10 Replies Latest reply on Feb 19, 2011 1:21 PM by William Frederick
    Adobe Reader X and protected PDF files
    William Frederick
      I installed Adobe Reader X yesterday. Today I cannot open any secured PDF files. I get a redirection to the FileOpen web site instead.Unprotected PDF's open just fine. The secured PDF's opened fine in my previous Adobe Reader 9 program.
      What is the problem and how does Adobe plan to fix it? I re-downloaded Reader 9.4 but it would not install, telling me a later version was already installed.
      Thanks for any information you may be able to offer.
      Bill Sharpe
        • 1. Re: Adobe Reader X and protected PDF files
          PankhriS Level 2
          What exactly do you mean when you say Secured File. How is it secured?
          You can try this :
          Launch Reader . Go to Edit - >Preferences.->General . Uncheck "Protected mode at startup.
          • 2. Re: Adobe Reader X and protected PDF files
            Bernd Alheit Adobe Community Professional & MVP
            Did you install the FileOpen plugin?
            • 3. Re: Adobe Reader X and protected PDF files
              Dave Merchant MVP & Adobe Community Professional
              You're opening PDF files that use the proprietary DRM system from FileOpen.com, and so you must install their plugin for each new version of Acrobat or Reader you install:
              http://plugin.fileopen.com/all.aspx
              If there are any issues with the plugin not running properly under Reader X, they must be addressed to FileOpen directly. These forums do not provide customer support for third-party software.
              • 4. Re: Adobe Reader X and protected PDF files
                William Frederick Level 1
                The zip files for the FileOpen plug-ins all have dates at least six months old, so I don't believe they apply to Acrobat Reader X. My protected files opened just fine in Reader Versions 7, 8, and 9. All other PDF files open fine in Reader X. I uninstalled Reader X, then reinstalled Reader 9.4 and my protected PDF's are again visible.
                Nevertheless, I have left a message at the FileOpen site asking for help.
                • 5. Re: Adobe Reader X and protected PDF files
                  The FileOpen plug-in was already installed and worked just fine in Reader versions 7, 8, and 9 without any further action on my part.
                  I looked at the plug-n downloads at the FileOpen site -- the zip file didn't contain any files after July 2010 and Reader X was released just a few days ago.
                  I have left a message at the FileOpen site asking for help, although I think it's sloppy programming on Adobe's part to have important support files such as these broken with a new release of Reader.
                  Message was edited by: William Sharpe -- corrected spelling error
                  • 6. Re: Adobe Reader X and protected PDF files
                    Did you install the FileOPen plugin after the installation of Adobe Reader X ?
                    • 7. Re: Adobe Reader X and protected PDF files
                      monkeyofdoom
                      Some of my customers are experiencing similar issues. They have contacted me to say that the forms I have created on Adobe Acrobat Pro 9 are no longer fillable forms in Adobe X. They can see where the fields should be, but Adobe X will not allow them to fill in the form or alter previously entered information from version 9. I have double checked the security settings I have placed on the file, I secured the files with password security, allowing them to fill in currently existing forms and elements, low-res printing is enabled. After securing the file, I extended features to Reader to enable saving the form after it is completed.
                      Disabling Protected Mode has not resolved the issue, but going back to version 9 solves the issue immediately. My superiors do not want to upgrade to version X, worried that it may interfere with our current products, and worried that any files created on version X would not be compatible with earlier versions.
                      I have been unable to find any solutions for my customers. Any suggestions or solutions would be greatly appreciated!
                      • 8. Re: Adobe Reader X and protected PDF files
                        I did not install the FileOpen plug-in after installing Reader X. The plug-ins were already installed.
                        When I removed Reader X and re-installed Reader 9.4, I was able to view my protected PDF's again. My technical contact at Scott Publishing, the company that placed the security on the PDF's, informs me that the FileOpen security will not work with Reader X and suggested that I got back to version 9.
                        I also left a message at FileOpen's site Thursday asking what was going on. Although they claim that they will respond within 24 hours I have not heard from them as of Saturday morning and probably won't until at least Tuesday.
                        I would like to continue installing updates and upgrades from Adobe because of security concerns but I also need to view these PDF files.
                        • 9. Re: Adobe Reader X and protected PDF files
                          As you suggested, I installed Reader X, then added the plug-in files using the FileOpen msi installer.
                          Still no joy.   I now have the fileopen.api file located in both of these subdirectories:
                          c:\program files\adobe\reader 10.0\reader\plug_ins\
                          c:\program files\adobe\reader 9.0\reader\plug_ins\
                          I was able to view my protected files using Reader 9, but I still cannot open them at all in Reader X.
                          Any further suggestions?
                          • 10. Re: Adobe Reader X and protected PDF files
                            I got a response this morning -- yes, Saturday -- from FileOpen Systems suggesting that I try the following installation for the fileopen security:
                            http://www.resolver.com/client/foClientInstaller.exe
                            That worked and I am now able to view my protected files in Reader X.
                            Bill
                            PS Do I get ten points for answering my own question
                            Message was edited by: William Frederick added the PS and emoticon
