4 Replies Latest reply on Feb 17, 2011 10:37 PM by drom_techmarine
    Property Resets to Zero?
    bmberkowitz2010 Level 1
      I have a set of handlers in a behavior that takes a number input from a field and dynamically scales a 3D sphere model.  However, the variable that holds the previous radius of the sphere (pPreviousRad) keeps resetting to zero, which screws everything up.  Does anyone know why that might be?  Here is the part of my code:
      global gIsActive
      property pSprite
      property pMember
      property pModel
      property pRadius
      property pPreviousRad
      on enterFrame me
        if gIsActive = TRUE then
          radiusActive()
        end if
      end
      on radiusActive()
        if NOT(value(member("Size Field").text) = pPreviousRad) AND NOT(member("Size Field").text="") then
          prevRad = pPreviousRad
          newRad = modifyRadius(prevRad)
          pPreviousRad = newRad
        end if
      end
      on modifyRadius(prevRad)
        if prevRad > 0 then
          scaleFactor = (value(member("Size Field").text))/(10*prevRad)
          pModel.scale(scaleFactor, scaleFactor, scaleFactor)
        end if
        returnRad = value(member("Size Field").text)/10
        return returnRad
      end
