1. Re: Question about Edit Original feature
thersher Feb 13, 2011 8:01 AM (in response to thersher)Oops, I should mention I'm using CS4. Thanks!
2. Re: Question about Edit Original feature
Wade_Zimmerman Feb 13, 2011 4:56 PM (in response to thersher)this works similar in windows as it does on a Mac on the Windows platform you find anywhere on your mounted hard drives a jpeg file right click and choose Properties in the properties panel there is the option to open the file in a specific application and another option to make this so for all similar files of this format.
Once you have made this change all your files of this format will open in the application you have chosen. If you choose photoshop al jpegs will open in Photoshop even from the edit original.
3. Re: Question about Edit Original feature
Mike Gondek2 Feb 14, 2011 6:00 AM (in response to thersher)After you define what apps open whcih file formats as per wade, you can also opt(alt on pc) double click on the image for a shortcut to edit original.
4. Re: Question about Edi't Original feature
Wade_Zimmerman Feb 14, 2011 6:15 AM (in response to Mike Gondek2)That's a good shortcut but will it change the editing aplication back to Photoshop?
