26 Replies Latest reply on Mar 1, 2011 10:26 AM by chriswillis100
    Custom Colorpicker
    chriswillis100
      Hey guys,
      I'm quite new to flex and i'm using an SDK that provents me from using the mx:colorpicker function
      What is the best way to go about making a simple one?
      Basically what i need it to do is look and act like a normal colorpicker (press the colorpicker button and the pallet slides out), but i only need 12 boxes for the colors (about 35x35)
      Can someone explain the simplest way of doing this
      Chris
        • 1. Re: Custom Colorpicker
          miguel8312 Level 3
          simplest way is to use the 3.5 sdk. why not do that... is there a reason your app must be on 4,0? you can also just import the mx: namespace into your app and then it should be available to you.
          Miguel
          Message was edited by: miguel8312
          • 2. Re: Custom Colorpicker
            chriswillis100 Level 1
            Because i'm using a Mobile Project, so i need to use flex hero because 3.5 doesn't support mobile projects
            • 3. Re: Custom Colorpicker
              miguel8312 Level 3
              I just did this using sdk 4 and it worked like a charm...
                    xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
              <fx:Declarations>
                <!-- Place non-visual elements (e.g., services, value objects) here -->
              </fx:Declarations>
              <mx:ColorPicker>
              </mx:ColorPicker>
              </s:Application>
              • 4. Re: Custom Colorpicker
                I think you're misunderstanding me,
                I'm using an SDK that wont allow me to use flex 3.5 in a mobile application
                Here's the error message
                The prefix "mx" for element "mx:ColorPicker" is not bound
                • 5. Re: Custom Colorpicker
                  robglobal
                  You're missing the namespace that defines what "mx" means:
                  in your top MXML node
                  • 6. Re: Custom Colorpicker
                    Sorry yeah i did forget that
                    This is the error message:
                    Could not resolve <mx:ColorPicker> to a component implementation.
                    • 7. Re: Custom Colorpicker
                      Flex harUI Adobe Employee
                      Mobile projects probably don't include the mx.swc in them.  The old MX
                      components don't have a good UI for mobile and will add weight to the app.
                      If you only have 12 colors, put them in a List or TileList and use a state
                      and transition to slide them out or in based on a ToggleButton.
                      • 8. Re: Custom Colorpicker
                        Ok, so i guess i'll use buttons as the color blocks
                        But i need to call the color of the button and i can't do that
                        • 9. Re: Custom Colorpicker
                          One option would be to use a List with a renderer that just colors its
                          background based on the data property, not a button.  Then the selectedIndex
                          would map to the color
                          You could also custom skin a buttonbar and get the same effect.
                          • 10. Re: Custom Colorpicker
                            But with a list i could only have 1 block of colour per row right?
                            Or i could only select one row even if it did have lots of color blocks
                            • 11. Re: Custom Colorpicker
                              A TileList could have multiple renderers per row
                              • 12. Re: Custom Colorpicker
                                How do you create the empty rows and coloums in the list and how to you relate to them in the item renderer?
                                • 13. Re: Custom Colorpicker
                                  I pretty much need this spelled out to me, because i've been trying for two days to sort this and i've got nowhere
                                  Chris
                                  • 14. Re: Custom Colorpicker
                                    Draw a picture of what you want it to look like.
                                    • 15. Re: Custom Colorpicker
                                      Thats what i'd like it to be like
                                      If you could write a list of things to do that would be much appeciated
                                      Chris
                                      • 16. Re: Custom Colorpicker
                                        I started with the Spark ColorPicker example on my blog.
                                        In ColorPickerListSkin.as, I:
                                        1) ripped out the Hgroup containing the Preview and TextInput, and all code
                                        that related to it
                                        2) changed from FocusGroup to s:Group
                                        3) modified the sizes of the swatchPanel Rect and DataGroup
                                        4) modified the size of the swatch
                                        In SparkColorPicker.as, I replaced the WebSafePalette with a custom
                                        ArrayList with the desired colors.
                                        • 17. Re: Custom Colorpicker
                                          private var colorlist:ArrayList
                                              private var colors:Array = new Array(0x000000, 0xCD0000, 0x00CD00)
                                              public function SparkColorPicker()
                                                  super();
                                                  colorlist = new ArrayList(colors)
                                                  labelFunction = blank;
                                                  labelToItemFunction = colorFunction;
                                                  openOnInput = false;
                                                  addEventListener(Event.CHANGE, colorChangeHandler);
                                          I made the WebSafePallet into an array list like this, however i just get a big black box when i open the colorpicker, i can change the size of it by changing the swatch panel size but i cant get the 3 indivual swatchs to show up that i put in the array
                                          • 18. Re: Custom Colorpicker
                                            any ideas?
                                            • 19. Re: Custom Colorpicker
                                              That looked ok.  Here's the popupanchor as I have it.
                                                  <s:PopUpAnchor id="popUp"  displayPopUp.normal="false"
                                              displayPopUp.open="true" includeIn="open"
                                                      left="0" right="0" top="0" bottom="0" itemDestructionPolicy="auto"
                                                      popUpPosition="below" popUpWidthMatchesAnchorWidth="false">
                                                            This includes borders, background colors, scrollers, and
                                              filters.
                                                            @copy
                                              spark.components.supportClasses.DropDownListBase#dropDown
                                                      <s:Group id="dropDown" >
                                                          <!--- @private -->
                                                          <s:RectangularDropShadow id="dropShadow" blurX="20" blurY="20"
                                              alpha="0.45" distance="7"
                                                               angle="90" color="#000000" left="0" top="0" right="0"
                                              bottom="0"/>
                                                          <!--- @private -->
                                                          <s:Rect id="border" left="0" right="0" top="0" bottom="0">
                                                              <s:stroke>
        <!--- border stroke @private -->
        <s:SolidColorStroke id="borderStroke" weight="1"/>
                                                              </s:stroke>
                                                          </s:Rect>
                                                          <!-- fill -->
                                                          <!--- Defines the appearance of drop-down list's background
                                              fill. -->
                                                          <s:Rect id="background" left="1" right="1" top="1" bottom="1" >
                                                              <s:fill>
        The color of the drop down's background fill.
        The default color is 0xFFFFFF.
        <s:SolidColor id="bgFill" color="0xFFFFFF" />
                                                              </s:fill>
                                                          </s:Rect>
                                                          <s:VGroup id="swatchpanel" left="0" top="0" right="0" bottom="0"
                                                              <s:Group>
        <s:Rect left="0" top="0" right="0" bottom="0" width="90"
                                              height="120" >
        <s:fill>
        <s:SolidColor color="0x0" />
        </s:fill>
        </s:Rect>
        <s:DataGroup id="dataGroup" left="0" top="0" right="0"
                                              bottom="0" width="90" height="120" >
        <s:layout>
        <s:TileLayout verticalGap="0" horizontalGap="0"
                                              requestedColumnCount="3" requestedRowCount="4"/>
        </s:layout>
        <s:itemRenderer>
        <fx:Component>
        <s:ItemRenderer>
        <s:states>
        <s:State name="normal" />
        <s:State name="hovered" />
        <s:State name="selected" />
        </s:states>
        <s:Rect id="swatch" width="30"
                                              height="30">
        <s:fill>
        <s:SolidColor color="" />
        </s:fill>
        <s:stroke>
        <s:SolidColorStroke
                                              color="0xFFFF00" alpha.hovered="1" alpha="0" />
        </s:stroke>
        </s:Rect>
        </s:ItemRenderer>
        </fx:Component>
        </s:itemRenderer>
        </s:DataGroup>
                                                              </s:Group>
                                                          </s:VGroup>
                                                      </s:Group>
                                                  </s:PopUpAnchor
                                              • 20. Re: Custom Colorpicker
                                                Just copied your code in and got this:
                                                Initializer for 'color': cannot parse value of type uint from text ' '
                                                It's to do with this part of the code:
                                                <s:fill>
                                                <s:SolidColor color=" " />
                                                </s:fill>
                                                • 21. Re: Custom Colorpicker
                                                  The forum software often eats code.
                                                  It should be a binding to data.  Quote, open curly, data, close curly, end
                                                  quote
                                                  • 22. Re: Custom Colorpicker
                                                    Ok, got rid of the error but i still have just a black dropdownbox when i expand it
                                                    • 23. Re: Custom Colorpicker
                                                      Let's see if the forum will let me attach my code:
                                                      • 24. Re: Custom Colorpicker
                                                        Check your pm Flex harUI
                                                        • 25. Re: Custom Colorpicker
                                                          Try attaching this way.
                                                          • 26. Re: Custom Colorpicker
                                                            You're a genius!
                                                            It's all fixed now
                                                            Thank you so much for persisting with me
                                                            Chris
