1 Reply Latest reply on Feb 15, 2011 3:12 AM by ManishPali
    Docs cut off when printing
    PamNM
      I am using Reader X. I have a dual tray printer and print many large packages (100+ pp) using both legal and letter sized paper.  The bottom portion of text on SOME (not all) of the legal pages is not printing, even though it shows on the screen.  I do not prepare the pdf's...my clients do.  I just print them.  Other than uninstalling and going back to a previous version is there any fix for this>
        • 1. Re: Docs cut off when printing
          ManishPali Adobe Employee
          Could you please try turning off reader X protected mode and check if you continue to see the problem?
          You could turn off protected mode using following steps:
          1. Launch Reader X and select Edit->Preferences...
          2. Select General from left navigation
          3. Under application startup uncheck "Enable Protected Mode at Startup"
          Note: You should switch "ON" protected mode after verifying the problem. Purpose of Reader X Protected Mode is to keep your system safe from PDF based exploits and keeping protected mode OFF will leave your system vulnerable.
