7 Replies Latest reply on Feb 16, 2011 6:10 AM by Ilkhan
    Premiere CS5 AME Export slower than direct export?
    Ilkhan
      Hello everyone,
      I am testing premiere cs5 premium, and having some issues with AME export render times.
      When I export media to AME it shows about 6hours to render a sequence which is 15min long.
      Export settings :
      H.264 1280x720 25fps
      VBR, 2-Pass, Progressive
      Target 8Mbps
      Max 10Mbps
      Input Squence is directly from AVCHD handycam with native settings no resizing but some simple color correction
      However when I do the same export directly from Premiere Pro the render time drops to 38mins (which is btw also not so optimal)
      My Hardware Specs:
      Intel Core2Quad @ 2,40Ghz
      Ram : 8GB (premiere uses 6GB)
      Scratchdisk: non raid 1TB with 130Mbps average read/write
      (Raw Files on Scratchdisk)
      I used to export similar sequences alot faster with cs4 on the same machine..
      What could cause this problem?
      Thank you in advance for your answers
