11 Replies Latest reply on Feb 18, 2011 8:31 AM by feebeegeebee
    Persistent crash whilst fixing broken links
    feebeegeebee Level 1
      Using RH8 on Windows Vista SP2.
      I've had to reorganise a very large project as a result of major project changes.
      Although I carefully updated many, many links, I currently have several broken links listed.
      As I work through the list, fixing the topic links and topic references, I'm experiencing constant crashes.
      I can use Show Topic Links within the Broken Links area and update the links & save without problems.
      However, when I Show Topic References within the Broken Links area, update the links and save, I get a persistent crash. It is always after saving the last reference for that broken link that the crash occurs.
      It seems to save the change, but the following Microsoft Windows message appears:
      " Adobe RoboHelp 8 has stopped working.
      A problem caused the program to stop working correctly.
      Windows will close the program and notify you if a solution is available."
      There is then only the option to "Close Program".
      Any ideas why this should be happening and is anyone else experiencing the same problem?
      Thanks!
      Feebeegeebee
