14 Replies Latest reply on Feb 18, 2011 8:23 AM by teakeys2011
    Photoshop CS4 won't open RAW files
    teakeys2011
      Photoshop CS4 will not open RAW (.CR2) files. I have tried what is listed on Adobe's website (checking versions, uninstalling, reinstalling). Nothing has worked. It still gives me the error message: "Could not complete your request because Photoshop does not recognize this type of file."
      I am using CS4 on a 10.6.6 Mac OS with a Canon Rebel XS. I currently have Camera Raw 5.7 installed.
      Does anyone have any answers ?
      Thank you,
      Teresa
        • 1. Re: Photoshop CS4 won't open RAW files
          Jeff Schewe Level 5
          Are you sure? Where and how did you install ACR 5.7? ACR 5.7 should support the "EOS 1000D (Digital Rebel XS/EOS Kiss F)", is this the camera you are talking about? How are you trying to open the images, via Bridge or via Photoshop CS4? If via Bridge, have you tried purging the cache for the folder of ram files you are browsing?
          • 2. Re: Photoshop CS4 won't open RAW files
            teakeys2011 Level 1
            Hi Jeff,
            I'm not sure that it's properly installed , but it is installed. I checked under Photoshop > About Plug-In > Camera Raw and it says "5.7" (It was previously 5.0 which didn't work, and when several others had mentioned that I should update, I ran the updates, and now have 5.7) I do not know where exactly it is installed.
            Yes, that is the camera I have.
            I have tried to open via Bridge (using menu, "open in Camera Raw" is grayed out for the .CR2 files, using command + R, double-clicking, which opens a dialog box saying: "Could not complete your request because Photoshop does not recognize this type of file.")
            I have tried via Photoshop, all the .CR2's are grayed out.
            I have tried directly from the file itself … (it will open in Canon ImageBrowser)
            I have tried purging the cache in Bridge by going to Tools > Cache > Purge Cache … It still does not work.
            I am starting to think something is wrong with the files themselves.
            Teresa
            • 3. Re: Photoshop CS4 won't open RAW files
              Noel Carboni Level 8
              Is there a way you could put a copy of one of the files you can't open online, then share the link?  You could send it to yourself via YouSendIt.com, for example.  That way others could try opening it.
              -Noel
              • 4. Re: Photoshop CS4 won't open RAW files
                teakeys2011 Level 1
                Here is a link to one of my files: http://www.mediafire.com/?fgh4sb4hq9cxtcb
                Thank you,
                Teresa
                • 5. Re: Photoshop CS4 won't open RAW files
                  Level 4
                  That file does appear to be toast indeed.  :~(
                  I'm not familiar with files from that particular camera model, but 3.1 MB would be a puny file size for a raw from any DSLR I'm familiar with.
                  • 6. Re: Photoshop CS4 won't open RAW files
                    That image is only a little over 3 megabytes.  That's not large enough for a real CR2 file from your camera - they're normally upwards of 10 megabytes, right?
                    The raw file appears to be truncated.  Photoshop will not open it, and the freeware program IrfanView will only convert the upper-left quadrant.
                    As far as recovery of the images, at least partially, you may be in luck...  Canon Raw files contain an embedded JPEG preview image.  It's smaller than the full pixel size of the camera, and up front in the file.
                    Windows 7 Photo Viewer or the freeware program IrfanView will extract the entire embedded JPEG of the cat figure image from this file.  Perhaps you can use these tools to extract the previews for use.
                    How did you load the images into your computer?  It's worth trying to figure out how they were truncated.
                    -Noel
                    • 7. Re: Photoshop CS4 won't open RAW files
                      teakeys2011 Level 1
                      Hi Noel,
                      I took a better look into my camera's files and it seems as though the problem is my camera's RAW + JPG setting. It was creating those small files. I tried shooting with RAW only mode (file size  9.74 MB) and I can finally open it in Photoshop ! Now I just need to figure out what's wrong with the RAW + JPG mode …
                      Thank you for your help !
                      Teresa
                      • 8. Re: Photoshop CS4 won't open RAW files
                        How are you transferring the files to your computer?
                        I ask because at one time Canon drivers had a problem where if you transferred Raw + JPEG across a USB cable from the camera, the driver would cross up the files.  The workaround to doing that is to use a card reader instead.
                        -Noel
                        • 9. Re: Photoshop CS4 won't open RAW files
                          teakeys2011 Level 1
                          I am using a USB. However, I checked on the camera and the file size for the images were already too small, so it's something that has to do with the camera itself (only when I use the RAW + JPG mode).
                          Teresa
                          • 10. Re: Photoshop CS4 won't open RAW files
                            Level 4
                            In that case, I'd suspect the camera is writing "sRaw" files, which are not supported in ACR.
                            • 11. Re: Photoshop CS4 won't open RAW files
                              I thought that at first, Tai, but then became convinced that sRaw doesn't figure into this, as the file Teresa posted contained a small part of a full resolution file.
                              I am curious how one determines the size of a file on the camera itself, Teresa.  I don't have that model...  Does it just read out the file size(s)?
                              I would still think it would be very interesting to see, via a card reader, what the file sizes really are when Raw + JPEG is used.
                              Card readers are dirt cheap, by the way.
                              -Noel
                              • 12. Re: Photoshop CS4 won't open RAW files
                                ssprengel Adobe Community Professional & MVP
                                The CAT.CR2 file that was posted is from a 1000D that does not have sRAW capabilities.  Comparing the ExifTool data and the camera specifications, there should have been a small-sized preview JPG image and a large-sized RAW image in the file, but the file was truncated after the top-left quadrant of RAW data was written:
                                http://www.dpreview.com/reviews/canoneos1000d/page3.asp
                                ExifTool Version Number         : 8.09
                                File Name                       : Cat.CR2
                                Directory                       : P:/Pictures/home/xfer_Other/7DTests/Misc
                                File Size                       : 3.1 MB
                                File Modification Date/Time     : 2011:02:17 19:41:05-06:00
                                File Permissions                : rw-rw-rw-
                                File Type                       : CR2
                                MIME Type                       : image/x-raw
                                Exif Byte Order                 : Little-endian (Intel, II)
                                Image Width                     : 1936
                                Image Height                    : 1288
                                Bits Per Sample                 : 8 8 8
                                Compression                     : JPEG (old-style)
                                Make                            : Canon
                                Camera Model Name               : Canon EOS DIGITAL REBEL XS
                                Preview Image Start             : 42816
                                Orientation                     : Horizontal (normal)
                                Preview Image Length            : 356052
                                X Resolution                    : 72
                                Y Resolution                    : 72
                                Resolution Unit                 : inches
                                Modify Date                     : 2011:02:10 00:34:31
                                Exposure Time                   : 1/50
                                F Number                        : 5.0
                                Exposure Program                : Aperture-priority AE
                                ISO                             : 800
                                Exif Version                    : 0221
                                Date/Time Original              : 2011:02:10 00:34:31
                                Create Date                     : 2011:02:10 00:34:31
                                Components Configuration        : Y, Cb, Cr, -
                                Shutter Speed Value             : 1/49
                                Aperture Value                  : 5.0
                                Flash                           : Off, Did not fire
                                Focal Length                    : 30.0 mm
                                Macro Mode                      : Normal
                                Self Timer                      : Off
                                Quality                         : RAW
                                Canon Flash Mode                : Off
                                Continuous Drive                : Single
                                Focus Mode                      : Manual Focus (3)
                                Record Mode                     : CR2+JPEG
                                Canon Image Size                : Large
                                Easy Mode                       : Manual
                                Digital Zoom                    : None
                                Contrast                        : Normal
                                Saturation                      : Normal
                                Metering Mode                   : Evaluative
                                Focus Range                     : Not Known
                                Canon Exposure Mode             : Aperture-priority AE
                                Lens Type                       : Canon EF-S 18-55mm f/3.5-5.6 IS
                                Long Focal                      : 55 mm
                                Short Focal                     : 18 mm
                                Focal Units                     : 1/mm
                                Max Aperture                    : 4.4
                                Min Aperture                    : 29
                                Flash Activity                  : 0
                                Flash Bits                      : (none)
                                Zoom Source Width               : 0
                                Zoom Target Width               : 0
                                Manual Flash Output             : n/a
                                Color Tone                      : Normal
                                SRAW Quality                    : n/a
                                Auto ISO                        : 100
                                Base ISO                        : 800
                                Measured EV                     : 7.75
                                Target Aperture                 : 5
                                Target Exposure Time            : 1/51
                                Exposure Compensation           : +1/3
                                Slow Shutter                    : None
                                Shot Number In Continuous Burst : 0
                                Optical Zoom Code               : n/a
                                Flash Guide Number              : 0
                                Flash Exposure Compensation     : 0
                                Auto Exposure Bracketing        : Off
                                AEB Bracket Value               : 0
                                Control Mode                    : Camera Local Control
                                Measured EV 2                   : 7.75
                                Bulb Duration                   : 0
                                Camera Type                     : EOS High-end
                                ND Filter                       : Unknown (-1)
                                Canon Image Type                : Canon EOS DIGITAL REBEL XS
                                Canon Firmware Version          : Firmware Version 1.0.7
                                Owner Name                      :
                                Camera Body No.                 : xxxxxxx102
                                Flash Metering Mode             : Off
                                Camera Temperature              : 27 C
                                Camera Orientation              : Horizontal (normal)
                                Focus Distance Upper            : 0.28
                                Focus Distance Lower            : 0.27
                                White Balance                   : Auto
                                Firmware Version                : 1.0.7
                                Directory Index                 : 100
                                File Index                      : 452
                                Canon Model ID                  : EOS Rebel XS / 1000D / Kiss F
                                Thumbnail Image Valid Area      : 0 159 7 112
                                Serial Number Format            : Format 2
                                AF Mode                         : Off (Manual Focus)
                                Num AF Points                   : 7
                                Valid AF Points                 : 7
                                Canon Image Width               : 1936
                                Canon Image Height              : 1288
                                AF Image Width                  : 3888
                                AF Image Height                 : 2592
                                AF Area Widths                  : 194 139 139 194 139 139 194
                                AF Area Heights                 : 139 194 194 194 194 194 139
                                AF Area X Positions             : 0 -1283 -769 0 769 1283 0
                                AF Area Y Positions             : -640 0 0 0 0 0 640
                                AF Points In Focus              : (none)
                                AF Points Selected              : 0,1,2,3,4,5,6
                                Original Decision Data Offset   : 0
                                Bracket Mode                    : Off
                                Bracket Value                   : 0
                                Bracket Shot Number             : 0
                                Raw Jpg Size                    : Large
                                Long Exposure Noise Reduction 2 : Off
                                WB Bracket Mode                 : Off
                                WB Bracket Value AB             : 0
                                WB Bracket Value GM             : 0
                                Live View Shooting              : Off
                                Lens Model                      : EF-S18-55mm f/3.5-5.6 IS
                                Internal Serial Number          : xxxxxxx3UU
                                Dust Removal Data               : (Binary data 1024 bytes, use -b option to extract)
                                Exposure Level Increments       : 1/3 Stop
                                Flash Sync Speed Av             : Auto
                                Long Exposure Noise Reduction   : Off
                                High ISO Noise Reduction        : Off
                                Auto Lighting Optimizer         : Enable
                                AF Assist Beam                  : Emits
                                AF During Live View             : Disable
                                Mirror Lockup                   : Disable
                                Shutter-AE Lock                 : AF/AE lock
                                Set Button When Shooting        : LCD monitor On/Off
                                LCD Display At Power On         : Display
                                Add Original Decision Data      : Off
                                Tone Curve                      : Standard
                                Sharpness                       : 0
                                Sharpness Frequency             : n/a
                                Sensor Red Level                : 0
                                Sensor Blue Level               : 0
                                White Balance Red               : 0
                                White Balance Blue              : 0
                                Color Temperature               : 5200
                                Picture Style                   : Faithful
                                Digital Gain                    : 0
                                WB Shift AB                     : 0
                                WB Shift GM                     : 0
                                Measured RGGB                   : 1174 1024 1024 298
                                VRD Offset                      : 0
                                Sensor Width                    : 3948
                                Sensor Height                   : 2622
                                Sensor Left Border              : 52
                                Sensor Top Border               : 23
                                Sensor Right Border             : 3939
                                Sensor Bottom Border            : 2614
                                Black Mask Left Border          : 0
                                Black Mask Top Border           : 0
                                Black Mask Right Border         : 0
                                Black Mask Bottom Border        : 0
                                Color Data Version              : 5 (450D/1000D)
                                WB RGGB Levels As Shot          : 2491 1024 1024 1558
                                Color Temp As Shot              : 5781
                                WB RGGB Levels Auto             : 2491 1024 1024 1558
                                Color Temp Auto                 : 5781
                                WB RGGB Levels Measured         : 2488 1021 1026 1559
                                Color Temp Measured             : 5781
                                WB RGGB Levels Daylight         : 2162 1024 1024 1586
                                Color Temp Daylight             : 5200
                                WB RGGB Levels Shade            : 2551 1024 1024 1311
                                Color Temp Shade                : 7000
                                WB RGGB Levels Cloudy           : 2351 1024 1024 1429
                                Color Temp Cloudy               : 6000
                                WB RGGB Levels Tungsten         : 1608 1137 1137 2786
                                Color Temp Tungsten             : 3200
                                WB RGGB Levels Fluorescent      : 1856 1024 1024 2222
                                Color Temp Fluorescent          : 3864
                                WB RGGB Levels Kelvin           : 2162 1024 1024 1586
                                Color Temp Kelvin               : 5200
                                WB RGGB Levels Flash            : 2405 1024 1024 1423
                                Color Temp Flash                : 6142
                                Raw Measured RGGB               : 50562 43856 45217 12556
                                User Comment                    :
                                Sub Sec Time                    : 23
                                Sub Sec Time Original           : 23
                                Sub Sec Time Digitized          : 23
                                Flashpix Version                : 0100
                                Color Space                     : sRGB
                                Exif Image Width                : 3888
                                Exif Image Height               : 2592
                                Interoperability Index          : R98 - DCF basic file (sRGB)
                                Interoperability Version        : 0100
                                Focal Plane X Resolution        : 4438.356164
                                Focal Plane Y Resolution        : 4445.969125
                                Focal Plane Resolution Unit     : inches
                                Custom Rendered                 : Normal
                                Exposure Mode                   : Auto
                                Scene Capture Type              : Standard
                                Thumbnail Offset                : 38124
                                Thumbnail Length                : 4689
                                Photometric Interpretation      : RGB
                                Samples Per Pixel               : 3
                                Rows Per Strip                  : 324
                                Planar Configuration            : Chunky
                                Strip Offsets                   : 1343652
                                Strip Byte Counts               : 8949054
                                Raw Image Segmentation          : 1 1964 1984
                                Aperture                        : 5.0
                                Drive Mode                      : Single-frame shooting
                                File Number                     : 100-0452
                                Image Size                      : 3888x2592
                                Lens                            : 18.0 - 55.0 mm
                                Lens ID                         : Canon EF-S 18-55mm f/3.5-5.6 IS
                                Preview Image                   : (Binary data 356052 bytes, use -b option to extract)
                                Scale Factor To 35 mm Equivalent: 1.6
                                Shooting Mode                   : Aperture-priority AE
                                Shutter Speed                   : 1/50
                                Create Date                     : 2011:02:10 00:34:31.23
                                Date/Time Original              : 2011:02:10 00:34:31.23
                                Modify Date                     : 2011:02:10 00:34:31.23
                                Thumbnail Image                 : (Binary data 4689 bytes, use -b option to extract)
                                WB RGGB Levels                  : 2491 1024 1024 1558
                                Blue Balance                    : 1.521484
                                Circle Of Confusion             : 0.019 mm
                                Field Of View                   : 40.7 deg
                                Focal Length                    : 30.0 mm (35 mm equivalent: 48.6 mm)
                                Hyperfocal Distance             : 9.70 m
                                Lens                            : 18.0 - 55.0 mm (35 mm equivalent: 29.1 - 89.0 mm)
                                Light Value                     : 7.3
                                Red Balance                     : 2.432617
                                • 13. Re: Photoshop CS4 won't open RAW files
                                  I checked for firmware updates.  This specific problem is not mentioned.
                                  http://web.canon.jp/imaging/eosd/firm-e/eosdigital5/firmware.html
                                  Once you have gotten all the images off, I'd reformat that memory card.
                                  -Noel
                                  • 14. Re: Photoshop CS4 won't open RAW files
                                    teakeys2011 Level 1
                                    -Noel
                                    Yes, the file size is displayed in review mode.
                                    Interesting about the card reader, I will try to dig up my card reader and see what happens.
                                    Teresa
