3 Replies Latest reply on Feb 15, 2011 1:44 PM by gherome_gherome
    Writing a Class for making the 'enemies' follow the 'player'...
    gherome_gherome
      Greetings;
      I'm an actionscript beginner and trying  to write a class to  make the 'enemies' follow the 'player' (shown below). I'm trying to write it such that it takes two MovieClips as arguments, and moves the first one toward the second one. When I import the Class try to use it in Main.as by typing  " var followPlayer:FollowPlayer = new FollowPlayer(fishMov0, player);", I get the following error:
      "ArgumentError: Error #1063: Argument count mismatch on jab.enemy::FollowPlayer/followPlayer(). Expected 2, got 1."
      Any ideas/suggestions would be appreciated.
      Jeremy
      package  jab.enemy
          import flash.display.MovieClip;
          import flash.events.Event;
          public class FollowPlayer
              private var _clip1:MovieClip
              private var _clip2:MovieClip
              private var speed:uint = 1.5;
              public function FollowPlayer(clip1:MovieClip, clip2:MovieClip): void
              // clip1 is the enemy, clip2 the player being followed.
                  _clip1 = clip1;
                  _clip2 = clip2;
                  _clip1.stage.addEventListener(Event.ENTER_FRAME, followPlayer);
                  _clip2.stage.addEventListener(Event.ENTER_FRAME, followPlayer);
              private function followPlayer(_clip1:MovieClip, _clip2:MovieClip)
                      if (_clip1.y > _clip2.y)
                          _clip1.y -= speed;
                      if (_clip1.y < _clip2.y)
                          _clip1.y += speed;
                      if (_clip1.x > _clip2.x)
                          _clip1.x -= speed;
                          _clip1.x -= speed;
        • 1. Re: Writing a Class for making the 'enemies' follow the 'player'...
          kglad-zqbLf4 Level 3
          followPlayer() is being sent one parameter, not two and, that parameter is an event.
          • 2. Re: Writing a Class for making the 'enemies' follow the 'player'...
            moccamaximum Level 5
            another thing
            you can`t write
            no movieclip can parent the stage
            and you have two functions with the same name
            • 3. Re: Writing a Class for making the 'enemies' follow the 'player'...
              gherome_gherome Level 1
              Thanks guys! My code was seriously flawed, but I ended up getting it to work. For anyone else that might be interested, see 'FollowPlayer' below, an extremely simple class which takes two MovieClips as arguments, and moves the first one slowly (at 24fps) toward the second one:
              package  jab.enemy
                      private var speed = 1 + Math.random();
                          _clip1 = clip1;
                          _clip2 = clip2;
                          _clip1.stage.addEventListener(Event.ENTER_FRAME, onEnterFrame)
                          function onEnterFrame(event:Event):void
                                  _clip1.y -= speed;
                                  _clip1.y += speed;
                                  _clip1.x -= speed;
                              if (_clip1.x < _clip2.x)
                                  _clip1.x += speed;
