2 Replies Latest reply on Feb 17, 2011 2:35 AM by rohsin47
    exception while invoking submit in customised workspace
    rohsin47 Level 1
      I have built a custom workpace as per the requiremnts. also, custom approval container,
      now what is happening is that while submit the data from custom workspace , it is throwing exception;
      Exception when invoking service 'remoting-service': flex.messaging.MessageException: Cannot invoke method 'prepareForSubmit'. Method 'prepareForSubmit' not found.
      incomingMessage: Flex Message (flex.messaging.messages.RemotingMessage)
      operation = prepareForSubmit
      parameters = [EBB9CD44-7C5C-102D-8E25-00000A051045, 2902]
      clientId = BC3D5FB2-9709-5A3C-5C2A-92AB0A3A1430
      destination = task-actions
      messageId = A3AA04BE-D287-DAE6-C042-2D277978BD5A
      timestamp = 1297837685127
      timeToLive = 0
      body = null
      hdr(DSId) = BC3CAB65-5D1C-688A-272F-3D7C4343E301
      hdr(DSEndpoint) = workspace-polling-amf
      Exception: flex.messaging.MessageException: Cannot invoke method 'prepareForSubmit'. Method 'prepareForSubmit' not found.
      at flex.messaging.util.MethodMatcher.methodNotFound(MethodMatcher.java:378)
      at flex.messaging.util.MethodMatcher.getMethod(MethodMatcher.java:186)
      at flex.messaging.services.remoting.adapters.JavaAdapter.invoke(JavaAdapter.java:420)
      at flex.messaging.services.RemotingService.serviceMessage(RemotingService.java:183)
      at flex.messaging.MessageBroker.routeMessageToService(MessageBroker.java:1406)
      at flex.messaging.AsyncMessageBroker.routeMessageToService(AsyncMessageBroker.java:571)
      at flex.messaging.endpoints.AbstractEndpoint.serviceMessage(AbstractEndpoint.java:1005)
      at flex.messaging.endpoints.amf.MessageBrokerFilter.invoke(MessageBrokerFilter.java:103)
      at flex.messaging.endpoints.amf.LegacyFilter.invoke(LegacyFilter.java:158)
      at flex.messaging.endpoints.amf.SessionFilter.invoke(SessionFilter.java:44)
      at flex.messaging.endpoints.amf.BatchProcessFilter.invoke(BatchProcessFilter.java:67)
      at flex.messaging.endpoints.amf.SerializationFilter.invoke(SerializationFilter.java:165)
      at flex.messaging.endpoints.BaseHTTPEndpoint.service(BaseHTTPEndpoint.java:293)
      at flex.messaging.MessageBrokerServlet.service(MessageBrokerServlet.java:364)
      at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
      and form remains as usual in workspace. this is not happening with only my custom apprval container but also with default and approval container too.
      it's seems to me there is some probem with my custom workspace code. as it is working fine with default workspace.
      what i did, was created custom login, as well as  some header comp and just lc:ToDo componet to which session is bound in Main.mxml.
      what is going wrong here? can anybody explain?
      want to add some more is that "prepareForSubmit" is present in TaskManager - api project - workspcae source code. But what i don't understand why it is not able to found it?
        • 1. Re: exception while invoking submit in customised workspace
          Jon Bionda Level 3
          Sounds like a version mismatch.  Whatever SP level you are at, apply the latest Process Management patch to get both a server side update AND the workspace source zip update.  Make sure you customization is on the updated source in the patch.
          • 2. Re: exception while invoking submit in customised workspace
            rohsin47 Level 1
            Thanks a lot Jon.
            it working fine now. after reading your comments i realised  my mistake. what i did actually, when i was customizing workspace code, i found files missing and realised that it contains bugs. so,  i decided to apply workbench sp1 update for Es2 gm which updated the workspace source code.
            and i started working on new souce code and after customizations done , i deployed it on server. but i found that when i was hitting any of the approval container window task, which involves interaction with livecycle. it is generating fault events. i put my whole day into debugging and sorting out. but no results.
            as per the exeption, after you hit approve or deny button , it will go to TaskManager.prepare forSubmit() and there in taskutem ation , it is generating faultevent instead of resultevent for reason beyond my fathom.
            But ,after you said about version mismatch, i got it imedaitely, that i applied the sp1 update to workbench only and not to server. So, i applied it to the server and sort out some issues while that. and finally evything working gr8 again.
            thanks once again Jon.
