2 Replies Latest reply on Nov 9, 2006 11:52 AM by KCurley
    Slides Getting Cut Off
    KCurley
      When I publish a PPT presentation to Breeze, the information on the slides seems to get cut off, even when I reduce the font down to 18 pt. Has anyone else had this problem? Do I need to readjust my settings?
        • 1. Re: Slides Getting Cut Off
          Noriann
          Hi KCurley,
          Does the text appear to scroll off the screen and appears larger than it does inside of PowerPoint?
          If this is the case, it's possible that your desktop display settings are set to Large Size.
          Try to resolve it by setting the display settings back to normal:
          1. Right click on the desktop and select 'Properties'
          2. Select 'Settings > Advanced'
          3. On the General tab (might vary depending on video card) select DPI settings to 'Normal Size' (was initially set to Large Size)
          4. Restart machine and republish
          I hope this helps.
          • 2. Re: Slides Getting Cut Off
            KCurley Level 1
            YES! That fixed it! THANK YOU!
