1 Reply Latest reply on Mar 24, 2011 1:56 PM by joshua.paling
    Increasing idle CPU usage with repeated playing of very animated movie clip
    joshua.paling
      Hi All,
      I'm developing a touch-screen Flash  application for a shoe store, and it runs fine initially, but slows down  toward the end of the day. I've been diligent with removing event  listeners and so on. I've now narrowed the problem to be very specific -  it's one section of the application causing the problem, and one part  of that section:
      - I have a main movie clip which  contains the animation, which itself contains 5 nested movie clips, each  with their own timeline. All movie clips have a stop action on the  final frame.
      - images are transparent PNGs with outer glow "filter"
      - the issue is not with performance as such, but with CPU increasing  over time. Each time you play the clip, there is a small amount of CPU  usage that 'sticks' and doesn't get freed up. What happens is that if  you play the movie clip many (MANY MANY) times, then eventually it  starts to slow down. Mac's Activity Monitor shows that the idle CPU  usage is increasing slowly, over many times of playing the clip. It's  insignificant with each play, but adds up over time.
      You  may be inclined to say: oh filters effect CPU, so it will be slow - but  it isn't slow until it plays many, many times. Initially it's fast.
      I've uploaded a .zip with .app and .exe versions of my problem section. There are two files of each type:
      AutoPlay.app  (& .exe): plays the problem clip repeatedly (I've just removed the  final 'stop();' frame), so you can leave it open and come back in half  an hour to see it slowing down.
      ClickToPlay.app (& .exe): Plays the problem  clip once when you click the 'play' button, so you can click several  times, let it return to idle, and verify that the idle CPU usage is in  fact increasing.
      You can download them here: http://bbldigital.com.au/clients/sneakerology/AppsAndExes.zip
      For those who are interested enough (thankyou!) I've also uploaded my .fla and the one, simple .as file: http://bbldigital.com.au/clients/sneakerology/SourceFiles.zip
      Opening  the 'ClickToPlay' app, and using OSX's Activity Monitor to see what's  going on, initially idle CPU % is at 1.3 or so. After clicking 'play' 50  times, idle CPU % will settle down to around 7% - ie, it doesn't return  back to 1.3. Another 50 times and it's at 12 - 14%. No matter how long  you leave it, it doesn't return back to 1.3%.
      Over a  day or two's use in the shoe store, this problem cumulates to the app  having chuggy animation and slow response time. Does anyone have an idea  of what might be causing the gradual increase in idel CPU, over time of  repeatedly playing the animation (using other sections of the app don't  give the problem)? And, are there any ways around it?
      Any help is very much appreciated! Thank you so much in advance.
      Joshua
