1 Reply Latest reply on Feb 17, 2011 8:23 AM by cliffy2009
    Copied Flex Application to Ubuntu 10 Server
    cliffy2009 Level 1
      http://www.excalatedesign.com/Coldfusion
      Do you guys know if its possible to copy Flash builder Apps to ubuntu server 10. Everything works fine on my laptop, but when i moved it to the ubuntu server it gives me an error message. The MS SQL server is on a different machine and I can connect to it from COldfusion administrator.
      I need help.
      Cliff
        • 1. Re: Copied Flex Application to Ubuntu 10 Server
          cliffy2009 Level 1
          Can you guys help me. Let me know if it's possible or not. This is the error message I keep getting.
          mx.rpc::Fault)#0
            content = (Object)#1
            errorID = 0
            faultCode = "Client.Error.MessageSend"
            faultDetail = "Channel.Connect.Failed error NetConnection.Call.Failed: HTTP: Failed: url: 'http://www.excalatedesign.com/flex2gateway/'"
            faultString = "Send failed"
            message = "faultCode:Client.Error.MessageSend faultString:'Send failed' faultDetail:'Channel.Connect.Failed error NetConnection.Call.Failed: HTTP: Failed: url: 'http://www.excalatedesign.com/flex2gateway/''"
            name = "Error"
            rootCause = (mx.messaging.events::ChannelFaultEvent)#2
              bubbles = false
              cancelable = false
              channel = (mx.messaging.channels::AMFChannel)#3
                authenticated = false
                channelSets = (Array)#4
                connected = false
                connectTimeout = -1
                enableSmallMessages = false
                endpoint = "http://www.excalatedesign.com/flex2gateway/"
                failoverURIs = (Array)#5
                id = "my-cfamf"
                mpiEnabled = false
                netConnection = (flash.net::NetConnection)#6
                  client =
