15 Replies Latest reply on Feb 16, 2011 12:56 PM by kglad
    timeIssue
    Ron Colmen Level 2
      For some reason I'm unable to output the time returned by the php. This code is on my website and viewrs from different countries see different times.
      <?php
      date_default_timezone_set('Europe/Lisbon');
      echo time();
      //output example 1297797784
      AS
      var tl:MovieClip=this;
      var startTime:Number;
      server = new LoadVars();
      server.onData = function (src){
      tl.timeMS = Number(src);
      startTime=getTimer();
      clock_txt.onEnterFrame = timeF;
      server.load("http://www.myweb.com/timeServer.php");
      function timeF(){
      //var d:Date = new Date(tl.timeMS*1000+getTimer()-startTime);
      var d:Date = new Date(tl.timeMS*1000);
      //when I tried this, it displayed my local time.
      if(d.getHours()>12){
      var hours:Number=d.getHours()-12;
      var ampm:String = "PM";
      } else if(d.getHours()==12){
      hours=12;
      ampm="PM"
      } else {
      hours=d.getHours();
      ampm="AM";
      var hoursS:String = formatS(hours.toString());
      var minutes:String = formatS(d.getMinutes().toString());
      var seconds:String = formatS(d.getSeconds().toString());
      _root.clock_txt.clock_txt.text = hoursS + ":" + minutes + ":" + seconds +" "+ ampm;
      function formatS(s:String):String{
      while(s.length<2){
      s="0"+s;
      return s;
        • 1. Re: timeIssue
          <?php
          echo time();
          AS
          var sendLV:LoadVars = new LoadVars();
          var receiveLV:LoadVars=new LoadVars();
          receiveLV.onData = function (src){
          sendLV.sendAndLoad("http://www.myweb.com/timeServer.php",receiveLV,"POST");
          function timeF(){
          hours=12;
          ampm="PM"
          } else {
          hours=d.getHours();
          ampm="AM";
          while(s.length<2){
          s="0"+s;
          return s;
          • 2. Re: timeIssue
            Ron Colmen Level 2
            No luck. It still shows the local time.
            • 3. Re: timeIssue
              what php version is on your server?   eg, using your browser, open the php file containing:
              <?php
              phpinfo();
              • 4. Re: timeIssue
                Ron Colmen Level 2
                It's 5.2
                trace (d);
                output:
                Wed Feb 16 14:47:07 GMT+1000 2011
                • 5. Re: timeIssue
                  what's wrong with that date/time?
                  • 6. Re: timeIssue
                    Ron Colmen Level 2
                    That's the local time. tl.timeMS*1000 is supposed to be the time returned by the php.
                    • 7. Re: timeIssue
                      that looks like the correct time in lisbon to me:  ~8 hours in advance of the pacific time zone.
                      • 8. Re: timeIssue
                        Ron Colmen Level 2
                        Even if I change the php to output any other timezone, I don't see a time change in my swf... it just outputs the local time.
                        date_default_timezone_set('Australia/Sydney');
                        is this bold text causing the problem?
                        //rest of the code
                        I tried altering... but nothing was displayed.
                        _root.clock_txt.clock_txt.onEnterFrame = timeF;
                        //rest of the code
                        • 9. Re: timeIssue
                          why do you keep showing that screwy absolute url to your php file?
                          • 10. Re: timeIssue
                            Ron Colmen Level 2
                            I'm not sure if I red you correctly. Do you mean this? http://www.myweb.com/timeServer.php
                            That's just for illustrative purpose.
                            • 11. Re: timeIssue
                              yes, that's what i mean.  why don't you show your real url?  you are using a local path, correct?
                              • 12. Re: timeIssue
                                Ron Colmen Level 2
                                no. I've saved it in the ftp. I'm using a http://www. URL.to pull the time.
                                • 13. Re: timeIssue
                                  you should be using a local path though i don't know that will correct the problem.  in any case, the problem is on the server end.
                                  • 14. Re: timeIssue
                                    Ron Colmen Level 2
                                    Thanks. That's a good point.
                                    Any suggestions to fix this if the problem is on the server end?
                                    • 15. Re: timeIssue
                                      you can offset the old fashion way (use google), though php 5.1 or greater is supposed to support that date_default_timezone_set.
