8 Replies Latest reply on Feb 16, 2011 6:21 PM by areohbee
    exportServiceProvider.allowFileFormats
    jovenator
      I am trying to write a publish service provider that works with originals only. When I set the allowFileFormats to { 'ORIGINAL' }, the File Settings section in the configuration dialog is grayed out with Original selected. This is what I expect. But when I publish photos, they are always rendered as jpgs. If I remove the allowFileFormats setting from my plugin and explicitly choose Original in the File Settings section, then the photos are rendered in their original form. This sounds like a bug to me. Is there anything I can do to work around this?
      Thanks!
      Andy
        • 1. Re: exportServiceProvider.allowFileFormats
          areohbee Level 6
          Try hiding all formats and just explicitly set the format to 'ORIGINAL'.
          • 2. Re: exportServiceProvider.allowFileFormats
            jovenator Level 1
            I've tried hiding all formats but still see the same problem. Do I need to do anything to explicitly set the format to ORIGINAL? Its not obvious how I can programatically change the built-in settings.
            Thanks!
            Andy
            • 3. Re: exportServiceProvider.allowFileFormats
              areohbee Level 6
              Yes - you have to set the LR_format export property before the export has been started.
              I dont know how your export is getting kicked off but, somewere there needs to be line like:
              exportParams.LR_format= 'ORIGINAL'
              Here's a cut from NxTooey for exporting a tif:
                  local params = {}
                  params.LR_collisionHandling = 'rename' -- this should never happen - I'll be checking in case it does.
                  params.LR_export_bitDepth = 16
                  params.LR_export_colorSpace = prefs.tifColorSpace
                  params.LR_export_destinationType = "sourceFolder"
                  params.LR_export_useSubfolder = false
                  params.LR_extensionCase = "lowercase"
                  params.LR_format = "TIFF"
                  params.LR_initialSequenceNumber = 1
                  params.LR_jpeg_limitSize = 100
                  params.LR_jpeg_quality = 1
                  params.LR_jpeg_useLimitSize = false
                  params.LR_metadata_keywordOptions = "lightroomHierarchical"
                  params.LR_minimizeEmbeddedMetadata = false
                  params.LR_outputSharpeningLevel = 2
                  params.LR_outputSharpeningMedia = "screen"
                  params.LR_outputSharpeningOn = false
                  params.LR_reimportExportedPhoto = false
                  params.LR_reimport_stackWithOriginal = false
                  params.LR_reimport_stackWithOriginal_position = "below"
                  params.LR_renamingTokensOn = true
                  params.LR_size_doConstrain = false
                  params.LR_size_resolution = 240
                  params.LR_size_resolutionUnits = "inch"
                  params.LR_tokenCustomString = ""
                  params.LR_tokens = LrPathUtils.removeExtension( filename )
                  params.LR_useWatermark = false
                  params.LR_watermarking_id = "<simpleCopyrightWatermark>"
                  local exportSession = LrExportSession {
                      photosToExport = { photo },
                      exportSettings = params,
                  exportSession:doExportOnCurrentTask() -- block until all renditions are created.
              Rob
              • 4. Re: exportServiceProvider.allowFileFormats
                jovenator Level 1
                Thanks Rob that worked great!
                • 5. Re: exportServiceProvider.allowFileFormats
                  areohbee Level 6
                  jovenator,
                  I'm guessing if format is not specified, Lightroom defaults to jpeg or something.
                  Glad you got it working!
                  Cheers,
                  Rob
                  • 6. Re: exportServiceProvider.allowFileFormats
                    jovenator Level 1
                    Are these LR_xxx parameters documented somewhere?
                    Andy
                    • 7. Re: exportServiceProvider.allowFileFormats
                      jovenator Level 1
                      Nevermind. Found em in the guide.
                      • 8. Re: exportServiceProvider.allowFileFormats
                        areohbee Level 6
                        They didn’t used to be, but they're in the pdf guide now - search for LR_format.
                        In case you want to double-check the document, run a test export and dump the export params using exportParams:pairs() - export parameters are an ordinary observable property table.
