe 8350e\
                Property(S): payload.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A = C:\Windows\winsxs\x86_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_9.0.30729.4137_x-ww_35349982\
                Property(S): WinSxsManifests.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2 A = C:\Windows\winsxs\Manifests\
                Property(S): WinSxsPolicies.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A = C:\Windows\winsxs\Policies\
                Property(S): policydir.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A = C:\Windows\winsxs\Policies\x86_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_x-ww_fe8be9c7\
                Property(S): policydir_ul.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A = C:\Windows\winsxs\x86_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_x-ww_fe8be9c7\
                Property(S): WinSxsDirectory.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37E4_C37F_3B9C_8A4D_ 0B4F390FB6DC = C:\Windows\winsxs\
                Property(S): payload_ul.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37E4_C37F_3B9C_8A4D_0B4F3 90FB6DC = C:\Windows\winsxs\x86_policy.9.0.microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.4137_none_ f0eecac0f8a1c174\
                Property(S): WinSxsPolicies.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37E4_C37F_3B9C_8A4D_0 B4F390FB6DC = C:\Windows\winsxs\Policies\
                Property(S): policydir.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37E4_C37F_3B9C_8A4D_0B4F39 0FB6DC = C:\Windows\winsxs\Policies\x86_policy.9.0.Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_x-ww_9e7eb5 01\
                Property(S): WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37E4_C37F_3B9C_8A4D_0B 4F390FB6DC = C:\Windows\
                Property(S): ProductCode = {033E378E-6AD3-4AD5-BDEB-CBD69B31046C}
                Property(S): ProductName = Microsoft_VC90_ATL_x86
                Property(S): DWUSLINK = CEAC70DF2E8BD79FDEACA7FFC98B978FCE1B808FFE0BB73FCE1BE08F4EDCE7AFE9FB809F89AC
                Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adbB0D2.tmp
                Property(S): PackageCode = {BC1C6355-192C-4334-94F9-4A03B0DCB75C}
                === Logging stopped: 13/02/2011  12:53:19 ===
                1: 2 2: 0
                1: 2 2: 1
                [    6204] Sun Feb 13 12:53:20 2011  INFO
                :: END TIMER :: [Payload Operation :{033E378E-6AD3-4AD5-BDEB-CBD69B31046C}] took 2028.04 miliseconds (2.02804 seconds)
                Calling the custom action code for post-repair for payload {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86
                Calling the custom action code for pre-repair for payload {6B485102-4593-43F6-BA45-F14D690B0C64}
                ::START TIMER:: [Payload Operation :{6B485102-4593-43F6-BA45-F14D690B0C64}]
                [    3656] Sun Feb 13 12:53:20 2011  INFO
                Installer Operation: PayloadUninstaller
                Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {6B485102-4593-43F6-BA45-F14D690B0C64}
                Effective AdobeCode for: {6B485102-4593-43F6-BA45-F14D690B0C64} is {6B485102-4593-43F6-BA45-F14D690B0C64}
                Session includes local copy of payload for repair source
                Repair payload source package: E:\Adobe CS5\payloads\AdobeSuiteSharedConfiguration-mul\Install.db
                Extracting assets...
                [    3656] Sun Feb 13 12:53:21 2011  INFO
                Extracting assets complete. Number assets: 1
                Beginning installation for payload at E:\Adobe CS5\payloads\AdobeSuiteSharedConfiguration-mul\Install.db
                [    3656] Sun Feb 13 12:53:22 2011  INFO
                Evaluating condition# 1
                Condition failed
                Completing installation for payload at E:\Adobe CS5\payloads\AdobeSuiteSharedConfiguration-mul\Install.db
                UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{6B485102-4593-43F6-BA45-F14D690B0C64}.db
                Physical payload repair result:0
                [    6204] Sun Feb 13 12:53:23 2011  INFO
                *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
                :: END TIMER :: [Payload Operation :{6B485102-4593-43F6-BA45-F14D690B0C64}] took 3017.88 miliseconds (3.01788 seconds) DTR = 2.65086 KBPS (0.00258873 MBPS)
                [    6204] Sun Feb 13 12:53:24 2011  INFO
                Calling the custom action code for post-repair for payload {6B485102-4593-43F6-BA45-F14D690B0C64} Suite Shared Configuration CS5
                Calling the custom action code for pre-repair for payload {BD0D6363-E961-410F-8BF4-ECD8795F3923}
                ::START TIMER:: [Payload Operation :{BD0D6363-E961-410F-8BF4-ECD8795F3923}]
                [    2100] Sun Feb 13 12:53:24 2011  INFO
                Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {BD0D6363-E961-410F-8BF4-ECD8795F3923}
                Effective AdobeCode for: {BD0D6363-E961-410F-8BF4-ECD8795F3923} is {BD0D6363-E961-410F-8BF4-ECD8795F3923}
                Repair payload source package: E:\Adobe CS5\payloads\AdobeCMaps3-mul\Install.db
                [    2100] Sun Feb 13 12:53:25 2011  INFO
                Beginning installation for payload at E:\Adobe CS5\payloads\AdobeCMaps3-mul\Install.db
                [    2100] Sun Feb 13 12:53:34 2011  INFO
                Completing installation for payload at E:\Adobe CS5\payloads\AdobeCMaps3-mul\Install.db
                UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{BD0D6363-E961-410F-8BF4-ECD8795F3923}.db
                [    6204] Sun Feb 13 12:53:35 2011  INFO
                :: END TIMER :: [Payload Operation :{BD0D6363-E961-410F-8BF4-ECD8795F3923}] took 11046.7 miliseconds (11.0467 seconds) DTR = 325.888 KBPS (0.31825 MBPS)
                Calling the custom action code for post-repair for payload {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5
                Calling the custom action code for pre-repair for payload {6F3A624B-1B72-4081-96E8-23261F389C5C}
                ::START TIMER:: [Payload Operation :{6F3A624B-1B72-4081-96E8-23261F389C5C}]
                [    5460] Sun Feb 13 12:53:35 2011  INFO
                Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {6F3A624B-1B72-4081-96E8-23261F389C5C}
                [    5460] Sun Feb 13 12:53:36 2011  INFO
                Effective AdobeCode for: {6F3A624B-1B72-4081-96E8-23261F389C5C} is {6F3A624B-1B72-4081-96E8-23261F389C5C}
                Repair payload source package: E:\Adobe CS5\payloads\AdobeTypeSupport10-mul\Install.db
                [    5460] Sun Feb 13 12:53:37 2011  INFO
                Beginning installation for payload at E:\Adobe CS5\payloads\AdobeTypeSupport10-mul\Install.db
                [    5460] Sun Feb 13 12:53:38 2011  INFO
                Completing installation for payload at E:\Adobe CS5\payloads\AdobeTypeSupport10-mul\Install.db
                UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{6F3A624B-1B72-4081-96E8-23261F389C5C}.db
                [    6204] Sun Feb 13 12:53:38 2011  INFO
                :: END TIMER :: [Payload Operation :{6F3A624B-1B72-4081-96E8-23261F389C5C}] took 3027.26 miliseconds (3.02726 seconds)
                Calling the custom action code for post-repair for payload {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5
                Calling the custom action code for pre-repair for payload {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}
                ::START TIMER:: [Payload Operation :{0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}]
                [    6756] Sun Feb 13 12:53:38 2011  INFO
                Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC80_ATL_x86\Microsoft_VC80_ATL_x86.msi
                MsiSourceListAddSource for  E:\Adobe CS5\payloads\Microsoft_VC80_ATL_x86\Microsoft_VC80_ATL_x86.msi is 0
                MsiSourceListSetInfo with updated name: Microsoft_VC80_ATL_x86.msi, Result: 0
                [    6756] Sun Feb 13 12:53:39 2011  INFO
                MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC80_ATL_x86\, Result: 0
                Configuring MSI ProductCode: {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}
                ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress   REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adb196.tmp"
                === Logging started: 13/02/2011  12:53:39 ===
                Message type: 0, Argument: 1033
                Message type: 1, Argument: Microsoft_VC80_ATL_x86
                Action 12:53:39: INSTALL.
                Action start 12:53:39: INSTALL.
                Action 12:53:39: WindowsFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E.
                Action start 12:53:39: WindowsFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E.
                Action ended 12:53:39: WindowsFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E. Return value 1.
                Action 12:53:39: SystemFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E.
                Action start 12:53:39: SystemFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E.
                Action ended 12:53:39: SystemFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E. Return value 1.
                Action 12:53:39: WindowsFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E.
                Action start 12:53:39: WindowsFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E.
                Action ended 12:53:39: WindowsFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E. Return value 1.
                Action 12:53:39: SystemFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E.
                Action start 12:53:39: SystemFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E.
                Action ended 12:53:39: SystemFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E. Return value 1.
                Action 12:53:39: AppSearch. Searching for installed applications
                Action start 12:53:39: AppSearch.
                Action ended 12:53:39: AppSearch. Return value 0.
                Action 12:53:39: FindRelatedProducts. Searching for related applications
                Action start 12:53:39: FindRelatedProducts.
                Action ended 12:53:39: FindRelatedProducts. Return value 0.
                Action 12:53:39: ValidateProductID.
                Action start 12:53:39: ValidateProductID.
                Action ended 12:53:39: ValidateProductID. Return value 1.
                Action 12:53:39: CostInitialize. Computing space requirements
                Action start 12:53:39: CostInitialize.
                Action ended 12:53:39: CostInitialize. Return value 1.
                Action 12:53:39: FileCost. Computing space requirements
                Action start 12:53:39: FileCost.
                Action ended 12:53:39: FileCost. Return value 1.
                Action 12:53:39: IsolateComponents.
                Action start 12:53:39: IsolateComponents.
                Action ended 12:53:39: IsolateComponents. Return value 0.
                Action 12:53:39: CostFinalize. Computing space requirements
                Action start 12:53:39: CostFinalize.
                Action ended 12:53:39: CostFinalize. Return value 1.
                Action 12:53:39: SetODBCFolders. Initializing ODBC directories
                Action start 12:53:39: SetODBCFolders.
                Action ended 12:53:39: SetODBCFolders. Return value 0.
                Action 12:53:39: MigrateFeatureStates. Migrating feature states from related applications
                Action start 12:53:39: MigrateFeatureStates.
                Action ended 12:53:39: MigrateFeatureStates. Return value 0.
                Action 12:53:39: InstallValidate. Validating install
                Action start 12:53:39: InstallValidate.
                Action ended 12:53:39: InstallValidate. Return value 1.
                Action 12:53:39: RemoveExistingProducts. Removing applications
                Action start 12:53:39: RemoveExistingProducts.
                Action ended 12:53:39: RemoveExistingProducts. Return value 0.
                Action 12:53:39: InstallInitialize.
                Action start 12:53:39: InstallInitialize.
                Action ended 12:53:39: InstallInitialize. Return value 1.
                Action 12:53:39: SxsInstallCA.
                Action start 12:53:39: SxsInstallCA.
                1: sxsdelca 2: traceop 3: 1256 4: 0
                1: sxsdelca 2: traceop 3: 1257 4: 0
                1: sxsdelca 2: traceop 3: 1258 4: 0
                1: sxsdelca 2: traceop 3: 1284 4: 0
                1: sxsdelca 2: traceop 3: 1288 4: 0
                1: sxsdelca 2: traceop 3: 1289 4: 0
                1: sxsdelca 2: traceop 3: 1290 4: 0
                1: sxsdelca 2: traceop 3: 1292 4: 0
                1: sxsdelca 2: traceop 3: 1318 4: 0
                1: sxsdelca: Skipping component  2: uplevel.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4053.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.89.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.96.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.94.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.93.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.99.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.98.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.95.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.97.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.100.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.104.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3044.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.101.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.103.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.193.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3069.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.1833.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.238.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4028.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3051.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4027.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4029.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4052.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4045.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: uplevel.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
                1: sxsdelca 2: traceop 3: 1284 4: 259
                1: sxsdelca 2: SxsMsmInstall completed 3: 0 4: 0
                Action ended 12:53:39: SxsInstallCA. Return value 1.
                Action 12:53:39: ProcessComponents. Updating component registration
                Action start 12:53:39: ProcessComponents.
                Action 12:53:39: GenerateScript. Generating script operations for action:
                Action ended 12:53:39: ProcessComponents. Return value 1.
                Action 12:53:39: UnpublishComponents. Unpublishing Qualified Components
                Action start 12:53:39: UnpublishComponents.
                Action ended 12:53:39: UnpublishComponents. Return value 0.
                Action 12:53:39: MsiUnpublishAssemblies. Unpublishing assembly information
                Action start 12:53:39: MsiUnpublishAssemblies.
                Action ended 12:53:39: MsiUnpublishAssemblies. Return value 1.
                Action 12:53:39: UnpublishFeatures. Unpublishing product features
                Action start 12:53:39: UnpublishFeatures.
                Action ended 12:53:39: UnpublishFeatures. Return value 1.
                Action 12:53:39: StopServices. Stopping services
                Action start 12:53:39: StopServices.
                Action ended 12:53:39: StopServices. Return value 1.
                Action 12:53:39: DeleteServices. Deleting services
                Action start 12:53:39: DeleteServices.
                Action ended 12:53:39: DeleteServices. Return value 1.
                Action 12:53:39: UnregisterComPlus. Unregistering COM+ Applications and Components
                Action start 12:53:39: UnregisterComPlus.
                Action ended 12:53:39: UnregisterComPlus. Return value 0.
                Action 12:53:39: SelfUnregModules. Unregistering modules
                Action start 12:53:39: SelfUnregModules.
                Action ended 12:53:39: SelfUnregModules. Return value 1.
                Action 12:53:39: UnregisterTypeLibraries. Unregistering type libraries
                Action start 12:53:39: UnregisterTypeLibraries.
                Action ended 12:53:39: UnregisterTypeLibraries. Return value 0.
                Action 12:53:39: RemoveODBC. Removing ODBC components
                Action start 12:53:39: RemoveODBC.
                Action ended 12:53:39: RemoveODBC. Return value 1.
                Action 12:53:39: UnregisterFonts. Unregistering fonts
                Action start 12:53:39: UnregisterFonts.
                Action ended 12:53:39: UnregisterFonts. Return value 1.
                Action 12:53:39: RemoveRegistryValues. Removing system registry values
                Action start 12:53:39: RemoveRegistryValues.
                Action ended 12:53:39: RemoveRegistryValues. Return value 1.
                Action 12:53:39: UnregisterClassInfo. Unregister class servers
                Action start 12:53:39: UnregisterClassInfo.
                Action ended 12:53:39: UnregisterClassInfo. Return value 0.
                Action 12:53:39: UnregisterExtensionInfo. Unregistering extension servers
                Action start 12:53:39: UnregisterExtensionInfo.
                Action ended 12:53:39: UnregisterExtensionInfo. Return value 0.
                Action 12:53:39: UnregisterProgIdInfo. Unregistering program identifiers
                Action start 12:53:39: UnregisterProgIdInfo.
                Action ended 12:53:39: UnregisterProgIdInfo. Return value 0.
                Action 12:53:39: UnregisterMIMEInfo. Unregistering MIME info
                Action start 12:53:39: UnregisterMIMEInfo.
                Action ended 12:53:39: UnregisterMIMEInfo. Return value 0.
                Action 12:53:39: RemoveIniValues. Removing INI file entries
                Action start 12:53:39: RemoveIniValues.
                Action ended 12:53:39: RemoveIniValues. Return value 1.
                Action 12:53:39: RemoveShortcuts. Removing shortcuts
                Action start 12:53:39: RemoveShortcuts.
                Action ended 12:53:39: RemoveShortcuts. Return value 0.
                Action 12:53:39: RemoveEnvironmentStrings. Updating environment strings
                Action start 12:53:39: RemoveEnvironmentStrings.
                Action ended 12:53:39: RemoveEnvironmentStrings. Return value 1.
                Action 12:53:39: RemoveDuplicateFiles. Removing duplicated files
                Action start 12:53:39: RemoveDuplicateFiles.
                Action ended 12:53:39: RemoveDuplicateFiles. Return value 1.
                Action 12:53:39: RemoveFiles. Removing files
                Action start 12:53:39: RemoveFiles.
                Action ended 12:53:39: RemoveFiles. Return value 0.
                Action 12:53:39: RemoveFolders. Removing folders
                Action start 12:53:39: RemoveFolders.
                Action ended 12:53:39: RemoveFolders. Return value 0.
                Action 12:53:39: CreateFolders. Creating folders
                Action start 12:53:39: CreateFolders.
                Action ended 12:53:39: CreateFolders. Return value 0.
                Action 12:53:39: MoveFiles. Moving files
                Action start 12:53:39: MoveFiles.
                Action ended 12:53:39: MoveFiles. Return value 1.
                Action 12:53:39: InstallFiles. Copying new files
                Action start 12:53:39: InstallFiles.
                [    6756] Sun Feb 13 12:53:40 2011  INFO
                Action ended 12:53:40: InstallFiles. Return value 1.
                Action 12:53:40: PatchFiles. Patching files
                Action start 12:53:40: PatchFiles.
                Action ended 12:53:40: PatchFiles. Return value 0.
                Action 12:53:40: DuplicateFiles. Creating duplicate files
                Action start 12:53:40: DuplicateFiles.
                Action ended 12:53:40: DuplicateFiles. Return value 1.
                Action 12:53:40: BindImage. Binding executables
                Action start 12:53:40: BindImage.
                Action ended 12:53:40: BindImage. Return value 1.
                Action 12:53:40: CreateShortcuts. Creating shortcuts
                Action start 12:53:40: CreateShortcuts.
                Action ended 12:53:40: CreateShortcuts. Return value 0.
                Action 12:53:40: RegisterClassInfo. Registering class servers
                Action start 12:53:40: RegisterClassInfo.
                Action ended 12:53:40: RegisterClassInfo. Return value 0.
                Action 12:53:40: RegisterExtensionInfo. Registering extension servers
                Action start 12:53:40: RegisterExtensionInfo.
                Action ended 12:53:40: RegisterExtensionInfo. Return value 0.
                Action 12:53:40: RegisterProgIdInfo. Registering program identifiers
                Action start 12:53:40: RegisterProgIdInfo.
                Action ended 12:53:40: RegisterProgIdInfo. Return value 0.
                Action 12:53:40: RegisterMIMEInfo. Registering MIME info
                Action start 12:53:40: RegisterMIMEInfo.
                Action ended 12:53:40: RegisterMIMEInfo. Return value 0.
                Action 12:53:40: WriteRegistryValues. Writing system registry values
                Action start 12:53:40: WriteRegistryValues.
                Action ended 12:53:40: WriteRegistryValues. Return value 1.
                Action 12:53:40: WriteIniValues. Writing INI file values
                Action start 12:53:40: WriteIniValues.
                Action ended 12:53:40: WriteIniValues. Return value 1.
                Action 12:53:40: WriteEnvironmentStrings. Updating environment strings
                Action start 12:53:40: WriteEnvironmentStrings.
                Action ended 12:53:40: WriteEnvironmentStrings. Return value 1.
                Action 12:53:40: RegisterFonts. Registering fonts
                Action start 12:53:40: RegisterFonts.
                Action ended 12:53:40: RegisterFonts. Return value 1.
                Action 12:53:40: InstallODBC. Installing ODBC components
                Action start 12:53:40: InstallODBC.
                Action ended 12:53:40: InstallODBC. Return value 0.
                Action 12:53:40: RegisterTypeLibraries. Registering type libraries
                Action start 12:53:40: RegisterTypeLibraries.
                Action ended 12:53:40: RegisterTypeLibraries. Return value 0.
                Action 12:53:40: SelfRegModules. Registering modules
                Action start 12:53:40: SelfRegModules.
                Action ended 12:53:40: SelfRegModules. Return value 1.
                Action 12:53:40: RegisterComPlus. Registering COM+ Applications and Components
                Action start 12:53:40: RegisterComPlus.
                Action ended 12:53:40: RegisterComPlus. Return value 0.
                Action 12:53:40: InstallServices. Installing new services
                Action start 12:53:40: InstallServices.
                Action ended 12:53:40: InstallServices. Return value 1.
                Action 12:53:40: StartServices. Starting services
                Action start 12:53:40: StartServices.
                Action ended 12:53:40: StartServices. Return value 1.
                Action 12:53:40: RegisterUser. Registering user
                Action start 12:53:40: RegisterUser.
                Action ended 12:53:40: RegisterUser. Return value 0.
                Action 12:53:40: RegisterProduct. Registering product
                Action start 12:53:40: RegisterProduct.
                Registering product
                Action ended 12:53:40: RegisterProduct. Return value 1.
                Action 12:53:40: PublishComponents. Publishing qualified components
                Action start 12:53:40: PublishComponents.
                Action ended 12:53:40: PublishComponents. Return value 0.
                Action 12:53:40: MsiPublishAssemblies. Publishing assembly information
                Action start 12:53:40: MsiPublishAssemblies.
                Action ended 12:53:40: MsiPublishAssemblies. Return value 1.
                Action 12:53:40: PublishFeatures. Publishing product features
                Action start 12:53:40: PublishFeatures.
                Action ended 12:53:40: PublishFeatures. Return value 1.
                Action 12:53:40: PublishProduct. Publishing product information
                Action start 12:53:40: PublishProduct.
                Action ended 12:53:40: PublishProduct. Return value 1.
                Action 12:53:40: InstallFinalize.
                Action start 12:53:40: InstallFinalize.
                Action 12:53:40: ProcessComponents. Updating component registration
                Action 12:53:40: RemoveODBC. Removing ODBC components
                Action 12:53:40: InstallFiles. Copying new files
                40d86.msi
                [    6756] Sun Feb 13 12:53:41 2011  INFO
                Action 12:53:41: MsiPublishAssemblies. Publishing assembly information
                Application Context:Global, Assembly Name:Microsoft.VC80.ATL,type="win32",version="8.0.50727.4053",publicKeyToken="1fc8b3b9a1e 18e3b",processorArchitecture="x86"
                Application Context:Global, Assembly Name:policy.8.0.Microsoft.VC80.ATL,type="win32-policy",version="8.0.50727.4053",publicKey Token="1fc8b3b9a1e18e3b",processorArchitecture="x86"
                Action 12:53:41: PublishFeatures. Publishing product features
                Feature: Microsoft_VC80_ATL_x86_
                Action 12:53:41: PublishProduct. Publishing product information
                Action 12:53:41: RollbackCleanup. Removing backup files
                File: C:\Config.Msi\354077.rbf
                File: C:\Config.Msi\354078.rbf
                Action ended 12:53:41: InstallFinalize. Return value 1.
                Action ended 12:53:41: INSTALL. Return value 1.
                Property(S): SourcedirProduct = {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}
                Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC80_ATL_x86\
                Property(S): UpgradeCode = {B42842E9-F9F7-4A0F-A616-857958BC88BF}
                Property(S): Installed = 2009/11/13 01:34:20
                Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC80_ATL_x86\Microsoft_VC80_ATL_x86.msi
                Property(S): DATABASE = C:\Windows\Installer\354071.msi
                Property(S): Time = 12:53:41
                Property(S): VirtualMemory = 14350
                Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC80_ATL_x86\
                Property(S): WinSxsDirectory.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
                Property(S): payload_ul.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_microsoft.vc80.atl_1fc8b3b9a1e18e3b_8.0.50727.4053_none_d1c738ec435 78ea1\
                Property(S): payload.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_6e805841\
                Property(S): WindowsFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\
                Property(S): SystemFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
                Property(S): WinSxsManifests.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
                Property(S): WinSxsPolicies.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
                Property(S): policydir.8.0.50727.101.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
                Property(S): policydir.8.0.50727.238.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
                Property(S): policydir.8.0.50727.100.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
                Property(S): payload.8.0.50727.89.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_6e845944\
                Property(S): payload.8.0.50727.94.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_6e85597e\
                Property(S): payload.8.0.50727.93.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_6e85597d\
                Property(S): policydir.8.0.50727.103.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
                Property(S): ANSIFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
                Property(S): payload.8.0.50727.95.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_6e85597f\
                Property(S): policydir.8.0.50727.1833.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
                Property(S): payload.8.0.50727.96.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_6e855980\
                Property(S): payload.8.0.50727.99.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_6e855983\
                Property(S): payload.8.0.50727.97.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_6e855981\
                Property(S): payload.8.0.50727.98.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_6e855982\
                Property(S): payload.8.0.50727.100.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_c8b815f2\
                Property(S): payload.8.0.50727.101.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_c8b815f3\
                Property(S): policydir.8.0.50727.3069.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
                Property(S): payload.8.0.50727.104.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_c8b815f6\
                Property(S): payload.8.0.50727.103.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_c8b815f5\
                Property(S): policydir.8.0.50727.104.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
                Property(S): payload.8.0.50727.193.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_c8c1182c\
                Property(S): payload.8.0.50727.3044.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_18ae9600\
                Property(S): payload.8.0.50727.238.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_c9392638\
                Property(S): payload.8.0.50727.3069.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_18b09683\
                Property(S): policydir.8.0.50727.3044.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
                Property(S): payload.8.0.50727.3051.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_18af963c\
                Property(S): payload.8.0.50727.4028.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_47336645\
                Property(S): payload.8.0.50727.4027.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_47336644\
                Property(S): payload.8.0.50727.1833.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_bf90704a\
                Property(S): policydir_ul.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_473666fd\
                Property(S): payload.8.0.50727.4029.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_47336646\
                Property(S): payload.8.0.50727.4053.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_473666fd\
                Property(S): policydir.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
                Property(S): policydir.8.0.50727.99.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
                Property(S): policydir.8.0.50727.98.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
                Property(S): policydir.8.0.50727.97.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
                Property(S): policydir.8.0.50727.96.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
                Property(S): policydir.8.0.50727.95.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
                Property(S): policydir.8.0.50727.94.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
                Property(S): payload.8.0.50727.4045.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_473566c0\
                Property(S): payload.8.0.50727.4052.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_473666fc\
                Property(S): policydir.8.0.50727.93.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
                Property(S): policydir.8.0.50727.89.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
                Property(S): policydir.8.0.50727.4053.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
                Property(S): policydir.8.0.50727.4052.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
                Property(S): policydir.8.0.50727.4045.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
                Property(S): policydir.8.0.50727.4029.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
                Property(S): policydir.8.0.50727.4028.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
                Property(S): policydir.8.0.50727.3051.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
                Property(S): policydir.8.0.50727.193.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
                Property(S): policydir.8.0.50727.4027.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
                Property(S): RecentFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Recent\
                Property(S): WinSxsDirectory.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
                Property(S): payload_ul.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.atl_1fc8b3b9a1e18e3b_8.0.50727.4053_none_ 4ddfc6cd11929a02\
                Property(S): WinSxsPolicies.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
                Property(S): policydir.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbc ff\
                Property(S): WindowsFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\
                Property(S): SystemFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
                Property(S): WinSxsManifests.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
                Property(S): payload.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_b2 841548\
                Property(S): policydir.8.0.50727.103.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbc ff\
                Property(S): policydir.8.0.50727.96.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbc ff\
                Property(S): policydir_ul.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_ 8b3a2404\
                Property(S): policydir.8.0.50727.94.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbc ff\
                Property(S): policydir.8.0.50727.89.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbc ff\
                Property(S): policydir.8.0.50727.95.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbc ff\
                Property(S): policydir.8.0.50727.100.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbc ff\
                Property(S): policydir.8.0.50727.93.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbc ff\
                Property(S): payload.8.0.50727.94.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_b2 891685\
                Property(S): policydir.8.0.50727.193.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbc ff\
                Property(S): policydir.8.0.50727.98.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbc ff\
                Property(S): payload.8.0.50727.89.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_b2 88164b\
                Property(S): policydir.8.0.50727.104.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbc ff\
                Property(S): payload.8.0.50727.93.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_b2 891684\
                Property(S): policydir.8.0.50727.99.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbc ff\
                Property(S): policydir.8.0.50727.101.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbc ff\
                Property(S): policydir.8.0.50727.97.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbc ff\
                Property(S): policydir.8.0.50727.4028.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbc ff\
                Property(S): payload.8.0.50727.95.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_b2 891686\
                Property(S): policydir.8.0.50727.3044.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbc ff\
                Property(S): payload.8.0.50727.96.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_b2 891687\
                Property(S): policydir.8.0.50727.238.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbc ff\
                Property(S): payload.8.0.50727.97.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_b2 891688\
                Property(S): policydir.8.0.50727.4052.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbc ff\
                Property(S): payload.8.0.50727.98.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_b2 891689\
                Property(S): policydir.8.0.50727.1833.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbc ff\
                Property(S): payload.8.0.50727.99.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_b2 89168a\
                Property(S): policydir.8.0.50727.3051.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbc ff\
                Property(S): payload.8.0.50727.100.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_0 cbbd2f9\
                Property(S): payload.8.0.50727.101.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_0 cbbd2fa\
                Property(S): policydir.8.0.50727.4029.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbc ff\
                Property(S): payload.8.0.50727.103.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_0 cbbd2fc\
                Property(S): payload.8.0.50727.104.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_0 cbbd2fd\
                Property(S): policydir.8.0.50727.4045.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbc ff\
                Property(S): policydir.8.0.50727.4027.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbc ff\
                Property(S): payload.8.0.50727.193.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_0 cc4d533\
                Property(S): policydir.8.0.50727.3069.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbc ff\
                Property(S): policydir.8.0.50727.4053.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbc ff\
                Property(S): payload.8.0.50727.238.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_0 d3ce33f\
                Property(S): payload.8.0.50727.3044.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_ 5cb25307\
                Property(S): payload.8.0.50727.3051.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_ 5cb35343\
                Property(S): payload.8.0.50727.3069.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_ 5cb4538a\
                Property(S): payload.8.0.50727.1833.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_ 03942d51\
                Property(S): payload.8.0.50727.4027.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_ 8b37234b\
                Property(S): payload.8.0.50727.4028.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_ 8b37234c\
                Property(S): payload.8.0.50727.4029.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_ 8b37234d\
                Property(S): payload.8.0.50727.4045.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_ 8b3923c7\
                Property(S): payload.8.0.50727.4052.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_ 8b3a2403\
                Property(S): payload.8.0.50727.4053.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_ 8b3a2404\
                Property(S): PrintHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
                Property(S): NetHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
                Property(S): RemoteAdminTS = 1
                Property(S): MsiNTSuitePersonal = 1
                Property(S): MsiNTProductType = 1
                Property(S): ServicePackLevelMinor = 0
                Property(S): ServicePackLevel = 0
                Property(S): WindowsBuild = 7600
                Property(S): VersionNT64 = 601
                Property(S): VersionMsi = 5.00
                Property(S): ISCHECKFORPRODUCTUPDATES = 1
                Property(S): ApplicationUsers = AllUsers
                Property(S): AgreeToLicense = No
                Property(S): _IsMaintenance = Change
                Property(S): SetupType = Typical
                Property(S): _IsSetupTypeMin = Typical
                Property(S): IS_SQLSERVER_USERNAME = sa
                Property(S): IS_SQLSERVER_AUTHENTICATION = 0
                Property(S): RestartManagerOption = CloseRestart
                Property(S): Display_IsBitmapDlg = 1
                Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
                Property(S): DefaultUIFont = Tahoma8
                Property(S): DialogCaption = InstallShield for Windows Installer
                Property(S): DisplayNameCustom = Custom
                Property(S): DisplayNameMinimal = Minimal
                Property(S): DisplayNameTypical = Typical
                Property(S): DWUSINTERVAL = 30
                Property(S): ErrorDialog = SetupError
                Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
                Property(S): InstallChoice = AR
                Property(S): INSTALLLEVEL = 100
                Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
                Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
                Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
                Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
                Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
                Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
                Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
                Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
                Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
                Property(S): ISVROOT_PORT_NO = 0
                Property(S): Manufacturer = Adobe
                Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
                Property(S): ProductCode = {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}
                Property(S): ProductID = none
                Property(S): ProductLanguage = 1033
                Property(S): ProductName = Microsoft_VC80_ATL_x86
                Property(S): ProductVersion = 8.0.50727.4053
                Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
                Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
                Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
                Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
                Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
                Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
                Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
                Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
                Property(S): ProgressType0 = install
                Property(S): ProgressType1 = Installing
                Property(S): ProgressType2 = installed
                Property(S): ProgressType3 = installs
                Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
                Property(S): RebootYesNo = No
                Property(S): ReinstallModeText = omus
                Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
                Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
                Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
                Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
                Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
                Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
                Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
                Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
                Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
                Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
                Property(S): DWUSLINK = CE0B90581E3CF05FFEAC57B89EEC978F9EDC508F591B0798CEABF7DFDEAB57D8FE1C47B8D9AC
                Property(S): ARPURLINFOABOUT = http://www.adobe.com
                Property(S): SHOWLAUNCHPROGRAM = 0
                Property(S): ARPSYSTEMCOMPONENT = 1
                Property(S): REBOOT = ReallySuppress
                Property(S): VersionDatabase = 200
                Property(S): PRODUCTLANGUAGE = 1033
                Property(S): MsiSystemRebootPending = 1
                Property(S): CURRENTMEDIAVOLUMELABEL = CS5 Master Coll1
                Property(S): CLIENTPROCESSID = 5888
                Property(S): MSICLIENTUSESEXTERNALUI = 1
                Property(S): CLIENTUILEVEL = 3
                Property(S): CURRENTDIRECTORY = C:\Users\Gary & Susan\AppData\Local\Adobe\OOBE\PDApp\DWA
                Property(S): ADDLOCAL = ALL
                Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adb196.tmp
                Property(S): REINSTALLMODE = pvoums
                Property(S): REINSTALL = ALL
                Property(S): MSIRESTARTMANAGERCONTROL = Disable
                Property(S): ADOBE_SETUP = 1
                Property(S): USERNAME = Gary & Susan
                Property(S): ProductToBeRegistered = 1
                Property(S): ProductState = 5
                Property(S): PackageCode = {3C0DD3C2-B6EC-46C4-8544-00189BC45D86}
                === Logging stopped: 13/02/2011  12:53:41 ===
                1: 2 2: 0
                1: 2 2: 1
                [    6204] Sun Feb 13 12:53:41 2011  INFO
                *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
                :: END TIMER :: [Payload Operation :{0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}] took 3023.4 miliseconds (3.0234 seconds) DTR = 23.8142 KBPS (0.0232561 MBPS)
                User specified overrideFile:
                [    6204] Sun Feb 13 12:53:42 2011  INFO
                Calling the custom action code for post-repair for payload {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86
                Calling the custom action code for pre-repair for payload {A8798E04-96FF-4564-9157-0D4C89CB794C}
                ::START TIMER:: [Payload Operation :{A8798E04-96FF-4564-9157-0D4C89CB794C}]
                [    3380] Sun Feb 13 12:53:42 2011  INFO
                Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {A8798E04-96FF-4564-9157-0D4C89CB794C}
                Effective AdobeCode for: {A8798E04-96FF-4564-9157-0D4C89CB794C} is {A8798E04-96FF-4564-9157-0D4C89CB794C}
                Repair payload source package: E:\Adobe CS5\payloads\AdobeDynamiclinkSupport5All\Install.db
                [    3380] Sun Feb 13 12:53:43 2011  INFO
                Beginning installation for payload at E:\Adobe CS5\payloads\AdobeDynamiclinkSupport5All\Install.db
                Completing installation for payload at E:\Adobe CS5\payloads\AdobeDynamiclinkSupport5All\Install.db
                UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{A8798E04-96FF-4564-9157-0D4C89CB794C}.db
                [    6204] Sun Feb 13 12:53:44 2011  INFO
                :: END TIMER :: [Payload Operation :{A8798E04-96FF-4564-9157-0D4C89CB794C}] took 2024.29 miliseconds (2.02429 seconds) DTR = 825.967 KBPS (0.806608 MBPS)
                Calling the custom action code for post-repair for payload {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport
                Calling the custom action code for pre-repair for payload {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
                ::START TIMER:: [Payload Operation :{92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}]
                [    1300] Sun Feb 13 12:53:44 2011  INFO
                Installer Operation: ModifyThirdPartyPayloadOperation
                Modify Thirdparty payload
                Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\Microsoft_VC90_CRT_x86_x64.msi
                MsiSourceListAddSource for  E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\Microsoft_VC90_CRT_x86_x64.msi is 0
                MsiSourceListSetInfo with updated name: Microsoft_VC90_CRT_x86_x64.msi, Result: 0
                Payload exists on removable media: E:\
                [    1300] Sun Feb 13 12:53:45 2011  INFO
                Updating Media for package
                Added volume name: CS5 Master Coll1 for diskID: 1 with result: 0
                MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\, Result: 0
                Configuring MSI ProductCode: {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
                Setting AFLPath C:\Program Files (x86)\Common Files\Adobe\Installers\{FBB02B04-C034-4382-A3F6-57416E2752C4}
                MsiConfigureProductEx command line:
                ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress   REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adb19D8.tmp"
                1: 0 2: 0 3: 1252
                1: 0 2: 0 3: 1252
                === Logging started: 13/02/2011  12:53:45 ===
                Message type: 1, Argument: Microsoft_VC90_CRT_x86_x64
                Action 12:53:45: INSTALL.
                Action start 12:53:45: INSTALL.
                Action 12:53:45: AppSearch. Searching for installed applications
                Action start 12:53:45: AppSearch.
                Action ended 12:53:45: AppSearch. Return value 0.
                Action 12:53:45: FindRelatedProducts. Searching for related applications
                Action start 12:53:45: FindRelatedProducts.
                Action ended 12:53:45: FindRelatedProducts. Return value 0.
                Action 12:53:45: ValidateProductID.
                Action start 12:53:45: ValidateProductID.
                Action ended 12:53:45: ValidateProductID. Return value 1.
                Action 12:53:45: WindowsFolder.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812.
                Action start 12:53:45: WindowsFolder.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812.
                Action ended 12:53:45: WindowsFolder.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812. Return value 1.
                Action 12:53:45: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506B F31308B.
                Action start 12:53:45: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506B F31308B.
                Action ended 12:53:45: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506B F31308B. Return value 1.
                Action 12:53:45: CostInitialize. Computing space requirements
                Action start 12:53:45: CostInitialize.
                Action ended 12:53:45: CostInitialize. Return value 1.
                Action 12:53:45: FileCost. Computing space requirements
                Action start 12:53:45: FileCost.
                Action ended 12:53:45: FileCost. Return value 1.
                Action 12:53:45: IsolateComponents.
                Action start 12:53:45: IsolateComponents.
                Action ended 12:53:45: IsolateComponents. Return value 0.
                Action 12:53:45: CostFinalize. Computing space requirements
                Action start 12:53:45: CostFinalize.
                Action ended 12:53:45: CostFinalize. Return value 1.
                Action 12:53:45: SetODBCFolders. Initializing ODBC directories
                Action start 12:53:45: SetODBCFolders.
                Action ended 12:53:45: SetODBCFolders. Return value 0.
                Action 12:53:45: MigrateFeatureStates. Migrating feature states from related applications
                Action start 12:53:45: MigrateFeatureStates.
                Action ended 12:53:45: MigrateFeatureStates. Return value 0.
                Action 12:53:45: InstallValidate. Validating install
                Action start 12:53:45: InstallValidate.
                Action ended 12:53:45: InstallValidate. Return value 1.
                Action 12:53:45: RemoveExistingProducts. Removing applications
                Action start 12:53:45: RemoveExistingProducts.
                Action ended 12:53:45: RemoveExistingProducts. Return value 0.
                Action 12:53:45: InstallInitialize.
                Action start 12:53:45: InstallInitialize.
                [    1300] Sun Feb 13 12:53:46 2011  INFO
                Action ended 12:53:46: InstallInitialize. Return value 1.
                Action 12:53:46: ProcessComponents. Updating component registration
                Action start 12:53:46: ProcessComponents.
                Action 12:53:46: GenerateScript. Generating script operations for action:
                Action ended 12:53:46: ProcessComponents. Return value 1.
                Action 12:53:46: UnpublishComponents. Unpublishing Qualified Components
                Action start 12:53:46: UnpublishComponents.
                Action ended 12:53:46: UnpublishComponents. Return value 0.
                Action 12:53:46: MsiUnpublishAssemblies. Unpublishing assembly information
                Action start 12:53:46: MsiUnpublishAssemblies.
                Action ended 12:53:46: MsiUnpublishAssemblies. Return value 1.
                Action 12:53:46: UnpublishFeatures. Unpublishing product features
                Action start 12:53:46: UnpublishFeatures.
                Action ended 12:53:46: UnpublishFeatures. Return value 1.
                Action 12:53:46: StopServices. Stopping services
                Action start 12:53:46: StopServices.
                Action ended 12:53:46: StopServices. Return value 1.
                Action 12:53:46: DeleteServices. Deleting services
                Action start 12:53:46: DeleteServices.
                Action ended 12:53:46: DeleteServices. Return value 1.
                Action 12:53:46: UnregisterComPlus. Unregistering COM+ Applications and Components
                Action start 12:53:46: UnregisterComPlus.
                Action ended 12:53:46: UnregisterComPlus. Return value 0.
                Action 12:53:46: SelfUnregModules. Unregistering modules
                Action start 12:53:46: SelfUnregModules.
                Action ended 12:53:46: SelfUnregModules. Return value 1.
                Action 12:53:46: UnregisterTypeLibraries. Unregistering type libraries
                Action start 12:53:46: UnregisterTypeLibraries.
                Action ended 12:53:46: UnregisterTypeLibraries. Return value 0.
                Action 12:53:46: RemoveODBC. Removing ODBC components
                Action start 12:53:46: RemoveODBC.
                Action ended 12:53:46: RemoveODBC. Return value 1.
                Action 12:53:46: UnregisterFonts. Unregistering fonts
                Action start 12:53:46: UnregisterFonts.
                Action ended 12:53:46: UnregisterFonts. Return value 1.
                Action 12:53:46: RemoveRegistryValues. Removing system registry values
                Action start 12:53:46: RemoveRegistryValues.
                Action ended 12:53:46: RemoveRegistryValues. Return value 1.
                Action 12:53:46: UnregisterClassInfo. Unregister class servers
                Action start 12:53:46: UnregisterClassInfo.
                Action ended 12:53:46: UnregisterClassInfo. Return value 0.
                Action 12:53:46: UnregisterExtensionInfo. Unregistering extension servers
                Action start 12:53:46: UnregisterExtensionInfo.
                Action ended 12:53:46: UnregisterExtensionInfo. Return value 0.
                Action 12:53:46: UnregisterProgIdInfo. Unregistering program identifiers
                Action start 12:53:46: UnregisterProgIdInfo.
                Action ended 12:53:46: UnregisterProgIdInfo. Return value 0.
                Action 12:53:46: UnregisterMIMEInfo. Unregistering MIME info
                Action start 12:53:46: UnregisterMIMEInfo.
                Action ended 12:53:46: UnregisterMIMEInfo. Return value 0.
                Action 12:53:46: RemoveIniValues. Removing INI file entries
                Action start 12:53:46: RemoveIniValues.
                Action ended 12:53:46: RemoveIniValues. Return value 1.
                Action 12:53:46: RemoveShortcuts. Removing shortcuts
                Action start 12:53:46: RemoveShortcuts.
                Action ended 12:53:46: RemoveShortcuts. Return value 0.
                Action 12:53:46: RemoveEnvironmentStrings. Updating environment strings
                Action start 12:53:46: RemoveEnvironmentStrings.
                Action ended 12:53:46: RemoveEnvironmentStrings. Return value 1.
                Action 12:53:46: RemoveDuplicateFiles. Removing duplicated files
                Action start 12:53:46: RemoveDuplicateFiles.
                Action ended 12:53:46: RemoveDuplicateFiles. Return value 1.
                Action 12:53:46: RemoveFiles. Removing files
                Action start 12:53:46: RemoveFiles.
                Action ended 12:53:46: RemoveFiles. Return value 0.
                Action 12:53:46: RemoveFolders. Removing folders
                Action start 12:53:46: RemoveFolders.
                Action ended 12:53:46: RemoveFolders. Return value 0.
                Action 12:53:46: CreateFolders. Creating folders
                Action start 12:53:46: CreateFolders.
                Action ended 12:53:46: CreateFolders. Return value 0.
                Action 12:53:46: MoveFiles. Moving files
                Action start 12:53:46: MoveFiles.
                Action ended 12:53:46: MoveFiles. Return value 1.
                Action 12:53:46: InstallFiles. Copying new files
                Action start 12:53:46: InstallFiles.
                File: Copying new files,  Directory: ,  Size:
                Action ended 12:53:46: InstallFiles. Return value 1.
                Action 12:53:46: PatchFiles. Patching files
                Action start 12:53:46: PatchFiles.
                Action ended 12:53:46: PatchFiles. Return value 0.
                Action 12:53:46: DuplicateFiles. Creating duplicate files
                Action start 12:53:46: DuplicateFiles.
                Action ended 12:53:46: DuplicateFiles. Return value 1.
                Action 12:53:46: BindImage. Binding executables
                Action start 12:53:46: BindImage.
                Action ended 12:53:46: BindImage. Return value 1.
                Action 12:53:46: CreateShortcuts. Creating shortcuts
                Action start 12:53:46: CreateShortcuts.
                Shortcut: Creating shortcuts
                Action ended 12:53:46: CreateShortcuts. Return value 0.
                Action 12:53:46: RegisterClassInfo. Registering class servers
                Action start 12:53:46: RegisterClassInfo.
                Action ended 12:53:46: RegisterClassInfo. Return value 0.
                Action 12:53:46: RegisterExtensionInfo. Registering extension servers
                Action start 12:53:46: RegisterExtensionInfo.
                Action ended 12:53:46: RegisterExtensionInfo. Return value 0.
                Action 12:53:46: RegisterProgIdInfo. Registering program identifiers
                Action start 12:53:46: RegisterProgIdInfo.
                Action ended 12:53:46: RegisterProgIdInfo. Return value 0.
                Action 12:53:46: RegisterMIMEInfo. Registering MIME info
                Action start 12:53:46: RegisterMIMEInfo.
                Action ended 12:53:46: RegisterMIMEInfo. Return value 0.
                Action 12:53:46: WriteRegistryValues. Writing system registry values
                Action start 12:53:46: WriteRegistryValues.
                Action ended 12:53:46: WriteRegistryValues. Return value 1.
                Action 12:53:46: WriteIniValues. Writing INI file values
                Action start 12:53:46: WriteIniValues.
                Action ended 12:53:46: WriteIniValues. Return value 1.
                Action 12:53:46: WriteEnvironmentStrings. Updating environment strings
                Action start 12:53:46: WriteEnvironmentStrings.
                Action ended 12:53:46: WriteEnvironmentStrings. Return value 1.
                Action 12:53:46: RegisterFonts. Registering fonts
                Action start 12:53:46: RegisterFonts.
                Action ended 12:53:46: RegisterFonts. Return value 1.
                Action 12:53:46: InstallODBC. Installing ODBC components
                Action start 12:53:46: InstallODBC.
                Action ended 12:53:46: InstallODBC. Return value 0.
                Action 12:53:46: RegisterTypeLibraries. Registering type libraries
                Action start 12:53:46: RegisterTypeLibraries.
                Action ended 12:53:46: RegisterTypeLibraries. Return value 0.
                Action 12:53:46: SelfRegModules. Registering modules
                Action start 12:53:46: SelfRegModules.
                Action ended 12:53:46: SelfRegModules. Return value 1.
                Action 12:53:46: RegisterComPlus. Registering COM+ Applications and Components
                Action start 12:53:46: RegisterComPlus.
                Action ended 12:53:46: RegisterComPlus. Return value 0.
                Action 12:53:46: InstallServices. Installing new services
                Action start 12:53:46: InstallServices.
                Action ended 12:53:46: InstallServices. Return value 1.
                Action 12:53:46: StartServices. Starting services
                Action start 12:53:46: StartServices.
                Action ended 12:53:46: StartServices. Return value 1.
                Action 12:53:46: RegisterUser. Registering user
                Action start 12:53:46: RegisterUser.
                Action ended 12:53:46: RegisterUser. Return value 0.
                Action 12:53:46: RegisterProduct. Registering product
                Action start 12:53:46: RegisterProduct.
                Registering product
                Action ended 12:53:46: RegisterProduct. Return value 1.
                Action 12:53:46: PublishComponents. Publishing qualified components
                Action start 12:53:46: PublishComponents.
                Action ended 12:53:46: PublishComponents. Return value 0.
                Action 12:53:46: MsiPublishAssemblies. Publishing assembly information
                Action start 12:53:46: MsiPublishAssemblies.
                Application Context:Publishing assembly information, Assembly Name:
                Action ended 12:53:46: MsiPublishAssemblies. Return value 1.
                Action 12:53:46: PublishFeatures. Publishing product features
                Action start 12:53:46: PublishFeatures.
                Feature: Publishing product features
                Action ended 12:53:46: PublishFeatures. Return value 1.
                Action 12:53:46: PublishProduct. Publishing product information
                Action start 12:53:46: PublishProduct.
                Action ended 12:53:46: PublishProduct. Return value 1.
                Action 12:53:46: InstallFinalize.
                Action start 12:53:46: InstallFinalize.
                Message type: 0, Argument: 0
                Shortcut: ARPPRODUCTICON.exe
                40d8f.msi
                Application Context:Global, Assembly Name:Microsoft.VC90.CRT,version="9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b",processor Architecture="amd64",type="win32"
                Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.CRT,version="9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b ",processorArchitecture="amd64",type="win32-policy"
                Feature: Microsoft_VC90_CRT_x86_
                Message type: 2, Argument: 0
                Action 12:53:46: RollbackCleanup. Removing backup files
                File: C:\Config.Msi\354080.rbf
                File: C:\Config.Msi\354081.rbf
                Message type: 2, Argument: 1
                Action ended 12:53:46: InstallFinalize. Return value 1.
                Action ended 12:53:46: INSTALL. Return value 1.
                Property(S): DiskPrompt = [1]
                Property(S): UpgradeCode = {54AE2BD2-7685-4215-9490-3BBF14C2BBB4}
                Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\
                Property(S): SourcedirProduct = {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
                Property(S): Installed = 2009/03/11 04:02:22
                Property(S): PrimaryVolumeSpaceRemaining = 0
                Property(S): PrimaryVolumeSpaceRequired = 0
                Property(S): PrimaryVolumeSpaceAvailable = 0
                Property(S): OutOfNoRbDiskSpace = 0
                Property(S): OutOfDiskSpace = 0
                Property(S): CostingComplete = 1
                Property(S): ROOTDRIVE = F:\
                Property(S): ACTION = INSTALL
                Property(S): Preselected = 1
                Property(S): QFEUpgrade = 1
                Property(S): UILevel = 2
                Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\Microsoft_VC90_CRT_x86_x64.msi
                Property(S): DATABASE = C:\Windows\Installer\35407a.msi
                Property(S): Privileged = 1
                Property(S): MsiRunningElevated = 1
                [    1300] Sun Feb 13 12:53:47 2011  INFO
                Property(S): RedirectedDllSupport = 2
                Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
                Property(S): MsiNetAssemblySupport = 4.0.30319.1
                Property(S): Date = 13/02/2011
                Property(S): Time = 12:53:47
                Property(S): TTCSupport = 1
                Property(S): ColorBits = 32
                Property(S): TextInternalLeading = 3
                Property(S): TextHeight = 16
                Property(S): BorderSide = 1
                Property(S): BorderTop = 1
                Property(S): CaptionHeight = 22
                Property(S): ScreenY = 768
                Property(S): ScreenX = 1024
                Property(S): SystemLanguageID = 3081
                Property(S): ComputerName = PC
                Property(S): UserLanguageID = 3081
                Property(S): UserSID = S-1-5-21-618155685-1063480468-518450737-1000
                Property(S): LogonUser = Gary & Susan
                Property(S): MsiTrueAdminUser = 1
                Property(S): AdminUser = 1
                Property(S): PhysicalMemory = 8151
                Property(S): Intel = 6
                Property(S): Msix64 = 6
                Property(S): MsiAMD64 = 6
                Property(S): ShellAdvtSupport = 1
                Property(S): OLEAdvtSupport = 1
                Property(S): GPTSupport = 1
                Property(S): VersionNT = 601
                Property(S): ProgramFilesFolder = C:\Program Files (x86)\
                Property(S): ADOBE = C:\Program Files (x86)\Adobe\
                Property(S): TARGETDIR = F:\
                Property(S): ALLUSERSPROFILE = F:\
                Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
                Property(S): AppDataFolder = C:\Users\Gary & Susan\AppData\Roaming\
                Property(S): CommonAppDataFolder = C:\ProgramData\
                Property(S): CommonFiles64Folder = C:\Program Files\Common Files\
                Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
                Property(S): ISYourDataBaseDir = C:\Program Files (x86)\Adobe\My Product Name\Database\
                Property(S): DATABASEDIR = C:\Program Files (x86)\Adobe\My Product Name\Database\
                Property(S): DesktopFolder = C:\Users\Public\Desktop\
                Property(S): FavoritesFolder = C:\Users\Gary & Susan\Favorites\
                Property(S): FontsFolder = C:\Windows\Fonts\
                Property(S): GlobalAssemblyCache = F:\
                Property(S): MY_PRODUCT_NAME = C:\Program Files (x86)\Adobe\My Product Name\
                Property(S): INSTALLDIR = C:\Program Files (x86)\Adobe\My Product Name\
                Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
                Property(S): ISMyCompanyDir = C:\Program Files (x86)\My Company Name\
                Property(S): ISMyProductDir = C:\Program Files (x86)\My Company Name\My Product Name\
                Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
                Property(S): LocalAppDataFolder = C:\Users\Gary & Susan\AppData\Local\
                Property(S): MyPicturesFolder = C:\Users\Gary & Susan\Pictures\
                Property(S): PersonalFolder = C:\Users\Gary & Susan\Documents\
                Property(S): PrimaryVolumePath = F:\
                Property(S): ProgramFiles64Folder = C:\Program Files\
                Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
                Property(S): SendToFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\SendTo\
                Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
                Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
                Property(S): System16Folder = F:\
                Property(S): System64Folder = C:\Windows\system32\
                Property(S): SystemFolder = C:\Windows\SysWOW64\
                Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\
                Property(S): TempFolder = C:\Users\GARY&S~1\AppData\Local\Temp\
                Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
                Property(S): USERPROFILE = F:\
                Property(S): WindowsFolder = C:\Windows\
                Property(S): WindowsVolume = C:\
                Property(S): WinSxsDirectory.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\
                Property(S): payload_ul.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.1_none_99b61f5e8371 c1d4\
                Property(S): payload.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\amd64_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_a17e7c1e\
                Property(S): WinSxsManifests.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\Manifests\
                Property(S): WindowsFolder.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\
                Property(S): WinSxsPolicies.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\Policies\
                Property(S): policydir.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\Policies\amd64_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_7701165b\
                Property(S): policydir_ul.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\amd64_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_7701165b\
                Property(S): ALLUSERS = 1
                Property(S): WinSxsDirectory.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_050 6BF31308B = C:\Windows\winsxs\
                Property(S): payload_ul.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF31 308B = C:\Windows\winsxs\amd64_policy.9.0.microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.1_none_3 da38fdebd0e6822\
                Property(S): WinSxsPolicies.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506 BF31308B = C:\Windows\winsxs\Policies\
                Property(S): policydir.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF313 08B = C:\Windows\winsxs\Policies\amd64_policy.9.0.Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_16f3 e195\
                Property(S): WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506B F31308B = C:\Windows\
                Property(S): ProductCode = {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
                Property(S): ProductName = Microsoft_VC90_CRT_x86_x64
                Property(S): ProductVersion = 1.00.0000
                Property(S): DWUSLINK = CE1C879F4EDBE0A8A9ACB06F8E0B978FAE9CF08F598C9758CE1CB08FFE8CF0C8AE8CF0EF8EAC
                Property(S): ARPURLINFOABOUT = http://www.Adobe.com
                Property(S): PRODUCTLANGUAGE = 0
                Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adb19D8.tmp
                Property(S): PackageCode = {EBEBD87C-43F1-4673-9D38-D8BA645AA1C5}
                === Logging stopped: 13/02/2011  12:53:47 ===
                1: 2 2: 0
                1: 2 2: 1
                [    6204] Sun Feb 13 12:53:47 2011  INFO
                :: END TIMER :: [Payload Operation :{92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}] took 3014.58 miliseconds (3.01458 seconds)
                [    6204] Sun Feb 13 12:53:48 2011  INFO
                Calling the custom action code for post-repair for payload {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64
                Calling the custom action code for pre-repair for payload {8557397C-A42D-486F-97B3-A2CBC2372593}
                ::START TIMER:: [Payload Operation :{8557397C-A42D-486F-97B3-A2CBC2372593}]
                [    6544] Sun Feb 13 12:53:48 2011  INFO
                Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\Microsoft_VC90_ATL_x86_x64.msi
                MsiSourceListAddSource for  E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\Microsoft_VC90_ATL_x86_x64.msi is 0
                MsiSourceListSetInfo with updated name: Microsoft_VC90_ATL_x86_x64.msi, Result: 0
                MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\, Result: 0
                Configuring MSI ProductCode: {8557397C-A42D-486F-97B3-A2CBC2372593}
                ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress   REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adb261A.tmp"
                1: 0 2: 0 3: 1252
                1: 0 2: 0 3: 1252
                === Logging started: 13/02/2011  12:53:48 ===
                Message type: 0, Argument: 1033
                Message type: 1, Argument: Microsoft_VC90_ATL_x86_x64
                Action 12:53:48: INSTALL.
                Action start 12:53:48: INSTALL.
                Action 12:53:48: AppSearch. Searching for installed applications
                Action start 12:53:48: AppSearch.
                Action ended 12:53:48: AppSearch. Return value 0.
                Action 12:53:48: FindRelatedProducts. Searching for related applications
                Action start 12:53:48: FindRelatedProducts.
                Action ended 12:53:48: FindRelatedProducts. Return value 0.
                Action 12:53:48: ValidateProductID.
                Action start 12:53:48: ValidateProductID.
                Action ended 12:53:48: ValidateProductID. Return value 1.
                Action 12:53:48: WindowsFolder.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C.
                Action start 12:53:48: WindowsFolder.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C.
                Action ended 12:53:48: WindowsFolder.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C. Return value 1.
                Action 12:53:48: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA 0CD0479.
                Action start 12:53:48: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA 0CD0479.
                Action ended 12:53:48: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA 0CD0479. Return value 1.
                Action 12:53:48: CostInitialize. Computing space requirements
                Action start 12:53:48: CostInitialize.
                Action ended 12:53:48: CostInitialize. Return value 1.
                Action 12:53:48: FileCost. Computing space requirements
                Action start 12:53:48: FileCost.
                Action ended 12:53:48: FileCost. Return value 1.
                Action 12:53:48: IsolateComponents.
                Action start 12:53:48: IsolateComponents.
                Action ended 12:53:48: IsolateComponents. Return value 0.
                Action 12:53:48: CostFinalize. Computing space requirements
                Action start 12:53:48: CostFinalize.
                Action ended 12:53:48: CostFinalize. Return value 1.
                Action 12:53:48: SetODBCFolders. Initializing ODBC directories
                Action start 12:53:48: SetODBCFolders.
                Action ended 12:53:48: SetODBCFolders. Return value 0.
                Action 12:53:48: MigrateFeatureStates. Migrating feature states from related applications
                Action start 12:53:48: MigrateFeatureStates.
                Action ended 12:53:48: MigrateFeatureStates. Return value 0.
                Action 12:53:48: InstallValidate. Validating install
                Action start 12:53:48: InstallValidate.
                Action ended 12:53:48: InstallValidate. Return value 1.
                Action 12:53:48: RemoveExistingProducts. Removing applications
                Action start 12:53:48: RemoveExistingProducts.
                Action ended 12:53:48: RemoveExistingProducts. Return value 0.
                Action 12:53:48: InstallInitialize.
                Action start 12:53:48: InstallInitialize.
                Action ended 12:53:48: InstallInitialize. Return value 1.
                Action 12:53:48: ProcessComponents. Updating component registration
                Action start 12:53:48: ProcessComponents.
                Action 12:53:48: GenerateScript. Generating script operations for action:
                Action ended 12:53:48: ProcessComponents. Return value 1.
                Action 12:53:48: UnpublishComponents. Unpublishing Qualified Components
                Action start 12:53:48: UnpublishComponents.
                Action ended 12:53:48: UnpublishComponents. Return value 0.
                Action 12:53:48: MsiUnpublishAssemblies. Unpublishing assembly information
                Action start 12:53:48: MsiUnpublishAssemblies.
                Action ended 12:53:48: MsiUnpublishAssemblies. Return value 1.
                Action 12:53:48: UnpublishFeatures. Unpublishing product features
                Action start 12:53:48: UnpublishFeatures.
                Action ended 12:53:48: UnpublishFeatures. Return value 1.
                Action 12:53:48: StopServices. Stopping services
                Action start 12:53:48: StopServices.
                Action ended 12:53:48: StopServices. Return value 1.
                Action 12:53:48: DeleteServices. Deleting services
                Action start 12:53:48: DeleteServices.
                Action ended 12:53:48: DeleteServices. Return value 1.
                Action 12:53:48: UnregisterComPlus. Unregistering COM+ Applications and Components
                Action start 12:53:48: UnregisterComPlus.
                Action ended 12:53:48: UnregisterComPlus. Return value 0.
                Action 12:53:48: SelfUnregModules. Unregistering modules
                Action start 12:53:48: SelfUnregModules.
                Action ended 12:53:48: SelfUnregModules. Return value 1.
                Action 12:53:48: UnregisterTypeLibraries. Unregistering type libraries
                Action start 12:53:48: UnregisterTypeLibraries.
                Action ended 12:53:48: UnregisterTypeLibraries. Return value 0.
                Action 12:53:48: RemoveODBC. Removing ODBC components
                Action start 12:53:48: RemoveODBC.
                Action ended 12:53:48: RemoveODBC. Return value 1.
                Action 12:53:48: UnregisterFonts. Unregistering fonts
                Action start 12:53:48: UnregisterFonts.
                Action ended 12:53:48: UnregisterFonts. Return value 1.
                Action 12:53:48: RemoveRegistryValues. Removing system registry values
                Action start 12:53:48: RemoveRegistryValues.
                Action ended 12:53:48: RemoveRegistryValues. Return value 1.
                Action 12:53:48: UnregisterClassInfo. Unregister class servers
                Action start 12:53:48: UnregisterClassInfo.
                Action ended 12:53:48: UnregisterClassInfo. Return value 0.
                Action 12:53:48: UnregisterExtensionInfo. Unregistering extension servers
                Action start 12:53:48: UnregisterExtensionInfo.
                Action ended 12:53:48: UnregisterExtensionInfo. Return value 0.
                [    6544] Sun Feb 13 12:53:49 2011  INFO
                Action 12:53:49: UnregisterProgIdInfo. Unregistering program identifiers
                Action start 12:53:49: UnregisterProgIdInfo.
                Action ended 12:53:49: UnregisterProgIdInfo. Return value 0.
                Action 12:53:49: UnregisterMIMEInfo. Unregistering MIME info
                Action start 12:53:49: UnregisterMIMEInfo.
                Action ended 12:53:49: UnregisterMIMEInfo. Return value 0.
                Action 12:53:49: RemoveIniValues. Removing INI file entries
                Action start 12:53:49: RemoveIniValues.
                Action ended 12:53:49: RemoveIniValues. Return value 1.
                Action 12:53:49: RemoveShortcuts. Removing shortcuts
                Action start 12:53:49: RemoveShortcuts.
                Action ended 12:53:49: RemoveShortcuts. Return value 0.
                Action 12:53:49: RemoveEnvironmentStrings. Updating environment strings
                Action start 12:53:49: RemoveEnvironmentStrings.
                Action ended 12:53:49: RemoveEnvironmentStrings. Return value 1.
                Action 12:53:49: RemoveDuplicateFiles. Removing duplicated files
                Action start 12:53:49: RemoveDuplicateFiles.
                Action ended 12:53:49: RemoveDuplicateFiles. Return value 1.
                Action 12:53:49: RemoveFiles. Removing files
                Action start 12:53:49: RemoveFiles.
                Action ended 12:53:49: RemoveFiles. Return value 0.
                Action 12:53:49: RemoveFolders. Removing folders
                Action start 12:53:49: RemoveFolders.
                Action ended 12:53:49: RemoveFolders. Return value 0.
                Action 12:53:49: CreateFolders. Creating folders
                Action start 12:53:49: CreateFolders.
                Action ended 12:53:49: CreateFolders. Return value 0.
                Action 12:53:49: MoveFiles. Moving files
                Action start 12:53:49: MoveFiles.
                Action ended 12:53:49: MoveFiles. Return value 1.
                Action 12:53:49: InstallFiles. Copying new files
                Action start 12:53:49: InstallFiles.
                Action ended 12:53:49: InstallFiles. Return value 1.
                Action 12:53:49: PatchFiles. Patching files
                Action start 12:53:49: PatchFiles.
                Action ended 12:53:49: PatchFiles. Return value 0.
                Action 12:53:49: DuplicateFiles. Creating duplicate files
                Action start 12:53:49: DuplicateFiles.
                Action ended 12:53:49: DuplicateFiles. Return value 1.
                Action 12:53:49: BindImage. Binding executables
                Action start 12:53:49: BindImage.
                Action ended 12:53:49: BindImage. Return value 1.
                Action 12:53:49: CreateShortcuts. Creating shortcuts
                Action start 12:53:49: CreateShortcuts.
                Action ended 12:53:49: CreateShortcuts. Return value 0.
                Action 12:53:49: RegisterClassInfo. Registering class servers
                Action start 12:53:49: RegisterClassInfo.
                Action ended 12:53:49: RegisterClassInfo. Return value 0.
                Action 12:53:49: RegisterExtensionInfo. Registering extension servers
                Action start 12:53:49: RegisterExtensionInfo.
                Action ended 12:53:49: RegisterExtensionInfo. Return value 0.
                Action 12:53:49: RegisterProgIdInfo. Registering program identifiers
                Action start 12:53:49: RegisterProgIdInfo.
                Action ended 12:53:49: RegisterProgIdInfo. Return value 0.
                Action 12:53:49: RegisterMIMEInfo. Registering MIME info
                Action start 12:53:49: RegisterMIMEInfo.
                Action ended 12:53:49: RegisterMIMEInfo. Return value 0.
                Action 12:53:49: WriteRegistryValues. Writing system registry values
                Action start 12:53:49: WriteRegistryValues.
                Action ended 12:53:49: WriteRegistryValues. Return value 1.
                Action 12:53:49: WriteIniValues. Writing INI file values
                Action start 12:53:49: WriteIniValues.
                Action ended 12:53:49: WriteIniValues. Return value 1.
                Action 12:53:49: WriteEnvironmentStrings. Updating environment strings
                Action start 12:53:49: WriteEnvironmentStrings.
                Action ended 12:53:49: WriteEnvironmentStrings. Return value 1.
                Action 12:53:49: RegisterFonts. Registering fonts
                Action start 12:53:49: RegisterFonts.
                Action ended 12:53:49: RegisterFonts. Return value 1.
                Action 12:53:49: InstallODBC. Installing ODBC components
                Action start 12:53:49: InstallODBC.
                Action ended 12:53:49: InstallODBC. Return value 0.
                Action 12:53:49: RegisterTypeLibraries. Registering type libraries
                Action start 12:53:49: RegisterTypeLibraries.
                Action ended 12:53:49: RegisterTypeLibraries. Return value 0.
                Action 12:53:49: SelfRegModules. Registering modules
                Action start 12:53:49: SelfRegModules.
                Action ended 12:53:49: SelfRegModules. Return value 1.
                Action 12:53:49: RegisterComPlus. Registering COM+ Applications and Components
                Action start 12:53:49: RegisterComPlus.
                Action ended 12:53:49: RegisterComPlus. Return value 0.
                Action 12:53:49: InstallServices. Installing new services
                Action start 12:53:49: InstallServices.
                Action ended 12:53:49: InstallServices. Return value 1.
                Action 12:53:49: StartServices. Starting services
                Action start 12:53:49: StartServices.
                Action ended 12:53:49: StartServices. Return value 1.
                Action 12:53:49: RegisterUser. Registering user
                Action start 12:53:49: RegisterUser.
                Action ended 12:53:49: RegisterUser. Return value 0.
                Action 12:53:49: RegisterProduct. Registering product
                Action start 12:53:49: RegisterProduct.
                Registering product
                Action ended 12:53:49: RegisterProduct. Return value 1.
                Action 12:53:49: PublishComponents. Publishing qualified components
                Action start 12:53:49: PublishComponents.
                Action ended 12:53:49: PublishComponents. Return value 0.
                Action 12:53:49: MsiPublishAssemblies. Publishing assembly information
                Action start 12:53:49: MsiPublishAssemblies.
                Action ended 12:53:49: MsiPublishAssemblies. Return value 1.
                Action 12:53:49: PublishFeatures. Publishing product features
                Action start 12:53:49: PublishFeatures.
                Action ended 12:53:49: PublishFeatures. Return value 1.
                Action 12:53:49: PublishProduct. Publishing product information
                Action start 12:53:49: PublishProduct.
                Action ended 12:53:49: PublishProduct. Return value 1.
                Action 12:53:49: InstallFinalize.
                Action start 12:53:49: InstallFinalize.
                Action 12:53:49: ProcessComponents. Updating component registration
                Action 12:53:49: RemoveODBC. Removing ODBC components
                40d98.msi
                Application Context:Global, Assembly Name:Microsoft.VC90.ATL,version="9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b",processor Architecture="amd64",type="win32"
                Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.ATL,version="9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b ",processorArchitecture="amd64",type="win32-policy"
                Feature: Microsoft_VC90_ATL_x86_
                Action 12:53:49: RollbackCleanup. Removing backup files
                File: C:\Config.Msi\354089.rbf
                File: C:\Config.Msi\35408a.rbf
                Action ended 12:53:49: InstallFinalize. Return value 1.
                Action ended 12:53:49: INSTALL. Return value 1.
                Property(S): UpgradeCode = {B178CFE7-E127-4205-991D-147FA189D61F}
                Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\
                Property(S): SourcedirProduct = {8557397C-A42D-486F-97B3-A2CBC2372593}
                Property(S): Installed = 2009/03/11 03:58:08
                Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\Microsoft_VC90_ATL_x86_x64.msi
                Property(S): DATABASE = C:\Windows\Installer\354083.msi
                Property(S): Time = 12:53:49
                Property(S): VirtualMemory = 14349
                Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\
                Property(S): WinSxsDirectory.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\
                Property(S): payload_ul.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\amd64_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.1_none_9aefdaaa829e b818\
                Property(S): payload.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\amd64_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_021e6992\
                Property(S): WinSxsManifests.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\Manifests\
                Property(S): WindowsFolder.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\
                Property(S): WinSxsPolicies.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\Policies\
                Property(S): policydir.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\Policies\amd64_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_x-ww_5e4a8be7\
                Property(S): policydir_ul.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\amd64_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_x-ww_5e4a8be7\
                Property(S): WinSxsDirectory.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593 EA0CD0479 = C:\Windows\winsxs\
                Property(S): payload_ul.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA0CD 0479 = C:\Windows\winsxs\amd64_policy.9.0.microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.1_none_3 a15284abf58447e\
                Property(S): WinSxsPolicies.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593E A0CD0479 = C:\Windows\winsxs\Policies\
                Property(S): policydir.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA0CD0 479 = C:\Windows\winsxs\Policies\amd64_policy.9.0.Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_x-ww_fe3d 5721\
                Property(S): WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA 0CD0479 = C:\Windows\
                Property(S): ProductCode = {8557397C-A42D-486F-97B3-A2CBC2372593}
                Property(S): ProductName = Microsoft_VC90_ATL_x86_x64
                Property(S): DWUSLINK = CEFCF71FEE8B30FFC9ACD09FCEDB978F9E9B078F69FC00D8CE9B17F8C9CBF7D899AC806FE9AC
                Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adb261A.tmp
                Property(S): PackageCode = {60C47539-11AA-4C6D-BA88-692C748A2ABC}
                === Logging stopped: 13/02/2011  12:53:49 ===
                1: 2 2: 0
                1: 2 2: 1
                [    6204] Sun Feb 13 12:53:50 2011  INFO
                :: END TIMER :: [Payload Operation :{8557397C-A42D-486F-97B3-A2CBC2372593}] took 2030.72 miliseconds (2.03072 seconds)
                Calling the custom action code for post-repair for payload {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64
                Calling the custom action code for pre-repair for payload {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}
                ::START TIMER:: [Payload Operation :{A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}]
                [    4016] Sun Feb 13 12:53:50 2011  INFO
                Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\Microsoft_VC90_MFC_x86_x64.msi
                MsiSourceListAddSource for  E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\Microsoft_VC90_MFC_x86_x64.msi is 0
                MsiSourceListSetInfo with updated name: Microsoft_VC90_MFC_x86_x64.msi, Result: 0
                MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\, Result: 0
                Configuring MSI ProductCode: {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}
                ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress   REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adb2EC3.tmp"
                [    4016] Sun Feb 13 12:53:51 2011  INFO
                1: 0 2: 0 3: 1252
                [    4016] Sun Feb 13 12:53:52 2011  INFO
                1: 0 2: 0 3: 1252
                === Logging started: 13/02/2011  12:53:52 ===
                Message type: 1, Argument: Microsoft_VC90_MFC_x86_x64
                Action 12:53:52: INSTALL.
                Action start 12:53:52: INSTALL.
                Action 12:53:52: AppSearch. Searching for installed applications
                Action start 12:53:52: AppSearch.
                Action ended 12:53:52: AppSearch. Return value 0.
                Action 12:53:52: FindRelatedProducts. Searching for related applications
                Action start 12:53:52: FindRelatedProducts.
                Action ended 12:53:52: FindRelatedProducts. Return value 0.
                Action 12:53:52: ValidateProductID.
                Action start 12:53:52: ValidateProductID.
                Action ended 12:53:52: ValidateProductID. Return value 1.
                Action 12:53:52: WindowsFolder.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436.
                Action start 12:53:52: WindowsFolder.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436.
                Action ended 12:53:52: WindowsFolder.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436. Return value 1.
                Action 12:53:52: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_90581 91930F7.
                Action start 12:53:52: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_90581 91930F7.
                Action ended 12:53:52: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_90581 91930F7. Return value 1.
                Action 12:53:52: CostInitialize. Computing space requirements
                Action start 12:53:52: CostInitialize.
                Action ended 12:53:52: CostInitialize. Return value 1.
                Action 12:53:52: FileCost. Computing space requirements
                Action start 12:53:52: FileCost.
                Action ended 12:53:52: FileCost. Return value 1.
                Action 12:53:52: IsolateComponents.
                Action start 12:53:52: IsolateComponents.
                Action ended 12:53:52: IsolateComponents. Return value 0.
                Action 12:53:52: CostFinalize. Computing space requirements
                Action start 12:53:52: CostFinalize.
                Action ended 12:53:52: CostFinalize. Return value 1.
                Action 12:53:52: SetODBCFolders. Initializing ODBC directories
                Action start 12:53:52: SetODBCFolders.
                Action ended 12:53:52: SetODBCFolders. Return value 0.
                Action 12:53:52: MigrateFeatureStates. Migrating feature states from related applications
                Action start 12:53:52: MigrateFeatureStates.
                Action ended 12:53:52: MigrateFeatureStates. Return value 0.
                Action 12:53:52: InstallValidate. Validating install
                Action start 12:53:52: InstallValidate.
                Action ended 12:53:52: InstallValidate. Return value 1.
                Action 12:53:52: RemoveExistingProducts. Removing applications
                Action start 12:53:52: RemoveExistingProducts.
                Action ended 12:53:52: RemoveExistingProducts. Return value 0.
                Action 12:53:52: InstallInitialize.
                Action start 12:53:52: InstallInitialize.
                Action ended 12:53:52: InstallInitialize. Return value 1.
                Action 12:53:52: ProcessComponents. Updating component registration
                Action start 12:53:52: ProcessComponents.
                Action 12:53:52: GenerateScript. Generating script operations for action:
                Action ended 12:53:52: ProcessComponents. Return value 1.
                Action 12:53:52: UnpublishComponents. Unpublishing Qualified Components
                Action start 12:53:52: UnpublishComponents.
                Action ended 12:53:52: UnpublishComponents. Return value 0.
                Action 12:53:52: MsiUnpublishAssemblies. Unpublishing assembly information
                Action start 12:53:52: MsiUnpublishAssemblies.
                Action ended 12:53:52: MsiUnpublishAssemblies. Return value 1.
                Action 12:53:52: UnpublishFeatures. Unpublishing product features
                Action start 12:53:52: UnpublishFeatures.
                Action ended 12:53:52: UnpublishFeatures. Return value 1.
                Action 12:53:52: StopServices. Stopping services
                Action start 12:53:52: StopServices.
                Action ended 12:53:52: StopServices. Return value 1.
                Action 12:53:52: DeleteServices. Deleting services
                Action start 12:53:52: DeleteServices.
                Action ended 12:53:52: DeleteServices. Return value 1.
                Action 12:53:52: UnregisterComPlus. Unregistering COM+ Applications and Components
                Action start 12:53:52: UnregisterComPlus.
                Action ended 12:53:52: UnregisterComPlus. Return value 0.
                Action 12:53:52: SelfUnregModules. Unregistering modules
                Action start 12:53:52: SelfUnregModules.
                Action ended 12:53:52: SelfUnregModules. Return value 1.
                Action 12:53:52: UnregisterTypeLibraries. Unregistering type libraries
                Action start 12:53:52: UnregisterTypeLibraries.
                Action ended 12:53:52: UnregisterTypeLibraries. Return value 0.
                Action 12:53:52: RemoveODBC. Removing ODBC components
                Action start 12:53:52: RemoveODBC.
                Action ended 12:53:52: RemoveODBC. Return value 1.
                Action 12:53:52: UnregisterFonts. Unregistering fonts
                Action start 12:53:52: UnregisterFonts.
                Action ended 12:53:52: UnregisterFonts. Return value 1.
                Action 12:53:52: RemoveRegistryValues. Removing system registry values
                Action start 12:53:52: RemoveRegistryValues.
                Action ended 12:53:52: RemoveRegistryValues. Return value 1.
                Action 12:53:52: UnregisterClassInfo. Unregister class servers
                Action start 12:53:52: UnregisterClassInfo.
                Action ended 12:53:52: UnregisterClassInfo. Return value 0.
                Action 12:53:52: UnregisterExtensionInfo. Unregistering extension servers
                Action start 12:53:52: UnregisterExtensionInfo.
                Action ended 12:53:52: UnregisterExtensionInfo. Return value 0.
                Action 12:53:52: UnregisterProgIdInfo. Unregistering program identifiers
                Action start 12:53:52: UnregisterProgIdInfo.
                Action ended 12:53:52: UnregisterProgIdInfo. Return value 0.
                Action 12:53:52: UnregisterMIMEInfo. Unregistering MIME info
                Action start 12:53:52: UnregisterMIMEInfo.
                Action ended 12:53:52: UnregisterMIMEInfo. Return value 0.
                Action 12:53:52: RemoveIniValues. Removing INI file entries
                Action start 12:53:52: RemoveIniValues.
                Action ended 12:53:52: RemoveIniValues. Return value 1.
                Action 12:53:52: RemoveShortcuts. Removing shortcuts
                Action start 12:53:52: RemoveShortcuts.
                Action ended 12:53:52: RemoveShortcuts. Return value 0.
                Action 12:53:52: RemoveEnvironmentStrings. Updating environment strings
                Action start 12:53:52: RemoveEnvironmentStrings.
                Action ended 12:53:52: RemoveEnvironmentStrings. Return value 1.
                Action 12:53:52: RemoveDuplicateFiles. Removing duplicated files
                Action start 12:53:52: RemoveDuplicateFiles.
                Action ended 12:53:52: RemoveDuplicateFiles. Return value 1.
                Action 12:53:52: RemoveFiles. Removing files
                Action start 12:53:52: RemoveFiles.
                Action ended 12:53:52: RemoveFiles. Return value 0.
                Action 12:53:52: RemoveFolders. Removing folders
                Action start 12:53:52: RemoveFolders.
                Action ended 12:53:52: RemoveFolders. Return value 0.
                Action 12:53:52: CreateFolders. Creating folders
                Action start 12:53:52: CreateFolders.
                Action ended 12:53:52: CreateFolders. Return value 0.
                Action 12:53:52: MoveFiles. Moving files
                Action start 12:53:52: MoveFiles.
                Action ended 12:53:52: MoveFiles. Return value 1.
                Action 12:53:52: InstallFiles. Copying new files
                Action start 12:53:52: InstallFiles.
                Action ended 12:53:52: InstallFiles. Return value 1.
                Action 12:53:52: PatchFiles. Patching files
                Action start 12:53:52: PatchFiles.
                Action ended 12:53:52: PatchFiles. Return value 0.
                Action 12:53:52: DuplicateFiles. Creating duplicate files
                Action start 12:53:52: DuplicateFiles.
                Action ended 12:53:52: DuplicateFiles. Return value 1.
                Action 12:53:52: BindImage. Binding executables
                Action start 12:53:52: BindImage.
                Action ended 12:53:52: BindImage. Return value 1.
                Action 12:53:52: CreateShortcuts. Creating shortcuts
                Action start 12:53:52: CreateShortcuts.
                Action ended 12:53:52: CreateShortcuts. Return value 0.
                Action 12:53:52: RegisterClassInfo. Registering class servers
                Action start 12:53:52: RegisterClassInfo.
                Action ended 12:53:52: RegisterClassInfo. Return value 0.
                Action 12:53:52: RegisterExtensionInfo. Registering extension servers
                Action start 12:53:52: RegisterExtensionInfo.
                Action ended 12:53:52: RegisterExtensionInfo. Return value 0.
                Action 12:53:52: RegisterProgIdInfo. Registering program identifiers
                Action start 12:53:52: RegisterProgIdInfo.
                Action ended 12:53:52: RegisterProgIdInfo. Return value 0.
                Action 12:53:52: RegisterMIMEInfo. Registering MIME info
                Action start 12:53:52: RegisterMIMEInfo.
                Action ended 12:53:52: RegisterMIMEInfo. Return value 0.
                Action 12:53:52: WriteRegistryValues. Writing system registry values
                Action start 12:53:52: WriteRegistryValues.
                Action ended 12:53:52: WriteRegistryValues. Return value 1.
                Action 12:53:52: WriteIniValues. Writing INI file values
                Action start 12:53:52: WriteIniValues.
                Action ended 12:53:52: WriteIniValues. Return value 1.
                Action 12:53:52: WriteEnvironmentStrings. Updating environment strings
                Action start 12:53:52: WriteEnvironmentStrings.
                Action ended 12:53:52: WriteEnvironmentStrings. Return value 1.
                Action 12:53:52: RegisterFonts. Registering fonts
                Action start 12:53:52: RegisterFonts.
                Action ended 12:53:52: RegisterFonts. Return value 1.
                Action 12:53:52: InstallODBC. Installing ODBC components
                Action start 12:53:52: InstallODBC.
                Action ended 12:53:52: InstallODBC. Return value 0.
                Action 12:53:52: RegisterTypeLibraries. Registering type libraries
                Action start 12:53:52: RegisterTypeLibraries.
                Action ended 12:53:52: RegisterTypeLibraries. Return value 0.
                Action 12:53:52: SelfRegModules. Registering modules
                Action start 12:53:52: SelfRegModules.
                Action ended 12:53:52: SelfRegModules. Return value 1.
                Action 12:53:52: RegisterComPlus. Registering COM+ Applications and Components
                Action start 12:53:52: RegisterComPlus.
                Action ended 12:53:52: RegisterComPlus. Return value 0.
                Action 12:53:52: InstallServices. Installing new services
                Action start 12:53:52: InstallServices.
                Action ended 12:53:52: InstallServices. Return value 1.
                Action 12:53:52: StartServices. Starting services
                Action start 12:53:52: StartServices.
                Action ended 12:53:52: StartServices. Return value 1.
                Action 12:53:52: RegisterUser. Registering user
                Action start 12:53:52: RegisterUser.
                Action ended 12:53:52: RegisterUser. Return value 0.
                Action 12:53:52: RegisterProduct. Registering product
                Action start 12:53:52: RegisterProduct.
                Registering product
                Action ended 12:53:52: RegisterProduct. Return value 1.
                Action 12:53:52: PublishComponents. Publishing qualified components
                Action start 12:53:52: PublishComponents.
                Action ended 12:53:52: PublishComponents. Return value 0.
                Action 12:53:52: MsiPublishAssemblies. Publishing assembly information
                Action start 12:53:52: MsiPublishAssemblies.
                Action ended 12:53:52: MsiPublishAssemblies. Return value 1.
                Action 12:53:52: PublishFeatures. Publishing product features
                Action start 12:53:52: PublishFeatures.
                Action ended 12:53:52: PublishFeatures. Return value 1.
                Action 12:53:52: PublishProduct. Publishing product information
                Action start 12:53:52: PublishProduct.
                Action ended 12:53:52: PublishProduct. Return value 1.
                Action 12:53:52: InstallFinalize.
                Action start 12:53:52: InstallFinalize.
                40da1.msi
                Application Context:Global, Assembly Name:Microsoft.VC90.MFC,version="9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b",processor Architecture="amd64",type="win32"
                Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.MFC,version="9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b ",processorArchitecture="amd64",type="win32-policy"
                Feature: Microsoft_VC90_MFC_x86_
                Action 12:53:52: RollbackCleanup. Removing backup files
                File: C:\Config.Msi\354092.rbf
                File: C:\Config.Msi\354093.rbf
                Action ended 12:53:52: InstallFinalize. Return value 1.
                Action ended 12:53:52: INSTALL. Return value 1.
                Property(S): UpgradeCode = {D27B3F91-AF97-4C28-90D0-9243BD36B1CE}
                Property(S): SourcedirProduct = {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}
                Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\
                Property(S): Installed = 2009/03/11 04:06:40
                Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\Microsoft_VC90_MFC_x86_x64.msi
                Property(S): DATABASE = C:\Windows\Installer\35408c.msi
                Property(S): Time = 12:53:52
                Property(S): VirtualMemory = 14347
                Property(S): RecentFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Recent\
                Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\
                Property(S): WinSxsDirectory.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\
                Property(S): payload_ul.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\amd64_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.1_none_951ab4128654 b0c9\
                Property(S): payload.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\amd64_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_7264ef23\
                Property(S): WinSxsManifests.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\Manifests\
                Property(S): WindowsFolder.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\
                Property(S): WinSxsPolicies.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\Policies\
                Property(S): policydir.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\Policies\amd64_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_x-ww_0eb49216\
                Property(S): policydir_ul.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\amd64_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_x-ww_0eb49216\
                Property(S): WinSxsDirectory.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_905 8191930F7 = C:\Windows\winsxs\
                Property(S): payload_ul.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_90581919 30F7 = C:\Windows\winsxs\amd64_policy.9.0.microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.1_none_3 624aa14c1dce505\
                Property(S): WinSxsPolicies.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_9058 191930F7 = C:\Windows\winsxs\Policies\
                Property(S): policydir.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_905819193 0F7 = C:\Windows\winsxs\Policies\amd64_policy.9.0.Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_x-ww_aea7 5d50\
                Property(S): WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_90581 91930F7 = C:\Windows\
                Property(S): ProductCode = {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}
                Property(S): ProductName = Microsoft_VC90_MFC_x86_x64
                [    4016] Sun Feb 13 12:53:53 2011  INFO
                Property(S): DWUSLINK = CECCB788E98CF7E89EAC97BF99EB978FEE8BF08F69BCD7CFCEBC7798696BC0BF497CA0CFBEAC
                Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adb2EC3.tmp
                Property(S): PackageCode = {C90E5245-A463-4F12-854D-D812F26436F2}
                === Logging stopped: 13/02/2011  12:53:53 ===
                1: 2 2: 0
                1: 2 2: 1
                [    6204] Sun Feb 13 12:53:53 2011  INFO
                :: END TIMER :: [Payload Operation :{A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}] took 3032.1 miliseconds (3.0321 seconds) DTR = 21.1075 KBPS (0.0206128 MBPS)
                Calling the custom action code for post-repair for payload {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64
                Calling the custom action code for pre-repair for payload {3BF96AC2-0CA1-11DF-B07B-459956D89593}
                ::START TIMER:: [Payload Operation :{3BF96AC2-0CA1-11DF-B07B-459956D89593}]
                [    3104] Sun Feb 13 12:53:53 2011  INFO
                Repairing third party payload with source: E:\Adobe CS5\payloads\AdobeHelp\AIRInstallerRunner.exe
                Third party application path:E:\Adobe CS5\payloads\AdobeHelp\AIRInstallerRunner.exe
                CommandLine: -airAppPath AdobeHelp.air -airRuntime AdobeAIRInstaller.exe -eulaAccepted -programMenu -silent
                [    6204] Sun Feb 13 12:54:00 2011  INFO
                :: END TIMER :: [Payload Operation :{3BF96AC2-0CA1-11DF-B07B-459956D89593}] took 7029.74 miliseconds (7.02974 seconds) DTR = 0.569011 KBPS (0.000555675 MBPS)
                Calling the custom action code for post-repair for payload {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp
                [    6204] Sun Feb 13 12:54:00 2011  WARN
                Warning: {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
                Calling the custom action code for pre-repair for payload {F6FA54C9-3E8F-4416-905C-DA5398DF9640}
                ::START TIMER:: [Payload Operation :{F6FA54C9-3E8F-4416-905C-DA5398DF9640}]
                [    2580] Sun Feb 13 12:54:00 2011  INFO
                Repairing third party payload with source: E:\Adobe CS5\payloads\AdobeAIR1.5.3-mul\AdobeAIRInstaller.exe
                Third party application path:E:\Adobe CS5\payloads\AdobeAIR1.5.3-mul\AdobeAIRInstaller.exe
                CommandLine: -silent
                [    6204] Sun Feb 13 12:54:03 2011  INFO
                :: END TIMER :: [Payload Operation :{F6FA54C9-3E8F-4416-905C-DA5398DF9640}] took 3028.74 miliseconds (3.02874 seconds)
                Calling the custom action code for post-repair for payload {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR
                Calling the custom action code for pre-repair for payload {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A}
                ::START TIMER:: [Payload Operation :{03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A}]
                [    6708] Sun Feb 13 12:54:03 2011  INFO
                Repairing third party payload with source: E:\Adobe CS5\payloads\AdobeAMP1.8-mul\AdobeAIRInstaller.exe
                Third party application path:E:\Adobe CS5\payloads\AdobeAMP1.8-mul\AdobeAIRInstaller.exe
                CommandLine: -silent -eulaAccepted -programMenu adobe_media_player.air
                [    6204] Sun Feb 13 12:54:08 2011  INFO
                :: END TIMER :: [Payload Operation :{03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A}] took 5038.27 miliseconds (5.03827 seconds)
                [    6204] Sun Feb 13 12:54:09 2011  INFO
                Calling the custom action code for post-repair for payload {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player
                Calling the custom action code for pre-repair for payload {7E5AA19B-0B85-4f44-BA26-728851489200}
                ::START TIMER:: [Payload Operation :{7E5AA19B-0B85-4f44-BA26-728851489200}]
                [    7028] Sun Feb 13 12:54:09 2011  INFO
                Repairing third party payload with source: E:\Adobe CS5\payloads\AdobeFlashPlayer10_axRel_mul\AdobeFlashPlayer10_axRel_mul.msi
                Installing payload
                Attempting to install package from:E:\Adobe CS5\payloads\AdobeFlashPlayer10_axRel_mul\AdobeFlashPlayer10_axRel_mul.msi
                [    7028] Sun Feb 13 12:54:10 2011  INFO
                Command line arguments:  /UILevel=2  REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress
                1: 0 2: 1033 3: 1252
                === Logging started: 13/02/2011  12:54:10 ===
                Message type: 1, Argument: Adobe Flash Player 10 ActiveX
                Action 12:54:10: INSTALL.
                Action start 12:54:10: INSTALL.
                Action 12:54:10: ISSetAllUsers.
                Action start 12:54:10: ISSetAllUsers.
                InstallShield 12:54:10: Begin SetAllUsers()
                InstallShield 12:54:10: Getting records from Upgrade table
                InstallShield 12:54:10: UpgradeCode: {42463807-970B-4257-BC95-5C348D61DF1C}    MinVersion: 6.0.0.0    MaxVersion: 10.1.52.14    Language:     Attributes: 769
                InstallShield 12:54:10: No related products for UpgradeCode {42463807-970B-4257-BC95-5C348D61DF1C} found
                InstallShield 12:54:10: UpgradeCode: {91ACC36E-CB92-44F0-AF4E-0BACC033F7F1}    MinVersion:     MaxVersion: 10.1.52.14    Language:     Attributes: 257
                InstallShield 12:54:10: No related products for UpgradeCode {91ACC36E-CB92-44F0-AF4E-0BACC033F7F1} found
                InstallShield 12:54:10: UpgradeCode: {ECA98E30-EB7E-47D1-B47F-B3BEC081B7D8}    MinVersion:     MaxVersion: 10.1.52.14    Language:     Attributes: 257
                InstallShield 12:54:10: No related products for UpgradeCode {ECA98E30-EB7E-47D1-B47F-B3BEC081B7D8} found
                InstallShield 12:54:10: End SetAllUsers()
                Action ended 12:54:10: ISSetAllUsers. Return value 1.
                Action 12:54:10: AppSearch. Searching for installed applications
                Action start 12:54:10: AppSearch.
                Action ended 12:54:10: AppSearch. Return value 0.
                Action 12:54:10: LaunchConditions. Evaluating launch conditions
                Action start 12:54:10: LaunchConditions.
                Action ended 12:54:10: LaunchConditions. Return value 1.
                Action 12:54:10: FindRelatedProducts. Searching for related applications
                Action start 12:54:10: FindRelatedProducts.
                Action ended 12:54:10: FindRelatedProducts. Return value 1.
                Action 12:54:10: ValidateProductID.
                Action start 12:54:10: ValidateProductID.
                Action ended 12:54:10: ValidateProductID. Return value 1.
                Action 12:54:10: CostInitialize. Computing space requirements
                Action start 12:54:10: CostInitialize.
                Action ended 12:54:10: CostInitialize. Return value 1.
                Action 12:54:10: FileCost. Computing space requirements
                Action start 12:54:10: FileCost.
                Action ended 12:54:10: FileCost. Return value 1.
                Action 12:54:10: IsolateComponents.
                Action start 12:54:10: IsolateComponents.
                Action ended 12:54:10: IsolateComponents. Return value 0.
                Action 12:54:10: CostFinalize. Computing space requirements
                Action start 12:54:10: CostFinalize.
                Action ended 12:54:10: CostFinalize. Return value 1.
                Action 12:54:10: SetARPINSTALLLOCATION.
                Action start 12:54:10: SetARPINSTALLLOCATION.
                Action ended 12:54:10: SetARPINSTALLLOCATION. Return value 1.
                Action 12:54:10: SetODBCFolders. Initializing ODBC directories
                Action start 12:54:10: SetODBCFolders.
                Action ended 12:54:10: SetODBCFolders. Return value 0.
                Action 12:54:10: MigrateFeatureStates. Migrating feature states from related applications
                Action start 12:54:10: MigrateFeatureStates.
                Action ended 12:54:10: MigrateFeatureStates. Return value 0.
                Action 12:54:10: InstallValidate. Validating install
                Action start 12:54:10: InstallValidate.
                Action ended 12:54:10: InstallValidate. Return value 1.
                Action 12:54:10: RemoveExistingProducts. Removing applications
                Action start 12:54:10: RemoveExistingProducts.
                Action ended 12:54:10: RemoveExistingProducts. Return value 0.
                Action 12:54:10: InstallInitialize.
                Action start 12:54:10: InstallInitialize.
                Action ended 12:54:10: InstallInitialize. Return value 1.
                Action 12:54:10: CallExeUninstaller.
                Action start 12:54:10: CallExeUninstaller.
                Action 12:54:10: GenerateScript. Generating script operations for action:
                CallExeUninstaller
                Action ended 12:54:10: CallExeUninstaller. Return value 1.
                Action 12:54:10: MakePropsAvailable.
                Action start 12:54:10: MakePropsAvailable.
                Action ended 12:54:10: MakePropsAvailable. Return value 1.
                Action 12:54:10: AllocateRegistrySpace. Allocating registry space
                Action start 12:54:10: AllocateRegistrySpace.
                Action ended 12:54:10: AllocateRegistrySpace. Return value 1.
                Action 12:54:10: ProcessComponents. Updating component registration
                Action start 12:54:10: ProcessComponents.
                Action ended 12:54:10: ProcessComponents. Return value 1.
                Action 12:54:10: UnpublishComponents. Unpublishing Qualified Components
                Action start 12:54:10: UnpublishComponents.
                Action ended 12:54:10: UnpublishComponents. Return value 0.
                Action 12:54:10: UnpublishFeatures. Unpublishing product features
                Action start 12:54:10: UnpublishFeatures.
                Action ended 12:54:10: UnpublishFeatures. Return value 1.
                Action 12:54:10: StopServices. Stopping services
                Action start 12:54:10: StopServices.
                Action ended 12:54:10: StopServices. Return value 1.
                Action 12:54:10: DeleteServices. Deleting services
                Action start 12:54:10: DeleteServices.
                Action ended 12:54:10: DeleteServices. Return value 1.
                Action 12:54:10: UnregisterComPlus. Unregistering COM+ Applications and Components
                Action start 12:54:10: UnregisterComPlus.
                Action ended 12:54:10: UnregisterComPlus. Return value 0.
                Action 12:54:10: SelfUnregModules. Unregistering modules
                Action start 12:54:10: SelfUnregModules.
                Action ended 12:54:10: SelfUnregModules. Return value 1.
                Action 12:54:10: UnregisterTypeLibraries. Unregistering type libraries
                Action start 12:54:10: UnregisterTypeLibraries.
                Action ended 12:54:10: UnregisterTypeLibraries. Return value 0.
                Action 12:54:10: RemoveODBC. Removing ODBC components
                Action start 12:54:10: RemoveODBC.
                Action ended 12:54:10: RemoveODBC. Return value 1.
                Action 12:54:10: UnregisterFonts. Unregistering fonts
                Action start 12:54:10: UnregisterFonts.
                Action ended 12:54:10: UnregisterFonts. Return value 1.
                Action 12:54:10: RemoveRegistryValues. Removing system registry values
                Action start 12:54:10: RemoveRegistryValues.
                Action ended 12:54:10: RemoveRegistryValues. Return value 1.
                Action 12:54:10: UnregisterClassInfo. Unregister class servers
                Action start 12:54:10: UnregisterClassInfo.
                Action ended 12:54:10: UnregisterClassInfo. Return value 0.
                Action 12:54:10: UnregisterExtensionInfo. Unregistering extension servers
                Action start 12:54:10: UnregisterExtensionInfo.
                Action ended 12:54:10: UnregisterExtensionInfo. Return value 0.
                Action 12:54:10: UnregisterProgIdInfo. Unregistering program identifiers
                Action start 12:54:10: UnregisterProgIdInfo.
                Action ended 12:54:10: UnregisterProgIdInfo. Return value 0.
                Action 12:54:10: UnregisterMIMEInfo. Unregistering MIME info
                Action start 12:54:10: UnregisterMIMEInfo.
                Action ended 12:54:10: UnregisterMIMEInfo. Return value 0.
                Action 12:54:10: RemoveIniValues. Removing INI file entries
                Action start 12:54:10: RemoveIniValues.
                Action ended 12:54:10: RemoveIniValues. Return value 1.
                Action 12:54:10: RemoveShortcuts. Removing shortcuts
                Action start 12:54:10: RemoveShortcuts.
                Action ended 12:54:10: RemoveShortcuts. Return value 0.
                Action 12:54:10: RemoveEnvironmentStrings. Updating environment strings
                Action start 12:54:10: RemoveEnvironmentStrings.
                Action ended 12:54:10: RemoveEnvironmentStrings. Return value 1.
                Action 12:54:10: RemoveDuplicateFiles. Removing duplicated files
                Action start 12:54:10: RemoveDuplicateFiles.
                Action ended 12:54:10: RemoveDuplicateFiles. Return value 1.
                Action 12:54:10: RemoveFolders. Removing folders
                Action start 12:54:10: RemoveFolders.
                Action ended 12:54:10: RemoveFolders. Return value 1.
                Action 12:54:10: CreateFolders. Creating folders
                Action start 12:54:10: CreateFolders.
                Action ended 12:54:10: CreateFolders. Return value 1.
                Action 12:54:10: MoveFiles. Moving files
                Action start 12:54:10: MoveFiles.
                Action ended 12:54:10: MoveFiles. Return value 1.
                Action 12:54:10: InstallFiles. Copying new files
                Action start 12:54:10: InstallFiles.
                Action ended 12:54:10: InstallFiles. Return value 1.
                Action 12:54:10: NewCustomAction1.
                Action start 12:54:10: NewCustomAction1.
                Error 2753.The File 'InstallAX.exe' is not marked for installation.
                Action ended 12:54:10: NewCustomAction1. Return value 3.
                [    7028] Sun Feb 13 12:54:11 2011  INFO
                Action ended 12:54:11: INSTALL. Return value 3.
                Property(S): UpgradeCode = {42463807-970B-4257-BC95-5C348D61DF1C}
                Property(S): ProductCode = {6E9EF98E-259E-416D-B5F8-0ABDB99942CE}
                Property(S): SourcedirProduct = {6E9EF98E-259E-416D-B5F8-0ABDB99942CE}
                Property(S): SOURCEDIR = E:\Adobe CS5\payloads\AdobeFlashPlayer10_axRel_mul\
                Property(S): REMOVE = ALL
                Property(S): MACROMED = C:\Windows\SysWOW64\Macromed\
                Property(S): FLASH = C:\Windows\SysWOW64\Macromed\Flash\
                Property(S): INSTALLDIR = C:\Windows\SysWOW64\Macromed\Flash\
                Property(S): SourceDir = E:\Adobe CS5\payloads\AdobeFlashPlayer10_axRel_mul\
                Property(S): OriginalDatabase = E:\Adobe CS5\payloads\AdobeFlashPlayer10_axRel_mul\AdobeFlashPlayer10_axRel_mul.msi
                Property(S): DATABASE = C:\Windows\Installer\354095.msi
                Property(S): Time = 12:54:11
                Property(S): ISCHECKFORPRODUCTUPDATES = 1
                Property(S): ApplicationUsers = AllUsers
                Property(S): AgreeToLicense = No
                Property(S): _IsMaintenance = Change
                Property(S): RestartManagerOption = CloseRestart
                Property(S): IS_SQLSERVER_USERNAME = sa
                Property(S): IS_SQLSERVER_AUTHENTICATION = 0
                Property(S): SetupType = Typical
                Property(S): _IsSetupTypeMin = Typical
                Property(S): Display_IsBitmapDlg = 1
                Property(S): ProductName = Adobe Flash Player 10 ActiveX
                Property(S): ARPHELPLINK = http://www.adobe.com/go/flashplayer_support/
                Property(S): ARPNOMODIFY = 1
                Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
                Property(S): ARPURLINFOABOUT = http://www.adobe.com
                Property(S): DWUSINTERVAL = 30
                Property(S): DWUSLINK = CECCA75FE9CBA098D9ACE02FFEDB978FBEECA78F69BBE0B8CE8BA7CFE97CF0AFCEBCE08FD9AC
                Property(S): DefaultUIFont = Tahoma8
                Property(S): DialogCaption = InstallShield for Windows Installer
                Property(S): DisplayNameCustom = Custom
                Property(S): DisplayNameMinimal = Minimal
                Property(S): DisplayNameTypical = Typical
                Property(S): ErrorDialog = SetupError
                Property(S): INSTALLLEVEL = 100
                Property(S): ISSCRIPT_VERSION_MISSING = The InstallScript engine is missing from this machine.  If available, please run ISScript.msi, or contact your support personnel for further assistance.
                Property(S): ISVROOT_PORT_NO = 0
                Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
                Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
                Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
                Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
                Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
                Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
                Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
                Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
                Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
                Property(S): InstallChoice = AR
                Property(S): Manufacturer = Adobe Systems, Inc.
                Property(S): MsiLogging = voicewarmupx
                Property(S): NewProperty2 = 0
                Property(S): NewProperty3 = 0
                Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
                Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
                Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
                Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
                Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
                Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
                Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
                Property(S): PROGMSG_IIS_CREATEWEBSITE = Creating IIS website %s
                Property(S): PROGMSG_IIS_CREATEWEBSITES = Creating IIS websites...
                Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
                Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
                Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
                Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
                Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
                Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
                Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
                Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
                Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
                Property(S): PROGMSG_IIS_REMOVEWEBSITES = Removing IIS websites...
                Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
                Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
                Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
                Property(S): ProductID = none
                Property(S): ProductLanguage = 1033
                Property(S): ProductVersion = 10.1.52.14
                Property(S): ProgressType0 = install
                Property(S): ProgressType1 = Installing
                Property(S): ProgressType2 = installed
                Property(S): ProgressType3 = installs
                Property(S): RebootYesNo = Yes
                Property(S): ReinstallModeText = omus
                Property(S): SHOWLAUNCHPROGRAM = 0
                Property(S): SecureCustomProperties = ISACTIONPROP1;ISACTIONPROP2;ISACTIONPROP3;SUPPORTDIR
                Property(S): UNINSTALLER_EXE = [SystemFolder]\Macromed\Flash\uninstall_activeX.exe
                Property(S): RemoveFilesCA = C:\Windows\SysWOW64\Macromed\Flash\
                Property(S): ARPINSTALLLOCATION = C:\Windows\SysWOW64\Macromed\Flash\
                Property(S): VirtualMemory = 14352
                Property(S): USERNAME = Gary & Susan
                Property(S): PrintHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
                Property(S): NetHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
                Property(S): RemoteAdminTS = 1
                Property(S): MsiNTSuitePersonal = 1
                Property(S): MsiNTProductType = 1
                Property(S): ServicePackLevelMinor = 0
                Property(S): ServicePackLevel = 0
                Property(S): WindowsBuild = 7600
                Property(S): VersionNT64 = 601
                Property(S): VersionMsi = 5.00
                Property(S): VersionDatabase = 110
                Property(S): MsiSystemRebootPending = 1
                Property(S): CURRENTMEDIAVOLUMELABEL = CS5 Master Coll1
                Property(S): CLIENTPROCESSID = 5888
                Property(S): MSICLIENTUSESEXTERNALUI = 1
                Property(S): CLIENTUILEVEL = 3
                Property(S): CURRENTDIRECTORY = C:\Users\Gary & Susan\AppData\Local\Adobe\OOBE\PDApp\DWA
                Property(S): REBOOT = ReallySuppress
                Property(S): REINSTALLMODE = pvoums
                Property(S): REINSTALL = ALL
                Property(S): /UILEVEL = 2
                Property(S): PackagecodeChanging = 1
                Property(S): ProductState = -1
                Property(S): PackageCode = {8C02D971-B819-4CCC-940B-1F1E34164635}
                Property(S): MsiLogFileLocation = C:\Users\GARY&S~1\AppData\Local\Temp\MSI67a2f.LOG
                === Logging stopped: 13/02/2011  12:54:11 ===
                1: 2 2: 0
                1: 2 2: 1
                Installation result: 1603
                [    6204] Sun Feb 13 12:54:11 2011  INFO
                *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
                :: END TIMER :: [Payload Operation :{7E5AA19B-0B85-4f44-BA26-728851489200}] took 2023.54 miliseconds (2.02354 seconds) DTR = 94.8833 KBPS (0.0926595 MBPS)
                User specified overrideFile:
                Calling the ROLLBACK custom action code for pre-repair for payload {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX
                [    6204] Sun Feb 13 12:54:12 2011  INFO
                Calling the custom action code for pre-install for payload {40F95A03-885A-45fb-9A14-486BEFEDDF34}
                ::START TIMER:: [Payload Operation :{40F95A03-885A-45fb-9A14-486BEFEDDF34}]
                [    5524] Sun Feb 13 12:54:12 2011  INFO
                Installer Operation: InstallThirdPartyPayloadOperation
                Installing third party payload
                Installing payload
                Attempting to install package from:E:\Adobe CS5\payloads\AdobeFlashPlayer10_plRel_mul\AdobeFlashPlayer10_plRel_mul.msi
                Command line arguments:  UILevel=2
                [    5524] Sun Feb 13 12:54:13 2011  INFO
                === Logging started: 13/02/2011  12:54:13 ===
                Message type: 1, Argument: Adobe Flash Player 10 Plugin
                Action 12:54:13: INSTALL.
                Action start 12:54:13: INSTALL.
                Action 12:54:13: ISSetAllUsers.
                Action start 12:54:13: ISSetAllUsers.
                InstallShield 12:54:13: Begin SetAllUsers()
                InstallShield 12:54:13: Getting records from Upgrade table
                InstallShield 12:54:13: UpgradeCode: {D85A1A59-DC52-4D13-9445-EF3F379D4DB5}    MinVersion: 6.0.47.0    MaxVersion: 10.1.52.14    Language:     Attributes: 769
                InstallShield 12:54:13: No related products for UpgradeCode {D85A1A59-DC52-4D13-9445-EF3F379D4DB5} found
                InstallShield 12:54:13: End SetAllUsers()
                Action ended 12:54:13: ISSetAllUsers. Return value 1.
                Action 12:54:13: AppSearch. Searching for installed applications
                Action start 12:54:13: AppSearch.
                Action ended 12:54:13: AppSearch. Return value 0.
                Action 12:54:13: LaunchConditions. Evaluating launch conditions
                Action start 12:54:13: LaunchConditions.
                Action ended 12:54:13: LaunchConditions. Return value 1.
                Action 12:54:13: FindRelatedProducts. Searching for related applications
                Action start 12:54:13: FindRelatedProducts.
                Action ended 12:54:13: FindRelatedProducts. Return value 1.
                Action 12:54:13: ValidateProductID.
                Action start 12:54:13: ValidateProductID.
                Action ended 12:54:13: ValidateProductID. Return value 1.
                Action 12:54:13: CostInitialize. Computing space requirements
                Action start 12:54:13: CostInitialize.
                Action ended 12:54:13: CostInitialize. Return value 1.
                Action 12:54:13: FileCost. Computing space requirements
                Action start 12:54:13: FileCost.
                Action ended 12:54:13: FileCost. Return value 1.
                Action 12:54:13: IsolateComponents.
                Action start 12:54:13: IsolateComponents.
                Action ended 12:54:13: IsolateComponents. Return value 0.
                Action 12:54:13: CostFinalize. Computing space requirements
                Action start 12:54:13: CostFinalize.
                Action ended 12:54:13: CostFinalize. Return value 1.
                Action 12:54:13: SetARPINSTALLLOCATION.
                Action start 12:54:13: SetARPINSTALLLOCATION.
                Action ended 12:54:13: SetARPINSTALLLOCATION. Return value 1.
                Action 12:54:13: SetODBCFolders. Initializing ODBC directories
                Action start 12:54:13: SetODBCFolders.
                Action ended 12:54:13: SetODBCFolders. Return value 0.
                Action 12:54:13: MigrateFeatureStates. Migrating feature states from related applications
                Action start 12:54:13: MigrateFeatureStates.
                Action ended 12:54:13: MigrateFeatureStates. Return value 0.
                Action 12:54:13: InstallValidate. Validating install
                Action start 12:54:13: InstallValidate.
                Action ended 12:54:13: InstallValidate. Return value 1.
                Action 12:54:13: RemoveExistingProducts. Removing applications
                Action start 12:54:13: RemoveExistingProducts.
                Action ended 12:54:13: RemoveExistingProducts. Return value 1.
                Action 12:54:13: InstallInitialize.
                Action start 12:54:13: InstallInitialize.
                Action ended 12:54:13: InstallInitialize. Return value 1.
                Action 12:54:13: MakePropsAvailable.
                Action start 12:54:13: MakePropsAvailable.
                Action ended 12:54:13: MakePropsAvailable. Return value 1.
                Action 12:54:13: AllocateRegistrySpace. Allocating registry space
                Action start 12:54:13: AllocateRegistrySpace.
                Action ended 12:54:13: AllocateRegistrySpace. Return value 1.
                Action 12:54:13: ProcessComponents. Updating component registration
                Action start 12:54:13: ProcessComponents.
                Action 12:54:13: GenerateScript. Generating script operations for action:
                Action ended 12:54:13: ProcessComponents. Return value 1.
                Action 12:54:13: UnpublishComponents. Unpublishing Qualified Components
                Action start 12:54:13: UnpublishComponents.
                Action ended 12:54:13: UnpublishComponents. Return value 0.
                Action 12:54:13: UnpublishFeatures. Unpublishing product features
                Action start 12:54:13: UnpublishFeatures.
                Action ended 12:54:13: UnpublishFeatures. Return value 1.
                Action 12:54:13: StopServices. Stopping services
                Action start 12:54:13: StopServices.
                Action ended 12:54:13: StopServices. Return value 1.
                Action 12:54:13: DeleteServices. Deleting services
                Action start 12:54:13: DeleteServices.
                Action ended 12:54:13: DeleteServices. Return value 1.
                Action 12:54:13: UnregisterComPlus. Unregistering COM+ Applications and Components
                Action start 12:54:13: UnregisterComPlus.
                Action ended 12:54:13: UnregisterComPlus. Return value 0.
                Action 12:54:13: SelfUnregModules. Unregistering modules
                Action start 12:54:13: SelfUnregModules.
                Action ended 12:54:13: SelfUnregModules. Return value 1.
                Action 12:54:13: UnregisterTypeLibraries. Unregistering type libraries
                Action start 12:54:13: UnregisterTypeLibraries.
                Action ended 12:54:13: UnregisterTypeLibraries. Return value 0.
                Action 12:54:13: RemoveODBC. Removing ODBC components
                Action start 12:54:13: RemoveODBC.
                Action ended 12:54:13: RemoveODBC. Return value 1.
                Action 12:54:13: UnregisterFonts. Unregistering fonts
                Action start 12:54:13: UnregisterFonts.
                Action ended 12:54:13: UnregisterFonts. Return value 1.
                Action 12:54:13: RemoveRegistryValues. Removing system registry values
                Action start 12:54:13: RemoveRegistryValues.
                Action ended 12:54:13: RemoveRegistryValues. Return value 1.
                Action 12:54:13: UnregisterClassInfo. Unregister class servers
                Action start 12:54:13: UnregisterClassInfo.
                Action ended 12:54:13: UnregisterClassInfo. Return value 0.
                Action 12:54:13: UnregisterExtensionInfo. Unregistering extension servers
                Action start 12:54:13: UnregisterExtensionInfo.
                Action ended 12:54:13: UnregisterExtensionInfo. Return value 0.
                Action 12:54:13: UnregisterProgIdInfo. Unregistering program identifiers
                Action start 12:54:13: UnregisterProgIdInfo.
                Action ended 12:54:13: UnregisterProgIdInfo. Return value 0.
                Action 12:54:13: UnregisterMIMEInfo. Unregistering MIME info
                Action start 12:54:13: UnregisterMIMEInfo.
                Action ended 12:54:13: UnregisterMIMEInfo. Return value 0.
                Action 12:54:13: RemoveIniValues. Removing INI file entries
                Action start 12:54:13: RemoveIniValues.
                Action ended 12:54:13: RemoveIniValues. Return value 1.
                Action 12:54:13: RemoveShortcuts. Removing shortcuts
                Action start 12:54:13: RemoveShortcuts.
                Action ended 12:54:13: RemoveShortcuts. Return value 0.
                Action 12:54:13: RemoveEnvironmentStrings. Updating environment strings
                Action start 12:54:13: RemoveEnvironmentStrings.
                Action ended 12:54:13: RemoveEnvironmentStrings. Return value 1.
                Action 12:54:13: RemoveDuplicateFiles. Removing duplicated files
                Action start 12:54:13: RemoveDuplicateFiles.
                Action ended 12:54:13: RemoveDuplicateFiles. Return value 1.
                Action 12:54:13: RemoveFolders. Removing folders
                Action start 12:54:13: RemoveFolders.
                Action ended 12:54:13: RemoveFolders. Return value 1.
                Action 12:54:13: CreateFolders. Creating folders
                Action start 12:54:13: CreateFolders.
                Folder: Creating folders
                Action ended 12:54:13: CreateFolders. Return value 1.
                Action 12:54:13: MoveFiles. Moving files
                Action start 12:54:13: MoveFiles.
                Action ended 12:54:13: MoveFiles. Return value 1.
                Action 12:54:13: InstallFiles. Copying new files
                Action start 12:54:13: InstallFiles.
                File: Copying new files,  Directory: ,  Size:
                Action ended 12:54:13: InstallFiles. Return value 1.
                Action 12:54:13: NewCustomAction1.
                Action start 12:54:13: NewCustomAction1.
                Action ended 12:54:13: NewCustomAction1. Return value 1.
                Action 12:54:13: PatchFiles. Patching files
                Action start 12:54:13: PatchFiles.
                Action ended 12:54:13: PatchFiles. Return value 1.
                Action 12:54:13: DuplicateFiles. Creating duplicate files
                Action start 12:54:13: DuplicateFiles.
                Action ended 12:54:13: DuplicateFiles. Return value 1.
                Action 12:54:13: BindImage. Binding executables
                Action start 12:54:13: BindImage.
                Action ended 12:54:13: BindImage. Return value 1.
                Action 12:54:13: CreateShortcuts. Creating shortcuts
                Action start 12:54:13: CreateShortcuts.
                Shortcut: Creating shortcuts
                Action ended 12:54:13: CreateShortcuts. Return value 0.
                Action 12:54:13: RegisterClassInfo. Registering class servers
                Action start 12:54:13: RegisterClassInfo.
                Action ended 12:54:13: RegisterClassInfo. Return value 0.
                Action 12:54:13: RegisterExtensionInfo. Registering extension servers
                Action start 12:54:13: RegisterExtensionInfo.
                Action ended 12:54:13: RegisterExtensionInfo. Return value 0.
                Action 12:54:13: RegisterProgIdInfo. Registering program identifiers
                Action start 12:54:13: RegisterProgIdInfo.
                Action ended 12:54:13: RegisterProgIdInfo. Return value 0.
                Action 12:54:13: RegisterMIMEInfo. Registering MIME info
                Action start 12:54:13: RegisterMIMEInfo.
                Action ended 12:54:13: RegisterMIMEInfo. Return value 0.
                Action 12:54:13: WriteRegistryValues. Writing system registry values
                Action start 12:54:13: WriteRegistryValues.
                Key: Writing system registry values, Name: , Value:
                Action ended 12:54:13: WriteRegistryValues. Return value 1.
                Action 12:54:13: WriteIniValues. Writing INI file values
                Action start 12:54:13: WriteIniValues.
                Action ended 12:54:13: WriteIniValues. Return value 1.
                Action 12:54:13: WriteEnvironmentStrings. Updating environment strings
                Action start 12:54:13: WriteEnvironmentStrings.
                Action ended 12:54:13: WriteEnvironmentStrings. Return value 1.
                Action 12:54:13: RegisterFonts. Registering fonts
                Action start 12:54:13: RegisterFonts.
                Action ended 12:54:13: RegisterFonts. Return value 1.
                Action 12:54:13: InstallODBC. Installing ODBC components
                Action start 12:54:13: InstallODBC.
                Action ended 12:54:13: InstallODBC. Return value 0.
                Action 12:54:13: RegisterTypeLibraries. Registering type libraries
                Action start 12:54:13: RegisterTypeLibraries.
                Action ended 12:54:13: RegisterTypeLibraries. Return value 0.
                Action 12:54:13: SelfRegModules. Registering modules
                Action start 12:54:13: SelfRegModules.
                Action ended 12:54:13: SelfRegModules. Return value 1.
                Action 12:54:13: RegisterComPlus. Registering COM+ Applications and Components
                Action start 12:54:13: RegisterComPlus.
                Action ended 12:54:13: RegisterComPlus. Return value 0.
                Action 12:54:13: InstallServices. Installing new services
                Action start 12:54:13: InstallServices.
                Action ended 12:54:13: InstallServices. Return value 1.
                Action 12:54:13: StartServices. Starting services
                Action start 12:54:13: StartServices.
                Action ended 12:54:13: StartServices. Return value 1.
                Action 12:54:13: RegisterUser. Registering user
                Action start 12:54:13: RegisterUser.
                Registering user
                Action ended 12:54:13: RegisterUser. Return value 1.
                Action 12:54:13: RegisterProduct. Registering product
                Action start 12:54:13: RegisterProduct.
                Registering product
                Action ended 12:54:13: RegisterProduct. Return value 1.
                Action 12:54:13: PublishComponents. Publishing qualified components
                Action start 12:54:13: PublishComponents.
                Action ended 12:54:13: PublishComponents. Return value 0.
                Action 12:54:13: PublishFeatures. Publishing product features
                Action start 12:54:13: PublishFeatures.
                Feature: Publishing product features
                Action ended 12:54:13: PublishFeatures. Return value 1.
                Action 12:54:13: PublishProduct. Publishing product information
                Action start 12:54:13: PublishProduct.
                Action ended 12:54:13: PublishProduct. Return value 1.
                Action 12:54:13: InstallFinalize.
                Action start 12:54:13: InstallFinalize.
                Folder: C:\Windows\SysWOW64\Macromed\Flash\
                File: InstallPlugin.exe,  Directory: C:\Users\GARY&S~1\AppData\Local\Temp\,  Size: 2516992
                Shortcut: ARPPRODUCTICON.exe
                Key: \Software\Macromedia\FlashPlayer, Name: , Value:
                Key: \Software\Macromedia\FlashPlayer, Name: FlashPlayerVersion, Value: 10.1.52.14
                {BC41C09D-FAA9-4346-9FE6-1E0017BC551A}
                Feature: FlashPlayerAXInstaller
                Message type: 2, Argument: 0
                Action 12:54:13: RollbackCleanup. Removing backup files
                Message type: 2, Argument: 1
                [    5524] Sun Feb 13 12:54:14 2011  INFO
                Action ended 12:54:14: InstallFinalize. Return value 1.
                Action ended 12:54:14: INSTALL. Return value 1.
                Property(S): DiskPrompt = [1]
                Property(S): UpgradeCode = {D85A1A59-DC52-4D13-9445-EF3F379D4DB5}
                Property(S): ProductCode = {BC41C09D-FAA9-4346-9FE6-1E0017BC551A}
                Property(S): ProductToBeRegistered = 1
                Property(S): SourcedirProduct = {BC41C09D-FAA9-4346-9FE6-1E0017BC551A}
                Property(S): SOURCEDIR = E:\Adobe CS5\payloads\AdobeFlashPlayer10_plRel_mul\
                Property(S): VersionNT = 601
                Property(S): TARGETDIR = F:\
                Property(S): ALLUSERSPROFILE = F:\
                Property(S): PrimaryVolumeSpaceRemaining = 0
                Property(S): PrimaryVolumeSpaceRequired = 0
                Property(S): PrimaryVolumeSpaceAvailable = 0
                Property(S): OutOfNoRbDiskSpace = 0
                Property(S): OutOfDiskSpace = 0
                Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
                Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
                Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
                Property(S): SystemFolder = C:\Windows\SysWOW64\
                Property(S): CostingComplete = 1
                Property(S): SourceDir = E:\Adobe CS5\payloads\AdobeFlashPlayer10_plRel_mul\
                Property(S): TempFolder = C:\Users\GARY&S~1\AppData\Local\Temp\
                Property(S): USERPROFILE = F:\
                Property(S): ROOTDRIVE = F:\
                Property(S): ACTION = INSTALL
                Property(S): UILevel = 2
                Property(S): OriginalDatabase = E:\Adobe CS5\payloads\AdobeFlashPlayer10_plRel_mul\AdobeFlashPlayer10_plRel_mul.msi
                Property(S): DATABASE = C:\Windows\Installer\35409a.msi
                Property(S): Privileged = 1
                Property(S): MsiRunningElevated = 1
                Property(S): RedirectedDllSupport = 2
                Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
                Property(S): MsiNetAssemblySupport = 4.0.30319.1
                Property(S): Date = 13/02/2011
                Property(S): Time = 12:54:14
                Property(S): TTCSupport = 1
                Property(S): ColorBits = 32
                Property(S): TextInternalLeading = 3
                Property(S): TextHeight = 16
                Property(S): BorderSide = 1
                Property(S): BorderTop = 1
                Property(S): CaptionHeight = 22
                Property(S): ProductName = Adobe Flash Player 10 Plugin
                Property(S): ALLUSERS = 1
                Property(S): ScreenY = 768
                Property(S): SecureCustomProperties = ISACTIONPROP1;SUPPORTDIR
                Property(S): UNINSTALLER_EXE = [SystemFolder]\Macromed\Flash\uninstall_plugin.exe
                Property(S): ScreenX = 1024
                Property(S): SystemLanguageID = 3081
                Property(S): ComputerName = PC
                Property(S): UserLanguageID = 3081
                Property(S): AdminUser = 1
                Property(S): UserSID = S-1-5-21-618155685-1063480468-518450737-1000
                Property(S): LogonUser = Gary & Susan
                Property(S): MsiTrueAdminUser = 1
                Property(S): VirtualMemory = 14348
                Property(S): PhysicalMemory = 8151
                Property(S): Intel = 6
                Property(S): Msix64 = 6
                Property(S): MsiAMD64 = 6
                Property(S): ShellAdvtSupport = 1
                Property(S): OLEAdvtSupport = 1
                Property(S): GPTSupport = 1
                Property(S): FontsFolder = C:\Windows\Fonts\
                Property(S): DesktopFolder = C:\Users\Public\Desktop\
                Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
                Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
                Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
                Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
                Property(S): MyPicturesFolder = C:\Users\Gary & Susan\Pictures\
                Property(S): LocalAppDataFolder = C:\Users\Gary & Susan\AppData\Local\
                Property(S): CommonAppDataFolder = C:\ProgramData\
                Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
                Property(S): SendToFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\SendTo\
                Property(S): PersonalFolder = C:\Users\Gary & Susan\Documents\
                Property(S): FavoritesFolder = C:\Users\Gary & Susan\Favorites\
                Property(S): AppDataFolder = C:\Users\Gary & Susan\AppData\Roaming\
                Property(S): CommonFiles64Folder = C:\Program Files\Common Files\
                Property(S): ProgramFiles64Folder = C:\Program Files\
                Property(S): ProgramFilesFolder = C:\Program Files (x86)\
                Property(S): System64Folder = C:\Windows\system32\
                Property(S): WindowsVolume = C:\
                Property(S): WindowsFolder = C:\Windows\
                Property(S): UILEVEL = 2
                Property(S): PackageCode = {BD4109FD-A808-4EAE-B2BE-144DA3F3A299}
                Property(S): MsiLogFileLocation = C:\Users\GARY&S~1\AppData\Local\Temp\MSI67a30.LOG
                === Logging stopped: 13/02/2011  12:54:14 ===
                1: 2 2: 0
                1: 2 2: 1
                Installation result: 0
                Third party payload succeded.  Testing return code: 0
                [    6204] Sun Feb 13 12:54:14 2011  INFO
                *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
                :: END TIMER :: [Payload Operation :{40F95A03-885A-45fb-9A14-486BEFEDDF34}] took 2017.95 miliseconds (2.01795 seconds) DTR = 3280.56 KBPS (3.20367 MBPS)
                Calling the custom action code for post-install for payload {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin
                Calling the custom action code for pre-repair for payload {7745F18B-FD8A-4011-BE16-588900C503D0}
                ::START TIMER:: [Pre payload :{7745F18B-FD8A-4011-BE16-588900C503D0}]
                Font Installer: productName is Adobe Flash Fonts1
                Font Installer: Using [AdobeCommon] path: C:\Program Files (x86)\Common Files\Adobe
                Custom action return code: 0
                :: END TIMER :: [Pre payload :{7745F18B-FD8A-4011-BE16-588900C503D0}] took 29.6055 miliseconds (0.0296055 seconds)
                ::START TIMER:: [Payload Operation :{7745F18B-FD8A-4011-BE16-588900C503D0}]
                [    3648] Sun Feb 13 12:54:14 2011  INFO
                Installer Operation: PayloadUninstaller
                Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {7745F18B-FD8A-4011-BE16-588900C503D0}
                Effective AdobeCode for: {7745F18B-FD8A-4011-BE16-588900C503D0} is {7745F18B-FD8A-4011-BE16-588900C503D0}
                Session includes local copy of payload for repair source
                Repair payload source package: E:\Adobe CS5\payloads\AdobeFlashFonts1-mul\Install.db
                Extracting assets...
                Extracting assets complete. Number assets: 1
                Beginning installation for payload at E:\Adobe CS5\payloads\AdobeFlashFonts1-mul\Install.db
                [    3648] Sun Feb 13 12:54:15 2011  INFO
                Evaluating condition# 1
                Condition failed
                Completing installation for payload at E:\Adobe CS5\payloads\AdobeFlashFonts1-mul\Install.db
                UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{7745F18B-FD8A-4011-BE16-588900C503D0}.db
                Physical payload repair result:0
                [    6204] Sun Feb 13 12:54:15 2011  INFO
                :: END TIMER :: [Payload Operation :{7745F18B-FD8A-4011-BE16-588900C503D0}] took 1023.53 miliseconds (1.02353 seconds) DTR = 590.115 KBPS (0.576285 MBPS)
                Calling the custom action code for post-repair for payload {7745F18B-FD8A-4011-BE16-588900C503D0} Adobe Flash Fonts1
                ::START TIMER:: [Post payload :{7745F18B-FD8A-4011-BE16-588900C503D0}]
                Font Installer: Did not find any font files under:C:\Program Files (x86)\Common Files\Adobe\SavedFonts\current
                :: END TIMER :: [Post payload :{7745F18B-FD8A-4011-BE16-588900C503D0}] took 2.37978 miliseconds (0.00237978 seconds) DTR = 13446.6 KBPS (13.1315 MBPS)
                Disk Swap Needed, Prompting user to swap disk CS5 Master Coll2 E:\
                [    6204] Sun Feb 13 12:54:53 2011  INFO
                Starting installation from Disk 2 - CS5 Master Coll2
                Calling the custom action code for pre-repair for payload {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}
                ::START TIMER:: [Payload Operation :{C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}]
                [    6248] Sun Feb 13 12:54:53 2011  INFO
                Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}
                Effective AdobeCode for: {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1} is {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}
                Repair payload source package: E:\Adobe CS5\payloads\AdobeAfterEffects10ProtectedAll\Install.db
                [    6248] Sun Feb 13 12:55:08 2011  INFO
                Extracting assets complete. Number assets: 2
                Beginning installation for payload at E:\Adobe CS5\payloads\AdobeAfterEffects10ProtectedAll\Install.db
                [    6248] Sun Feb 13 12:55:15 2011  INFO
                Evaluating condition# 2
                Condition failed
                Condition failed
                [    6248] Sun Feb 13 12:55:23 2011  INFO
                Completing installation for payload at E:\Adobe CS5\payloads\AdobeAfterEffects10ProtectedAll\Install.db
                UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}.db
                [    6248] Sun Feb 13 12:55:27 2011  INFO
                [    6204] Sun Feb 13 12:55:28 2011  INFO
                :: END TIMER :: [Payload Operation :{C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}] took 35063.3 miliseconds (35.0633 seconds) DTR = 6585.12 KBPS (6.43078 MBPS)
                Calling the custom action code for post-repair for payload {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1} Adobe After Effects CS5 Third Party Content
                Calling the custom action code for pre-repair for payload {CD29B5CA-4727-4114-9AD9-25CCCE6E4014}
                ::START TIMER:: [Payload Operation :{CD29B5CA-4727-4114-9AD9-25CCCE6E4014}]
                [    5252] Sun Feb 13 12:55:28 2011  INFO
                Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {CD29B5CA-4727-4114-9AD9-25CCCE6E4014}
                Effective AdobeCode for: {CD29B5CA-4727-4114-9AD9-25CCCE6E4014} is {CD29B5CA-4727-4114-9AD9-25CCCE6E4014}
                Repair payload source package: E:\Adobe CS5\payloads\AdobeAfterEffects10RoyaltyAll\Install.db
                [    5252] Sun Feb 13 12:55:29 2011  INFO
                Beginning installation for payload at E:\Adobe CS5\payloads\AdobeAfterEffects10RoyaltyAll\Install.db
                Condition failed
                Condition failed
                [    5252] Sun Feb 13 12:55:30 2011  INFO
                Completing installation for payload at E:\Adobe CS5\payloads\AdobeAfterEffects10RoyaltyAll\Install.db
                UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{CD29B5CA-4727-4114-9AD9-25CCCE6E4014}.db
                [    6204] Sun Feb 13 12:55:31 2011  INFO
                :: END TIMER :: [Payload Operation :{CD29B5CA-4727-4114-9AD9-25CCCE6E4014}] took 3029.25 miliseconds (3.02925 seconds)
                Calling the custom action code for post-repair for payload {CD29B5CA-4727-4114-9AD9-25CCCE6E4014} Adobe After Effects CS5 Third Party Royalty Content
                Calling the custom action code for pre-repair for payload {0E3C6C75-872D-4B0D-B0B2-31C717250691}
                ::START TIMER:: [Payload Operation :{0E3C6C75-872D-4B0D-B0B2-31C717250691}]
                [    4844] Sun Feb 13 12:55:31 2011  INFO
                Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {0E3C6C75-872D-4B0D-B0B2-31C717250691}
                Effective AdobeCode for: {0E3C6C75-872D-4B0D-B0B2-31C717250691} is {0E3C6C75-872D-4B0D-B0B2-31C717250691}
                Repair payload source package: E:\Adobe CS5\payloads\AdobeEncore5RoyaltyAll\Install.db
                [    4844] Sun Feb 13 12:55:32 2011  INFO
                Beginning installation for payload at E:\Adobe CS5\payloads\AdobeEncore5RoyaltyAll\Install.db
                [    4844] Sun Feb 13 12:55:34 2011  INFO
                Completing installation for payload at E:\Adobe CS5\payloads\AdobeEncore5RoyaltyAll\Install.db
                UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{0E3C6C75-872D-4B0D-B0B2-31C717250691}.db
                [    6204] Sun Feb 13 12:55:34 2011  INFO
                :: END TIMER :: [Payload Operation :{0E3C6C75-872D-4B0D-B0B2-31C717250691}] took 3023.11 miliseconds (3.02311 seconds) DTR = 1354.9 KBPS (1.32314 MBPS)
                Calling the custom action code for post-repair for payload {0E3C6C75-872D-4B0D-B0B2-31C717250691} Adobe Encore CS5 Third Party Royalty Content
                Calling the custom action code for pre-repair for payload {5DDABB74-A879-4BE7-A4C6-FD41793942DB}
                ::START TIMER:: [Payload Operation :{5DDABB74-A879-4BE7-A4C6-FD41793942DB}]
                [     832] Sun Feb 13 12:55:34 2011  INFO
                Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {5DDABB74-A879-4BE7-A4C6-FD41793942DB}
                Effective AdobeCode for: {5DDABB74-A879-4BE7-A4C6-FD41793942DB} is {5DDABB74-A879-4BE7-A4C6-FD41793942DB}
                [     832] Sun Feb 13 12:55:35 2011  INFO
                Repair payload source package: E:\Adobe CS5\payloads\AMEDolby5All_x64\Install.db
                [     832] Sun Feb 13 12:55:39 2011  INFO
                Beginning installation for payload at E:\Adobe CS5\payloads\AMEDolby5All_x64\Install.db
                [     832] Sun Feb 13 12:55:40 2011  INFO
                Completing installation for payload at E:\Adobe CS5\payloads\AMEDolby5All_x64\Install.db
                UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{5DDABB74-A879-4BE7-A4C6-FD41793942DB}.db
                [    6204] Sun Feb 13 12:55:40 2011  INFO
                :: END TIMER :: [Payload Operation :{5DDABB74-A879-4BE7-A4C6-FD41793942DB}] took 6035.72 miliseconds (6.03572 seconds)
                [    6204] Sun Feb 13 12:55:41 2011  INFO
                Calling the custom action code for post-repair for payload {5DDABB74-A879-4BE7-A4C6-FD41793942DB} Adobe Media Encoder CS5 Dolby X64
                Calling the custom action code for pre-repair for payload {F9C71630-0EE3-475C-9E2B-ED95AE197DBD}
                ::START TIMER:: [Payload Operation :{F9C71630-0EE3-475C-9E2B-ED95AE197DBD}]
                [    4644] Sun Feb 13 12:55:41 2011  INFO
                Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {F9C71630-0EE3-475C-9E2B-ED95AE197DBD}
                Effective AdobeCode for: {F9C71630-0EE3-475C-9E2B-ED95AE197DBD} is {F9C71630-0EE3-475C-9E2B-ED95AE197DBD}
                Repair payload source package: E:\Adobe CS5\payloads\AMEPCI5All_x64\Install.db
                [    4644] Sun Feb 13 12:55:43 2011  INFO
                Beginning installation for payload at E:\Adobe CS5\payloads\AMEPCI5All_x64\Install.db
                [    4644] Sun Feb 13 12:55:46 2011  INFO
                Completing installation for payload at E:\Adobe CS5\payloads\AMEPCI5All_x64\Install.db
                UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{F9C71630-0EE3-475C-9E2B-ED95AE197DBD}.db
                [    6204] Sun Feb 13 12:55:47 2011  INFO
                :: END TIMER :: [Payload Operation :{F9C71630-0EE3-475C-9E2B-ED95AE197DBD}] took 6017.98 miliseconds (6.01798 seconds) DTR = 170.821 KBPS (0.166818 MBPS)
                Calling the custom action code for post-repair for payload {F9C71630-0EE3-475C-9E2B-ED95AE197DBD} Adobe Media Encoder CS5 PCI X64
                Calling the custom action code for pre-repair for payload {7816FDDE-40D4-482D-AD7D-97858985DB3E}
                ::START TIMER:: [Payload Operation :{7816FDDE-40D4-482D-AD7D-97858985DB3E}]
                [    6232] Sun Feb 13 12:55:47 2011  INFO
                Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {7816FDDE-40D4-482D-AD7D-97858985DB3E}
                Effective AdobeCode for: {7816FDDE-40D4-482D-AD7D-97858985DB3E} is {7816FDDE-40D4-482D-AD7D-97858985DB3E}
                Repair payload source package: E:\Adobe CS5\payloads\AdobeOnLocation5RoyaltyAll\Install.db
                [    6232] Sun Feb 13 12:55:48 2011  INFO
                Beginning installation for payload at E:\Adobe CS5\payloads\AdobeOnLocation5RoyaltyAll\Install.db
                Completing installation for payload at E:\Adobe CS5\payloads\AdobeOnLocation5RoyaltyAll\Install.db
                UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{7816FDDE-40D4-482D-AD7D-97858985DB3E}.db
                [    6204] Sun Feb 13 12:55:49 2011  INFO
                :: END TIMER :: [Payload Operation :{7816FDDE-40D4-482D-AD7D-97858985DB3E}] took 2031.72 miliseconds (2.03172 seconds) DTR = 13.7814 KBPS (0.0134584 MBPS)
                Calling the custom action code for post-repair for payload {7816FDDE-40D4-482D-AD7D-97858985DB3E} Adobe OnLocation CS5 Royalty Content
                Calling the custom action code for pre-repair for payload {B8D286BC-A68D-4E74-9F68-8756A49896D8}
                ::START TIMER:: [Payload Operation :{B8D286BC-A68D-4E74-9F68-8756A49896D8}]
                [    6572] Sun Feb 13 12:55:49 2011  INFO
                Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {B8D286BC-A68D-4E74-9F68-8756A49896D8}
                Effective AdobeCode for: {B8D286BC-A68D-4E74-9F68-8756A49896D8} is {B8D286BC-A68D-4E74-9F68-8756A49896D8}
                Repair payload source package: E:\Adobe CS5\payloads\AdobePremierePro5ProtectedAll\Install.db
                Beginning installation for payload at E:\Adobe CS5\payloads\AdobePremierePro5ProtectedAll\Install.db
                Condition failed
                Condition failed
                Completing installation for payload at E:\Adobe CS5\payloads\AdobePremierePro5ProtectedAll\Install.db
                UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{B8D286BC-A68D-4E74-9F68-8756A49896D8}.db
                [    6204] Sun Feb 13 12:55:50 2011  INFO
                :: END TIMER :: [Payload Operation :{B8D286BC-A68D-4E74-9F68-8756A49896D8}] took 1018.41 miliseconds (1.01841 seconds)
                Calling the custom action code for post-repair for payload {B8D286BC-A68D-4E74-9F68-8756A49896D8} Adobe Premiere Pro CS5 Third Party Content
                Calling the custom action code for pre-repair for payload {565DE707-5798-4FC3-8DF6-0F58A348A9B0}
                ::START TIMER:: [Payload Operation :{565DE707-5798-4FC3-8DF6-0F58A348A9B0}]
                [    4476] Sun Feb 13 12:55:50 2011  INFO
                Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {565DE707-5798-4FC3-8DF6-0F58A348A9B0}
                Effective AdobeCode for: {565DE707-5798-4FC3-8DF6-0F58A348A9B0} is {565DE707-5798-4FC3-8DF6-0F58A348A9B0}
                Repair payload source package: E:\Adobe CS5\payloads\AdobePremierePro5RoyaltyAll\Install.db
                [    4476] Sun Feb 13 12:55:55 2011  INFO
                Beginning installation for payload at E:\Adobe CS5\payloads\AdobePremierePro5RoyaltyAll\Install.db
                Condition failed
                Condition failed
                [    4476] Sun Feb 13 12:55:56 2011  INFO
                Completing installation for payload at E:\Adobe CS5\payloads\AdobePremierePro5RoyaltyAll\Install.db
                UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{565DE707-5798-4FC3-8DF6-0F58A348A9B0}.db
                [    6204] Sun Feb 13 12:55:57 2011  INFO
                :: END TIMER :: [Payload Operation :{565DE707-5798-4FC3-8DF6-0F58A348A9B0}] took 7032.99 miliseconds (7.03299 seconds) DTR = 3.41249 KBPS (0.00333251 MBPS)
                Calling the custom action code for post-repair for payload {565DE707-5798-4FC3-8DF6-0F58A348A9B0} Adobe Premiere Pro CS5 Third Party Royalty Content
                Calling the custom action code for pre-repair for payload {DE5DE662-2ECB-4D93-967B-221FBCC8A736}
                ::START TIMER:: [Payload Operation :{DE5DE662-2ECB-4D93-967B-221FBCC8A736}]
                [    3884] Sun Feb 13 12:55:57 2011  INFO
                Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {DE5DE662-2ECB-4D93-967B-221FBCC8A736}
                Effective AdobeCode for: {DE5DE662-2ECB-4D93-967B-221FBCC8A736} is {DE5DE662-2ECB-4D93-967B-221FBCC8A736}
                Repair payload source package: E:\Adobe CS5\payloads\AdobeSoundbooth3ProtectedAll\Install.db
                [    3884] Sun Feb 13 12:55:58 2011  INFO
                Beginning installation for payload at E:\Adobe CS5\payloads\AdobeSoundbooth3ProtectedAll\Install.db
                [    3884] Sun Feb 13 12:56:00 2011  INFO
                Completing installation for payload at E:\Adobe CS5\payloads\AdobeSoundbooth3ProtectedAll\Install.db
                UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{DE5DE662-2ECB-4D93-967B-221FBCC8A736}.db
                [    6204] Sun Feb 13 12:56:00 2011  INFO
                :: END TIMER :: [Payload Operation :{DE5DE662-2ECB-4D93-967B-221FBCC8A736}] took 3028.75 miliseconds (3.02875 seconds) DTR = 450.35 KBPS (0.439795 MBPS)
                Calling the custom action code for post-repair for payload {DE5DE662-2ECB-4D93-967B-221FBCC8A736} Adobe Soundbooth CS5 Codecs
                Calling the custom action code for pre-repair for payload {F319804F-E3A4-4C02-8AEC-CB39A4F6447E}
                ::START TIMER:: [Payload Operation :{F319804F-E3A4-4C02-8AEC-CB39A4F6447E}]
                [    2556] Sun Feb 13 12:56:00 2011  INFO
                Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {F319804F-E3A4-4C02-8AEC-CB39A4F6447E}
                [    2556] Sun Feb 13 12:56:01 2011  INFO
                Effective AdobeCode for: {F319804F-E3A4-4C02-8AEC-CB39A4F6447E} is {F319804F-E3A4-4C02-8AEC-CB39A4F6447E}
                Repair payload source package: E:\Adobe CS5\payloads\AdobeSoundbooth3RoyaltyAll\Install.db
                [    2556] Sun Feb 13 12:56:02 2011  INFO
                Beginning installation for payload at E:\Adobe CS5\payloads\AdobeSoundbooth3RoyaltyAll\Install.db
                [    2556] Sun Feb 13 12:56:03 2011  INFO
                Completing installation for payload at E:\Adobe CS5\payloads\AdobeSoundbooth3RoyaltyAll\Install.db
                UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{F319804F-E3A4-4C02-8AEC-CB39A4F6447E}.db
                [    2556] Sun Feb 13 12:56:04 2011  INFO
                [    6204] Sun Feb 13 12:56:04 2011  INFO
                :: END TIMER :: [Payload Operation :{F319804F-E3A4-4C02-8AEC-CB39A4F6447E}] took 4024.33 miliseconds (4.02433 seconds)
                [    6204] Sun Feb 13 12:56:05 2011  INFO
                Calling the custom action code for post-repair for payload {F319804F-E3A4-4C02-8AEC-CB39A4F6447E} Adobe Soundbooth CS5 Royalty Codecs
                Calling the custom action code for pre-repair for payload {FBB02B04-C034-4382-A3F6-57416E2752C4}
                ::START TIMER:: [Payload Operation :{FBB02B04-C034-4382-A3F6-57416E2752C4}]
                [    4936] Sun Feb 13 12:56:05 2011  INFO
                Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {FBB02B04-C034-4382-A3F6-57416E2752C4}
                Effective AdobeCode for: {FBB02B04-C034-4382-A3F6-57416E2752C4} is {FBB02B04-C034-4382-A3F6-57416E2752C4}
                Repair payload source package: E:\Adobe CS5\payloads\AdobeMasterCollection5-mul\Install.db
                Beginning installation for payload at E:\Adobe CS5\payloads\AdobeMasterCollection5-mul\Install.db
                Condition failed
                [    4936] Sun Feb 13 12:56:06 2011  INFO
                Completing installation for payload at E:\Adobe CS5\payloads\AdobeMasterCollection5-mul\Install.db
                UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{FBB02B04-C034-4382-A3F6-57416E2752C4}.db
                [    6204] Sun Feb 13 12:56:06 2011  INFO
                :: END TIMER :: [Payload Operation :{FBB02B04-C034-4382-A3F6-57416E2752C4}] took 1028.25 miliseconds (1.02825 seconds)
                Calling the custom action code for post-repair for payload {FBB02B04-C034-4382-A3F6-57416E2752C4} Creative Suite 5 Master Collection
                Calling the custom action code for pre-install for payload {177E1CA1-14CC-4398-AB15-A5746EFE8F22}
                ::START TIMER:: [Pre payload :{177E1CA1-14CC-4398-AB15-A5746EFE8F22}]
                In PrePayloadInstallProc
                hook checkDirs passed str:
                C:\Program Files (x86)\Adobe
                detected bad URL character
                CHRC_NULL_POINTER_VALUE
                Custom action return code: 1
                :: END TIMER :: [Pre payload :{177E1CA1-14CC-4398-AB15-A5746EFE8F22}] took 1.15487 miliseconds (0.00115487 seconds)
                [    6204] Sun Feb 13 12:56:06 2011 ERROR
                Custom Action for payload {177E1CA1-14CC-4398-AB15-A5746EFE8F22} Adobe Flash Builder returned error. Failing this payload.
                [    6204] Sun Feb 13 12:56:07 2011  INFO
                Calling the custom action code for pre-install for payload {E8815668-95B0-443D-AC92-2BFD7DD8F16A}
                ::START TIMER:: [Pre payload :{E8815668-95B0-443D-AC92-2BFD7DD8F16A}]
                :: END TIMER :: [Pre payload :{E8815668-95B0-443D-AC92-2BFD7DD8F16A}] took 1.13178 miliseconds (0.00113178 seconds)
                [    6204] Sun Feb 13 12:56:07 2011 ERROR
                Custom Action for payload {E8815668-95B0-443D-AC92-2BFD7DD8F16A} Adobe Flash Catalyst CS5 returned error. Failing this payload.
                No operation.  We're done:
                Updating driver data - Action: Remove driver entry
                Updating driver data successful. Driver entry was added. ARP estimated size 21458917KB
                [    6204] Sun Feb 13 12:56:09 2011  INFO
                Successfully installed 1 component:
                - Adobe Flash Player 10 Plugin
                Successfully repaired 31 components:
                - Microsoft_VC90_ATL_x86
                - Adobe Media Player
                - Microsoft_VC90_CRT_x86
                - Adobe Encore CS5 Third Party Royalty Content
                - Microsoft_VC80_ATL_x86
                - Adobe Player for Embedding
                - AdobeHelp
                - Adobe Premiere Pro CS5 Third Party Royalty Content
                - Adobe Media Encoder CS5 Dolby X64
                - Microsoft_VC90_MFC_x86
                - Adobe Media Encoder CS5 X64
                - Suite Shared Configuration CS5
                - AdobeTypeSupport CS5
                - Adobe Flash Fonts1
                - Adobe OnLocation CS5 Royalty Content
                - Microsoft_VC90_ATL_x86_x64
                - Microsoft_VC90_CRT_x86_x64
                - Microsoft_VC80_CRT_x86
                - Microsoft_VC90_MFC_x86_x64
                - DynamiclinkSupport
                - Adobe Premiere Pro CS5 Third Party Content
                - AdobeCMaps CS5
                - Adobe After Effects CS5 Third Party Content
                - Adobe After Effects CS5 Third Party Royalty Content
                - Microsoft_VC80_MFC_x86
                - Microsoft_VC80_MFCLOC_x86
                - Adobe Soundbooth CS5 Codecs
                - Adobe Soundbooth CS5 Royalty Codecs
                - Adobe AIR
                - Adobe Media Encoder CS5 PCI X64
                - Creative Suite 5 Master Collection
                Total components removed: 0
                [    6204] Sun Feb 13 12:56:09 2011 ERROR
                The following payload errors were found during install:
                - Adobe Flash Builder: Install failed
                - Adobe Flash Player 10 ActiveX: Install failed
                - Adobe Flash Catalyst CS5: Install failed
                Restarting your computer is recommended:
                In order to complete the installation, please restart the computer
                Call PostSession Custom Hook
                :: END TIMER :: [Total Timer] took 240207 miliseconds (240.207 seconds) DTR = 1038.12 KBPS (1.01379 MBPS)
                -------------------------------------- Summary --------------------------------------
                - 0 fatal error(s), 6 error(s), 4 warning(s)
                WARNING: Warning: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
                WARNING: Warning: {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
                ERROR: Custom Action for payload {177E1CA1-14CC-4398-AB15-A5746EFE8F22} Adobe Flash Builder returned error. Failing this payload.
                ERROR: Custom Action for payload {E8815668-95B0-443D-AC92-2BFD7DD8F16A} Adobe Flash Catalyst CS5 returned error. Failing this payload.
                ERROR: The following payload errors were found during install:
                ERROR:  - Adobe Flash Builder: Install failed
                ERROR:  - Adobe Flash Player 10 ActiveX: Install failed
                ERROR:  - Adobe Flash Catalyst CS5: Install failed
                Search the same string above to find when the error occured.
                Exit Code: 6 - Silent workflow completed with errors
                END - Installer Session
                [    3432] Sun Feb 13 13:04:32 2011  INFO
                Visit http://www.adobe.com/go/loganalyzer/ for more information
                START - Installer Session
                RIBS version: 3.0.122.0
                Win OS version: 6.1.0.0 64 bit Type: 1
                ::START TIMER:: [Total Timer]
                CHECK: Single instance running
                CHECK : Credentials
                Load Deployment File
                Create Required Folders
                Assuming install mode
                ::START TIMER:: [Bootstrap]
                Perform Bootstrapping ...
                :: END TIMER :: [Bootstrap] took 10220.6 miliseconds (10.2206 seconds) DTR = 149.893 KBPS (0.14638 MBPS)
                Looking up install source path
                Sync Media DB ...
                ::START TIMER:: [Sync Media DB]
                Pre check media db sync
                End of Pre check media db sync. Exit code: 1
                Media db sync skipped as session is already installed
                :: END TIMER :: [Sync Media DB] took 172.551 miliseconds (0.172551 seconds)
                Ready to initialize session to start with ...
                ::START TIMER:: [CreatePayloadSession]
                -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
                Updated source path: E:\Adobe CS5
                Updating media info for: {01367616-4132-4311-911F-49D2EA82F7C2}
                  Type: 1, Volume Order: 1, Media Name: CS5 Master Coll1
                  Path: E:\Adobe CS5\payloads\AdobeOnLocation5RoyaltyWrapperAll\Install.db
                Updating media info for: {02731921-5711-4E7A-A898-D6BCF0F2A1CD}
                  Path: E:\Adobe CS5\payloads\AdobeCSXSInfrastructure2-mul\Install.db
                Updating media info for: {033E378E-6AD3-4AD5-BDEB-CBD69B31046C}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86\Microsoft_VC90_ATL_x86.msi
                Updating media info for: {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A}
                  Path: E:\Adobe CS5\payloads\AdobeAMP1.8-mul\AdobeAIRInstaller.exe
                Updating media info for: {03EEF3DA-71F9-4FE5-92AD-D10142E26459}
                  Path: E:\Adobe CS5\payloads\SiteCatalystNetAverages1-mul\Install.db
                Updating media info for: {04D84E18-23ED-46EA-9B41-789433E34D03}
                  Path: E:\Adobe CS5\payloads\AdobeContribute6-FFPlugin\Install.db
                Updating media info for: {0669F23C-1B69-41B4-A3ED-4F54A5986D66}
                  Path: E:\Adobe CS5\payloads\AdobeLinguisticsAll_x64\Install.db
                Updating media info for: {08D2E121-7F6A-43EB-97FD-629B44903403}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi
                Updating media info for: {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A}
                  Path: E:\Adobe CS5\payloads\AdobePhotoshop12-Support\Install.db
                Updating media info for: {0A9AAB1E-0FEA-1033-851A-888C0B8E78B5}
                  Type: 1, Volume Order: 2, Media Name: CS5 Master Coll2
                  Path: E:\Adobe CS5\payloads\AdobeInDesign7CommonLang-en_US\AdobeInDesign7CommonLang-en_US.msi
                Updating media info for: {0B754B55-6F63-461E-BB75-E8C883BDF88F}
                  Path: E:\Adobe CS5\payloads\AdobePremierePro5AllRetail\AdobePremierePro5AllRetail.msi
                Updating media info for: {0D067D13-C3D7-4EA6-B346-740CD91FD547}
                  Path: E:\Adobe CS5\payloads\AdobeBridge4-mul\Install.db
                Updating media info for: {0E3C6C75-872D-4B0D-B0B2-31C717250691}
                  Path: E:\Adobe CS5\payloads\AdobeEncore5RoyaltyAll\AdobeEncore5RoyaltyAll.msi
                Updating media info for: {0E659C1D-7686-4322-A501-58E3FEB4E743}
                  Path: E:\Adobe CS5\payloads\AdobeAfterEffects10AllRetail\AdobeAfterEffects10AllRetail.msi
                Updating media info for: {0EDAD58E-71F3-4D0E-9D32-A205533FC0E9}
                  Path: E:\Adobe CS5\payloads\AdobeKoreanSpeechAnalysisModels2All\AdobeKoreanSpeechAnalysisModels2All.msi
                Updating media info for: {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC80_ATL_x86\Microsoft_VC80_ATL_x86.msi
                Updating media info for: {11C0657F-2BD4-4CBC-87F3-9455DC91886E}
                  Path: E:\Adobe CS5\payloads\AdobeFontsRecommended_x64-mul\Install.db
                Updating media info for: {14A2CC02-4638-405D-8190-ECD7BFD32D6E}
                  Path: E:\Adobe CS5\payloads\AdobeFlash11-en_USLanguagePack\AdobeFlash11-en_USLanguagePack.msi
                Updating media info for: {157D044B-C60D-1015-B0DB-A40823CC0F49}
                  Path: E:\Adobe CS5\payloads\AdobeToolhints-mul\Install.db
                Updating media info for: {164965E8-4BB0-4EEB-AFBA-75785A2A2A7F}
                  Path: E:\Adobe CS5\payloads\AdobeFireworks11All\AdobeFireworks11All.msi
                Updating media info for: {177E1CA1-14CC-4398-AB15-A5746EFE8F22}
                  Path: E:\Adobe CS5\payloads\AdobeFlashBuilder-mul\AdobeFlashBuilder-mul.msi
                Updating media info for: {17C6080E-F475-4B49-A30C-EEB85673E999}
                  Path: E:\Adobe CS5\payloads\AdobePDFL9.9_x64-mul\Install.db
                Updating media info for: {1A48007B-34D2-44BD-8708-B570F5339C14}
                  Path: E:\Adobe CS5\payloads\AdobeEncore5RoyaltyWrapperAll\Install.db
                Updating media info for: {1D809D80-28A4-11DF-A816-0024E8692489}
                  Path: E:\Adobe CS5\payloads\DeviceCentral3LP-en_US\Install.db
                Updating media info for: {1D830E80-28A4-11DF-A025-0024E8692489}
                  Path: E:\Adobe CS5\payloads\DeviceCentral3LP-en_GB\Install.db
                Updating media info for: {1E9FC118-651D-4934-97BE-E53CAE5C7D45}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86_x64\Microsoft_VC80_MFCLOC_x86_x64.msi
                Updating media info for: {20F72893-AEC7-4954-9EAA-F07FD6184781}
                  Path: E:\Adobe CS5\payloads\AdobeAfterEffects10RoyaltyWrapperAll\Install.db
                Updating media info for: {22F41D72-2E97-46AE-B8C4-EF66876C7838}
                  Path: E:\Adobe CS5\payloads\AdobePremierePro5ProtectedWrapperAll\AdobePremierePro5ProtectedWrapperAll.ms i
                Updating media info for: {234A555C-70F5-48FB-A7E2-32410EB5AF64}
                  Path: E:\Adobe CS5\payloads\AdobeItalianSpeechAnalysisModels2All\AdobeItalianSpeechAnalysisModels2All.ms i
                Updating media info for: {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655}
                  Path: E:\Adobe CS5\payloads\AdobeMobileExtension_Flash11-en_US\AdobeMobileExtension_Flash11-en_US.msi
                Updating media info for: {26B63C3A-0BFF-1033-B389-A7ACEC31657E}
                  Path: E:\Adobe CS5\payloads\AdobeInDesign7AppLang-en_GB\AdobeInDesign7AppLang-en_GB.msi
                Updating media info for: {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA}
                  Path: E:\Adobe CS5\payloads\AdobeXMPPanelsAll\Install.db
                Updating media info for: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5}
                  Path: E:\Adobe CS5\payloads\AdobeAPE3-mul\Install.db
                Updating media info for: {30221E3E-4C47-4560-A296-DD9ABB500C21}
                  Path: E:\Adobe CS5\payloads\AIR2_Flash11-mul\Install.db
                Updating media info for: {33A3F995-8333-4676-8D6F-AB7674BB52EA}
                  Path: E:\Adobe CS5\payloads\AMEPCIWrapper5All\Install.db
                Updating media info for: {34F82E6B-8096-45CA-B604-ACACAC22E553}
                  Path: E:\Adobe CS5\payloads\AdobePremierePro5en_USLanguagePack\AdobePremierePro5en_USLanguagePack.msi
                Updating media info for: {36D02DA9-35F2-4686-A2FE-EF3014D2E226}
                  Path: E:\Adobe CS5\payloads\AdobeSpanishSpeechAnalysisModels2All\AdobeSpanishSpeechAnalysisModels2All.ms i
                Updating media info for: {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3}
                  Path: E:\Adobe CS5\payloads\AdobeCameraRaw6.0All\Install.db
                Updating media info for: {39CB2E53-5326-4939-8B5A-0402C6EFBFE3}
                  Path: E:\Adobe CS5\payloads\AdobeColorCommonSetCMYK3-mul\Install.db
                Updating media info for: {3A8C7CB3-2A2E-4EB9-99C9-DF08C324BA70}
                  Path: E:\Adobe CS5\payloads\AdobeFireworks11en_USLanguagePack\AdobeFireworks11en_USLanguagePack.msi
                Updating media info for: {3BF96AC2-0CA1-11DF-B07B-459956D89593}
                  Path: E:\Adobe CS5\payloads\AdobeHelp\AIRInstallerRunner.exe
                Updating media info for: {3F023875-4A52-4605-9DB6-A88D4A813E8D}
                  Path: E:\Adobe CS5\payloads\AdobeCameraRawProfile6.0All\Install.db
                Updating media info for: {3F6B5CAC-733F-1029-B5BD-C0F5E35809F0}
                  Path: E:\Adobe CS5\payloads\AdobeBuzzword-mul\Install.db
                Updating media info for: {406D22BD-7910-479B-96AA-0DB8A36C694B}
                  Path: E:\Adobe CS5\payloads\AdobeAfterEffects10ProtectedWrapperAll\Install.db
                Updating media info for: {40F95A03-885A-45fb-9A14-486BEFEDDF34}
                  Path: E:\Adobe CS5\payloads\AdobeFlashPlayer10_plRel_mul\AdobeFlashPlayer10_plRel_mul.msi
                Updating media info for: {414BDCF9-DE14-4083-BE96-2F4193CE8BBA}
                  Path: E:\Adobe CS5\payloads\AdobeContribute6en_USLanguagePack\AdobeContribute6en_USLanguagePack.msi
                Updating media info for: {4355EE3F-2FDD-4EF4-83EA-2465FBF95B16}
                  Path: E:\Adobe CS5\payloads\AdobeGermanSpeechAnalysisModels2All\Install.db
                Updating media info for: {4438C826-1FD0-4D04-A70B-24FE1580AB21}
                  Path: E:\Adobe CS5\payloads\AdobeMiniBridge1-mul\Install.db
                Updating media info for: {4569AD91-47F4-4D9E-8FC9-717EC32D7AE1}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86_x64\Microsoft_VC80_CRT_x86_x64.msi
                Updating media info for: {479C08E9-FACF-4190-A37A-81D65B4C8D4E}
                  Path: E:\Adobe CS5\payloads\AdobeContribute6-IEPlugin\Install.db
                Updating media info for: {4BE1791F-1D8A-4B8E-B803-D97C5D7CB245}
                  Path: E:\Adobe CS5\payloads\AdobeSoundbooth3ProtectedWrapperAll\Install.db
                Updating media info for: {4C08199E-0D93-4227-8325-F024E71CA7A1}
                  Path: E:\Adobe CS5\payloads\AdobeSING3-mul\Install.db
                Updating media info for: {50A16F0B-47DA-4583-B4FE-E026719A2024}
                  Path: E:\Adobe CS5\payloads\AdobePhotoshop12-en_US_x64\AdobePhotoshop12-en_US_x64.msi
                Updating media info for: {54F4466A-091A-46DA-B697-43D55CEF9DF6}
                  Path: E:\Adobe CS5\payloads\AdobeColorJA_ExtraSettings3-mul\Install.db
                Updating media info for: {56540320-C921-1029-83D9-FE864D1FC1DF}
                  Path: E:\Adobe CS5\payloads\AdobeReviewPanel2-mul\Install.db
                Updating media info for: {5658F35F-15B9-1033-8337-97B78F2D0BE0}
                  Path: E:\Adobe CS5\payloads\AdobeInDesign7IconHandler64-mul\AdobeInDesign7IconHandler64-mul.msi
                Updating media info for: {565DE707-5798-4FC3-8DF6-0F58A348A9B0}
                  Path: E:\Adobe CS5\payloads\AdobePremierePro5RoyaltyAll\AdobePremierePro5RoyaltyAll.msi
                Updating media info for: {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD}
                  Path: E:\Adobe CS5\payloads\AdobeMobileExtension_Flash11-mul\AdobeMobileExtension_Flash11-mul.msi
                Updating media info for: {5DDABB74-A879-4BE7-A4C6-FD41793942DB}
                  Path: E:\Adobe CS5\payloads\AMEDolby5All_x64\AMEDolby5All_x64.msi
                Updating media info for: {5E08533A-2C1B-469D-AFD5-953C9D00031F}
                  Path: E:\Adobe CS5\payloads\BrowserLabCSLive-mul\Install.db
                Updating media info for: {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41}
                  Path: E:\Adobe CS5\payloads\AdobeCameraRaw6.0All-x64\Install.db
                Updating media info for: {635DCFA5-3A47-4452-AEC7-D3B23FFE929D}
                  Path: E:\Adobe CS5\payloads\iPhone_Flash11-mul\iPhone_Flash11-mul.msi
                Updating media info for: {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86\Microsoft_VC90_MFC_x86.msi
                Updating media info for: {64D991B0-4E64-47AC-8A35-291DA2E7D02F}
                  Path: E:\Adobe CS5\payloads\AdobeAfterEffects10SupportAll\Install.db
                Updating media info for: {66173EC7-974E-4652-9468-4A93D2481BF0}
                  Path: E:\Adobe CS5\payloads\AdobeStoryExtension-mul\Install.db
                Updating media info for: {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}
                  Path: E:\Adobe CS5\payloads\AdobePhotoshop12-Core_x64\AdobePhotoshop12-Core_x64.msi
                Updating media info for: {681DE732-3F3A-42F2-91C9-84B1CC9B8535}
                  Path: E:\Adobe CS5\payloads\AdobeContribute6en_GBLanguagePack\AdobeContribute6en_GBLanguagePack.msi
                Updating media info for: {68CEA5C9-2964-4ECB-84A4-D77C511332BC}
                  Path: E:\Adobe CS5\payloads\AMECore5All_x64\Install.db
                Updating media info for: {694213D7-1E0E-4C8F-B822-E2E3680C0FCE}
                  Path: E:\Adobe CS5\payloads\AMECore5All\Install.db
                Updating media info for: {69582206-7E5D-4476-A8F4-ECF90E9C8A69}
                  Path: E:\Adobe CS5\payloads\AdobePhotoshop12-en_US\AdobePhotoshop12-en_US.msi
                Updating media info for: {6ACDB89B-63FB-4C7D-8490-7528E248F25B}
                  Path: E:\Adobe CS5\payloads\AdobeAfterEffects10en_USLanguagePack\AdobeAfterEffects10en_USLanguagePack.ms i
                Updating media info for: {6B485102-4593-43F6-BA45-F14D690B0C64}
                  Path: E:\Adobe CS5\payloads\AdobeSuiteSharedConfiguration-mul\Install.db
                Updating media info for: {6BA6F6D7-1D30-482A-B9B8-20E79D6DB4F9}
                  Path: E:\Adobe CS5\payloads\AdobePremierePro5RoyaltyWrapperAll\AdobePremierePro5RoyaltyWrapperAll.msi
                Updating media info for: {6C7D437A-D2E9-4FE9-A4D9-A6329860835C}
                  Path: E:\Adobe CS5\payloads\AdobeLinguisticsAll\Install.db
                Updating media info for: {6D96660C-1444-410E-9A84-681C0AFB8937}
                  Path: E:\Adobe CS5\payloads\AdobePDFSettings10-mul\AdobePDFSettings10-mul.msi
                Updating media info for: {6E505C8F-2896-11DF-9B64-0013724DD917}
                  Path: E:\Adobe CS5\payloads\AdobeDeviceCentral3-all\Install.db
                Updating media info for: {6F29BE46-E5F3-4146-8A84-20301E5C985A}
                  Path: E:\Adobe CS5\payloads\AdobeColorEU_ExtraSettings3-mul\Install.db
                Updating media info for: {6F3A624B-1B72-4081-96E8-23261F389C5C}
                  Path: E:\Adobe CS5\payloads\AdobeTypeSupport10-mul\Install.db
                Updating media info for: {73A4DC5E-226E-42BA-8ECA-2822592AC044}
                  Path: E:\Adobe CS5\payloads\AdobeVideoProfilesCS3-mul\Install.db
                Updating media info for: {771C9F59-3F22-4610-A23E-321A98ECA264}
                  Path: E:\Adobe CS5\payloads\AdobeOnLocation5en_USLanguagePack\AdobeOnLocation5en_USLanguagePack.msi
                Updating media info for: {7745F18B-FD8A-4011-BE16-588900C503D0}
                  Path: E:\Adobe CS5\payloads\AdobeFlashFonts1-mul\Install.db
                Updating media info for: {7816FDDE-40D4-482D-AD7D-97858985DB3E}
                  Path: E:\Adobe CS5\payloads\AdobeOnLocation5RoyaltyAll\AdobeOnLocation5RoyaltyAll.msi
                Updating media info for: {78A53622-CDBA-49D1-A3D0-D563FB398D0C}
                  Path: E:\Adobe CS5\payloads\AdobeColorCommonSetRGB3-mul\Install.db
                Updating media info for: {7A33510F-1580-42C2-877E-8C5502566292}
                  Path: E:\Adobe CS5\payloads\AdobeAPE3_x64-mul\Install.db
                Updating media info for: {7B7DE224-2ACA-41E2-A94D-5A6C6D75106D}
                  Path: E:\Adobe CS5\payloads\AdobeContribute6-OfficePlugin\AdobeContribute6-OfficePlugin.msi
                Updating media info for: {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E}
                  Path: E:\Adobe CS5\payloads\AdobePhotoshop12-Core\AdobePhotoshop12-Core.msi
                Updating media info for: {7E5AA19B-0B85-4f44-BA26-728851489200}
                  Path: E:\Adobe CS5\payloads\AdobeFlashPlayer10_axRel_mul\AdobeFlashPlayer10_axRel_mul.msi
                Updating media info for: {7EB208EE-0C2B-1033-A6DC-E1BD0289A1F4}
                  Path: E:\Adobe CS5\payloads\AdobeInDesign7AppLang-en_US\AdobeInDesign7AppLang-en_US.msi
                Updating media info for: {7F9C94CD-0BAC-4F8F-8990-6A5886F4D550}
                  Path: E:\Adobe CS5\payloads\AdobeFontsRequired_x64-mul\Install.db
                Updating media info for: {805ABF27-1582-1033-B4AC-82A1DE0DD827}
                  Path: E:\Adobe CS5\payloads\AdobeInDesign7CommonBase-mul\Install.db
                Updating media info for: {8557397C-A42D-486F-97B3-A2CBC2372593}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\Microsoft_VC90_ATL_x86_x64.msi
                Updating media info for: {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B}
                  Path: E:\Adobe CS5\payloads\AdobePhotoshop12-en_GB\AdobePhotoshop12-en_GB.msi
                Updating media info for: {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}
                  Path: E:\Adobe CS5\payloads\AdobeCSXSExtensions2-mul\Install.db
                Updating media info for: {925D058B-564A-443A-B4B2-7E90C6432E55}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC80_ATL_x86_x64\Microsoft_VC80_ATL_x86_x64.msi
                Updating media info for: {925ED7E4-E1B6-4544-8141-1C98A18D2E2E}
                  Path: E:\Adobe CS5\payloads\AdobeOutputModuleAll\Install.db
                Updating media info for: {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\Microsoft_VC90_CRT_x86_x64.msi
                Updating media info for: {92D4A929-78F1-4EC3-B626-08B3CF5B784F}
                  Path: E:\Adobe CS5\payloads\AMEPCI5All\AMEPCI5All.msi
                Updating media info for: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
                Updating media info for: {955EB78F-C938-4EA8-8470-C6EA71685834}
                  Path: E:\Adobe CS5\payloads\AIR2_Flash11-en_US\Install.db
                Updating media info for: {966B69F2-0FBD-1033-B01C-D13C02FFF33F}
                  Path: E:\Adobe CS5\payloads\AdobeInDesign7CommonLang-en_GB\AdobeInDesign7CommonLang-en_GB.msi
                Updating media info for: {98DD55B6-C58C-462F-B8A4-F0585BFEBB15}
                  Path: E:\Adobe CS5\payloads\AdobeCMaps3_x64-mul\Install.db
                Updating media info for: {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7}
                  Path: E:\Adobe CS5\payloads\AdobeTypeSupport10_x64-mul\Install.db
                Updating media info for: {9B97EC91-B3FD-4BFF-88FC-5345A26AC2E7}
                  Path: E:\Adobe CS5\payloads\AdobeIllustrator15-mul\AdobeIllustrator15-mul.msi
                Updating media info for: {A013B68A-B1D9-470F-BB0F-816752F096A3}
                  Path: E:\Adobe CS5\payloads\AMEPCIWrapper5All_x64\Install.db
                Updating media info for: {A1E0C87F-BFE5-490A-898E-05BD4DD2BADF}
                  Path: E:\Adobe CS5\payloads\AdobeInternationalEnglishSpeechAnalysisModels2All\AdobeInternationalEnglishS peechAnalysisModels2All.msi
                Updating media info for: {A32910E5-4084-4A0E-9FFF-D2E9C1B1C134}
                  Path: E:\Adobe CS5\payloads\AdobeEncoreFunctionalContent5All\Install.db
                Updating media info for: {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\Microsoft_VC90_MFC_x86_x64.msi
                Updating media info for: {A47C8AE9-D51B-4A58-A051-396158FC3012}
                  Path: E:\Adobe CS5\payloads\AdobePhotoshop12-en_GB_x64\AdobePhotoshop12-en_GB_x64.msi
                Updating media info for: {A5A8E72E-1B9D-4F99-ADED-F3595CB3D03E}
                  Path: E:\Adobe CS5\payloads\AdobeVideoProfilesAE3-mul\Install.db
                Updating media info for: {A8798E04-96FF-4564-9157-0D4C89CB794C}
                  Path: E:\Adobe CS5\payloads\AdobeDynamiclinkSupport5All\Install.db
                Updating media info for: {AAE6F374-91CB-45FB-9282-4CFA0DED2088}
                  Path: E:\Adobe CS5\payloads\AMEDolbyWrapper5All\Install.db
                Updating media info for: {ABDC1F61-2C50-4BB1-ACDA-66D412D72582}
                  Path: E:\Adobe CS5\payloads\AdobeOnLocation5All\AdobeOnLocation5All.msi
                Updating media info for: {ADAF6949-4547-4B3D-97C5-6FB4D0C08A1E}
                  Path: E:\Adobe CS5\payloads\AdobeSoundbooth3RoyaltyWrapperAll\Install.db
                Updating media info for: {AE9B837F-D135-42FC-BE03-33545B5DCBDC}
                  Path: E:\Adobe CS5\payloads\AdobeWinSoftLinguisticsPluginAll\Install.db
                Updating media info for: {B55FDCCB-8A45-4943-8D90-585C3490A032}
                  Path: E:\Adobe CS5\payloads\AdobeWinSoftLinguisticsPluginAll_x64\Install.db
                Updating media info for: {B60B8713-F828-44F9-BEEE-7596F814E540}
                  Path: E:\Adobe CS5\payloads\AdobeColorEU_Recommended3-mul\Install.db
                Updating media info for: {B842A584-A0BF-4870-A850-9C0E52FD6A20}
                  Path: E:\Adobe CS5\payloads\AdobeEncore5en_USLanguagePack\AdobeEncore5en_USLanguagePack.msi
                Updating media info for: {B8D286BC-A68D-4E74-9F68-8756A49896D8}
                  Path: E:\Adobe CS5\payloads\AdobePremierePro5ProtectedAll\AdobePremierePro5ProtectedAll.msi
                Updating media info for: {BAE5212B-6651-4AD8-B26A-1B284D2665C6}
                  Path: E:\Adobe CS5\payloads\AdobePDFL9.9-mul\Install.db
                Updating media info for: {BB024724-14D5-4AB6-B21C-74EDA63A0A39}
                  Path: E:\Adobe CS5\payloads\HIL_Help_Search\Install.db
                Updating media info for: {BD0D6363-E961-410F-8BF4-ECD8795F3923}
                  Path: E:\Adobe CS5\payloads\AdobeCMaps3-mul\Install.db
                Updating media info for: {BEC5B482-32A1-43E0-B7F7-9BF9592A1069}
                  Path: E:\Adobe CS5\payloads\AdobeColorNA_ExtraSettings3-mul\Install.db
                Updating media info for: {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}
                  Path: E:\Adobe CS5\payloads\AdobeAfterEffects10ProtectedAll\AdobeAfterEffects10ProtectedAll.msi
                Updating media info for: {C79312BD-3E76-4474-A10C-1435D1856A4B}
                  Path: E:\Adobe CS5\payloads\AdobeDreamweaver11-mul\AdobeDreamweaver11-mul.msi
                Updating media info for: {C8C1BAD5-54E6-4146-AD07-3A8AD36569C3}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC80_MFC_x86_x64\Microsoft_VC80_MFC_x86_x64.msi
                Updating media info for: {C925A34A-01B9-42C3-BB88-C7A78835F0EC}
                  Path: E:\Adobe CS5\payloads\ph\ph.msi
                Updating media info for: {CBDD7465-CE11-4A58-9497-C370B65923F1}
                  Path: E:\Adobe CS5\payloads\AdobeFontsRequired-mul\Install.db
                Updating media info for: {CBE4F6C3-788E-4CAC-BA25-26FE39A3BC8C}
                  Path: E:\Adobe CS5\payloads\AdobeSoundbooth3AllTrial\AdobeSoundbooth3AllTrial.msi
                Updating media info for: {CC0EF75D-9336-4E4F-B4A2-99E2E60E161F}
                  Path: E:\Adobe CS5\payloads\AdobeAfterEffectsPresets10All\Install.db
                Updating media info for: {CD29B5CA-4727-4114-9AD9-25CCCE6E4014}
                  Path: E:\Adobe CS5\payloads\AdobeAfterEffects10RoyaltyAll\AdobeAfterEffects10RoyaltyAll.msi
                Updating media info for: {CD693E49-C5EF-4FA6-9037-9B636931C02B}
                  Path: E:\Adobe CS5\payloads\AdobeAmericanEnglishSpeechAnalysisModels2All\Install.db
                Updating media info for: {CFA46C39-C539-4BE9-9364-495003C714AD}
                  Path: E:\Adobe CS5\payloads\SwitchBoard2.0All\Install.db
                Updating media info for: {CFC9F871-7C40-40B6-BE4A-B98A5B309716}
                  Path: E:\Adobe CS5\payloads\AdobeFlash11-mul\AdobeFlash11-mul.msi
                Updating media info for: {D0DAEA50-AD52-4BF9-AD5F-3E09564A8692}
                  Path: E:\Adobe CS5\payloads\AdobeIllustrator15en_GBLanguagePack\AdobeIllustrator15en_GBLanguagePack.msi
                Updating media info for: {D1A19B02-817E-4296-A45B-07853FD74D57}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC80_MFC_x86\Microsoft_VC80_MFC_x86.msi
                Updating media info for: {D26EEF95-420A-4726-B85D-AFBE752EF526}
                  Path: E:\Adobe CS5\payloads\AdobeColorNA_Recommended3-mul\Install.db
                Updating media info for: {D31D91FE-F0E8-4DF1-812C-9400BE92A386}
                  Path: E:\Adobe CS5\payloads\AdobeColorPhotoshop3-mul\Install.db
                Updating media info for: {D3598CAC-AEB3-4234-A1E0-16F47D5F38CC}
                  Path: E:\Adobe CS5\payloads\AMEDolby5All\AMEDolby5All.msi
                Updating media info for: {D3A8C87E-ED6A-41DB-8B21-C29EDA65B154}
                  Path: E:\Adobe CS5\payloads\AdobeIllustrator15en_USLanguagePack\AdobeIllustrator15en_USLanguagePack.msi
                Updating media info for: {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C}
                  Path: E:\Adobe CS5\payloads\aifsdk-win\Install.db
                Updating media info for: {D5E7D8B9-9B8F-4DA0-9B2C-167DC889B0E1}
                  Path: E:\Adobe CS5\payloads\AdobeAfterEffectsFunctionalContent10All\Install.db
                Updating media info for: {D8465547-5D5B-4856-A93A-8AC0A05C5D4D}
                  Path: E:\Adobe CS5\payloads\AdobeEncore5AllRetail\AdobeEncore5AllRetail.msi
                Updating media info for: {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
                  Path: E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\Microsoft_VC80_MFCLOC_x86.msi
                Updating media info for: {DE5DE662-2ECB-4D93-967B-221FBCC8A736}
                  Path: E:\Adobe CS5\payloads\AdobeSoundbooth3ProtectedAll\AdobeSoundbooth3ProtectedAll.msi
                Updating media info for: {DE60F0DE-469A-42DC-A678-978313210057}
                  Path: E:\Adobe CS5\payloads\AdobeContribute6-mul\AdobeContribute6-mul.msi
                Updating media info for: {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3}
                  Path: E:\Adobe CS5\payloads\AdobePDFSettings10-ja_JP\AdobePDFSettings10-ja_JP.msi
                Updating media info for: {DEC9BB26-1381-1033-A965-E3BD5F2EF8BC}
                  Path: E:\Adobe CS5\payloads\AdobeInDesign7AppBase2-mul\Install.db
                Updating media info for: {E319B9F9-4DE6-462C-970B-77D06C7807EE}
                  Path: E:\Adobe CS5\payloads\Players_Flash11-mul\Players_Flash11-mul.msi
                Updating media info for: {E39A5ABD-516B-46F9-A042-694BBA6A4E08}
                  Path: E:\Adobe CS5\payloads\AdobeFontsRecommended-mul\Install.db
                Updating media info for: {E3E040E8-4CCD-4C71-8BAF-80BB2AD5DA04}
                  Path: E:\Adobe CS5\payloads\AdobeDreamweaver11en_USLanguagePack\AdobeDreamweaver11en_USLanguagePack.msi
                Updating media info for: {E4CB336B-159D-1033-B84D-B9A01A0BE4A9}
                  Path: E:\Adobe CS5\payloads\AdobeInDesign7IconHandler-mul\Install.db
                Updating media info for: {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6}
                  Path: E:\Adobe CS5\payloads\AdobeExtensionManager5.0All\Install.db
                Updating media info for: {E5087BCA-6496-47A7-B9C4-B85D1CF062AE}
                  Path: E:\Adobe CS5\payloads\AdobeColorJA_Recommended3-mul\Install.db
                Updating media info for: {E5DD149F-8370-48F9-A32C-2E3DC776CFFB}
                  Path: E:\Adobe CS5\payloads\AdobeJRECS5-mul\Install.db
                Updating media info for: {E6F68811-F702-492C-A7DA-D22CA670BC22}
                  Path: E:\Adobe CS5\payloads\AdobeSoundbooth3en_USLanguagePack\AdobeSoundbooth3en_USLanguagePack.msi
                Updating media info for: {E7F2C606-8529-4028-B26E-8407DB43DD45}
                  Path: E:\Adobe CS5\payloads\AdobeFrenchSpeechAnalysisModels2All\Install.db
                Updating media info for: {E8815668-95B0-443D-AC92-2BFD7DD8F16A}
                  Path: E:\Adobe CS5\payloads\AdobeFlashCatalyst-mul\AdobeFlashCatalyst-mul.msi
                Updating media info for: {E995AC53-954A-48D2-A861-613B8D42A9BE}
                  Path: E:\Adobe CS5\payloads\AdobeExtendScriptToolkit3.5.0-mul\Install.db
                Updating media info for: {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345}
                  Path: E:\Adobe CS5\payloads\TLF_Flash11-mul\TLF_Flash11-mul.msi
                Updating media info for: {F319804F-E3A4-4C02-8AEC-CB39A4F6447E}
                  Path: E:\Adobe CS5\payloads\AdobeSoundbooth3RoyaltyAll\AdobeSoundbooth3RoyaltyAll.msi
                Updating media info for: {F3ECF5C7-9A9D-460A-B3D6-C7E4C1DFD040}
                  Path: E:\Adobe CS5\payloads\AdobeMotionPicture3-mul\Install.db
                Updating media info for: {F46A4C18-2EAD-49F0-A244-994226F93B39}
                  Path: E:\Adobe CS5\payloads\AdobeJapaneseSpeechAnalysisModels2All\AdobeJapaneseSpeechAnalysisModels2All. msi
                Updating media info for: {F4EC52C6-1223-4EA9-8C48-F4E6AB2EEC19}
                  Path: E:\Adobe CS5\payloads\AdobePremiereProFunctionalContent5All\Install.db
                Updating media info for: {F6CCA85F-7527-4AFF-82B6-26532A74A244}
                  Path: E:\Adobe CS5\payloads\AdobeFireworks11en_GBLanguagePack\AdobeFireworks11en_GBLanguagePack.msi
                Updating media info for: {F6FA54C9-3E8F-4416-905C-DA5398DF9640}
                  Path: E:\Adobe CS5\payloads\AdobeAIR1.5.3-mul\AdobeAIRInstaller.exe
                Updating media info for: {F77882B9-A94F-44F4-A739-8370749255B6}
                  Path: E:\Adobe CS5\payloads\AdobePremierePro5SupportAll\Install.db
                Updating media info for: {F8F0792D-8A6B-44F6-B2AF-AD1A40DF1BFD}
                  Path: E:\Adobe CS5\payloads\AMEDolbyWrapper5All_x64\Install.db
                Updating media info for: {F9766AC1-1461-1033-B862-DF8FE1C033BE}
                  Path: E:\Adobe CS5\payloads\AdobeInDesign7AppBase-mul\AdobeInDesign7AppBase-mul.msi
                Updating media info for: {F9C71630-0EE3-475C-9E2B-ED95AE197DBD}
                  Path: E:\Adobe CS5\payloads\AMEPCI5All_x64\AMEPCI5All_x64.msi
                Updating media info for: {FBB02B04-C034-4382-A3F6-57416E2752C4}
                  Path: E:\Adobe CS5\payloads\AdobeMasterCollection5-mul\AdobeMasterCollection5-mul.msi
                Updating media info for: {FD5603A3-1375-1033-872D-8F09140FFDB2}
                  Path: E:\Adobe CS5\payloads\AdobeInDesign7AppFSet-Roman\Install.db
                --------------------  END  - Updating Media Sources -  END  --------------------
                [    3432] Sun Feb 13 13:04:33 2011  INFO
                Supported RIBS version range: [0.0.66.0,3.0.122.0]
                ----------------- CreatePayloadSession: machine is x64 ---------------
                [    3432] Sun Feb 13 13:04:38 2011  INFO
                ______ Verify Dependency Subscribers ______
                Setting property "INSTALLDIR" to: C:\Program Files\Adobe
                Setting property "installLanguage" to: en_GB
                Attempting to find the selected language in the set of available payload languages
                Setting property "installSourcePath" to: E:\Adobe CS5
                Overwrite property "userASUPath" to: C:\Users\GARY&S~1\AppData\Local\Adobe\OOBE\PDApp\
                Found payload actions:
                Deciding what installer mode to use...
                BEGIN Setting requested payload actions
                Value returned on lookup of payload: {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 is: true
                Action string for  {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86  is none
                Value returned on lookup of payload: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86 is: true
                Action string for  {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86  is none
                Value returned on lookup of payload: {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86 is: true
                Action string for  {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86  is none
                Value returned on lookup of payload: {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86 is: true
                Action string for  {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86  is none
                Value returned on lookup of payload: {55516693-25E2-4620-BF94-6BA66B00419F} Adobe Player for Embedding_3.1_AdobeAPE3-mul is: true
                Action string for  {55516693-25E2-4620-BF94-6BA66B00419F} Adobe Player for Embedding_3.1_AdobeAPE3-mul  is none
                Payload {55516693-25E2-4620-BF94-6BA66B00419F} Adobe Player for Embedding_3.1_AdobeAPE3-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding is: true
                Action string for  {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding  is none
                Value returned on lookup of payload: {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 is: true
                Action string for  {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86  is none
                Value returned on lookup of payload: {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86 is: true
                Action string for  {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86  is none
                Value returned on lookup of payload: {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE is: true
                Action string for  {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE  is none
                Value returned on lookup of payload: {A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All is: true
                Action string for  {A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All  is none
                Payload {A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer is: true
                Action string for  {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer  is none
                Value returned on lookup of payload: {6B485102-4593-43F6-BA45-F14D690B0C64} Suite Shared Configuration CS5 is: true
                Action string for  {6B485102-4593-43F6-BA45-F14D690B0C64} Suite Shared Configuration CS5  is none
                Value returned on lookup of payload: {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 is: true
                Action string for  {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5  is none
                Value returned on lookup of payload: {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 is: true
                Action string for  {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5  is none
                Value returned on lookup of payload: {FA2A2592-3F40-456D-ACEC-166CB79D4F98} Adobe CSXS Infrastructure CS5_2.0.1_AdobeCSXSInfrastructure2-mul is: true
                Action string for  {FA2A2592-3F40-456D-ACEC-166CB79D4F98} Adobe CSXS Infrastructure CS5_2.0.1_AdobeCSXSInfrastructure2-mul  is none
                Payload {FA2A2592-3F40-456D-ACEC-166CB79D4F98} Adobe CSXS Infrastructure CS5_2.0.1_AdobeCSXSInfrastructure2-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5 is: true
                Action string for  {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5  is none
                Value returned on lookup of payload: {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86 is: true
                Action string for  {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86  is none
                Value returned on lookup of payload: {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 is: true
                Action string for  {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5  is none
                Value returned on lookup of payload: {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport is: true
                Action string for  {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport  is none
                Value returned on lookup of payload: {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule is: true
                Action string for  {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule  is none
                Value returned on lookup of payload: {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0 is: true
                Action string for  {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0  is none
                Value returned on lookup of payload: {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64 is: true
                Action string for  {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64  is none
                Value returned on lookup of payload: {4569AD91-47F4-4D9E-8FC9-717EC32D7AE1} Microsoft_VC80_CRT_x86_x64 is: true
                Action string for  {4569AD91-47F4-4D9E-8FC9-717EC32D7AE1} Microsoft_VC80_CRT_x86_x64  is none
                Value returned on lookup of payload: {1E9FC118-651D-4934-97BE-E53CAE5C7D45} Microsoft_VC80_MFCLOC_x86_x64 is: true
                Action string for  {1E9FC118-651D-4934-97BE-E53CAE5C7D45} Microsoft_VC80_MFCLOC_x86_x64  is none
                Value returned on lookup of payload: {C8C1BAD5-54E6-4146-AD07-3A8AD36569C3} Microsoft_VC80_MFC_x86_x64 is: true
                Action string for  {C8C1BAD5-54E6-4146-AD07-3A8AD36569C3} Microsoft_VC80_MFC_x86_x64  is none
                Value returned on lookup of payload: {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64 is: true
                Action string for  {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64  is none
                Value returned on lookup of payload: {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64 is: true
                Action string for  {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64  is none
                Value returned on lookup of payload: {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp is: true
                Action string for  {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp  is none
                Value returned on lookup of payload: {0061DED1-0204-44C5-B6E0-FAD6AA00E320} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll is: true
                Action string for  {0061DED1-0204-44C5-B6E0-FAD6AA00E320} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll  is none
                Payload {0061DED1-0204-44C5-B6E0-FAD6AA00E320} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 is: true
                Action string for  {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5  is none
                Value returned on lookup of payload: {187A7A38-6DD4-4549-AECD-22BA6BC2F002} Adobe ExtendScript Toolkit CS5_3.5.0_AdobeExtendScriptToolkit3.5.0-mul is: true
                Action string for  {187A7A38-6DD4-4549-AECD-22BA6BC2F002} Adobe ExtendScript Toolkit CS5_3.5.0_AdobeExtendScriptToolkit3.5.0-mul  is none
                Payload {187A7A38-6DD4-4549-AECD-22BA6BC2F002} Adobe ExtendScript Toolkit CS5_3.5.0_AdobeExtendScriptToolkit3.5.0-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5 is: true
                Action string for  {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5  is none
                Value returned on lookup of payload: {9AF7B703-B806-4C74-94E5-82963EFC0188} Adobe Extension Manager CS5_5.0.1_AdobeExtensionManager5.0All is: true
                Action string for  {9AF7B703-B806-4C74-94E5-82963EFC0188} Adobe Extension Manager CS5_5.0.1_AdobeExtensionManager5.0All  is none
                Payload {9AF7B703-B806-4C74-94E5-82963EFC0188} Adobe Extension Manager CS5_5.0.1_AdobeExtensionManager5.0All is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5 is: true
                Action string for  {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5  is none
                Value returned on lookup of payload: {FD58D99B-9927-4226-8E00-959A4F76BD89} Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All is: true
                Action string for  {FD58D99B-9927-4226-8E00-959A4F76BD89} Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All  is none
                Payload {FD58D99B-9927-4226-8E00-959A4F76BD89} Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw is: true
                Action string for  {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw  is none
                Value returned on lookup of payload: {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5 is: true
                Action string for  {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5  is none
                Value returned on lookup of payload: {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB is: true
                Action string for  {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB  is none
                Value returned on lookup of payload: {D8676884-2C59-41BB-B315-486D98A20867} Adobe Media Encoder CS5 X64_5.0.1_AMECore5All_x64 is: true
                Action string for  {D8676884-2C59-41BB-B315-486D98A20867} Adobe Media Encoder CS5 X64_5.0.1_AMECore5All_x64  is none
                Payload {D8676884-2C59-41BB-B315-486D98A20867} Adobe Media Encoder CS5 X64_5.0.1_AMECore5All_x64 is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 is: true
                Action string for  {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64  is none
                Value returned on lookup of payload: {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK is: true
                Action string for  {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK  is none
                Value returned on lookup of payload: {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5 is: false
                Action string for  {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5  is none
                Value returned on lookup of payload: {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5 is: true
                Action string for  {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5  is none
                Value returned on lookup of payload: {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5 is: true
                Action string for  {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5  is none
                Value returned on lookup of payload: {E5087BCA-6496-47A7-B9C4-B85D1CF062AE} AdobeColorJA CS5 is: false
                Action string for  {E5087BCA-6496-47A7-B9C4-B85D1CF062AE} AdobeColorJA CS5  is none
                Value returned on lookup of payload: {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5 is: true
                Action string for  {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5  is none
                Value returned on lookup of payload: {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5 is: false
                Action string for  {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5  is none
                Value returned on lookup of payload: {F9997A85-B21A-48E4-9C8A-7E1352AB1C62} Adobe Player for Embedding x64_3.1_AdobeAPE3_x64-mul is: true
                Action string for  {F9997A85-B21A-48E4-9C8A-7E1352AB1C62} Adobe Player for Embedding x64_3.1_AdobeAPE3_x64-mul  is none
                Payload {F9997A85-B21A-48E4-9C8A-7E1352AB1C62} Adobe Player for Embedding x64_3.1_AdobeAPE3_x64-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {7A33510F-1580-42C2-877E-8C5502566292} Adobe Player for Embedding x64 is: true
                Action string for  {7A33510F-1580-42C2-877E-8C5502566292} Adobe Player for Embedding x64  is none
                Value returned on lookup of payload: {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5 is: true
                Action string for  {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5  is none
                Value returned on lookup of payload: {98DD55B6-C58C-462F-B8A4-F0585BFEBB15} AdobeCMaps x64 CS5 is: true
                Action string for  {98DD55B6-C58C-462F-B8A4-F0585BFEBB15} AdobeCMaps x64 CS5  is none
                Value returned on lookup of payload: {17C6080E-F475-4B49-A30C-EEB85673E999} AdobePDFL x64 CS5 is: true
                Action string for  {17C6080E-F475-4B49-A30C-EEB85673E999} AdobePDFL x64 CS5  is none
                Value returned on lookup of payload: {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7} AdobeTypeSupport x64 CS5 is: true
                Action string for  {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7} AdobeTypeSupport x64 CS5  is none
                Value returned on lookup of payload: {5056CCD0-DDD6-47D1-9D46-612FA03FF82E} Adobe Media Encoder CS5 PCI WRAPPER X64_5.0.1_AMEPCIWrapper5All_x64 is: true
                Action string for  {5056CCD0-DDD6-47D1-9D46-612FA03FF82E} Adobe Media Encoder CS5 PCI WRAPPER X64_5.0.1_AMEPCIWrapper5All_x64  is none
                Payload {5056CCD0-DDD6-47D1-9D46-612FA03FF82E} Adobe Media Encoder CS5 PCI WRAPPER X64_5.0.1_AMEPCIWrapper5All_x64 is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {A013B68A-B1D9-470F-BB0F-816752F096A3} Adobe Media Encoder CS5 PCI WRAPPER X64 is: true
                Action string for  {A013B68A-B1D9-470F-BB0F-816752F096A3} Adobe Media Encoder CS5 PCI WRAPPER X64  is none
                Value returned on lookup of payload: {7F9C94CD-0BAC-4F8F-8990-6A5886F4D550} Required Common Fonts Installation x64 is: true
                Action string for  {7F9C94CD-0BAC-4F8F-8990-6A5886F4D550} Required Common Fonts Installation x64  is none
                Value returned on lookup of payload: {5C6A2D6E-4C4B-40AC-998A-B09B24DB631F} Adobe Media Encoder CS5 Dolby WRAPPER X64_5.0.1_AMEDolbyWrapper5All_x64 is: true
                Action string for  {5C6A2D6E-4C4B-40AC-998A-B09B24DB631F} Adobe Media Encoder CS5 Dolby WRAPPER X64_5.0.1_AMEDolbyWrapper5All_x64  is none
                Payload {5C6A2D6E-4C4B-40AC-998A-B09B24DB631F} Adobe Media Encoder CS5 Dolby WRAPPER X64_5.0.1_AMEDolbyWrapper5All_x64 is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {F8F0792D-8A6B-44F6-B2AF-AD1A40DF1BFD} Adobe Media Encoder CS5 Dolby WRAPPER X64 is: true
                Action string for  {F8F0792D-8A6B-44F6-B2AF-AD1A40DF1BFD} Adobe Media Encoder CS5 Dolby WRAPPER X64  is none
                Value returned on lookup of payload: {010B3947-C8F7-4F18-BF03-49A8662CC4A9} Adobe Photoshop CS5 Support_12.0.3_AdobePhotoshop12-Support is: true
                Action string for  {010B3947-C8F7-4F18-BF03-49A8662CC4A9} Adobe Photoshop CS5 Support_12.0.3_AdobePhotoshop12-Support  is none
                Payload {010B3947-C8F7-4F18-BF03-49A8662CC4A9} Adobe Photoshop CS5 Support_12.0.3_AdobePhotoshop12-Support is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A} Adobe Photoshop CS5 Support is: true
                Action string for  {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A} Adobe Photoshop CS5 Support  is none
                Value returned on lookup of payload: {A1CABA8D-CF84-402F-8948-D2567915D40C} Pixel Bender Toolkit_2.5_aifsdk-win is: true
                Action string for  {A1CABA8D-CF84-402F-8948-D2567915D40C} Pixel Bender Toolkit_2.5_aifsdk-win  is none
                Payload {A1CABA8D-CF84-402F-8948-D2567915D40C} Pixel Bender Toolkit_2.5_aifsdk-win is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C} Pixel Bender Toolkit is: true
                Action string for  {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C} Pixel Bender Toolkit  is none
                Value returned on lookup of payload: {3FE9B5F2-1ABD-1027-89E7-AA1204825831} Adobe InDesign CS5 Application Base Files2_7.0.3.535_AdobeInDesign7AppBase2-mul is: true
                Action string for  {3FE9B5F2-1ABD-1027-89E7-AA1204825831} Adobe InDesign CS5 Application Base Files2_7.0.3.535_AdobeInDesign7AppBase2-mul  is none
                Payload {3FE9B5F2-1ABD-1027-89E7-AA1204825831} Adobe InDesign CS5 Application Base Files2_7.0.3.535_AdobeInDesign7AppBase2-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {DEC9BB26-1381-1033-A965-E3BD5F2EF8BC} Adobe InDesign CS5 Application Base Files2 is: true
                Action string for  {DEC9BB26-1381-1033-A965-E3BD5F2EF8BC} Adobe InDesign CS5 Application Base Files2  is none
                Value returned on lookup of payload: {FD5603A3-1375-1033-872D-8F09140FFDB2} Adobe InDesign CS5 Application Feature Set Files is: true
                Action string for  {FD5603A3-1375-1033-872D-8F09140FFDB2} Adobe InDesign CS5 Application Feature Set Files  is none
                Value returned on lookup of payload: {805ABF27-1582-1033-B4AC-82A1DE0DD827} Adobe InDesign CS5 Common Base Files is: true
                Action string for  {805ABF27-1582-1033-B4AC-82A1DE0DD827} Adobe InDesign CS5 Common Base Files  is none
                Value returned on lookup of payload: {925D058B-564A-443A-B4B2-7E90C6432E55} Microsoft_VC80_ATL_x86_x64 is: true
                Action string for  {925D058B-564A-443A-B4B2-7E90C6432E55} Microsoft_VC80_ATL_x86_x64  is none
                Value returned on lookup of payload: {C925A34A-01B9-42C3-BB88-C7A78835F0EC} ph is: true
                Action string for  {C925A34A-01B9-42C3-BB88-C7A78835F0EC} ph  is none
                Value returned on lookup of payload: {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR is: true
                Action string for  {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR  is none
                Value returned on lookup of payload: {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player is: true
                Action string for  {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player  is none
                Value returned on lookup of payload: {03AA8100-8A65-11DF-9F66-0013724DD917} DeviceCentral_3.0.1_AdobeDeviceCentral3-all is: true
                Action string for  {03AA8100-8A65-11DF-9F66-0013724DD917} DeviceCentral_3.0.1_AdobeDeviceCentral3-all  is none
                Payload {03AA8100-8A65-11DF-9F66-0013724DD917} DeviceCentral_3.0.1_AdobeDeviceCentral3-all is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral is: true
                Action string for  {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral  is none
                Value returned on lookup of payload: {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US is: false
                Action string for  {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US  is none
                Payload {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {AD3268E2-8A6B-11DF-8A38-0024E8692489} DeviceCentral_3.0.1_DeviceCentral3LP-en_GB is: true
                Action string for  {AD3268E2-8A6B-11DF-8A38-0024E8692489} DeviceCentral_3.0.1_DeviceCentral3LP-en_GB  is none
                Payload {AD3268E2-8A6B-11DF-8A38-0024E8692489} DeviceCentral_3.0.1_DeviceCentral3LP-en_GB is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB is: true
                Action string for  {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB  is none
                Payload {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {123ABCFA-AE86-4B1C-A4D8-A732BEF9C86B} Adobe Bridge CS5_4.0.4_AdobeBridge4-mul is: true
                Action string for  {123ABCFA-AE86-4B1C-A4D8-A732BEF9C86B} Adobe Bridge CS5_4.0.4_AdobeBridge4-mul  is none
                Payload {123ABCFA-AE86-4B1C-A4D8-A732BEF9C86B} Adobe Bridge CS5_4.0.4_AdobeBridge4-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5 is: true
                Action string for  {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5  is none
                Value returned on lookup of payload: {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5 is: true
                Action string for  {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5  is none
                Value returned on lookup of payload: {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5 is: true
                Action string for  {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5  is none
                Value returned on lookup of payload: {66173EC7-974E-4652-9468-4A93D2481BF0} CSXS Story Extension is: true
                Action string for  {66173EC7-974E-4652-9468-4A93D2481BF0} CSXS Story Extension  is none
                Value returned on lookup of payload: {BB024724-14D5-4AB6-B21C-74EDA63A0A39} HIL Help Search is: true
                Action string for  {BB024724-14D5-4AB6-B21C-74EDA63A0A39} HIL Help Search  is none
                Value returned on lookup of payload: {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5 is: true
                Action string for  {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5  is none
                Value returned on lookup of payload: {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3} PDF Settings CS5 is: false
                Action string for  {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3} PDF Settings CS5  is none
                Value returned on lookup of payload: {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation is: true
                Action string for  {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation  is none
                Value returned on lookup of payload: {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation is: true
                Action string for  {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation  is none
                Value returned on lookup of payload: {03EEF3DA-71F9-4FE5-92AD-D10142E26459} SiteCatalyst NetAverages is: true
                Action string for  {03EEF3DA-71F9-4FE5-92AD-D10142E26459} SiteCatalyst NetAverages  is none
                Value returned on lookup of payload: {5E08533A-2C1B-469D-AFD5-953C9D00031F} Adobe BrowserLab CS Live is: true
                Action string for  {5E08533A-2C1B-469D-AFD5-953C9D00031F} Adobe BrowserLab CS Live  is none
                Value returned on lookup of payload: {32841ECE-EC28-42CD-A4DD-6CE832A7EA8D} Photoshop Camera Raw (64 bit)_6.3_AdobeCameraRaw6.0All-x64 is: true
                Action string for  {32841ECE-EC28-42CD-A4DD-6CE832A7EA8D} Photoshop Camera Raw (64 bit)_6.3_AdobeCameraRaw6.0All-x64  is none
                Payload {32841ECE-EC28-42CD-A4DD-6CE832A7EA8D} Photoshop Camera Raw (64 bit)_6.3_AdobeCameraRaw6.0All-x64 is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41} Photoshop Camera Raw (64 bit) is: true
                Action string for  {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41} Photoshop Camera Raw (64 bit)  is none
                Value returned on lookup of payload: {4438C826-1FD0-4D04-A70B-24FE1580AB21} Adobe Mini Bridge CS5 is: true
                Action string for  {4438C826-1FD0-4D04-A70B-24FE1580AB21} Adobe Mini Bridge CS5  is none
                Value returned on lookup of payload: {694213D7-1E0E-4C8F-B822-E2E3680C0FCE} Adobe Media Encoder CS5 is: false
                Action string for  {694213D7-1E0E-4C8F-B822-E2E3680C0FCE} Adobe Media Encoder CS5  is donotinstall
                Selection of payload {694213D7-1E0E-4C8F-B822-E2E3680C0FCE} Adobe Media Encoder CS5 is allowed but the user has marked it for not to install
                Value returned on lookup of payload: {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX is: true
                Action string for  {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX  is none
                Value returned on lookup of payload: {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin is: true
                Action string for  {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin  is none
                Value returned on lookup of payload: {11C0657F-2BD4-4CBC-87F3-9455DC91886E} Recommended Common Fonts Installation x64 is: true
                Action string for  {11C0657F-2BD4-4CBC-87F3-9455DC91886E} Recommended Common Fonts Installation x64  is none
                Value returned on lookup of payload: {B55FDCCB-8A45-4943-8D90-585C3490A032} Adobe WinSoft Linguistics Plugin CS5 x64 is: true
                Action string for  {B55FDCCB-8A45-4943-8D90-585C3490A032} Adobe WinSoft Linguistics Plugin CS5 x64  is none
                Value returned on lookup of payload: {D31D91FE-F0E8-4DF1-812C-9400BE92A386} AdobeColorPhotoshop CS5 is: true
                Action string for  {D31D91FE-F0E8-4DF1-812C-9400BE92A386} AdobeColorPhotoshop CS5  is none
                Value returned on lookup of payload: {73A4DC5E-226E-42BA-8ECA-2822592AC044} AdobeColorVideoProfilesCS CS5 is: true
                Action string for  {73A4DC5E-226E-42BA-8ECA-2822592AC044} AdobeColorVideoProfilesCS CS5  is none
                Value returned on lookup of payload: {CD693E49-C5EF-4FA6-9037-9B636931C02B} AmericanEnglishSpeechAnalysisModels is: true
                Action string for  {CD693E49-C5EF-4FA6-9037-9B636931C02B} AmericanEnglishSpeechAnalysisModels  is none
                Value returned on lookup of payload: {0669F23C-1B69-41B4-A3ED-4F54A5986D66} Adobe Linguistics CS5 x64 is: true
                Action string for  {0669F23C-1B69-41B4-A3ED-4F54A5986D66} Adobe Linguistics CS5 x64  is none
                Value returned on lookup of payload: {88BE801D-C8EC-46A4-92AC-06CE56FE0E0A} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-mul is: true
                Action string for  {88BE801D-C8EC-46A4-92AC-06CE56FE0E0A} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-mul  is none
                Payload {88BE801D-C8EC-46A4-92AC-06CE56FE0E0A} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {30221E3E-4C47-4560-A296-DD9ABB500C21} AIR2 For Adobe Flash Pro is: true
                Action string for  {30221E3E-4C47-4560-A296-DD9ABB500C21} AIR2 For Adobe Flash Pro  is none
                Value returned on lookup of payload: {A69CC698-119E-450F-9AEC-2F377C03B33B} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-en_US is: true
                Action string for  {A69CC698-119E-450F-9AEC-2F377C03B33B} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-en_US  is none
                Payload {A69CC698-119E-450F-9AEC-2F377C03B33B} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-en_US is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US is: true
                Action string for  {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US  is none
                Payload {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {CC0EF75D-9336-4E4F-B4A2-99E2E60E161F} Adobe After Effects CS5 Presets is: true
                Action string for  {CC0EF75D-9336-4E4F-B4A2-99E2E60E161F} Adobe After Effects CS5 Presets  is none
                Value returned on lookup of payload: {64D991B0-4E64-47AC-8A35-291DA2E7D02F} Adobe After Effects CS5 Support is: true
                Action string for  {64D991B0-4E64-47AC-8A35-291DA2E7D02F} Adobe After Effects CS5 Support  is none
                Value returned on lookup of payload: {D5E7D8B9-9B8F-4DA0-9B2C-167DC889B0E1} Adobe After Effects CS5 Template Projects & Footage is: true
                Action string for  {D5E7D8B9-9B8F-4DA0-9B2C-167DC889B0E1} Adobe After Effects CS5 Template Projects & Footage  is none
                Value returned on lookup of payload: {AAC33035-8CD9-4089-900B-10F4350AE81E} Adobe After Effects CS5 Third Party Content Wrapper_10.0.1_AdobeAfterEffects10ProtectedWrapperAll is: true
                Action string for  {AAC33035-8CD9-4089-900B-10F4350AE81E} Adobe After Effects CS5 Third Party Content Wrapper_10.0.1_AdobeAfterEffects10ProtectedWrapperAll  is none
                Payload {AAC33035-8CD9-4089-900B-10F4350AE81E} Adobe After Effects CS5 Third Party Content Wrapper_10.0.1_AdobeAfterEffects10ProtectedWrapperAll is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {406D22BD-7910-479B-96AA-0DB8A36C694B} Adobe After Effects CS5 Third Party Content Wrapper is: true
                Action string for  {406D22BD-7910-479B-96AA-0DB8A36C694B} Adobe After Effects CS5 Third Party Content Wrapper  is none
                Value returned on lookup of payload: {A8573435-DB08-4E7E-8E19-D16BD9A04736} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper_10.0.1_AdobeAfterEffects10RoyaltyWrapperAll is: true
                Action string for  {A8573435-DB08-4E7E-8E19-D16BD9A04736} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper_10.0.1_AdobeAfterEffects10RoyaltyWrapperAll  is none
                Payload {A8573435-DB08-4E7E-8E19-D16BD9A04736} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper_10.0.1_AdobeAfterEffects10RoyaltyWrapperAll is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {20F72893-AEC7-4954-9EAA-F07FD6184781} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper is: true
                Action string for  {20F72893-AEC7-4954-9EAA-F07FD6184781} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper  is none
                Value returned on lookup of payload: {DF2B2B91-F938-1051-88C6-AE7C8C5B3B23} Adobe Buzzword CS5_1.0_AdobeBuzzword-mul is: true
                Action string for  {DF2B2B91-F938-1051-88C6-AE7C8C5B3B23} Adobe Buzzword CS5_1.0_AdobeBuzzword-mul  is none
                Payload {DF2B2B91-F938-1051-88C6-AE7C8C5B3B23} Adobe Buzzword CS5_1.0_AdobeBuzzword-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {3F6B5CAC-733F-1029-B5BD-C0F5E35809F0} Adobe Buzzword CS5 is: true
                Action string for  {3F6B5CAC-733F-1029-B5BD-C0F5E35809F0} Adobe Buzzword CS5  is none
                Value returned on lookup of payload: {A32910E5-4084-4A0E-9FFF-D2E9C1B1C134} Adobe Encore CS5 Library is: true
                Action string for  {A32910E5-4084-4A0E-9FFF-D2E9C1B1C134} Adobe Encore CS5 Library  is none
                Value returned on lookup of payload: {1A48007B-34D2-44BD-8708-B570F5339C14} Adobe Encore CS5 Royalty Codecs Installer Wrapper is: true
                Action string for  {1A48007B-34D2-44BD-8708-B570F5339C14} Adobe Encore CS5 Royalty Codecs Installer Wrapper  is none
                Value returned on lookup of payload: {7745F18B-FD8A-4011-BE16-588900C503D0} Adobe Flash Fonts1 is: true
                Action string for  {7745F18B-FD8A-4011-BE16-588900C503D0} Adobe Flash Fonts1  is none
                Value returned on lookup of payload: {E4CB336B-159D-1033-B84D-B9A01A0BE4A9} Adobe InDesign CS5 Icon Handler is: true
                Action string for  {E4CB336B-159D-1033-B84D-B9A01A0BE4A9} Adobe InDesign CS5 Icon Handler  is none
                Value returned on lookup of payload: {AAE6F374-91CB-45FB-9282-4CFA0DED2088} Adobe Media Encoder CS5 Dolby WRAPPER is: false
                Action string for  {AAE6F374-91CB-45FB-9282-4CFA0DED2088} Adobe Media Encoder CS5 Dolby WRAPPER  is donotinstall
                Selection of payload {AAE6F374-91CB-45FB-9282-4CFA0DED2088} Adobe Media Encoder CS5 Dolby WRAPPER is not allowed therefore shall be re-checking later
                Value returned on lookup of payload: {33A3F995-8333-4676-8D6F-AB7674BB52EA} Adobe Media Encoder CS5 PCI WRAPPER is: false
                Action string for  {33A3F995-8333-4676-8D6F-AB7674BB52EA} Adobe Media Encoder CS5 PCI WRAPPER  is donotinstall
                Selection of payload {33A3F995-8333-4676-8D6F-AB7674BB52EA} Adobe Media Encoder CS5 PCI WRAPPER is not allowed therefore shall be re-checking later
                Value returned on lookup of payload: {6C6D990F-FC88-4F07-912C-DA37468D9A3C} Adobe OnLocation CS5 Royalty Content Wrapper_5.0.1_AdobeOnLocation5RoyaltyWrapperAll is: true
                Action string for  {6C6D990F-FC88-4F07-912C-DA37468D9A3C} Adobe OnLocation CS5 Royalty Content Wrapper_5.0.1_AdobeOnLocation5RoyaltyWrapperAll  is none
                Payload {6C6D990F-FC88-4F07-912C-DA37468D9A3C} Adobe OnLocation CS5 Royalty Content Wrapper_5.0.1_AdobeOnLocation5RoyaltyWrapperAll is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {01367616-4132-4311-911F-49D2EA82F7C2} Adobe OnLocation CS5 Royalty Content Wrapper is: true
                Action string for  {01367616-4132-4311-911F-49D2EA82F7C2} Adobe OnLocation CS5 Royalty Content Wrapper  is none
                Value returned on lookup of payload: {F4EC52C6-1223-4EA9-8C48-F4E6AB2EEC19} Adobe Premiere Pro CS5 Functional Content is: true
                Action string for  {F4EC52C6-1223-4EA9-8C48-F4E6AB2EEC19} Adobe Premiere Pro CS5 Functional Content  is none
                Value returned on lookup of payload: {F77882B9-A94F-44F4-A739-8370749255B6} Adobe Premiere Pro CS5 Support is: true
                Action string for  {F77882B9-A94F-44F4-A739-8370749255B6} Adobe Premiere Pro CS5 Support  is none
                Value returned on lookup of payload: {4C08199E-0D93-4227-8325-F024E71CA7A1} Adobe SING CS5 is: true
                Action string for  {4C08199E-0D93-4227-8325-F024E71CA7A1} Adobe SING CS5  is none
                Value returned on lookup of payload: {4BE1791F-1D8A-4B8E-B803-D97C5D7CB245} Adobe Soundbooth CS5 Codecs Wrapper is: true
                Action string for  {4BE1791F-1D8A-4B8E-B803-D97C5D7CB245} Adobe Soundbooth CS5 Codecs Wrapper  is none
                Value returned on lookup of payload: {ADAF6949-4547-4B3D-97C5-6FB4D0C08A1E} Adobe Soundbooth CS5 Royalty Codecs Wrapper is: true
                Action string for  {ADAF6949-4547-4B3D-97C5-6FB4D0C08A1E} Adobe Soundbooth CS5 Royalty Codecs Wrapper  is none
                Value returned on lookup of payload: {157D044B-C60D-1015-B0DB-A40823CC0F49} Adobe Toolhints CS5 is: true
                Action string for  {157D044B-C60D-1015-B0DB-A40823CC0F49} Adobe Toolhints CS5  is none
                Value returned on lookup of payload: {A5A8E72E-1B9D-4F99-ADED-F3595CB3D03E} AdobeColorVideoProfilesAE CS5 is: true
                Action string for  {A5A8E72E-1B9D-4F99-ADED-F3595CB3D03E} AdobeColorVideoProfilesAE CS5  is none
                Value returned on lookup of payload: {F3ECF5C7-9A9D-460A-B3D6-C7E4C1DFD040} AdobeMotionPicture CS5 is: true
                Action string for  {F3ECF5C7-9A9D-460A-B3D6-C7E4C1DFD040} AdobeMotionPicture CS5  is none
                Value returned on lookup of payload: {04D84E18-23ED-46EA-9B41-789433E34D03} Firefox Plugin CS5 is: true
                Action string for  {04D84E18-23ED-46EA-9B41-789433E34D03} Firefox Plugin CS5  is none
                Value returned on lookup of payload: {E7F2C606-8529-4028-B26E-8407DB43DD45} FrenchSpeechAnalysisModels is: true
                Action string for  {E7F2C606-8529-4028-B26E-8407DB43DD45} FrenchSpeechAnalysisModels  is none
                Value returned on lookup of payload: {4355EE3F-2FDD-4EF4-83EA-2465FBF95B16} GermanSpeechAnalysisModels is: true
                Action string for  {4355EE3F-2FDD-4EF4-83EA-2465FBF95B16} GermanSpeechAnalysisModels  is none
                Value returned on lookup of payload: {479C08E9-FACF-4190-A37A-81D65B4C8D4E} IE Plugin CS5 is: true
                Action string for  {479C08E9-FACF-4190-A37A-81D65B4C8D4E} IE Plugin CS5  is none
                Value returned on lookup of payload: {A1E0C87F-BFE5-490A-898E-05BD4DD2BADF} InternationalEnglishSpeechAnalysisModels is: true
                Action string for  {A1E0C87F-BFE5-490A-898E-05BD4DD2BADF} InternationalEnglishSpeechAnalysisModels  is none
                Value returned on lookup of payload: {234A555C-70F5-48FB-A7E2-32410EB5AF64} ItalianSpeechAnalysisModels is: true
                Action string for  {234A555C-70F5-48FB-A7E2-32410EB5AF64} ItalianSpeechAnalysisModels  is none
                Value returned on lookup of payload: {F46A4C18-2EAD-49F0-A244-994226F93B39} JapaneseSpeechAnalysisModels is: true
                Action string for  {F46A4C18-2EAD-49F0-A244-994226F93B39} JapaneseSpeechAnalysisModels  is none
                Value returned on lookup of payload: {0EDAD58E-71F3-4D0E-9D32-A205533FC0E9} KoreanSpeechAnalysisModels is: true
                Action string for  {0EDAD58E-71F3-4D0E-9D32-A205533FC0E9} KoreanSpeechAnalysisModels  is none
                Value returned on lookup of payload: {7B7DE224-2ACA-41E2-A94D-5A6C6D75106D} Office Plugin CS5 is: true
                Action string for  {7B7DE224-2ACA-41E2-A94D-5A6C6D75106D} Office Plugin CS5  is none
                Value returned on lookup of payload: {E319B9F9-4DE6-462C-970B-77D06C7807EE} Players For Adobe Flash Pro is: true
                Action string for  {E319B9F9-4DE6-462C-970B-77D06C7807EE} Players For Adobe Flash Pro  is none
                Value returned on lookup of payload: {36D02DA9-35F2-4686-A2FE-EF3014D2E226} SpanishSpeechAnalysisModels is: true
                Action string for  {36D02DA9-35F2-4686-A2FE-EF3014D2E226} SpanishSpeechAnalysisModels  is none
                Value returned on lookup of payload: {22C1290B-8DC3-4C8B-93E2-4373B9AAB1CC} TLF For Adobe Flash Pro_1.0.1_TLF_Flash11-mul is: true
                Action string for  {22C1290B-8DC3-4C8B-93E2-4373B9AAB1CC} TLF For Adobe Flash Pro_1.0.1_TLF_Flash11-mul  is none
                Payload {22C1290B-8DC3-4C8B-93E2-4373B9AAB1CC} TLF For Adobe Flash Pro_1.0.1_TLF_Flash11-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345} TLF For Adobe Flash Pro is: true
                Action string for  {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345} TLF For Adobe Flash Pro  is none
                Value returned on lookup of payload: {62466A6D-1130-4D66-9D65-ED3E1A988E12} iPhone Publishing_1.0.1_iPhone_Flash11-mul is: true
                Action string for  {62466A6D-1130-4D66-9D65-ED3E1A988E12} iPhone Publishing_1.0.1_iPhone_Flash11-mul  is none
                Payload {62466A6D-1130-4D66-9D65-ED3E1A988E12} iPhone Publishing_1.0.1_iPhone_Flash11-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {635DCFA5-3A47-4452-AEC7-D3B23FFE929D} iPhone Publishing is: true
                Action string for  {635DCFA5-3A47-4452-AEC7-D3B23FFE929D} iPhone Publishing  is none
                Value returned on lookup of payload: {5658F35F-15B9-1033-8337-97B78F2D0BE0} Adobe InDesign CS5 Icon Handler x64 is: true
                Action string for  {5658F35F-15B9-1033-8337-97B78F2D0BE0} Adobe InDesign CS5 Icon Handler x64  is none
                Value returned on lookup of payload: {AAA45CA1-CEF2-45A9-9162-6774CFFF8260} Adobe Premiere Pro CS5 Third Party Content Wrapper_5.0.3_AdobePremierePro5ProtectedWrapperAll is: true
                Action string for  {AAA45CA1-CEF2-45A9-9162-6774CFFF8260} Adobe Premiere Pro CS5 Third Party Content Wrapper_5.0.3_AdobePremierePro5ProtectedWrapperAll  is none
                Payload {AAA45CA1-CEF2-45A9-9162-6774CFFF8260} Adobe Premiere Pro CS5 Third Party Content Wrapper_5.0.3_AdobePremierePro5ProtectedWrapperAll is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {22F41D72-2E97-46AE-B8C4-EF66876C7838} Adobe Premiere Pro CS5 Third Party Content Wrapper is: true
                Action string for  {22F41D72-2E97-46AE-B8C4-EF66876C7838} Adobe Premiere Pro CS5 Third Party Content Wrapper  is none
                Value returned on lookup of payload: {CB8BB160-EC13-4D89-8990-F15F01E74961} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper_5.0.3_AdobePremierePro5RoyaltyWrapperAll is: true
                Action string for  {CB8BB160-EC13-4D89-8990-F15F01E74961} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper_5.0.3_AdobePremierePro5RoyaltyWrapperAll  is none
                Payload {CB8BB160-EC13-4D89-8990-F15F01E74961} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper_5.0.3_AdobePremierePro5RoyaltyWrapperAll is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {6BA6F6D7-1D30-482A-B9B8-20E79D6DB4F9} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper is: true
                Action string for  {6BA6F6D7-1D30-482A-B9B8-20E79D6DB4F9} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper  is none
                Value returned on lookup of payload: {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1} Adobe After Effects CS5 Third Party Content is: true
                Action string for  {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1} Adobe After Effects CS5 Third Party Content  is install
                Selection of payload {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1} Adobe After Effects CS5 Third Party Content is forbidden by the policy.
                Value returned on lookup of payload: {CD29B5CA-4727-4114-9AD9-25CCCE6E4014} Adobe After Effects CS5 Third Party Royalty Content is: true
                Action string for  {CD29B5CA-4727-4114-9AD9-25CCCE6E4014} Adobe After Effects CS5 Third Party Royalty Content  is install
                Selection of payload {CD29B5CA-4727-4114-9AD9-25CCCE6E4014} Adobe After Effects CS5 Third Party Royalty Content is forbidden by the policy.
                Value returned on lookup of payload: {0E3C6C75-872D-4B0D-B0B2-31C717250691} Adobe Encore CS5 Third Party Royalty Content is: true
                Action string for  {0E3C6C75-872D-4B0D-B0B2-31C717250691} Adobe Encore CS5 Third Party Royalty Content  is install
                Selection of payload {0E3C6C75-872D-4B0D-B0B2-31C717250691} Adobe Encore CS5 Third Party Royalty Content is forbidden by the policy.
                Value returned on lookup of payload: {D3598CAC-AEB3-4234-A1E0-16F47D5F38CC} Adobe Media Encoder CS5 Dolby is: false
                Action string for  {D3598CAC-AEB3-4234-A1E0-16F47D5F38CC} Adobe Media Encoder CS5 Dolby  is none
                Value returned on lookup of payload: {5DDABB74-A879-4BE7-A4C6-FD41793942DB} Adobe Media Encoder CS5 Dolby X64 is: true
                Action string for  {5DDABB74-A879-4BE7-A4C6-FD41793942DB} Adobe Media Encoder CS5 Dolby X64  is install
                Selection of payload {5DDABB74-A879-4BE7-A4C6-FD41793942DB} Adobe Media Encoder CS5 Dolby X64 is forbidden by the policy.
                Value returned on lookup of payload: {92D4A929-78F1-4EC3-B626-08B3CF5B784F} Adobe Media Encoder CS5 PCI is: false
                Action string for  {92D4A929-78F1-4EC3-B626-08B3CF5B784F} Adobe Media Encoder CS5 PCI  is none
                Value returned on lookup of payload: {F9C71630-0EE3-475C-9E2B-ED95AE197DBD} Adobe Media Encoder CS5 PCI X64 is: true
                Action string for  {F9C71630-0EE3-475C-9E2B-ED95AE197DBD} Adobe Media Encoder CS5 PCI X64  is install
                Selection of payload {F9C71630-0EE3-475C-9E2B-ED95AE197DBD} Adobe Media Encoder CS5 PCI X64 is forbidden by the policy.
                Value returned on lookup of payload: {7816FDDE-40D4-482D-AD7D-97858985DB3E} Adobe OnLocation CS5 Royalty Content is: true
                Action string for  {7816FDDE-40D4-482D-AD7D-97858985DB3E} Adobe OnLocation CS5 Royalty Content  is install
                Selection of payload {7816FDDE-40D4-482D-AD7D-97858985DB3E} Adobe OnLocation CS5 Royalty Content is forbidden by the policy.
                Value returned on lookup of payload: {B8D286BC-A68D-4E74-9F68-8756A49896D8} Adobe Premiere Pro CS5 Third Party Content is: true
                Action string for  {B8D286BC-A68D-4E74-9F68-8756A49896D8} Adobe Premiere Pro CS5 Third Party Content  is install
                Selection of payload {B8D286BC-A68D-4E74-9F68-8756A49896D8} Adobe Premiere Pro CS5 Third Party Content is forbidden by the policy.
                Value returned on lookup of payload: {565DE707-5798-4FC3-8DF6-0F58A348A9B0} Adobe Premiere Pro CS5 Third Party Royalty Content is: true
                Action string for  {565DE707-5798-4FC3-8DF6-0F58A348A9B0} Adobe Premiere Pro CS5 Third Party Royalty Content  is install
                Selection of payload {565DE707-5798-4FC3-8DF6-0F58A348A9B0} Adobe Premiere Pro CS5 Third Party Royalty Content is forbidden by the policy.
                Value returned on lookup of payload: {DE5DE662-2ECB-4D93-967B-221FBCC8A736} Adobe Soundbooth CS5 Codecs is: true
                Action string for  {DE5DE662-2ECB-4D93-967B-221FBCC8A736} Adobe Soundbooth CS5 Codecs  is install
                Selection of payload {DE5DE662-2ECB-4D93-967B-221FBCC8A736} Adobe Soundbooth CS5 Codecs is forbidden by the policy.
                Value returned on lookup of payload: {F319804F-E3A4-4C02-8AEC-CB39A4F6447E} Adobe Soundbooth CS5 Royalty Codecs is: true
                Action string for  {F319804F-E3A4-4C02-8AEC-CB39A4F6447E} Adobe Soundbooth CS5 Royalty Codecs  is install
                Selection of payload {F319804F-E3A4-4C02-8AEC-CB39A4F6447E} Adobe Soundbooth CS5 Royalty Codecs is forbidden by the policy.
                Value returned on lookup of payload: {FBB02B04-C034-4382-A3F6-57416E2752C4} Creative Suite 5 Master Collection is: true
                Action string for  {FBB02B04-C034-4382-A3F6-57416E2752C4} Creative Suite 5 Master Collection  is install
                Value returned on lookup of payload: {CBE4F6C3-788E-4CAC-BA25-26FE39A3BC8C} Adobe Soundbooth is: true
                Action string for  {CBE4F6C3-788E-4CAC-BA25-26FE39A3BC8C} Adobe Soundbooth  is none
                Value returned on lookup of payload: {E6F68811-F702-492C-A7DA-D22CA670BC22} Adobe Soundbooth_AdobeSoundbooth3en_USLanguagePack is: true
                Action string for  {E6F68811-F702-492C-A7DA-D22CA670BC22} Adobe Soundbooth_AdobeSoundbooth3en_USLanguagePack  is none
                Payload {E6F68811-F702-492C-A7DA-D22CA670BC22} Adobe Soundbooth_AdobeSoundbooth3en_USLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {64C19EC0-24A3-4F6F-A0AD-C701C8C48700} Adobe OnLocation CS5_5.0.1_AdobeOnLocation5All is: true
                Action string for  {64C19EC0-24A3-4F6F-A0AD-C701C8C48700} Adobe OnLocation CS5_5.0.1_AdobeOnLocation5All  is none
                Payload {64C19EC0-24A3-4F6F-A0AD-C701C8C48700} Adobe OnLocation CS5_5.0.1_AdobeOnLocation5All is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {ABDC1F61-2C50-4BB1-ACDA-66D412D72582} Adobe OnLocation CS5 is: true
                Action string for  {ABDC1F61-2C50-4BB1-ACDA-66D412D72582} Adobe OnLocation CS5  is none
                Value returned on lookup of payload: {771C9F59-3F22-4610-A23E-321A98ECA264} Adobe OnLocation CS5_AdobeOnLocation5en_USLanguagePack is: true
                Action string for  {771C9F59-3F22-4610-A23E-321A98ECA264} Adobe OnLocation CS5_AdobeOnLocation5en_USLanguagePack  is none
                Payload {771C9F59-3F22-4610-A23E-321A98ECA264} Adobe OnLocation CS5_AdobeOnLocation5en_USLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {177E1CA1-14CC-4398-AB15-A5746EFE8F22} Adobe Flash Builder is: false
                Action string for  {177E1CA1-14CC-4398-AB15-A5746EFE8F22} Adobe Flash Builder  is install
                Value returned on lookup of payload: {4FC4B869-AD0D-4A56-B626-2926EB2C48D0} Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11-mul is: true
                Action string for  {4FC4B869-AD0D-4A56-B626-2926EB2C48D0} Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11-mul  is none
                Payload {4FC4B869-AD0D-4A56-B626-2926EB2C48D0} Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {C79312BD-3E76-4474-A10C-1435D1856A4B} Adobe Dreamweaver CS5 is: true
                Action string for  {C79312BD-3E76-4474-A10C-1435D1856A4B} Adobe Dreamweaver CS5  is none
                Value returned on lookup of payload: {F19DAA62-588A-46D3-A092-C808F565D633} Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11en_USLanguagePack is: true
                Action string for  {F19DAA62-588A-46D3-A092-C808F565D633} Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11en_USLanguagePack  is none
                Payload {F19DAA62-588A-46D3-A092-C808F565D633} Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11en_USLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {E3E040E8-4CCD-4C71-8BAF-80BB2AD5DA04} Adobe Dreamweaver CS5_AdobeDreamweaver11en_USLanguagePack is: true
                Action string for  {E3E040E8-4CCD-4C71-8BAF-80BB2AD5DA04} Adobe Dreamweaver CS5_AdobeDreamweaver11en_USLanguagePack  is none
                Payload {E3E040E8-4CCD-4C71-8BAF-80BB2AD5DA04} Adobe Dreamweaver CS5_AdobeDreamweaver11en_USLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {DE60F0DE-469A-42DC-A678-978313210057} Adobe Contribute CS5 is: true
                Action string for  {DE60F0DE-469A-42DC-A678-978313210057} Adobe Contribute CS5  is none
                Value returned on lookup of payload: {414BDCF9-DE14-4083-BE96-2F4193CE8BBA} Adobe Contribute CS5_AdobeContribute6en_USLanguagePack is: false
                Action string for  {414BDCF9-DE14-4083-BE96-2F4193CE8BBA} Adobe Contribute CS5_AdobeContribute6en_USLanguagePack  is none
                Payload {414BDCF9-DE14-4083-BE96-2F4193CE8BBA} Adobe Contribute CS5_AdobeContribute6en_USLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {681DE732-3F3A-42F2-91C9-84B1CC9B8535} Adobe Contribute CS5_AdobeContribute6en_GBLanguagePack is: true
                Action string for  {681DE732-3F3A-42F2-91C9-84B1CC9B8535} Adobe Contribute CS5_AdobeContribute6en_GBLanguagePack  is none
                Payload {681DE732-3F3A-42F2-91C9-84B1CC9B8535} Adobe Contribute CS5_AdobeContribute6en_GBLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {E8815668-95B0-443D-AC92-2BFD7DD8F16A} Adobe Flash Catalyst CS5 is: false
                Action string for  {E8815668-95B0-443D-AC92-2BFD7DD8F16A} Adobe Flash Catalyst CS5  is install
                Value returned on lookup of payload: {164965E8-4BB0-4EEB-AFBA-75785A2A2A7F} Adobe Fireworks CS5 is: true
                Action string for  {164965E8-4BB0-4EEB-AFBA-75785A2A2A7F} Adobe Fireworks CS5  is none
                Value returned on lookup of payload: {3A8C7CB3-2A2E-4EB9-99C9-DF08C324BA70} Adobe Fireworks CS5_AdobeFireworks11en_USLanguagePack is: false
                Action string for  {3A8C7CB3-2A2E-4EB9-99C9-DF08C324BA70} Adobe Fireworks CS5_AdobeFireworks11en_USLanguagePack  is none
                Payload {3A8C7CB3-2A2E-4EB9-99C9-DF08C324BA70} Adobe Fireworks CS5_AdobeFireworks11en_USLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {F6CCA85F-7527-4AFF-82B6-26532A74A244} Adobe Fireworks CS5_AdobeFireworks11en_GBLanguagePack is: true
                Action string for  {F6CCA85F-7527-4AFF-82B6-26532A74A244} Adobe Fireworks CS5_AdobeFireworks11en_GBLanguagePack  is none
                Payload {F6CCA85F-7527-4AFF-82B6-26532A74A244} Adobe Fireworks CS5_AdobeFireworks11en_GBLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {D8465547-5D5B-4856-A93A-8AC0A05C5D4D} Adobe Encore CS5 is: true
                Action string for  {D8465547-5D5B-4856-A93A-8AC0A05C5D4D} Adobe Encore CS5  is none
                Value returned on lookup of payload: {B842A584-A0BF-4870-A850-9C0E52FD6A20} Adobe Encore CS5_AdobeEncore5en_USLanguagePack is: true
                Action string for  {B842A584-A0BF-4870-A850-9C0E52FD6A20} Adobe Encore CS5_AdobeEncore5en_USLanguagePack  is none
                Payload {B842A584-A0BF-4870-A850-9C0E52FD6A20} Adobe Encore CS5_AdobeEncore5en_USLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {EA4B7009-6FAC-41b1-BBB6-E76680C924DC} Adobe Illustrator CS5_15.0.2_AdobeIllustrator15-mul is: true
                Action string for  {EA4B7009-6FAC-41b1-BBB6-E76680C924DC} Adobe Illustrator CS5_15.0.2_AdobeIllustrator15-mul  is none
                Payload {EA4B7009-6FAC-41b1-BBB6-E76680C924DC} Adobe Illustrator CS5_15.0.2_AdobeIllustrator15-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {9B97EC91-B3FD-4BFF-88FC-5345A26AC2E7} Adobe Illustrator CS5 is: true
                Action string for  {9B97EC91-B3FD-4BFF-88FC-5345A26AC2E7} Adobe Illustrator CS5  is none
                Value returned on lookup of payload: {D3A8C87E-ED6A-41DB-8B21-C29EDA65B154} Adobe Illustrator CS5_AdobeIllustrator15en_USLanguagePack is: false
                Action string for  {D3A8C87E-ED6A-41DB-8B21-C29EDA65B154} Adobe Illustrator CS5_AdobeIllustrator15en_USLanguagePack  is none
                Payload {D3A8C87E-ED6A-41DB-8B21-C29EDA65B154} Adobe Illustrator CS5_AdobeIllustrator15en_USLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {D0DAEA50-AD52-4BF9-AD5F-3E09564A8692} Adobe Illustrator CS5_AdobeIllustrator15en_GBLanguagePack is: true
                Action string for  {D0DAEA50-AD52-4BF9-AD5F-3E09564A8692} Adobe Illustrator CS5_AdobeIllustrator15en_GBLanguagePack  is none
                Payload {D0DAEA50-AD52-4BF9-AD5F-3E09564A8692} Adobe Illustrator CS5_AdobeIllustrator15en_GBLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {5733850A-FF54-431F-A935-71A96AE80F95} Adobe Photoshop CS5 Core_12.0.3_AdobePhotoshop12-Core is: true
                Action string for  {5733850A-FF54-431F-A935-71A96AE80F95} Adobe Photoshop CS5 Core_12.0.3_AdobePhotoshop12-Core  is none
                Payload {5733850A-FF54-431F-A935-71A96AE80F95} Adobe Photoshop CS5 Core_12.0.3_AdobePhotoshop12-Core is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} Adobe Photoshop CS5 Core is: true
                Action string for  {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} Adobe Photoshop CS5 Core  is none
                Value returned on lookup of payload: {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US is: false
                Action string for  {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US  is none
                Payload {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B} Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB is: true
                Action string for  {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B} Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB  is none
                Payload {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B} Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {FA5686B7-A305-4A41-93CD-48BAC929C313} Adobe Photoshop CS5 Core_x64_12.0.3_AdobePhotoshop12-Core_x64 is: true
                Action string for  {FA5686B7-A305-4A41-93CD-48BAC929C313} Adobe Photoshop CS5 Core_x64_12.0.3_AdobePhotoshop12-Core_x64  is none
                Payload {FA5686B7-A305-4A41-93CD-48BAC929C313} Adobe Photoshop CS5 Core_x64_12.0.3_AdobePhotoshop12-Core_x64 is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84} Adobe Photoshop CS5 Core_x64 is: true
                Action string for  {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84} Adobe Photoshop CS5 Core_x64  is none
                Value returned on lookup of payload: {50A16F0B-47DA-4583-B4FE-E026719A2024} Adobe Photoshop CS5 English Language Pack_x64_AdobePhotoshop12-en_US_x64 is: false
                Action string for  {50A16F0B-47DA-4583-B4FE-E026719A2024} Adobe Photoshop CS5 English Language Pack_x64_AdobePhotoshop12-en_US_x64  is none
                Payload {50A16F0B-47DA-4583-B4FE-E026719A2024} Adobe Photoshop CS5 English Language Pack_x64_AdobePhotoshop12-en_US_x64 is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {A47C8AE9-D51B-4A58-A051-396158FC3012} Adobe Photoshop CS5 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64 is: true
                Action string for  {A47C8AE9-D51B-4A58-A051-396158FC3012} Adobe Photoshop CS5 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64  is none
                Payload {A47C8AE9-D51B-4A58-A051-396158FC3012} Adobe Photoshop CS5 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64 is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {D20D27DB-B598-4142-8B7E-BE1342BA77C9} Adobe After Effects CS5_10.0.1_AdobeAfterEffects10AllRetail is: true
                Action string for  {D20D27DB-B598-4142-8B7E-BE1342BA77C9} Adobe After Effects CS5_10.0.1_AdobeAfterEffects10AllRetail  is none
                Payload {D20D27DB-B598-4142-8B7E-BE1342BA77C9} Adobe After Effects CS5_10.0.1_AdobeAfterEffects10AllRetail is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {0E659C1D-7686-4322-A501-58E3FEB4E743} Adobe After Effects CS5 is: true
                Action string for  {0E659C1D-7686-4322-A501-58E3FEB4E743} Adobe After Effects CS5  is none
                Value returned on lookup of payload: {6ACDB89B-63FB-4C7D-8490-7528E248F25B} Adobe After Effects CS5_AdobeAfterEffects10en_USLanguagePack is: true
                Action string for  {6ACDB89B-63FB-4C7D-8490-7528E248F25B} Adobe After Effects CS5_AdobeAfterEffects10en_USLanguagePack  is none
                Payload {6ACDB89B-63FB-4C7D-8490-7528E248F25B} Adobe After Effects CS5_AdobeAfterEffects10en_USLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {7E0C3ACA-19FA-1027-8580-84E7230B548F} Adobe InDesign CS5 Application Base Files_7.0.3.535_AdobeInDesign7AppBase-mul is: true
                Action string for  {7E0C3ACA-19FA-1027-8580-84E7230B548F} Adobe InDesign CS5 Application Base Files_7.0.3.535_AdobeInDesign7AppBase-mul  is none
                Payload {7E0C3ACA-19FA-1027-8580-84E7230B548F} Adobe InDesign CS5 Application Base Files_7.0.3.535_AdobeInDesign7AppBase-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {F9766AC1-1461-1033-B862-DF8FE1C033BE} Adobe InDesign CS5 Application Base Files is: true
                Action string for  {F9766AC1-1461-1033-B862-DF8FE1C033BE} Adobe InDesign CS5 Application Base Files  is none
                Value returned on lookup of payload: {7EB208EE-0C2B-1033-A6DC-E1BD0289A1F4} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_US is: false
                Action string for  {7EB208EE-0C2B-1033-A6DC-E1BD0289A1F4} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_US  is none
                Payload {7EB208EE-0C2B-1033-A6DC-E1BD0289A1F4} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_US is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {966B69F2-0FBD-1033-B01C-D13C02FFF33F} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_GB is: true
                Action string for  {966B69F2-0FBD-1033-B01C-D13C02FFF33F} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_GB  is none
                Payload {966B69F2-0FBD-1033-B01C-D13C02FFF33F} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_GB is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {05BAD153-18C5-1027-8235-EC70CC150594} Adobe InDesign CS5 Application Language Files_7.0.3.535_AdobeInDesign7AppLang-en_GB is: true
                Action string for  {05BAD153-18C5-1027-8235-EC70CC150594} Adobe InDesign CS5 Application Language Files_7.0.3.535_AdobeInDesign7AppLang-en_GB  is none
                Payload {05BAD153-18C5-1027-8235-EC70CC150594} Adobe InDesign CS5 Application Language Files_7.0.3.535_AdobeInDesign7AppLang-en_GB is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {26B63C3A-0BFF-1033-B389-A7ACEC31657E} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_GB is: true
                Action string for  {26B63C3A-0BFF-1033-B389-A7ACEC31657E} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_GB  is none
                Payload {26B63C3A-0BFF-1033-B389-A7ACEC31657E} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_GB is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {0A9AAB1E-0FEA-1033-851A-888C0B8E78B5} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_US is: true
                Action string for  {0A9AAB1E-0FEA-1033-851A-888C0B8E78B5} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_US  is none
                Payload {0A9AAB1E-0FEA-1033-851A-888C0B8E78B5} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_US is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {FDE4CB87-FDB7-40CE-A6D9-189E09FCABE8} Adobe Premiere Pro CS5_5.0.3_AdobePremierePro5AllRetail is: true
                Action string for  {FDE4CB87-FDB7-40CE-A6D9-189E09FCABE8} Adobe Premiere Pro CS5_5.0.3_AdobePremierePro5AllRetail  is none
                Payload {FDE4CB87-FDB7-40CE-A6D9-189E09FCABE8} Adobe Premiere Pro CS5_5.0.3_AdobePremierePro5AllRetail is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {0B754B55-6F63-461E-BB75-E8C883BDF88F} Adobe Premiere Pro CS5 is: true
                Action string for  {0B754B55-6F63-461E-BB75-E8C883BDF88F} Adobe Premiere Pro CS5  is none
                Value returned on lookup of payload: {B61DD7DA-4942-40A2-AF16-14957DFFEF09} Adobe Premiere Pro CS5_5.0.3_AdobePremierePro5en_USLanguagePack is: true
                Action string for  {B61DD7DA-4942-40A2-AF16-14957DFFEF09} Adobe Premiere Pro CS5_5.0.3_AdobePremierePro5en_USLanguagePack  is none
                Payload {B61DD7DA-4942-40A2-AF16-14957DFFEF09} Adobe Premiere Pro CS5_5.0.3_AdobePremierePro5en_USLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {34F82E6B-8096-45CA-B604-ACACAC22E553} Adobe Premiere Pro CS5_AdobePremierePro5en_USLanguagePack is: true
                Action string for  {34F82E6B-8096-45CA-B604-ACACAC22E553} Adobe Premiere Pro CS5_AdobePremierePro5en_USLanguagePack  is none
                Payload {34F82E6B-8096-45CA-B604-ACACAC22E553} Adobe Premiere Pro CS5_AdobePremierePro5en_USLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {70CAC073-3CDD-498C-80F7-79B76A61D7E6} Adobe Flash CS5_11.0.2_AdobeFlash11-mul is: true
                Action string for  {70CAC073-3CDD-498C-80F7-79B76A61D7E6} Adobe Flash CS5_11.0.2_AdobeFlash11-mul  is none
                Payload {70CAC073-3CDD-498C-80F7-79B76A61D7E6} Adobe Flash CS5_11.0.2_AdobeFlash11-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {CFC9F871-7C40-40B6-BE4A-B98A5B309716} Adobe Flash CS5 is: true
                Action string for  {CFC9F871-7C40-40B6-BE4A-B98A5B309716} Adobe Flash CS5  is none
                Value returned on lookup of payload: {F637969B-336C-4533-9D4D-D0163A39C42F} Adobe Flash CS5_11.0.2_AdobeFlash11-en_USLanguagePack is: true
                Action string for  {F637969B-336C-4533-9D4D-D0163A39C42F} Adobe Flash CS5_11.0.2_AdobeFlash11-en_USLanguagePack  is none
                Payload {F637969B-336C-4533-9D4D-D0163A39C42F} Adobe Flash CS5_11.0.2_AdobeFlash11-en_USLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack is: true
                Action string for  {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack  is none
                Payload {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul is: true
                Action string for  {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul  is none
                Payload {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul is extension payload. Aligning its action according to parent.
                Value returned on lookup of payload: {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US is: true
                Action string for  {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US  is none
                Payload {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US is extension payload. Aligning its action according to parent.
                Selection of payload {AAE6F374-91CB-45FB-9282-4CFA0DED2088} Adobe Media Encoder CS5 Dolby WRAPPER is allowed but the user has marked it for not to install
                Selection of payload {33A3F995-8333-4676-8D6F-AB7674BB52EA} Adobe Media Encoder CS5 PCI WRAPPER is allowed but the user has marked it for not to install
                END Setting requested payload actions
                Collected advanced path check information for INSTALLDIR
                INSTALLDIR is a well-formed path
                INSTALLDIR is not the root path
                INSTALLDIR is on a local volume
                INSTALLDIR is on a writable volume
                INSTALLDIR is not on a case sensitive volume
                INSTALLDIR passed path basic path validation: C:\Program Files (x86)\Adobe
                [    3432] Sun Feb 13 13:04:41 2011  INFO
                ::START TIMER:: [System check :{02731921-5711-4E7A-A898-D6BCF0F2A1CD}]
                In InstallPreSystemCheckProc
                Custom action return code: 0
                :: END TIMER :: [System check :{02731921-5711-4E7A-A898-D6BCF0F2A1CD}] took 14.8424 miliseconds (0.0148424 seconds)
                ::START TIMER:: [System check :{8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}]
                :: END TIMER :: [System check :{8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}] took 18.3078 miliseconds (0.0183078 seconds)
                ::START TIMER:: [System check :{7F9C94CD-0BAC-4F8F-8990-6A5886F4D550}]
                Font Installer: Fonts STI Custom Hook 1.6 Release
                :: END TIMER :: [System check :{7F9C94CD-0BAC-4F8F-8990-6A5886F4D550}] took 21.4545 miliseconds (0.0214545 seconds)
                [    3432] Sun Feb 13 13:04:42 2011  INFO
                ::START TIMER:: [System check :{0D067D13-C3D7-4EA6-B346-740CD91FD547}]
                CustomHooksTester -> In InstallPreSystemCheckProc
                :: END TIMER :: [System check :{0D067D13-C3D7-4EA6-B346-740CD91FD547}] took 14.6595 miliseconds (0.0146595 seconds)
                ::START TIMER:: [System check :{E39A5ABD-516B-46F9-A042-694BBA6A4E08}]
                :: END TIMER :: [System check :{E39A5ABD-516B-46F9-A042-694BBA6A4E08}] took 21.1902 miliseconds (0.0211902 seconds)
                ::START TIMER:: [System check :{CBDD7465-CE11-4A58-9497-C370B65923F1}]
                :: END TIMER :: [System check :{CBDD7465-CE11-4A58-9497-C370B65923F1}] took 43.5172 miliseconds (0.0435172 seconds)
                ::START TIMER:: [System check :{11C0657F-2BD4-4CBC-87F3-9455DC91886E}]
                :: END TIMER :: [System check :{11C0657F-2BD4-4CBC-87F3-9455DC91886E}] took 21.5817 miliseconds (0.0215817 seconds)
                ::START TIMER:: [System check :{7745F18B-FD8A-4011-BE16-588900C503D0}]
                :: END TIMER :: [System check :{7745F18B-FD8A-4011-BE16-588900C503D0}] took 21.2257 miliseconds (0.0212257 seconds)
                [    3432] Sun Feb 13 13:04:43 2011  INFO
                ::START TIMER:: [System check :{04D84E18-23ED-46EA-9B41-789433E34D03}]
                :: END TIMER :: [System check :{04D84E18-23ED-46EA-9B41-789433E34D03}] took 17.4473 miliseconds (0.0174473 seconds)
                ::START TIMER:: [System check :{177E1CA1-14CC-4398-AB15-A5746EFE8F22}]
                :: END TIMER :: [System check :{177E1CA1-14CC-4398-AB15-A5746EFE8F22}] took 15.8019 miliseconds (0.0158019 seconds)
                ::START TIMER:: [System check :{DE60F0DE-469A-42DC-A678-978313210057}]
                :: END TIMER :: [System check :{DE60F0DE-469A-42DC-A678-978313210057}] took 15.0342 miliseconds (0.0150342 seconds)
                ::START TIMER:: [System check :{E8815668-95B0-443D-AC92-2BFD7DD8F16A}]
                :: END TIMER :: [System check :{E8815668-95B0-443D-AC92-2BFD7DD8F16A}] took 15.517 miliseconds (0.015517 seconds)
                ::START TIMER:: [System check :{164965E8-4BB0-4EEB-AFBA-75785A2A2A7F}]
                :: END TIMER :: [System check :{164965E8-4BB0-4EEB-AFBA-75785A2A2A7F}] took 30.7866 miliseconds (0.0307866 seconds)
                [    3432] Sun Feb 13 13:04:43 2011  WARN
                Warning: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
                [    3432] Sun Feb 13 13:04:44 2011  WARN
                Warning: {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
                [    3432] Sun Feb 13 13:04:44 2011  INFO
                Payloads passed preflight validation.
                Call PreSession Custom Hook
                Calling the custom action code for pre-repair for payload {08D2E121-7F6A-43EB-97FD-629B44903403}
                ::START TIMER:: [Payload Operation :{08D2E121-7F6A-43EB-97FD-629B44903403}]
                [    3068] Sun Feb 13 13:04:44 2011  INFO
                Installer Operation: ModifyThirdPartyPayloadOperation
                Modify Thirdparty payload
                Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi
                [    3068] Sun Feb 13 13:04:46 2011  INFO
                MsiSourceListAddSource for  E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi is 0
                MsiSourceListSetInfo with updated name: Microsoft_VC90_CRT_x86.msi, Result: 0
                Payload exists on removable media: E:\
                Updating Media for package
                Added volume name: CS5 Master Coll1 for diskID: 1 with result: 0
                MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC90_CRT_x86\, Result: 0
                Configuring MSI ProductCode: {08D2E121-7F6A-43EB-97FD-629B44903403}
                Setting AFLPath C:\Program Files (x86)\Common Files\Adobe\Installers\{FBB02B04-C034-4382-A3F6-57416E2752C4}
                MsiConfigureProductEx command line:
                ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress   REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adbB06A.tmp"
                1: 0 2: 1033 3: 1252
                [    3068] Sun Feb 13 13:04:47 2011  INFO
                === Logging started: 13/02/2011  13:04:47 ===
                Message type: 0, Argument: 1033
                Message type: 1, Argument: Microsoft_VC90_CRT_x86
                Action 13:04:47: INSTALL.
                Action start 13:04:47: INSTALL.
                Action 13:04:47: SystemFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7.
                Action start 13:04:47: SystemFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7.
                Action ended 13:04:47: SystemFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7. Return value 1.
                Action 13:04:47: AppSearch. Searching for installed applications
                Action start 13:04:47: AppSearch.
                Action ended 13:04:47: AppSearch. Return value 0.
                Action 13:04:47: FindRelatedProducts. Searching for related applications
                Action start 13:04:47: FindRelatedProducts.
                Action ended 13:04:47: FindRelatedProducts. Return value 0.
                Action 13:04:47: ValidateProductID.
                Action start 13:04:47: ValidateProductID.
                Action ended 13:04:47: ValidateProductID. Return value 1.
                Action 13:04:47: WindowsFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7.
                Action start 13:04:47: WindowsFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7.
                Action ended 13:04:47: WindowsFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7. Return value 1.
                Action 13:04:47: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_75 44A81A5FCF.
                Action start 13:04:47: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_75 44A81A5FCF.
                Action ended 13:04:47: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_75 44A81A5FCF. Return value 1.
                Action 13:04:47: CostInitialize. Computing space requirements
                Action start 13:04:47: CostInitialize.
                Action ended 13:04:47: CostInitialize. Return value 1.
                Action 13:04:47: FileCost. Computing space requirements
                Action start 13:04:47: FileCost.
                Action ended 13:04:47: FileCost. Return value 1.
                Action 13:04:47: IsolateComponents.
                Action start 13:04:47: IsolateComponents.
                Action ended 13:04:47: IsolateComponents. Return value 0.
                Action 13:04:47: CostFinalize. Computing space requirements
                Action start 13:04:47: CostFinalize.
                Action ended 13:04:47: CostFinalize. Return value 1.
                Action 13:04:47: SetODBCFolders. Initializing ODBC directories
                Action start 13:04:47: SetODBCFolders.
                Action ended 13:04:47: SetODBCFolders. Return value 0.
                Action 13:04:47: MigrateFeatureStates. Migrating feature states from related applications
                Action start 13:04:47: MigrateFeatureStates.
                Action ended 13:04:47: MigrateFeatureStates. Return value 0.
                Action 13:04:47: InstallValidate. Validating install
                Action start 13:04:47: InstallValidate.
                Action ended 13:04:47: InstallValidate. Return value 1.
                Action 13:04:47: RemoveExistingProducts. Removing applications
                Action start 13:04:47: RemoveExistingProducts.
                Action ended 13:04:47: RemoveExistingProducts. Return value 0.
                Action 13:04:47: InstallInitialize.
                Action start 13:04:47: InstallInitialize.
                [    3068] Sun Feb 13 13:04:48 2011  INFO
                Action ended 13:04:48: InstallInitialize. Return value 1.
                Action 13:04:48: ProcessComponents. Updating component registration
                Action start 13:04:48: ProcessComponents.
                Action 13:04:48: GenerateScript. Generating script operations for action:
                Action ended 13:04:48: ProcessComponents. Return value 1.
                Action 13:04:48: UnpublishComponents. Unpublishing Qualified Components
                Action start 13:04:48: UnpublishComponents.
                Action ended 13:04:48: UnpublishComponents. Return value 0.
                Action 13:04:48: MsiUnpublishAssemblies. Unpublishing assembly information
                Action start 13:04:48: MsiUnpublishAssemblies.
                Action ended 13:04:48: MsiUnpublishAssemblies. Return value 1.
                Action 13:04:48: UnpublishFeatures. Unpublishing product features
                Action start 13:04:48: UnpublishFeatures.
                Action ended 13:04:48: UnpublishFeatures. Return value 1.
                Action 13:04:48: StopServices. Stopping services
                Action start 13:04:48: StopServices.
                Action ended 13:04:48: StopServices. Return value 1.
                Action 13:04:48: DeleteServices. Deleting services
                Action start 13:04:48: DeleteServices.
                Action ended 13:04:48: DeleteServices. Return value 1.
                Action 13:04:48: UnregisterComPlus. Unregistering COM+ Applications and Components
                Action start 13:04:48: UnregisterComPlus.
                Action ended 13:04:48: UnregisterComPlus. Return value 0.
                Action 13:04:48: SelfUnregModules. Unregistering modules
                Action start 13:04:48: SelfUnregModules.
                Action ended 13:04:48: SelfUnregModules. Return value 1.
                Action 13:04:48: UnregisterTypeLibraries. Unregistering type libraries
                Action start 13:04:48: UnregisterTypeLibraries.
                Action ended 13:04:48: UnregisterTypeLibraries. Return value 0.
                Action 13:04:48: RemoveODBC. Removing ODBC components
                Action start 13:04:48: RemoveODBC.
                Action ended 13:04:48: RemoveODBC. Return value 1.
                Action 13:04:48: UnregisterFonts. Unregistering fonts
                Action start 13:04:48: UnregisterFonts.
                Action ended 13:04:48: UnregisterFonts. Return value 1.
                Action 13:04:48: RemoveRegistryValues. Removing system registry values
                Action start 13:04:48: RemoveRegistryValues.
                Action ended 13:04:48: RemoveRegistryValues. Return value 1.
                Action 13:04:48: UnregisterClassInfo. Unregister class servers
                Action start 13:04:48: UnregisterClassInfo.
                Action ended 13:04:48: UnregisterClassInfo. Return value 0.
                Action 13:04:48: UnregisterExtensionInfo. Unregistering extension servers
                Action start 13:04:48: UnregisterExtensionInfo.
                Action ended 13:04:48: UnregisterExtensionInfo. Return value 0.
                Action 13:04:48: UnregisterProgIdInfo. Unregistering program identifiers
                Action start 13:04:48: UnregisterProgIdInfo.
                Action ended 13:04:48: UnregisterProgIdInfo. Return value 0.
                Action 13:04:48: UnregisterMIMEInfo. Unregistering MIME info
                Action start 13:04:48: UnregisterMIMEInfo.
                Action ended 13:04:48: UnregisterMIMEInfo. Return value 0.
                Action 13:04:48: RemoveIniValues. Removing INI file entries
                Action start 13:04:48: RemoveIniValues.
                Action ended 13:04:48: RemoveIniValues. Return value 1.
                Action 13:04:48: RemoveShortcuts. Removing shortcuts
                Action start 13:04:48: RemoveShortcuts.
                Action ended 13:04:48: RemoveShortcuts. Return value 0.
                Action 13:04:48: RemoveEnvironmentStrings. Updating environment strings
                Action start 13:04:48: RemoveEnvironmentStrings.
                Action ended 13:04:48: RemoveEnvironmentStrings. Return value 1.
                Action 13:04:48: RemoveDuplicateFiles. Removing duplicated files
                Action start 13:04:48: RemoveDuplicateFiles.
                Action ended 13:04:48: RemoveDuplicateFiles. Return value 1.
                Action 13:04:48: RemoveFiles. Removing files
                Action start 13:04:48: RemoveFiles.
                Action ended 13:04:48: RemoveFiles. Return value 0.
                Action 13:04:48: RemoveFolders. Removing folders
                Action start 13:04:48: RemoveFolders.
                Action ended 13:04:48: RemoveFolders. Return value 0.
                Action 13:04:48: CreateFolders. Creating folders
                Action start 13:04:48: CreateFolders.
                Action ended 13:04:48: CreateFolders. Return value 0.
                Action 13:04:48: MoveFiles. Moving files
                Action start 13:04:48: MoveFiles.
                Action ended 13:04:48: MoveFiles. Return value 1.
                Action 13:04:48: InstallFiles. Copying new files
                Action start 13:04:48: InstallFiles.
                File: Copying new files,  Directory: ,  Size:
                Action ended 13:04:48: InstallFiles. Return value 1.
                Action 13:04:48: PatchFiles. Patching files
                Action start 13:04:48: PatchFiles.
                Action ended 13:04:48: PatchFiles. Return value 0.
                Action 13:04:48: DuplicateFiles. Creating duplicate files
                Action start 13:04:48: DuplicateFiles.
                Action ended 13:04:48: DuplicateFiles. Return value 1.
                Action 13:04:48: BindImage. Binding executables
                Action start 13:04:48: BindImage.
                Action ended 13:04:48: BindImage. Return value 1.
                Action 13:04:48: CreateShortcuts. Creating shortcuts
                Action start 13:04:48: CreateShortcuts.
                Shortcut: Creating shortcuts
                Action ended 13:04:48: CreateShortcuts. Return value 0.
                Action 13:04:48: RegisterClassInfo. Registering class servers
                Action start 13:04:48: RegisterClassInfo.
                Action ended 13:04:48: RegisterClassInfo. Return value 0.
                Action 13:04:48: RegisterExtensionInfo. Registering extension servers
                Action start 13:04:48: RegisterExtensionInfo.
                Action ended 13:04:48: RegisterExtensionInfo. Return value 0.
                Action 13:04:48: RegisterProgIdInfo. Registering program identifiers
                Action start 13:04:48: RegisterProgIdInfo.
                Action ended 13:04:48: RegisterProgIdInfo. Return value 0.
                Action 13:04:48: RegisterMIMEInfo. Registering MIME info
                Action start 13:04:48: RegisterMIMEInfo.
                Action ended 13:04:48: RegisterMIMEInfo. Return value 0.
                Action 13:04:48: WriteRegistryValues. Writing system registry values
                Action start 13:04:48: WriteRegistryValues.
                Action ended 13:04:48: WriteRegistryValues. Return value 1.
                Action 13:04:48: WriteIniValues. Writing INI file values
                Action start 13:04:48: WriteIniValues.
                Action ended 13:04:48: WriteIniValues. Return value 1.
                Action 13:04:48: WriteEnvironmentStrings. Updating environment strings
                Action start 13:04:48: WriteEnvironmentStrings.
                Action ended 13:04:48: WriteEnvironmentStrings. Return value 1.
                Action 13:04:48: RegisterFonts. Registering fonts
                Action start 13:04:48: RegisterFonts.
                Action ended 13:04:48: RegisterFonts. Return value 1.
                Action 13:04:48: InstallODBC. Installing ODBC components
                Action start 13:04:48: InstallODBC.
                Action ended 13:04:48: InstallODBC. Return value 0.
                Action 13:04:48: RegisterTypeLibraries. Registering type libraries
                Action start 13:04:48: RegisterTypeLibraries.
                Action ended 13:04:48: RegisterTypeLibraries. Return value 0.
                Action 13:04:48: SelfRegModules. Registering modules
                Action start 13:04:48: SelfRegModules.
                Action ended 13:04:48: SelfRegModules. Return value 1.
                Action 13:04:48: RegisterComPlus. Registering COM+ Applications and Components
                Action start 13:04:48: RegisterComPlus.
                Action ended 13:04:48: RegisterComPlus. Return value 0.
                Action 13:04:48: InstallServices. Installing new services
                Action start 13:04:48: InstallServices.
                Action ended 13:04:48: InstallServices. Return value 1.
                Action 13:04:48: StartServices. Starting services
                Action start 13:04:48: StartServices.
                Action ended 13:04:48: StartServices. Return value 1.
                Action 13:04:48: RegisterUser. Registering user
                Action start 13:04:48: RegisterUser.
                Action ended 13:04:48: RegisterUser. Return value 0.
                Action 13:04:48: RegisterProduct. Registering product
                Action start 13:04:48: RegisterProduct.
                Registering product
                Action ended 13:04:48: RegisterProduct. Return value 1.
                Action 13:04:48: PublishComponents. Publishing qualified components
                Action start 13:04:48: PublishComponents.
                Action ended 13:04:48: PublishComponents. Return value 0.
                Action 13:04:48: MsiPublishAssemblies. Publishing assembly information
                Action start 13:04:48: MsiPublishAssemblies.
                Application Context:Publishing assembly information, Assembly Name:
                Action ended 13:04:48: MsiPublishAssemblies. Return value 1.
                Action 13:04:48: PublishFeatures. Publishing product features
                Action start 13:04:48: PublishFeatures.
                Feature: Publishing product features
                Action ended 13:04:48: PublishFeatures. Return value 1.
                Action 13:04:48: PublishProduct. Publishing product information
                Action start 13:04:48: PublishProduct.
                Action ended 13:04:48: PublishProduct. Return value 1.
                Action 13:04:48: InstallFinalize.
                Action start 13:04:48: InstallFinalize.
                Shortcut: ARPPRODUCTICON.exe
                354043.msi
                Application Context:Global, Assembly Name:Microsoft.VC90.CRT,version="9.0.30729.4137",publicKeyToken="1fc8b3b9a1e18e3b",proces sorArchitecture="x86",type="win32"
                Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.CRT,version="9.0.30729.4137",publicKeyToken="1fc8b3b9a1e18 e3b",processorArchitecture="x86",type="win32-policy"
                Feature: Microsoft_VC90_CRT_x86_
                Message type: 2, Argument: 0
                Action 13:04:48: RollbackCleanup. Removing backup files
                File: C:\Config.Msi\3b14a.rbf
                File: C:\Config.Msi\3b14b.rbf
                Message type: 2, Argument: 1
                Action ended 13:04:48: InstallFinalize. Return value 1.
                Action ended 13:04:48: INSTALL. Return value 1.
                Property(S): DiskPrompt = [1]
                Property(S): UpgradeCode = {0FD62DF3-05EA-44F2-9C45-98FA04CF85DE}
                Property(S): SourcedirProduct = {08D2E121-7F6A-43EB-97FD-629B44903403}
                Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\
                Property(S): Installed = 2009/07/28 04:12:16
                Property(S): PrimaryVolumeSpaceRemaining = 0
                Property(S): PrimaryVolumeSpaceRequired = 0
                Property(S): PrimaryVolumeSpaceAvailable = 0
                Property(S): OutOfNoRbDiskSpace = 0
                Property(S): OutOfDiskSpace = 0
                Property(S): CostingComplete = 1
                Property(S): ROOTDRIVE = F:\
                Property(S): ACTION = INSTALL
                Property(S): Preselected = 1
                Property(S): QFEUpgrade = 1
                Property(S): UILevel = 2
                Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi
                Property(S): DATABASE = C:\Windows\Installer\3b144.msi
                Property(S): Privileged = 1
                Property(S): MsiRunningElevated = 1
                Property(S): RedirectedDllSupport = 2
                Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
                Property(S): MsiNetAssemblySupport = 4.0.30319.1
                Property(S): Date = 13/02/2011
                Property(S): Time = 13:04:48
                Property(S): TTCSupport = 1
                Property(S): ColorBits = 32
                Property(S): TextInternalLeading = 3
                Property(S): TextHeight = 16
                Property(S): BorderSide = 1
                Property(S): BorderTop = 1
                Property(S): CaptionHeight = 22
                Property(S): ScreenY = 768
                Property(S): ScreenX = 1024
                Property(S): SystemLanguageID = 3081
                Property(S): ComputerName = PC
                Property(S): UserLanguageID = 3081
                Property(S): UserSID = S-1-5-21-618155685-1063480468-518450737-1000
                Property(S): LogonUser = Gary & Susan
                Property(S): MsiTrueAdminUser = 1
                Property(S): AdminUser = 1
                Property(S): VirtualMemory = 14324
                Property(S): PhysicalMemory = 8151
                Property(S): Intel = 6
                Property(S): Msix64 = 6
                Property(S): MsiAMD64 = 6
                Property(S): ShellAdvtSupport = 1
                Property(S): OLEAdvtSupport = 1
                Property(S): GPTSupport = 1
                Property(S): VersionNT = 601
                Property(S): ProgramFilesFolder = C:\Program Files (x86)\
                Property(S): ADOBE = C:\Program Files (x86)\Adobe\
                Property(S): TARGETDIR = F:\
                Property(S): ALLUSERSPROFILE = F:\
                Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
                Property(S): AppDataFolder = C:\Users\Gary & Susan\AppData\Roaming\
                Property(S): CommonAppDataFolder = C:\ProgramData\
                Property(S): CommonFiles64Folder = C:\Program Files (x86)\Common Files\
                Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
                Property(S): ISYourDataBaseDir = C:\Program Files (x86)\Adobe\My Product Name\Database\
                Property(S): DATABASEDIR = C:\Program Files (x86)\Adobe\My Product Name\Database\
                Property(S): DesktopFolder = C:\Users\Public\Desktop\
                Property(S): FavoritesFolder = C:\Users\Gary & Susan\Favorites\
                Property(S): FontsFolder = C:\Windows\Fonts\
                Property(S): GlobalAssemblyCache = F:\
                Property(S): MY_PRODUCT_NAME = C:\Program Files (x86)\Adobe\My Product Name\
                Property(S): INSTALLDIR = C:\Program Files (x86)\Adobe\My Product Name\
                Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
                Property(S): ISMyCompanyDir = C:\Program Files (x86)\My Company Name\
                Property(S): ISMyProductDir = C:\Program Files (x86)\My Company Name\My Product Name\
                Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
                Property(S): LocalAppDataFolder = C:\Users\Gary & Susan\AppData\Local\
                Property(S): MyPicturesFolder = C:\Users\Gary & Susan\Pictures\
                Property(S): PersonalFolder = C:\Users\Gary & Susan\Documents\
                Property(S): PrimaryVolumePath = F:\
                Property(S): ProgramFiles64Folder = C:\Program Files (x86)\
                Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
                Property(S): SendToFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\SendTo\
                Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
                Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
                Property(S): System16Folder = F:\
                Property(S): System64Folder = C:\Windows\SysWOW64\
                Property(S): SystemFolder = C:\Windows\SysWOW64\
                Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\
                Property(S): TempFolder = C:\Users\GARY&S~1\AppData\Local\Temp\
                Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
                Property(S): USERPROFILE = F:\
                Property(S): WindowsFolder = C:\Windows\
                Property(S): WindowsVolume = C:\
                Property(S): WindowsFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\
                Property(S): SystemFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\SysWOW64\
                Property(S): WinSxsDirectory.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B 7 = C:\Windows\winsxs\
                Property(S): payload_ul.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4137_none_508fc1d4bcb b3eca\
                Property(S): payload.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.4137_x-ww_d494ac0e\
                Property(S): WinSxsManifests.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B 7 = C:\Windows\winsxs\Manifests\
                Property(S): WinSxsPolicies.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\Policies\
                Property(S): policydir.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\Policies\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_1742743b\
                Property(S): policydir_ul.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_1742743b\
                Property(S): ALLUSERS = 1
                Property(S): WinSxsDirectory.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_ 7544A81A5FCF = C:\Windows\winsxs\
                Property(S): payload_ul.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_7544A 81A5FCF = C:\Windows\winsxs\x86_policy.9.0.microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4137_none_ f47d3254f657e518\
                Property(S): WinSxsPolicies.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_7 544A81A5FCF = C:\Windows\winsxs\Policies\
                Property(S): policydir.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_7544A8 1A5FCF = C:\Windows\winsxs\Policies\x86_policy.9.0.Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_b7353f 75\
                Property(S): WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_75 44A81A5FCF = C:\Windows\
                Property(S): RecentFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Recent\
                Property(S): PrintHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
                Property(S): NetHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
                Property(S): RemoteAdminTS = 1
                Property(S): MsiNTSuitePersonal = 1
                Property(S): MsiNTProductType = 1
                Property(S): ServicePackLevelMinor = 0
                Property(S): ServicePackLevel = 0
                Property(S): WindowsBuild = 7600
                Property(S): VersionNT64 = 601
                Property(S): VersionMsi = 5.00
                Property(S): ISCHECKFORPRODUCTUPDATES = 1
                Property(S): ApplicationUsers = AllUsers
                Property(S): AgreeToLicense = No
                Property(S): _IsMaintenance = Change
                Property(S): SetupType = Typical
                Property(S): _IsSetupTypeMin = Typical
                Property(S): IS_SQLSERVER_USERNAME = sa
                Property(S): IS_SQLSERVER_AUTHENTICATION = 0
                Property(S): RestartManagerOption = CloseRestart
                Property(S): Display_IsBitmapDlg = 1
                Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
                Property(S): DefaultUIFont = Tahoma8
                Property(S): DialogCaption = InstallShield for Windows Installer
                Property(S): DisplayNameCustom = Custom
                Property(S): DisplayNameMinimal = Minimal
                Property(S): DisplayNameTypical = Typical
                Property(S): DWUSINTERVAL = 30
                Property(S): ErrorDialog = SetupError
                Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
                Property(S): InstallChoice = AR
                Property(S): INSTALLLEVEL = 100
                Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
                Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
                Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
                Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
                Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
                Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
                Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
                Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
                Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
                Property(S): ISVROOT_PORT_NO = 0
                Property(S): Manufacturer = Adobe
                Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
                Property(S): ProductCode = {08D2E121-7F6A-43EB-97FD-629B44903403}
                Property(S): ProductID = none
                Property(S): ProductLanguage = 1033
                Property(S): ProductName = Microsoft_VC90_CRT_x86
                Property(S): ProductVersion = 1.00.0000
                Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
                Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
                Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
                Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
                Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
                Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
                Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
                Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
                Property(S): ProgressType0 = install
                Property(S): ProgressType1 = Installing
                Property(S): ProgressType2 = installed
                Property(S): ProgressType3 = installs
                Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
                Property(S): RebootYesNo = Yes
                Property(S): ReinstallModeText = omus
                Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
                Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
                Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
                Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
                Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
                Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
                Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
                Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
                Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
                Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
                Property(S): DWUSLINK = CEBCC75FFEEBF7C8BEACA0F8D9CB978FB9FB078FDE8CE0E8CE2BC08F9EAB5058BEDCD0A8FEAC
                Property(S): ARPURLINFOABOUT = http://www.Adobe.com
                Property(S): SHOWLAUNCHPROGRAM = 0
                Property(S): REBOOT = ReallySuppress
                Property(S): ARPSYSTEMCOMPONENT = 1
                Property(S): VersionDatabase = 200
                Property(S): PRODUCTLANGUAGE = 1033
                Property(S): CURRENTMEDIAVOLUMELABEL = CS5 Master Coll1
                Property(S): CLIENTPROCESSID = 4116
                Property(S): MSICLIENTUSESEXTERNALUI = 1
                Property(S): CLIENTUILEVEL = 3
                Property(S): CURRENTDIRECTORY = C:\Users\Gary & Susan\AppData\Local\Adobe\OOBE\PDApp\DWA
                Property(S): ADDLOCAL = ALL
                Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adbB06A.tmp
                Property(S): REINSTALLMODE = pvoums
                Property(S): REINSTALL = ALL
                Property(S): MSIRESTARTMANAGERCONTROL = Disable
                Property(S): ADOBE_SETUP = 1
                Property(S): ProductToBeRegistered = 1
                Property(S): USERNAME = Gary & Susan
                Property(S): ProductState = 5
                Property(S): PackageCode = {5DB7D0CC-71CB-4DD2-993F-C9E909FA78F0}
                === Logging stopped: 13/02/2011  13:04:48 ===
                1: 2 2: 0
                1: 2 2: 1
                [    3432] Sun Feb 13 13:04:48 2011  INFO
                *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
                :: END TIMER :: [Payload Operation :{08D2E121-7F6A-43EB-97FD-629B44903403}] took 4021.83 miliseconds (4.02183 seconds) DTR = 190.958 KBPS (0.186482 MBPS)
                Updating driver data - Action: Add driver entry
                Updating driver data successful. Driver entry was added. ARP estimated size 0KB
                User specified overrideFile:
                Calling the custom action code for post-repair for payload {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86
                Calling the custom action code for pre-repair for payload {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
                ::START TIMER:: [Payload Operation :{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}]
                [    3800] Sun Feb 13 13:04:48 2011  INFO
                Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
                MsiSourceListAddSource for  E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi is 0
                MsiSourceListSetInfo with updated name: Microsoft_VC80_CRT_x86.msi, Result: 0
                [    3800] Sun Feb 13 13:04:49 2011  INFO
                MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC80_CRT_x86\, Result: 0
                Configuring MSI ProductCode: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
                ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress   REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adbBAA9.tmp"
                [    3800] Sun Feb 13 13:04:50 2011  INFO
                === Logging started: 13/02/2011  13:04:50 ===
                Message type: 1, Argument: Microsoft_VC80_CRT_x86
                Action 13:04:50: INSTALL.
                Action start 13:04:50: INSTALL.
                Action 13:04:50: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
                Action start 13:04:50: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
                Action ended 13:04:50: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E. Return value 1.
                Action 13:04:50: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
                Action start 13:04:50: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
                Action ended 13:04:50: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E. Return value 1.
                Action 13:04:50: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
                Action start 13:04:50: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
                Action ended 13:04:50: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E. Return value 1.
                Action 13:04:50: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
                Action start 13:04:50: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
                Action ended 13:04:50: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E. Return value 1.
                Action 13:04:50: AppSearch. Searching for installed applications
                Action start 13:04:50: AppSearch.
                Action ended 13:04:50: AppSearch. Return value 0.
                Action 13:04:50: FindRelatedProducts. Searching for related applications
                Action start 13:04:50: FindRelatedProducts.
                Action ended 13:04:50: FindRelatedProducts. Return value 0.
                Action 13:04:50: ValidateProductID.
                Action start 13:04:50: ValidateProductID.
                Action ended 13:04:50: ValidateProductID. Return value 1.
                Action 13:04:50: CostInitialize. Computing space requirements
                Action start 13:04:50: CostInitialize.
                Action ended 13:04:50: CostInitialize. Return value 1.
                Action 13:04:50: FileCost. Computing space requirements
                Action start 13:04:50: FileCost.
                Action ended 13:04:50: FileCost. Return value 1.
                Action 13:04:50: IsolateComponents.
                Action start 13:04:50: IsolateComponents.
                Action ended 13:04:50: IsolateComponents. Return value 0.
                Action 13:04:50: CostFinalize. Computing space requirements
                Action start 13:04:50: CostFinalize.
                Action ended 13:04:50: CostFinalize. Return value 1.
                Action 13:04:50: SetODBCFolders. Initializing ODBC directories
                Action start 13:04:50: SetODBCFolders.
                Action ended 13:04:50: SetODBCFolders. Return value 0.
                Action 13:04:50: MigrateFeatureStates. Migrating feature states from related applications
                Action start 13:04:50: MigrateFeatureStates.
                Action ended 13:04:50: MigrateFeatureStates. Return value 0.
                Action 13:04:50: InstallValidate. Validating install
                Action start 13:04:50: InstallValidate.
                Action ended 13:04:50: InstallValidate. Return value 1.
                Action 13:04:50: RemoveExistingProducts. Removing applications
                Action start 13:04:50: RemoveExistingProducts.
                Action ended 13:04:50: RemoveExistingProducts. Return value 0.
                Action 13:04:50: InstallInitialize.
                Action start 13:04:50: InstallInitialize.
                Action ended 13:04:50: InstallInitialize. Return value 1.
                Action 13:04:50: SxsInstallCA.
                Action start 13:04:50: SxsInstallCA.
                1: sxsdelca 2: traceop 3: 1256 4: 0
                1: sxsdelca 2: traceop 3: 1257 4: 0
                1: sxsdelca 2: traceop 3: 1258 4: 0
                1: sxsdelca 2: traceop 3: 1284 4: 0
                1: sxsdelca 2: traceop 3: 1288 4: 0
                1: sxsdelca 2: traceop 3: 1289 4: 0
                1: sxsdelca 2: traceop 3: 1290 4: 0
                1: sxsdelca 2: traceop 3: 1292 4: 0
                1: sxsdelca 2: traceop 3: 1318 4: 0
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: uplevel.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: uplevel.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                1: sxsdelca 2: traceop 3: 1284 4: 259
                1: sxsdelca 2: SxsMsmInstall completed 3: 0 4: 0
                Action ended 13:04:50: SxsInstallCA. Return value 1.
                Action 13:04:50: ProcessComponents. Updating component registration
                Action start 13:04:50: ProcessComponents.
                Action 13:04:50: GenerateScript. Generating script operations for action:
                Action ended 13:04:50: ProcessComponents. Return value 1.
                Action 13:04:50: UnpublishComponents. Unpublishing Qualified Components
                Action start 13:04:50: UnpublishComponents.
                Action ended 13:04:50: UnpublishComponents. Return value 0.
                Action 13:04:50: MsiUnpublishAssemblies. Unpublishing assembly information
                Action start 13:04:50: MsiUnpublishAssemblies.
                Action ended 13:04:50: MsiUnpublishAssemblies. Return value 1.
                Action 13:04:50: UnpublishFeatures. Unpublishing product features
                Action start 13:04:50: UnpublishFeatures.
                Action ended 13:04:50: UnpublishFeatures. Return value 1.
                Action 13:04:50: StopServices. Stopping services
                Action start 13:04:50: StopServices.
                Action ended 13:04:50: StopServices. Return value 1.
                Action 13:04:50: DeleteServices. Deleting services
                Action start 13:04:50: DeleteServices.
                Action ended 13:04:50: DeleteServices. Return value 1.
                Action 13:04:50: UnregisterComPlus. Unregistering COM+ Applications and Components
                Action start 13:04:50: UnregisterComPlus.
                Action ended 13:04:50: UnregisterComPlus. Return value 0.
                Action 13:04:50: SelfUnregModules. Unregistering modules
                Action start 13:04:50: SelfUnregModules.
                Action ended 13:04:50: SelfUnregModules. Return value 1.
                Action 13:04:50: UnregisterTypeLibraries. Unregistering type libraries
                Action start 13:04:50: UnregisterTypeLibraries.
                Action ended 13:04:50: UnregisterTypeLibraries. Return value 0.
                Action 13:04:50: RemoveODBC. Removing ODBC components
                Action start 13:04:50: RemoveODBC.
                Action ended 13:04:50: RemoveODBC. Return value 1.
                Action 13:04:50: UnregisterFonts. Unregistering fonts
                Action start 13:04:50: UnregisterFonts.
                Action ended 13:04:50: UnregisterFonts. Return value 1.
                Action 13:04:50: RemoveRegistryValues. Removing system registry values
                Action start 13:04:50: RemoveRegistryValues.
                Action ended 13:04:50: RemoveRegistryValues. Return value 1.
                Action 13:04:50: UnregisterClassInfo. Unregister class servers
                Action start 13:04:50: UnregisterClassInfo.
                Action ended 13:04:50: UnregisterClassInfo. Return value 0.
                Action 13:04:50: UnregisterExtensionInfo. Unregistering extension servers
                Action start 13:04:50: UnregisterExtensionInfo.
                Action ended 13:04:50: UnregisterExtensionInfo. Return value 0.
                Action 13:04:50: UnregisterProgIdInfo. Unregistering program identifiers
                Action start 13:04:50: UnregisterProgIdInfo.
                Action ended 13:04:50: UnregisterProgIdInfo. Return value 0.
                Action 13:04:50: UnregisterMIMEInfo. Unregistering MIME info
                Action start 13:04:50: UnregisterMIMEInfo.
                Action ended 13:04:50: UnregisterMIMEInfo. Return value 0.
                Action 13:04:50: RemoveIniValues. Removing INI file entries
                Action start 13:04:50: RemoveIniValues.
                Action ended 13:04:50: RemoveIniValues. Return value 1.
                Action 13:04:50: RemoveShortcuts. Removing shortcuts
                Action start 13:04:50: RemoveShortcuts.
                Action ended 13:04:50: RemoveShortcuts. Return value 0.
                Action 13:04:50: RemoveEnvironmentStrings. Updating environment strings
                Action start 13:04:50: RemoveEnvironmentStrings.
                Action ended 13:04:50: RemoveEnvironmentStrings. Return value 1.
                Action 13:04:50: RemoveDuplicateFiles. Removing duplicated files
                Action start 13:04:50: RemoveDuplicateFiles.
                Action ended 13:04:50: RemoveDuplicateFiles. Return value 1.
                Action 13:04:50: RemoveFiles. Removing files
                Action start 13:04:50: RemoveFiles.
                Action ended 13:04:50: RemoveFiles. Return value 0.
                Action 13:04:50: RemoveFolders. Removing folders
                Action start 13:04:50: RemoveFolders.
                Action ended 13:04:50: RemoveFolders. Return value 0.
                Action 13:04:50: CreateFolders. Creating folders
                Action start 13:04:50: CreateFolders.
                Action ended 13:04:50: CreateFolders. Return value 0.
                Action 13:04:50: MoveFiles. Moving files
                Action start 13:04:50: MoveFiles.
                Action ended 13:04:50: MoveFiles. Return value 1.
                Action 13:04:50: InstallFiles. Copying new files
                Action start 13:04:50: InstallFiles.
                [    3800] Sun Feb 13 13:04:52 2011  INFO
                [    3800] Sun Feb 13 13:04:58 2011  INFO
                Action ended 13:04:58: InstallFiles. Return value 1.
                Action 13:04:58: PatchFiles. Patching files
                Action start 13:04:58: PatchFiles.
                Action ended 13:04:58: PatchFiles. Return value 0.
                Action 13:04:58: DuplicateFiles. Creating duplicate files
                Action start 13:04:58: DuplicateFiles.
                Action ended 13:04:58: DuplicateFiles. Return value 1.
                Action 13:04:58: BindImage. Binding executables
                Action start 13:04:58: BindImage.
                Action ended 13:04:58: BindImage. Return value 1.
                Action 13:04:58: CreateShortcuts. Creating shortcuts
                Action start 13:04:58: CreateShortcuts.
                Action ended 13:04:58: CreateShortcuts. Return value 0.
                Action 13:04:58: RegisterClassInfo. Registering class servers
                Action start 13:04:58: RegisterClassInfo.
                Action ended 13:04:58: RegisterClassInfo. Return value 0.
                Action 13:04:58: RegisterExtensionInfo. Registering extension servers
                Action start 13:04:58: RegisterExtensionInfo.
                Action ended 13:04:58: RegisterExtensionInfo. Return value 0.
                Action 13:04:58: RegisterProgIdInfo. Registering program identifiers
                Action start 13:04:58: RegisterProgIdInfo.
                Action ended 13:04:58: RegisterProgIdInfo. Return value 0.
                Action 13:04:58: RegisterMIMEInfo. Registering MIME info
                Action start 13:04:58: RegisterMIMEInfo.
                Action ended 13:04:58: RegisterMIMEInfo. Return value 0.
                Action 13:04:58: WriteRegistryValues. Writing system registry values
                Action start 13:04:58: WriteRegistryValues.
                Action ended 13:04:58: WriteRegistryValues. Return value 1.
                Action 13:04:58: WriteIniValues. Writing INI file values
                Action start 13:04:58: WriteIniValues.
                Action ended 13:04:58: WriteIniValues. Return value 1.
                Action 13:04:58: WriteEnvironmentStrings. Updating environment strings
                Action start 13:04:58: WriteEnvironmentStrings.
                Action ended 13:04:58: WriteEnvironmentStrings. Return value 1.
                Action 13:04:58: RegisterFonts. Registering fonts
                Action start 13:04:58: RegisterFonts.
                Action ended 13:04:58: RegisterFonts. Return value 1.
                Action 13:04:58: InstallODBC. Installing ODBC components
                Action start 13:04:58: InstallODBC.
                Action ended 13:04:58: InstallODBC. Return value 0.
                Action 13:04:58: RegisterTypeLibraries. Registering type libraries
                Action start 13:04:58: RegisterTypeLibraries.
                Action ended 13:04:58: RegisterTypeLibraries. Return value 0.
                Action 13:04:58: SelfRegModules. Registering modules
                Action start 13:04:58: SelfRegModules.
                Action ended 13:04:58: SelfRegModules. Return value 1.
                Action 13:04:58: RegisterComPlus. Registering COM+ Applications and Components
                Action start 13:04:58: RegisterComPlus.
                Action ended 13:04:58: RegisterComPlus. Return value 0.
                Action 13:04:58: InstallServices. Installing new services
                Action start 13:04:58: InstallServices.
                Action ended 13:04:58: InstallServices. Return value 1.
                Action 13:04:58: StartServices. Starting services
                Action start 13:04:58: StartServices.
                Action ended 13:04:58: StartServices. Return value 1.
                Action 13:04:58: RegisterUser. Registering user
                Action start 13:04:58: RegisterUser.
                Action ended 13:04:58: RegisterUser. Return value 0.
                Action 13:04:58: RegisterProduct. Registering product
                Action start 13:04:58: RegisterProduct.
                Registering product
                Action ended 13:04:58: RegisterProduct. Return value 1.
                Action 13:04:58: PublishComponents. Publishing qualified components
                Action start 13:04:58: PublishComponents.
                Action ended 13:04:58: PublishComponents. Return value 0.
                Action 13:04:58: MsiPublishAssemblies. Publishing assembly information
                Action start 13:04:58: MsiPublishAssemblies.
                Action ended 13:04:58: MsiPublishAssemblies. Return value 1.
                Action 13:04:58: PublishFeatures. Publishing product features
                Action start 13:04:58: PublishFeatures.
                Action ended 13:04:58: PublishFeatures. Return value 1.
                Action 13:04:58: PublishProduct. Publishing product information
                Action start 13:04:58: PublishProduct.
                Action ended 13:04:58: PublishProduct. Return value 1.
                Action 13:04:58: InstallFinalize.
                Action start 13:04:58: InstallFinalize.
                Action 13:04:58: ProcessComponents. Updating component registration
                Action 13:04:58: RemoveODBC. Removing ODBC components
                Action 13:04:58: InstallFiles. Copying new files
                [    3800] Sun Feb 13 13:04:59 2011  INFO
                Action 13:04:59: RegisterProduct. Registering product
                35404c.msi
                Action 13:04:59: MsiPublishAssemblies. Publishing assembly information
                Application Context:Global, Assembly Name:Microsoft.VC80.CRT,version="8.0.50727.4053",type="win32",publicKeyToken="1fc8b3b9a1e 18e3b",processorArchitecture="x86"
                Application Context:Global, Assembly Name:policy.8.0.Microsoft.VC80.CRT,version="8.0.50727.4053",type="win32-policy",publicKey Token="1fc8b3b9a1e18e3b",processorArchitecture="x86"
                Action 13:04:59: PublishFeatures. Publishing product features
                Feature: Microsoft_VC80_CRT_x86_
                Action 13:04:59: PublishProduct. Publishing product information
                Action 13:04:59: RollbackCleanup. Removing backup files
                File: C:\Config.Msi\3b153.rbf
                File: C:\Config.Msi\3b154.rbf
                Action ended 13:04:59: InstallFinalize. Return value 1.
                Action ended 13:04:59: INSTALL. Return value 1.
                Property(S): SourcedirProduct = {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
                Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\
                Property(S): UpgradeCode = {662366D8-8FF7-4EA3-92A8-C7FEA8AC8032}
                Property(S): Installed = 2009/11/13 21:21:16
                Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
                Property(S): DATABASE = C:\Windows\Installer\3b14d.msi
                Property(S): Time = 13:04:59
                Property(S): VirtualMemory = 14322
                Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\
                Property(S): WinSxsDirectory.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
                Property(S): payload_ul.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_d08d7da0442 a985d\
                Property(S): payload.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_0de06acd\
                Property(S): WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\
                Property(S): SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
                Property(S): WinSxsManifests.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
                Property(S): WinSxsPolicies.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
                Property(S): policydir.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): policydir_ul.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989\
                Property(S): policydir.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): policydir.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): policydir.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): policydir.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): policydir.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): policydir.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): payload.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_0de46bd0\
                Property(S): policydir.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): policydir.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): policydir.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): policydir.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): payload.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_0de56c0a\
                Property(S): payload.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_0de56c09\
                Property(S): policydir.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): policydir.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): payload.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_0de56c0b\
                Property(S): payload.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_0de56c0c\
                Property(S): policydir.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): policydir.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): payload.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_0de56c0d\
                Property(S): policydir.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): payload.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_0de56c0e\
                Property(S): payload.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_0de56c0f\
                Property(S): policydir.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): policydir.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): payload.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_6818287e\
                Property(S): policydir.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): payload.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_6818287f\
                Property(S): payload.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_68182881\
                Property(S): policydir.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): payload.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_68182882\
                Property(S): payload.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_68212ab8\
                Property(S): policydir.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): payload.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_689938c4\
                Property(S): policydir.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): payload.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_b80ea88c\
                Property(S): policydir.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): payload.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_b80fa8c8\
                Property(S): policydir.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): payload.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_b810a90f\
                Property(S): payload.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_5ef082d6\
                Property(S): payload.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_e69378d0\
                Property(S): policydir.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                Property(S): payload.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_e69378d1\
                Property(S): payload.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_e69378d2\
                Property(S): payload.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_e695794c\
                Property(S): payload.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_e6967988\
                Property(S): payload.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989\
                Property(S): WinSxsDirectory.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
                Property(S): payload_ul.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_ 516e2e610f48bda6\
                Property(S): WinSxsPolicies.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
                Property(S): policydir.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\
                Property(S): SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
                Property(S): WinSxsManifests.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
                Property(S): payload.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_51 e427d4\
                Property(S): policydir.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): policydir.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): policydir_ul.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_ 2a9a3690\
                Property(S): policydir.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): policydir.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): policydir.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): policydir.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): policydir.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): payload.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_51 e92911\
                Property(S): policydir.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): policydir.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): payload.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_51 e828d7\
                Property(S): policydir.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): payload.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_51 e92910\
                Property(S): policydir.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): policydir.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): policydir.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): policydir.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): payload.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_51 e92912\
                Property(S): policydir.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): payload.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_51 e92913\
                Property(S): policydir.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): payload.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_51 e92914\
                Property(S): policydir.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): payload.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_51 e92915\
                Property(S): policydir.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): payload.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_51 e92916\
                Property(S): policydir.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): payload.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_a c1be585\
                Property(S): payload.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_a c1be586\
                Property(S): policydir.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): payload.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_a c1be588\
                Property(S): payload.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_a c1be589\
                Property(S): policydir.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): policydir.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): payload.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_a c24e7bf\
                Property(S): policydir.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): policydir.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                Property(S): payload.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_a c9cf5cb\
                Property(S): payload.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_ fc126593\
                Property(S): payload.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_ fc1365cf\
                Property(S): payload.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_ fc146616\
                Property(S): payload.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_ a2f43fdd\
                Property(S): payload.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_ 2a9735d7\
                Property(S): payload.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_ 2a9735d8\
                Property(S): payload.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_ 2a9735d9\
                Property(S): payload.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_ 2a993653\
                Property(S): payload.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_ 2a9a368f\
                Property(S): payload.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_ 2a9a3690\
                Property(S): ProductCode = {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
                Property(S): ProductName = Microsoft_VC80_CRT_x86
                Property(S): ProductVersion = 8.0.50727.4053
                Property(S): RebootYesNo = No
                Property(S): DWUSLINK = CE2BC78F6EACC0E8D9AC408FEEFC978F8EBCE78FCE9CA7F8CE4B878F7EBC2738E98CA7A8F9AC
                Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adbBAA9.tmp
                Property(S): PackageCode = {FA041436-73B8-40C4-97F3-249E037C89EE}
                === Logging stopped: 13/02/2011  13:04:59 ===
                1: 2 2: 0
                1: 2 2: 1
                [    3432] Sun Feb 13 13:04:59 2011  INFO
                :: END TIMER :: [Payload Operation :{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}] took 11024.1 miliseconds (11.0241 seconds) DTR = 31.2043 KBPS (0.0304729 MBPS)
                Calling the custom action code for post-repair for payload {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86
                Calling the custom action code for pre-repair for payload {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
                ::START TIMER:: [Payload Operation :{D92BBB52-82FF-42ED-8A3C-4E062F944AB7}]
                [    3440] Sun Feb 13 13:04:59 2011  INFO
                Installer Operation: ModifyThirdPartyPayloadOperation
                Modify Thirdparty payload
                Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\Microsoft_VC80_MFCLOC_x86.msi
                [    3440] Sun Feb 13 13:05:00 2011  INFO
                MsiSourceListAddSource for  E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\Microsoft_VC80_MFCLOC_x86.msi is 0
                MsiSourceListSetInfo with updated name: Microsoft_VC80_MFCLOC_x86.msi, Result: 0
                Payload exists on removable media: E:\
                Updating Media for package
                Added volume name: CS5 Master Coll1 for diskID: 1 with result: 0
                MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\, Result: 0
                Configuring MSI ProductCode: {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
                Setting AFLPath C:\Program Files (x86)\Common Files\Adobe\Installers\{FBB02B04-C034-4382-A3F6-57416E2752C4}
                MsiConfigureProductEx command line:
                ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress   REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adbE62D.tmp"
                1: 0 2: 1033 3: 1252
                === Logging started: 13/02/2011  13:05:00 ===
                Message type: 0, Argument: 1033
                Message type: 1, Argument: Microsoft_VC80_MFCLOC_x86
                Action 13:05:00: INSTALL.
                Action start 13:05:00: INSTALL.
                Action 13:05:00: WindowsFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E.
                Action start 13:05:00: WindowsFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E.
                Action ended 13:05:00: WindowsFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E. Return value 1.
                Action 13:05:00: SystemFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E.
                Action start 13:05:00: SystemFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E.
                Action ended 13:05:00: SystemFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E. Return value 1.
                Action 13:05:00: WindowsFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E.
                Action start 13:05:00: WindowsFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E.
                Action ended 13:05:00: WindowsFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E. Return value 1.
                Action 13:05:00: SystemFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E.
                Action start 13:05:00: SystemFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E.
                Action ended 13:05:00: SystemFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E. Return value 1.
                Action 13:05:00: AppSearch. Searching for installed applications
                Action start 13:05:00: AppSearch.
                Action ended 13:05:00: AppSearch. Return value 0.
                Action 13:05:00: FindRelatedProducts. Searching for related applications
                Action start 13:05:00: FindRelatedProducts.
                Action ended 13:05:00: FindRelatedProducts. Return value 0.
                Action 13:05:00: ValidateProductID.
                Action start 13:05:00: ValidateProductID.
                Action ended 13:05:00: ValidateProductID. Return value 1.
                Action 13:05:00: CostInitialize. Computing space requirements
                Action start 13:05:00: CostInitialize.
                Action ended 13:05:00: CostInitialize. Return value 1.
                Action 13:05:00: FileCost. Computing space requirements
                Action start 13:05:00: FileCost.
                Action ended 13:05:00: FileCost. Return value 1.
                Action 13:05:00: IsolateComponents.
                Action start 13:05:00: IsolateComponents.
                Action ended 13:05:00: IsolateComponents. Return value 0.
                Action 13:05:00: CostFinalize. Computing space requirements
                Action start 13:05:00: CostFinalize.
                Action ended 13:05:00: CostFinalize. Return value 1.
                Action 13:05:00: SetODBCFolders. Initializing ODBC directories
                Action start 13:05:00: SetODBCFolders.
                Action ended 13:05:00: SetODBCFolders. Return value 0.
                Action 13:05:00: MigrateFeatureStates. Migrating feature states from related applications
                Action start 13:05:00: MigrateFeatureStates.
                Action ended 13:05:00: MigrateFeatureStates. Return value 0.
                Action 13:05:00: InstallValidate. Validating install
                Action start 13:05:00: InstallValidate.
                Action ended 13:05:00: InstallValidate. Return value 1.
                Action 13:05:00: RemoveExistingProducts. Removing applications
                Action start 13:05:00: RemoveExistingProducts.
                Action ended 13:05:00: RemoveExistingProducts. Return value 0.
                Action 13:05:00: InstallInitialize.
                Action start 13:05:00: InstallInitialize.
                Action ended 13:05:00: InstallInitialize. Return value 1.
                Action 13:05:00: SxsInstallCA.
                Action start 13:05:00: SxsInstallCA.
                [    3440] Sun Feb 13 13:05:02 2011  INFO
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4053.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: uplevel.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.89.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.93.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.94.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.95.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.96.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.97.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.98.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.99.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.100.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.101.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.103.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.104.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.193.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.238.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3044.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3051.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3069.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.1833.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4027.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4028.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4029.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4045.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4052.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: uplevel.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
                Action ended 13:05:02: SxsInstallCA. Return value 1.
                Action 13:05:02: ProcessComponents. Updating component registration
                Action start 13:05:02: ProcessComponents.
                Action 13:05:02: GenerateScript. Generating script operations for action:
                Action ended 13:05:02: ProcessComponents. Return value 1.
                Action 13:05:02: UnpublishComponents. Unpublishing Qualified Components
                Action start 13:05:02: UnpublishComponents.
                Action ended 13:05:02: UnpublishComponents. Return value 0.
                Action 13:05:02: MsiUnpublishAssemblies. Unpublishing assembly information
                Action start 13:05:02: MsiUnpublishAssemblies.
                Action ended 13:05:02: MsiUnpublishAssemblies. Return value 1.
                Action 13:05:02: UnpublishFeatures. Unpublishing product features
                Action start 13:05:02: UnpublishFeatures.
                Action ended 13:05:02: UnpublishFeatures. Return value 1.
                Action 13:05:02: StopServices. Stopping services
                Action start 13:05:02: StopServices.
                Action ended 13:05:02: StopServices. Return value 1.
                Action 13:05:02: DeleteServices. Deleting services
                Action start 13:05:02: DeleteServices.
                Action ended 13:05:02: DeleteServices. Return value 1.
                Action 13:05:02: UnregisterComPlus. Unregistering COM+ Applications and Components
                Action start 13:05:02: UnregisterComPlus.
                Action ended 13:05:02: UnregisterComPlus. Return value 0.
                Action 13:05:02: SelfUnregModules. Unregistering modules
                Action start 13:05:02: SelfUnregModules.
                Action ended 13:05:02: SelfUnregModules. Return value 1.
                Action 13:05:02: UnregisterTypeLibraries. Unregistering type libraries
                Action start 13:05:02: UnregisterTypeLibraries.
                Action ended 13:05:02: UnregisterTypeLibraries. Return value 0.
                Action 13:05:02: RemoveODBC. Removing ODBC components
                Action start 13:05:02: RemoveODBC.
                Action ended 13:05:02: RemoveODBC. Return value 1.
                Action 13:05:02: UnregisterFonts. Unregistering fonts
                Action start 13:05:02: UnregisterFonts.
                Action ended 13:05:02: UnregisterFonts. Return value 1.
                Action 13:05:02: RemoveRegistryValues. Removing system registry values
                Action start 13:05:02: RemoveRegistryValues.
                Action ended 13:05:02: RemoveRegistryValues. Return value 1.
                Action 13:05:02: UnregisterClassInfo. Unregister class servers
                Action start 13:05:02: UnregisterClassInfo.
                Action ended 13:05:02: UnregisterClassInfo. Return value 0.
                Action 13:05:02: UnregisterExtensionInfo. Unregistering extension servers
                Action start 13:05:02: UnregisterExtensionInfo.
                Action ended 13:05:02: UnregisterExtensionInfo. Return value 0.
                Action 13:05:02: UnregisterProgIdInfo. Unregistering program identifiers
                Action start 13:05:02: UnregisterProgIdInfo.
                Action ended 13:05:02: UnregisterProgIdInfo. Return value 0.
                Action 13:05:02: UnregisterMIMEInfo. Unregistering MIME info
                Action start 13:05:02: UnregisterMIMEInfo.
                Action ended 13:05:02: UnregisterMIMEInfo. Return value 0.
                Action 13:05:02: RemoveIniValues. Removing INI file entries
                Action start 13:05:02: RemoveIniValues.
                Action ended 13:05:02: RemoveIniValues. Return value 1.
                Action 13:05:02: RemoveShortcuts. Removing shortcuts
                Action start 13:05:02: RemoveShortcuts.
                Action ended 13:05:02: RemoveShortcuts. Return value 0.
                Action 13:05:02: RemoveEnvironmentStrings. Updating environment strings
                Action start 13:05:02: RemoveEnvironmentStrings.
                Action ended 13:05:02: RemoveEnvironmentStrings. Return value 1.
                Action 13:05:02: RemoveDuplicateFiles. Removing duplicated files
                Action start 13:05:02: RemoveDuplicateFiles.
                Action ended 13:05:02: RemoveDuplicateFiles. Return value 1.
                Action 13:05:02: RemoveFiles. Removing files
                Action start 13:05:02: RemoveFiles.
                Action ended 13:05:02: RemoveFiles. Return value 0.
                Action 13:05:02: RemoveFolders. Removing folders
                Action start 13:05:02: RemoveFolders.
                Action ended 13:05:02: RemoveFolders. Return value 0.
                Action 13:05:02: CreateFolders. Creating folders
                Action start 13:05:02: CreateFolders.
                Action ended 13:05:02: CreateFolders. Return value 0.
                Action 13:05:02: MoveFiles. Moving files
                Action start 13:05:02: MoveFiles.
                Action ended 13:05:02: MoveFiles. Return value 1.
                Action 13:05:02: InstallFiles. Copying new files
                Action start 13:05:02: InstallFiles.
                File: Copying new files,  Directory: ,  Size:
                Action ended 13:05:02: InstallFiles. Return value 1.
                Action 13:05:02: PatchFiles. Patching files
                Action start 13:05:02: PatchFiles.
                Action ended 13:05:02: PatchFiles. Return value 0.
                Action 13:05:02: DuplicateFiles. Creating duplicate files
                Action start 13:05:02: DuplicateFiles.
                Action ended 13:05:02: DuplicateFiles. Return value 1.
                Action 13:05:02: BindImage. Binding executables
                Action start 13:05:02: BindImage.
                Action ended 13:05:02: BindImage. Return value 1.
                Action 13:05:02: CreateShortcuts. Creating shortcuts
                Action start 13:05:02: CreateShortcuts.
                Shortcut: Creating shortcuts
                Action ended 13:05:02: CreateShortcuts. Return value 0.
                Action 13:05:02: RegisterClassInfo. Registering class servers
                Action start 13:05:02: RegisterClassInfo.
                Action ended 13:05:02: RegisterClassInfo. Return value 0.
                Action 13:05:02: RegisterExtensionInfo. Registering extension servers
                Action start 13:05:02: RegisterExtensionInfo.
                Action ended 13:05:02: RegisterExtensionInfo. Return value 0.
                Action 13:05:02: RegisterProgIdInfo. Registering program identifiers
                Action start 13:05:02: RegisterProgIdInfo.
                Action ended 13:05:02: RegisterProgIdInfo. Return value 0.
                Action 13:05:02: RegisterMIMEInfo. Registering MIME info
                Action start 13:05:02: RegisterMIMEInfo.
                Action ended 13:05:02: RegisterMIMEInfo. Return value 0.
                Action 13:05:02: WriteRegistryValues. Writing system registry values
                Action start 13:05:02: WriteRegistryValues.
                Action ended 13:05:02: WriteRegistryValues. Return value 1.
                Action 13:05:02: WriteIniValues. Writing INI file values
                Action start 13:05:02: WriteIniValues.
                Action ended 13:05:02: WriteIniValues. Return value 1.
                Action 13:05:02: WriteEnvironmentStrings. Updating environment strings
                Action start 13:05:02: WriteEnvironmentStrings.
                Action ended 13:05:02: WriteEnvironmentStrings. Return value 1.
                Action 13:05:02: RegisterFonts. Registering fonts
                Action start 13:05:02: RegisterFonts.
                Action ended 13:05:02: RegisterFonts. Return value 1.
                Action 13:05:02: InstallODBC. Installing ODBC components
                Action start 13:05:02: InstallODBC.
                Action ended 13:05:02: InstallODBC. Return value 0.
                Action 13:05:02: RegisterTypeLibraries. Registering type libraries
                Action start 13:05:02: RegisterTypeLibraries.
                Action ended 13:05:02: RegisterTypeLibraries. Return value 0.
                Action 13:05:02: SelfRegModules. Registering modules
                Action start 13:05:02: SelfRegModules.
                Action ended 13:05:02: SelfRegModules. Return value 1.
                Action 13:05:02: RegisterComPlus. Registering COM+ Applications and Components
                Action start 13:05:02: RegisterComPlus.
                Action ended 13:05:02: RegisterComPlus. Return value 0.
                Action 13:05:02: InstallServices. Installing new services
                Action start 13:05:02: InstallServices.
                Action ended 13:05:02: InstallServices. Return value 1.
                Action 13:05:02: StartServices. Starting services
                Action start 13:05:02: StartServices.
                Action ended 13:05:02: StartServices. Return value 1.
                Action 13:05:02: RegisterUser. Registering user
                Action start 13:05:02: RegisterUser.
                Action ended 13:05:02: RegisterUser. Return value 0.
                Action 13:05:02: RegisterProduct. Registering product
                Action start 13:05:02: RegisterProduct.
                Registering product
                Action ended 13:05:02: RegisterProduct. Return value 1.
                Action 13:05:02: PublishComponents. Publishing qualified components
                Action start 13:05:02: PublishComponents.
                Action ended 13:05:02: PublishComponents. Return value 0.
                Action 13:05:02: MsiPublishAssemblies. Publishing assembly information
                Action start 13:05:02: MsiPublishAssemblies.
                Application Context:Publishing assembly information, Assembly Name:
                Action ended 13:05:02: MsiPublishAssemblies. Return value 1.
                Action 13:05:02: PublishFeatures. Publishing product features
                Action start 13:05:02: PublishFeatures.
                Feature: Publishing product features
                Action ended 13:05:02: PublishFeatures. Return value 1.
                Action 13:05:02: PublishProduct. Publishing product information
                Action start 13:05:02: PublishProduct.
                Action ended 13:05:02: PublishProduct. Return value 1.
                Action 13:05:02: InstallFinalize.
                Action start 13:05:02: InstallFinalize.
                Shortcut: ARPPRODUCTICON.exe
                354055.msi
                Application Context:Global, Assembly Name:Microsoft.VC80.MFCLOC,publicKeyToken="1fc8b3b9a1e18e3b",version="8.0.50727.4053",typ e="win32",processorArchitecture="x86"
                Application Context:Global, Assembly Name:policy.8.0.Microsoft.VC80.MFCLOC,publicKeyToken="1fc8b3b9a1e18e3b",version="8.0.5072 7.4053",type="win32-policy",processorArchitecture="x86"
                Feature: Microsoft_VC80_MFCLOC_x
                Message type: 2, Argument: 0
                Action 13:05:02: RollbackCleanup. Removing backup files
                File: C:\Config.Msi\3b15c.rbf
                File: C:\Config.Msi\3b15d.rbf
                Message type: 2, Argument: 1
                Action ended 13:05:02: InstallFinalize. Return value 1.
                Action ended 13:05:02: INSTALL. Return value 1.
                Property(S): DiskPrompt = [1]
                Property(S): UpgradeCode = {DBBF67A0-1BA6-4CF4-A1EF-007F1FD45598}
                Property(S): SourcedirProduct = {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
                Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\
                Property(S): PrimaryVolumeSpaceRemaining = 0
                Property(S): PrimaryVolumeSpaceRequired = 0
                Property(S): PrimaryVolumeSpaceAvailable = 0
                Property(S): OutOfNoRbDiskSpace = 0
                Property(S): OutOfDiskSpace = 0
                Property(S): Installed = 2009/11/13 21:27:58
                Property(S): CostingComplete = 1
                Property(S): ROOTDRIVE = F:\
                Property(S): ACTION = INSTALL
                Property(S): Preselected = 1
                Property(S): QFEUpgrade = 1
                Property(S): UILevel = 2
                Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\Microsoft_VC80_MFCLOC_x86.msi
                Property(S): DATABASE = C:\Windows\Installer\3b156.msi
                Property(S): Privileged = 1
                Property(S): MsiRunningElevated = 1
                Property(S): RedirectedDllSupport = 2
                Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
                Property(S): MsiNetAssemblySupport = 4.0.30319.1
                Property(S): Date = 13/02/2011
                Property(S): Time = 13:05:02
                Property(S): TTCSupport = 1
                Property(S): ColorBits = 32
                Property(S): TextInternalLeading = 3
                Property(S): TextHeight = 16
                Property(S): BorderSide = 1
                Property(S): BorderTop = 1
                Property(S): CaptionHeight = 22
                Property(S): ScreenY = 768
                Property(S): ScreenX = 1024
                Property(S): SystemLanguageID = 3081
                Property(S): ComputerName = PC
                Property(S): UserLanguageID = 3081
                Property(S): UserSID = S-1-5-21-618155685-1063480468-518450737-1000
                Property(S): LogonUser = Gary & Susan
                Property(S): MsiTrueAdminUser = 1
                Property(S): AdminUser = 1
                Property(S): VirtualMemory = 14311
                Property(S): PhysicalMemory = 8151
                Property(S): Intel = 6
                Property(S): Msix64 = 6
                Property(S): MsiAMD64 = 6
                Property(S): ShellAdvtSupport = 1
                Property(S): OLEAdvtSupport = 1
                Property(S): GPTSupport = 1
                Property(S): VersionNT = 601
                Property(S): ProgramFilesFolder = C:\Program Files (x86)\
                Property(S): ADOBE = C:\Program Files (x86)\Adobe\
                Property(S): TARGETDIR = F:\
                Property(S): ALLUSERSPROFILE = F:\
                Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
                Property(S): AppDataFolder = C:\Users\Gary & Susan\AppData\Roaming\
                Property(S): CommonAppDataFolder = C:\ProgramData\
                Property(S): CommonFiles64Folder = C:\Program Files (x86)\Common Files\
                Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
                Property(S): ISYourDataBaseDir = C:\Program Files (x86)\Adobe\My Product Name\Database\
                Property(S): DATABASEDIR = C:\Program Files (x86)\Adobe\My Product Name\Database\
                Property(S): DesktopFolder = C:\Users\Public\Desktop\
                Property(S): FavoritesFolder = C:\Users\Gary & Susan\Favorites\
                Property(S): FontsFolder = C:\Windows\Fonts\
                Property(S): GlobalAssemblyCache = F:\
                Property(S): MY_PRODUCT_NAME = C:\Program Files (x86)\Adobe\My Product Name\
                Property(S): INSTALLDIR = C:\Program Files (x86)\Adobe\My Product Name\
                Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
                Property(S): ISMyCompanyDir = C:\Program Files (x86)\My Company Name\
                Property(S): ISMyProductDir = C:\Program Files (x86)\My Company Name\My Product Name\
                Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
                Property(S): LocalAppDataFolder = C:\Users\Gary & Susan\AppData\Local\
                Property(S): MyPicturesFolder = C:\Users\Gary & Susan\Pictures\
                Property(S): PersonalFolder = C:\Users\Gary & Susan\Documents\
                Property(S): PrimaryVolumePath = F:\
                Property(S): ProgramFiles64Folder = C:\Program Files (x86)\
                Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
                Property(S): SendToFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\SendTo\
                Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
                Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
                Property(S): System16Folder = F:\
                Property(S): System64Folder = C:\Windows\SysWOW64\
                Property(S): SystemFolder = C:\Windows\SysWOW64\
                Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\
                Property(S): TempFolder = C:\Users\GARY&S~1\AppData\Local\Temp\
                Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
                Property(S): USERPROFILE = F:\
                Property(S): WindowsFolder = C:\Windows\
                Property(S): WindowsVolume = C:\
                Property(S): WinSxsDirectory.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
                Property(S): payload_ul.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.4053_none_03ca5532 205cb096\
                Property(S): payload.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_3415f6d0\
                Property(S): WindowsFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\
                Property(S): SystemFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
                Property(S): WinSxsManifests.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
                Property(S): WinSxsPolicies.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
                Property(S): policydir.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): policydir_ul.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_0ccc058c \
                Property(S): policydir.8.0.50727.89.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): policydir.8.0.50727.94.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.89.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_3419f7d3\
                Property(S): policydir.8.0.50727.95.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): policydir.8.0.50727.93.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.93.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_341af80c\
                Property(S): payload.8.0.50727.94.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_341af80d\
                Property(S): policydir.8.0.50727.96.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): policydir.8.0.50727.97.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.95.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_341af80e\
                Property(S): policydir.8.0.50727.99.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.96.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_341af80f\
                Property(S): policydir.8.0.50727.98.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): policydir.8.0.50727.101.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.97.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_341af810\
                Property(S): payload.8.0.50727.98.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_341af811\
                Property(S): policydir.8.0.50727.100.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.99.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_341af812\
                Property(S): payload.8.0.50727.100.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_8e4db481\
                Property(S): policydir.8.0.50727.103.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): policydir.8.0.50727.104.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): policydir.8.0.50727.238.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.101.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_8e4db482\
                Property(S): policydir.8.0.50727.193.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.103.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_8e4db484\
                Property(S): payload.8.0.50727.104.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_8e4db485\
                Property(S): policydir.8.0.50727.3044.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.193.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_8e56b6bb\
                Property(S): policydir.8.0.50727.3069.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.238.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_8ecec4c7\
                Property(S): policydir.8.0.50727.3051.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.3044.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_de44348f \
                Property(S): payload.8.0.50727.3051.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_de4534cb \
                Property(S): policydir.8.0.50727.1833.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): policydir.8.0.50727.4027.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.3069.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_de463512 \
                Property(S): payload.8.0.50727.1833.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_85260ed9 \
                Property(S): policydir.8.0.50727.4028.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): policydir.8.0.50727.4029.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.4027.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_0cc904d3 \
                Property(S): payload.8.0.50727.4028.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_0cc904d4 \
                Property(S): policydir.8.0.50727.4045.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): policydir.8.0.50727.4052.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.4029.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_0cc904d5 \
                Property(S): payload.8.0.50727.4045.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_0ccb054f \
                Property(S): policydir.8.0.50727.4053.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
                Property(S): payload.8.0.50727.4052.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_0ccc058b \
                Property(S): payload.8.0.50727.4053.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_0ccc058c \
                Property(S): ALLUSERS = 1
                Property(S): WinSxsDirectory.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
                Property(S): payload_ul.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.4053_no ne_4db266e67dd280ef\
                Property(S): WinSxsPolicies.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
                Property(S): policydir.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): WindowsFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\
                Property(S): SystemFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
                Property(S): WinSxsManifests.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
                Property(S): payload.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww _63bb0537\
                Property(S): policydir.8.0.50727.103.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): policydir.8.0.50727.96.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): policydir_ul.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4053_x- ww_3c7113f3\
                Property(S): policydir.8.0.50727.94.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): policydir.8.0.50727.89.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): policydir.8.0.50727.95.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): policydir.8.0.50727.100.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): policydir.8.0.50727.93.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): payload.8.0.50727.94.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww _63c00674\
                Property(S): policydir.8.0.50727.193.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): policydir.8.0.50727.98.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): payload.8.0.50727.89.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww _63bf063a\
                Property(S): policydir.8.0.50727.104.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): payload.8.0.50727.93.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww _63c00673\
                Property(S): policydir.8.0.50727.99.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): policydir.8.0.50727.101.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): policydir.8.0.50727.97.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): policydir.8.0.50727.4028.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): payload.8.0.50727.95.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww _63c00675\
                Property(S): policydir.8.0.50727.3044.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): payload.8.0.50727.96.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww _63c00676\
                Property(S): policydir.8.0.50727.238.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): payload.8.0.50727.97.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww _63c00677\
                Property(S): policydir.8.0.50727.4052.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): payload.8.0.50727.98.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww _63c00678\
                Property(S): policydir.8.0.50727.1833.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): payload.8.0.50727.99.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww _63c00679\
                Property(S): policydir.8.0.50727.3051.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): payload.8.0.50727.100.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.100_x-w w_bdf2c2e8\
                Property(S): payload.8.0.50727.101.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.101_x-w w_bdf2c2e9\
                Property(S): policydir.8.0.50727.4029.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): payload.8.0.50727.103.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.103_x-w w_bdf2c2eb\
                Property(S): payload.8.0.50727.104.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.104_x-w w_bdf2c2ec\
                Property(S): policydir.8.0.50727.4045.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): policydir.8.0.50727.4027.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): payload.8.0.50727.193.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.193_x-w w_bdfbc522\
                Property(S): policydir.8.0.50727.3069.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): policydir.8.0.50727.4053.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_cae ee150\
                Property(S): payload.8.0.50727.238.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.238_x-w w_be73d32e\
                Property(S): payload.8.0.50727.3044.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.3044_x- ww_0de942f6\
                Property(S): payload.8.0.50727.3051.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.3051_x- ww_0dea4332\
                Property(S): payload.8.0.50727.3069.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.3069_x- ww_0deb4379\
                Property(S): payload.8.0.50727.1833.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.1833_x- ww_b4cb1d40\
                Property(S): payload.8.0.50727.4027.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4027_x- ww_3c6e133a\
                Property(S): payload.8.0.50727.4028.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4028_x- ww_3c6e133b\
                Property(S): payload.8.0.50727.4029.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4029_x- ww_3c6e133c\
                Property(S): payload.8.0.50727.4045.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4045_x- ww_3c7013b6\
                Property(S): payload.8.0.50727.4052.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4052_x- ww_3c7113f2\
                Property(S): payload.8.0.50727.4053.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4053_x- ww_3c7113f3\
                Property(S): RecentFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Recent\
                Property(S): PrintHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
                Property(S): NetHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
                Property(S): RemoteAdminTS = 1
                Property(S): MsiNTSuitePersonal = 1
                Property(S): MsiNTProductType = 1
                Property(S): ServicePackLevelMinor = 0
                Property(S): ServicePackLevel = 0
                Property(S): WindowsBuild = 7600
                Property(S): VersionNT64 = 601
                Property(S): VersionMsi = 5.00
                Property(S): ISCHECKFORPRODUCTUPDATES = 1
                Property(S): ApplicationUsers = AllUsers
                Property(S): AgreeToLicense = No
                Property(S): _IsMaintenance = Change
                Property(S): SetupType = Typical
                Property(S): _IsSetupTypeMin = Typical
                Property(S): IS_SQLSERVER_USERNAME = sa
                Property(S): IS_SQLSERVER_AUTHENTICATION = 0
                Property(S): RestartManagerOption = CloseRestart
                Property(S): Display_IsBitmapDlg = 1
                Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
                Property(S): DefaultUIFont = Tahoma8
                Property(S): DialogCaption = InstallShield for Windows Installer
                Property(S): DisplayNameCustom = Custom
                Property(S): DisplayNameMinimal = Minimal
                Property(S): DisplayNameTypical = Typical
                Property(S): DWUSINTERVAL = 30
                Property(S): ErrorDialog = SetupError
                Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
                Property(S): InstallChoice = AR
                Property(S): INSTALLLEVEL = 100
                Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
                Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
                Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
                Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
                Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
                Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
                Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
                Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
                Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
                Property(S): ISVROOT_PORT_NO = 0
                Property(S): Manufacturer = Adobe
                Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
                Property(S): ProductCode = {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
                Property(S): ProductID = none
                Property(S): ProductLanguage = 1033
                Property(S): ProductName = Microsoft_VC80_MFCLOC_x86
                Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
                Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
                Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
                Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
                Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
                Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
                Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
                Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
                Property(S): ProgressType0 = install
                Property(S): ProgressType1 = Installing
                Property(S): ProgressType2 = installed
                Property(S): ProgressType3 = installs
                Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
                Property(S): ReinstallModeText = omus
                Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
                Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
                Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
                Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
                Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
                Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
                Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
                Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
                Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
                Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
                Property(S): DWUSLINK = CE0BC0C8E9CBE7B86EACE7CFDEDC978F99CC678F49ABA0E8CE6BC7C8BEDB9088F9ACF798D9AC
                Property(S): ARPURLINFOABOUT = http://www.Adobe.com
                Property(S): SHOWLAUNCHPROGRAM = 0
                Property(S): ARPSYSTEMCOMPONENT = 1
                Property(S): REBOOT = ReallySuppress
                Property(S): VersionDatabase = 200
                Property(S): PRODUCTLANGUAGE = 1033
                Property(S): CURRENTMEDIAVOLUMELABEL = CS5 Master Coll1
                Property(S): CLIENTPROCESSID = 4116
                Property(S): MSICLIENTUSESEXTERNALUI = 1
                Property(S): CLIENTUILEVEL = 3
                Property(S): CURRENTDIRECTORY = C:\Users\Gary & Susan\AppData\Local\Adobe\OOBE\PDApp\DWA
                Property(S): ADDLOCAL = ALL
                Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adbE62D.tmp
                Property(S): REINSTALLMODE = pvoums
                Property(S): REINSTALL = ALL
                Property(S): MSIRESTARTMANAGERCONTROL = Disable
                Property(S): ADOBE_SETUP = 1
                Property(S): USERNAME = Gary & Susan
                Property(S): ProductToBeRegistered = 1
                Property(S): ProductState = 5
                Property(S): PackageCode = {AF8EF662-EF5A-426A-AA7B-B83C3A5FFFBB}
                === Logging stopped: 13/02/2011  13:05:02 ===
                1: 2 2: 0
                1: 2 2: 1
                [    3432] Sun Feb 13 13:05:02 2011  INFO
                *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
                :: END TIMER :: [Payload Operation :{D92BBB52-82FF-42ED-8A3C-4E062F944AB7}] took 3027.02 miliseconds (3.02702 seconds) DTR = 9.25001 KBPS (0.00903322 MBPS)
                [    3432] Sun Feb 13 13:05:03 2011  INFO
                User specified overrideFile:
                Calling the custom action code for post-repair for payload {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86
                Calling the custom action code for pre-repair for payload {D1A19B02-817E-4296-A45B-07853FD74D57}
                ::START TIMER:: [Payload Operation :{D1A19B02-817E-4296-A45B-07853FD74D57}]
                [    4664] Sun Feb 13 13:05:03 2011  INFO
                Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC80_MFC_x86\Microsoft_VC80_MFC_x86.msi
                MsiSourceListAddSource for  E:\Adobe CS5\payloads\Microsoft_VC80_MFC_x86\Microsoft_VC80_MFC_x86.msi is 0
                MsiSourceListSetInfo with updated name: Microsoft_VC80_MFC_x86.msi, Result: 0
                MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC80_MFC_x86\, Result: 0
                Configuring MSI ProductCode: {D1A19B02-817E-4296-A45B-07853FD74D57}
                ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress   REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adbF1B4.tmp"
                [    4664] Sun Feb 13 13:05:04 2011  INFO
                === Logging started: 13/02/2011  13:05:04 ===
                Message type: 1, Argument: Microsoft_VC80_MFC_x86
                Action 13:05:04: INSTALL.
                Action start 13:05:04: INSTALL.
                Action 13:05:04: WindowsFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E.
                Action start 13:05:04: WindowsFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E.
                Action ended 13:05:04: WindowsFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E. Return value 1.
                Action 13:05:04: SystemFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E.
                Action start 13:05:04: SystemFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E.
                Action ended 13:05:04: SystemFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E. Return value 1.
                Action 13:05:04: WindowsFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E.
                Action start 13:05:04: WindowsFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E.
                Action ended 13:05:04: WindowsFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E. Return value 1.
                Action 13:05:04: SystemFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E.
                Action start 13:05:04: SystemFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E.
                Action ended 13:05:04: SystemFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E. Return value 1.
                Action 13:05:04: AppSearch. Searching for installed applications
                Action start 13:05:04: AppSearch.
                Action ended 13:05:04: AppSearch. Return value 0.
                Action 13:05:04: FindRelatedProducts. Searching for related applications
                Action start 13:05:04: FindRelatedProducts.
                Action ended 13:05:04: FindRelatedProducts. Return value 0.
                Action 13:05:04: ValidateProductID.
                Action start 13:05:04: ValidateProductID.
                Action ended 13:05:04: ValidateProductID. Return value 1.
                Action 13:05:04: CostInitialize. Computing space requirements
                Action start 13:05:04: CostInitialize.
                Action ended 13:05:04: CostInitialize. Return value 1.
                Action 13:05:04: FileCost. Computing space requirements
                Action start 13:05:04: FileCost.
                Action ended 13:05:04: FileCost. Return value 1.
                Action 13:05:04: IsolateComponents.
                Action start 13:05:04: IsolateComponents.
                Action ended 13:05:04: IsolateComponents. Return value 0.
                Action 13:05:04: CostFinalize. Computing space requirements
                Action start 13:05:04: CostFinalize.
                Action ended 13:05:04: CostFinalize. Return value 1.
                Action 13:05:04: SetODBCFolders. Initializing ODBC directories
                Action start 13:05:04: SetODBCFolders.
                Action ended 13:05:04: SetODBCFolders. Return value 0.
                Action 13:05:04: MigrateFeatureStates. Migrating feature states from related applications
                Action start 13:05:04: MigrateFeatureStates.
                Action ended 13:05:04: MigrateFeatureStates. Return value 0.
                Action 13:05:04: InstallValidate. Validating install
                Action start 13:05:04: InstallValidate.
                Action ended 13:05:04: InstallValidate. Return value 1.
                Action 13:05:04: RemoveExistingProducts. Removing applications
                Action start 13:05:04: RemoveExistingProducts.
                Action ended 13:05:04: RemoveExistingProducts. Return value 0.
                Action 13:05:04: InstallInitialize.
                Action start 13:05:04: InstallInitialize.
                Action ended 13:05:04: InstallInitialize. Return value 1.
                Action 13:05:04: SxsInstallCA.
                Action start 13:05:04: SxsInstallCA.
                1: sxsdelca 2: traceop 3: 1256 4: 0
                1: sxsdelca 2: traceop 3: 1257 4: 0
                1: sxsdelca 2: traceop 3: 1258 4: 0
                1: sxsdelca 2: traceop 3: 1284 4: 0
                1: sxsdelca 2: traceop 3: 1288 4: 0
                1: sxsdelca 2: traceop 3: 1289 4: 0
                1: sxsdelca 2: traceop 3: 1290 4: 0
                1: sxsdelca 2: traceop 3: 1292 4: 0
                1: sxsdelca 2: traceop 3: 1318 4: 0
                1: sxsdelca: Skipping component  2: uplevel.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4053.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.89.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.94.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.93.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.95.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.96.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.97.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.98.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.99.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.100.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
                1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.101.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
