10 Replies Latest reply on Feb 14, 2011 1:36 PM by the_wine_snob
    Blending 2 videos
    filmschooljefe08!
      I'm trying to make a ghost effect in one of my videos and cant figure it how to do it.  I have 2 different shots and would like the one in the background to be ghost like while the main action to be in regular blend mode.
      I am currently using the blend effect, but anytime I change the blend mode both videos become transparent instead of just one.  Can anyone let me know how I will be able to do this?
      Jeff
        • 1. Re: Blending 2 videos
          the_wine_snob Level 9
          Jeff,
          If I understand what you are looking for, I would experiment with Levels on Video 1 Clips, to drop the Contrast and also the Levels, and then for Video 2's Clips, you have some choices: either drop the Opacity, or punch holes in it. Otherwise, it will cover the Clips on Video 1. How do you wish to see the "ghosted background" Video on Track 1?
          • 2. Re: Blending 2 videos
            filmschooljefe08! Level 1
            So first I would need to put the video I would like ghosted on video 1
            track? and then the one I would like full to be on Video track 2?
            I would like to see the ghosted background to look almost transparent,
            but still able to see the figures and see what they are doing.
            Jeff
            • 3. Re: Blending 2 videos
              shooternz Level 6
              I dont have an exact answer for you but you are on the right track.
              You need to play around with Blend Modes and Opacity in combinations on your clips.  Getting the combination is the trick!
              Be careful about Opacity.  It will leave what I call "OPACITY DROPPINGS" any time you touch it.  (others call them "opacity keyframes" but what ever ...they are automatically applied and can be a real PITA)
              • 4. Re: Blending 2 videos
                My issue  currently is that anytime I change the opacity or blend modes my video that i want to be at full is becoming transparent.  What I have is one person talking and then action going on behind him.  And i can make the action behind him transparent, but the guy talking is also becoming transparent and you can see the lamp that is behind him.
                Any ideas?
                • 5. Re: Blending 2 videos
                  Todd_Kopriva Level 8
                  Screenshots would help. It's hard to picture exactly what is going on based on your descriptions in words.
                  • 6. Re: Blending 2 videos
                    Is the person talking Keyed, so that the original background around them now held out?
                    Good luck, and I agree that screen-caps would be very helpful, as I am obviously not picturing, in my mind, what you want, and how you are going about creating it.
                    • 7. Re: Blending 2 videos
                      The image below on the right is my actor talking describing the scene that is about to go on behind him  This is in Video 1 Track.  Then the image on the left is the video that i want to be "ghost like" on video track 2 I am aware that I have some consistency issues such as lighting, chair placement, and the drapes, But I am ok with what the final result will be because of that.
                      When I add a blend mode and play with the opacity a little, I get the result seen below
                      as you can see both my actor speaking and the action going on behind is transparent.  Is there a way to keep the actor in black at full and then blend the background actors behind and make them ghostlike?
                      Thanks again.
                      • 8. Re: Blending 2 videos
                        I would look into going to AfterEffects and Keying the speaker with the RotoBrush. See this LINK.
                        To see the "ghosted" background behind, you need to either make the overlaying Video partially Transparent, what you do not want to do here, or "punch holes" in it.
                        Another option would be to do a PiP (Picture in Picture), and have the speaker in one "box," with the scene in another.
                        Good luck, and hope that others will offer a method, that is better for you.
                        • 9. Re: Blending 2 videos
                          I am thinking that punching holes in the video may be my best option.  How would I go about doing that?
                          Thanks again,
                          Jeff
                          • 10. Re: Blending 2 videos
                            See the above linked article on RotoBrush in AE.
                            If you had shot the actor against a green screen, you could do the Keying in PrPro, or in AE.
                            Otherwise, you have a couple of choices:
                            If the actor is static (not likely), you could use Track Matte Keying.
                            You could either apply the Crop Effect to the Clip with the actor, or apply one of the Garbage Mattes.
