3 Replies Latest reply on Feb 22, 2011 11:05 PM by flexiblekrish
    Want to access the current index of DataGroup component in the neasted datagroup
    flexiblekrish
      Hi
             I have 2 dimensional Arraycollection which contains the persons details. i want to display those by using Datagroup component. because it is a 2 dimentional i have to use nestead datagroup. but am not able to acces currentIndex (like repeater we can able to access). Please help me how can i access
      currentindex.
      sample code :
      <?xml version="1.0"?>
      <!-- repeater\RefNestedComponents.mxml -->
      <s:Application
      xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:mx="library://ns.adobe.com/flex/mx"
      xmlns:s="library://ns.adobe.com/flex/spark" xmlns:local="*" creationComplete="testd()">
      <fx:Script>
      <![CDATA[
      import mx.collections.ArrayCollection;
      import mx.collections.ArrayList;
      import mx.collections.IList;
      [Bindable]
      public var tests:ArrayCollection;
      public function testd():void{
      tests  = new ArrayCollection([
      {name:new ArrayCollection([{name:"Wilma Carter", Bats:"R", Throws:"R", Year:"So", Home: "Redlands, CA"}])},
      {name:new ArrayCollection([{name:"Sue Pennypacker", Bats:"L", Throws:"R", Year:"Fr", Home: "Athens, GA"}])},
      {name:new ArrayCollection([{name:"Jill Smithfield", Bats:"R", Throws:"L", Year:"Sr", Home: "Spokane, WA"}])},
      {name:new ArrayCollection([{name:"Shirley Goth", Bats:"R", Throws:"R", Year:"Sr", Home: "Carson, NV"}])},
      {name:new ArrayCollection([{name:"Jennifer Dunbar", Bats:"R", Throws:"R", Year:"Fr", Home: "Seaside, CA"}])},
      public function change(e:Event):void{
      tests[1].name ="tested";
      tests.refresh();
      </fx:Script>
      <s:layout>
      <s:VerticalLayout/>
      </s:layout>
      <s:DataGroup id="datagroup" dataProvider="{tests}" >
      <s:layout>
      <s:VerticalLayout/>
      </s:layout>
      <s:itemRenderer>
      <fx:Component >
        <!-- <s:DataGroup dataProvider="{outerDocument.tests[1].name}">-->
      <s:DataGroup dataProvider="{outerDocument.tests[INDEX].name}">
      <s:itemRenderer>
      <fx:Component>
      <mx:Text text="{data.name}"/>
      </fx:Component>
      </s:itemRenderer>
      </s:DataGroup>
      </fx:Component>
      </s:itemRenderer>
      </s:DataGroup>
      <s:Button click="change(event)"  label="click to change"/>
      </s:Application>
      in the above code :
      i want to get INDEX value ..
      please help me out .. thanks
        • 2. Re: Want to access the current index of DataGroup component in the neasted datagroup
          Shongrunden Adobe Employee
          In spark the ItemRenderer class should be the root tag inside your fx:Component tags.  That class has an itemIndex property built into it.
          Here is your code tweaked to show the itemIndex within the nested DataGroup and the outer DataGroup:
          <s:Application
              <fx:Script>
                  <![CDATA[
                      [Bindable]
                          tests.refresh();
              </fx:Script>
              <s:layout>
                  <s:VerticalLayout/>
              </s:layout>
                  <s:layout>
                      <s:VerticalLayout/>
                  </s:layout>
                  <s:itemRenderer>
                      <fx:Component>
                          <s:ItemRenderer>
                                  <s:itemRenderer>
                                      <fx:Component>
                                          <s:ItemRenderer>
                                              <mx:Text text="{data.name}, {itemIndex}, {outerDocument.itemIndex}"/>
                                          </s:ItemRenderer>
                                      </fx:Component>
                                  </s:itemRenderer>
                              </s:DataGroup>
                          </s:ItemRenderer>
                      </fx:Component>
                  </s:itemRenderer>
              </s:DataGroup>
          </s:Application>
          • 3. Re: Want to access the current index of DataGroup component in the neasted datagroup
            flexiblekrish Level 1
            Really you helpd me a lot ...thank you so much... am able to access.
