2 Replies Latest reply on Feb 19, 2011 8:29 AM by Alon K.
    "Export Release Build" does nothing in Burrito
    Alon K.
      I get an error when trying to export a release build of a library project:  Unhandled event loop exception
      1. Is it necessary to do a release build to get rid of debug data maximize performance, minimize size of the SWC?
      2. If this is a bug, should I use Apache Maven or some such system for release builds in the meantime?
      3. Is there some work-around?  I saw this was a problem is Flash Builder 4 and 4.0.1 too based on forum posts but never experienced it.
      Here is the complete log:
      java.lang.NullPointerException
      at com.adobe.flexbuilder.exportimport.ExportImportPlugin.getExportReleaseBuildUIManager(Expo rtImportPlugin.java:154)
      at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionWizard.getUIMana ger(ExportReleaseVersionWizard.java:108)
      at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionProjectAndLocati onPage.getPageContent(ExportReleaseVersionProjectAndLocationPage.java:249)
      at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionProjectAndLocati onPage.createControl(ExportReleaseVersionProjectAndLocationPage.java:176)
      at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.java:170)
      at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionWizard.createPag eControls(ExportReleaseVersionWizard.java:414)
      at org.eclipse.jface.wizard.WizardDialog.createPageControls(WizardDialog.java:734)
      at org.eclipse.jface.wizard.WizardDialog.createContents(WizardDialog.java:606)
      at org.eclipse.jface.window.Window.create(Window.java:431)
      at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
      at com.adobe.flexbuilder.exportimport.releaseversion.ExportReleaseVersionAction$1.run(Export ReleaseVersionAction.java:93)
      at com.adobe.flexbuilder.exportimport.releaseversion.ExportReleaseVersionAction.run(ExportRe leaseVersionAction.java:103)
      at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
      at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:229)
      at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionI tem.java:584)
      at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
      at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java :411)
      at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
      at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
      at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
      at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
      at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
      at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
      at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
      at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
      at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
      at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
      at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
      at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
      at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
      at java.lang.reflect.Method.invoke(Unknown Source)
      at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
      at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
      at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
      Session Data
      eclipse.buildId=M20100909-0800
      java.version=1.6.0_16
      java.vendor=Sun Microsystems Inc.
      BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
      Command-line arguments:  -os win32 -ws win32 -arch x86 -clean
