1. Re: Correct Time Stamp in Source Monitor ?
JSS1138 Feb 14, 2011 9:54 AM (in response to EckleySP)what is that number trying to tell me?
13:39:09:10
Hours:Minutes:Seconds:Frames. It could mean that clip began recording around 1:39 PM. Or it could mean the timecode hasn't been reset for the past 13+ hours wirth of recording.
You can get to a desired location by clicking the timecode numbers in the lower left of the monitor and hitting the + or - keys and how far you want to advance or go back. To go one minute ahead, you hit +10000 (1 for the minutes, two zeros for the seconds, and two zeros for the frames.)
2. Re: Correct Time Stamp in Source Monitor ?
davidbeisner2010 Feb 14, 2011 9:57 AM (in response to EckleySP)Is that an actual timestamp on a 24-clock, or is that a camera where the internal clock was set to free-run not regen? That'd be my guess... I've never heard of timecode built into video that gives you the date/time of the shot... My guess is that the OP's camera was set to free-run or continuous time code, and so even though this may be the first file in his shoot (I noted the file number is all zero's but perhaps the file numbers got reset?) that camera has run 13+ hours without the internal timecode being reset...
3. Re: Correct Time Stamp in Source Monitor ?
Colin Brougham Feb 14, 2011 10:01 AM (in response to EckleySP)It is Timecode, the Patron Saint of Video Production. Those numbers are absolute references to individual frames in a recorded video. Think of them as "addresses" to a particular frames. Most people actually want timecode
What it sounds like is you are looking for relative references to the beginning of a clip, e.g. 1 minutes 20 seconds in. Is this correct? If so, you can pretty quickly figure out the in and out point in your timecoded clip based on your relative references.
If you use the numeric keypad, you can press the "+" or "-" to move to a relative time. Let's say you want to start at 1 minute, 20 seconds into a clip. Load the clip into the Source Monitor, make sure the CTI is parked on the first frame, and type (without quote) "+1.20.0". You're telling Premiere to advance (that's the plus sign) 1 minute, 20 seconds, and 0 frames. When you hit Enter, the CTI will jump ahead that duration. Mark your in point, and repeat for the out point. If you know how long the duration of the selection is to be, you can just do that, e.g. 30 second or "+30.0", or you can return to the first frame and type in the relative time of the out point based on your notes.
Does that help?
4. Re: Correct Time Stamp in Source Monitor ?
davidbeisner2010 Feb 14, 2011 10:05 AM (in response to Colin Brougham)Nice tip, Colin! New one for me, and I'll certainly be able to use it...
