4 Replies Latest reply on Mar 17, 2011 7:23 AM by Flex harUI
    Creating Components On-Fly From String
    mattcom
      So, I've been playing around a while with the concept of being able to pass a string from a database into flex, and then flex being able to generate stuff on the fly.  Here's my code so far:
      <mx:Application
      xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical" creationComplete="intialBreakup()">
      <mx:Script>
      <![CDATA[
      import mx.controls.Text;
      import mx.controls.Label;
      import mx.controls.TextInput;
      private function intialBreakup():void
      var sample:String = 'This is an example[TextInput id="Bob" width="5"]that I am[TextInput id="joe"]trying to work with';
      var bracketCount:Array = sample.split("[");
      var compMe:RegExp = /\[.*?\]/ig;
      var labelMe:RegExp;
      for(var i:int = 1; i < bracketCount.length; i++)
      //compMe = /\[(\w*)\]/ig;
      if(i == 1)
      labelMe =
      else {
      labelMe =
      /\].*\[/i;
      makeLabel(labelMe.exec(sample));
      makeComponent(compMe.exec(sample));
      private function makeComponent(original:String):void
      var unBracketed:String = str_replace(original, "[", "");
      unBracketed = str_replace(unBracketed,
      //var compObject:Object = unBracketed.split(" ");
      var compArray:Array = unBracketed.split(" ");
      //var Temp:ClassFactory;
      switch(compArray[0])
      case "TextInput":
      var Temp:TextInput = new TextInput();
      break;
      // now add the parameters
      for(var i:int = 1; i<compArray.length; i++)
      var paramArray:Array = getParam(compArray[i]);
      switch(paramArray[0])
      case "id":
      Temp.id = paramArray[1];
      break;
      case "width":
      Temp.width = paramArray[1];
      break;
      question.addChild(Temp);
      private function getParam(original:String):Array
      var unquoted:String = str_replace(original, '"', '');
      var paramSplit:Array = unquoted.split("=");
      return paramSplit;
      private function makeLabel(original:String):void
      var textMe:Label = new Label();
      textMe.text = str_replace(original,
      textMe.text = str_replace(textMe.text,
      question.addChild(textMe);
      private function str_replace(original:String, found:String, replaced:String):String
      var array:Array = original.split(found);
      return array.join(replaced);
      </mx:Script>
      <mx:Text text="This is an example[TextInput id='Bob' width='5']that I am[TextInput id='joe']trying to work with"/>
      <mx:HBox id="question"/>
      </mx:Application>
      My problem is that I'd have to create many case statements in order to further it along.  Is there some kind of type for Temp, such as Temp:ClassFactory or something that is generic enough to say something like    Temp = new compArray[0](), and can you think of a way to do the same with the params, such as Temp.paramArray[0] = paramArray[1] so that I can avoid using case statements?
