1 Reply Latest reply on Feb 15, 2011 8:37 AM by BeriliaTubul
    [JS] XML : How to placeXML the content of a specific tag
    BeriliaTubul
      Hi, I'm new to scripting and I can't figure out how to do this :
      I need to find the first element with the tag "body" and make a placeXML on it.
      I make a function do find it, but I really don't know what to do after that.
      Here is my code :
      var tab= new Array();
      var body = findFirstElement(myDocument,"body", tab);
      function findFirstElement(elm, tag, tab)
          for (var i = 0; i < elm.xmlElements.length; i++)
              XMLelementName=elm.xmlElements[i].markupTag.name.toString();
              if(XMLelementName==tag)
                  elm.xmlElements[i].select();
                tab.push(elm.xmlElements[i]);
              else {
              findFirstElement(elm.xmlElements[i], tag, tab);
         return tab;
      At this point, body is [object XMLElement]
      So now, I would like to modify the following code to place body. I think I don't understand very well the structure of the document, but once again, I'm totally new at it.
      myDocument.xmlElements.item(0).xmlElements.item(0).placeXML(myDocument.pages.item(0).textF rames.item(0));
      If someone can help me...
        • 1. Re: [JS] XML : How to placeXML the content of a specific tag
          BeriliaTubul Level 1
          I finally found out how to do it : it's easy with XML Rules.
          Here is my code if someone is interested :
          var myRuleSet = new Array (new ShowBody);
          with(myDocument){
          var elements = xmlElements;
          __processRuleSet(elements.item(0), myRuleSet);
          function ShowBody(){
          this.name = "ShowBody";
          //XPath will match on every XML element in the XML structure.
          this.xpath = "//body";
          // Define the apply function.
          this.apply = function(myElement, myRuleProcessor){
          with(myElement){
          myElement.placeXML(myDocument.pages.item(0).textFrames.item(0));
          return true;
          // Succeeded
          } //End of apply function
