11 Replies Latest reply on Jan 18, 2014 4:17 AM by SanjayJangid
    Flip Book Example not working in flex 4
    linrsvp
      I downloaded the page flip example by Ruben Swieringa. I tried using the AS3 classes in my flex 4 application, like this :
                     xmlns:mx="library://ns.adobe.com/flex/mx"
                     xmlns:filters="flash.filters.*"
                     xmlns:book="com.rubenswieringa.book.*"
                     width="1000"
                     backgroundColor="#333333" >
          <s:layout>
              <s:BasicLayout />
          </s:layout>
          <fx:Script>
              <![CDATA[
                  import mx.controls.Alert;
                  import mx.core.FlexGlobals;
                  import mx.events.FlexEvent;
          </fx:Script>
          <fx:Declarations>
              <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <book:Book id="myBook" x="100" y="50"
                     width="800" height="530" openAt="0" autoFlipDuration="200" easing="0.7"
                     regionSize="150" sideFlip="true" hover="true" snap="false" flipOnClick="true">
              <book:Page id="page1">
                  <s:BorderContainer borderWeight="2" backgroundColor="#1AADBD" fontSize="16" fontWeight="bold"
                                     width="95%" height="95%">
                      <s:TextArea contentBackgroundAlpha="0" width="100%" height="100" borderAlpha="0"
                                  editable="false" selectable="false" text="{introText}" />
                  </s:BorderContainer>
              </book:Page>
              <book:Page id="page2">
                  <mx:Image source="@Embed('assets/img/sumeco/dreamscan.jpg')" />
                  <mx:Label
                      x="343" y="38"
                      fontFamily="Verdana" fontSize="9" color="#466C64"
                      text="beta2" />
                  <mx:Label
                      left="30" right="30" y="90"
                      fontFamily="Arial" fontSize="10" color="#9BBFBA" textAlign="center"
                      text="by Ruben Swieringa" />
              </book:Page>
              <book:Page id="page3">
              </book:Page>
              <book:Page id="page4">
                  <mx:Label
                      x="343" y="38"
                      text="beta2" />
                  <mx:Label
              </book:Page>
      The application compiles without any errors, but when I run the application, it dsnt show anything. I tried putting alerts at creationComplete, initialize and preinitialize events, but nothing shows up. it just shows the grey background that I have assigned to the application but the pages dsnt show....
      What am I doing wrong ? Please help as this is very urgent.
        • 1. Re: Flip Book Example not working in flex 4
          D Baron Level 1
          Hi There,
          Were you ever able to get the Flip Book working in Flex 4?  I also would like to use this code, but was concerned it might not work.  I contacted Ruben, but he basically has not worked on it for several years now and is only 'pretty sure' that is should work in Flex 4.x.
          Please let me know...
          -David
          • 2. Re: Flip Book Example not working in flex 4
            aktell2007 Level 1
            Hi there,
            If you use Flex Builder 4, but work it as 3.5 with everything with (mx) ! - already than it does not work any longer properly and Rubens knows about it ! I cam't understand why he would say that it should work with Flex 4 ?
            regards aktell2007
            • 3. Re: Flip Book Example not working in flex 4
              shmonika
              I have tried making the Flip Book Example in Flash Builder 4.5 and it works fine. Just make sure you use the <s:Application/> tag instead of <mx:Application/> and include all the namespaces. Include the style through <fx:Style>.
              Just dont blindly copy paste the downloaded code but make changes according to the 4.5 sdk.
              You will have to remove the backgroundAlpha property from all the TextArea also.
              Monika
              • 4. Re: Flip Book Example not working in flex 4
                Harpalsinh Rana
                I found the same problem. flipbook works for 3.5 or 3 but not for higher than 4.
                In flexbook.as file there is a delta property set in following way.
                delta = new Vector(new Point(x,_pointOfOriginalGrab.y),new Point(x+10,_pointOfOriginalGrab.y+1));
                But compiler gives error that vector class can not accept more than 0 arguments. Thogh Vector class inside the qs.utils pacakge constructor has created with two arguments.
                public class Vector
                          public var p1:Point;
                          public var p0:Point;
                          public function Vector(p0:Point,p1:Point):void
                                    this.p0 = p0.clone();
                                    this.p1 = p1.clone();
                Can anyone please help me to solve this issue? I see it only in flex 4 and 4.5 not in flex 3
                • 5. Re: Flip Book Example not working in flex 4
                  crowezr1
                  I know this thread is old, but I ran across this issue recently and found a simple solution.
                  It appears there is some sort of conflict with the internal Vector class in Flex 4 which causes the issues. If you simply rename the qs.utils.Vector to something else such as FlipBookVector, it should work just fine.
                  • 6. Re: Flip Book Example not working in flex 4
                    Vahid Arjmand
                    hi every one, i solved this problem the flex book dont compatible with flex 4.6 with this code :
                                   xmlns:rs="com.rubenswieringa.book.*"
                                   width="900" height="900" minWidth="900" minHeight="900" backgroundColor="#9EB9CD"
                                   creationComplete="onCreationComplete(event)" pageTitle="Flip Book Simple">
                        <s:layout>
                            <s:BasicLayout/>
                        </s:layout>
                        <fx:Declarations>
                        </fx:Declarations>
                        <fx:Script>
                            <![CDATA[
                                import com.carlcalderon.arthropod.Debug;
                                import com.rubenswieringa.book.*;
                                import flash.display.Loader;
                                import flash.display.MovieClip;
                                import flash.events.Event;
                                import flash.events.MouseEvent;
                                import flash.net.URLRequest;
                                import flash.text.TextFormat;
                                import mx.controls.Button;
                                import mx.controls.TextInput;
                                import mx.effects.Fade;
                                protected function onCreationComplete (event:FlexEvent):void {
                                    myBook.addEventListener(BookEvent.PAGE_TORN, onPageTorn);
                                    myBook.addEventListener(BookEvent.PAGE_TURNED, onPageTorned);
                                    myBook.addEventListener(BookEvent.STATUS_CHANGED, onPageStatus);
                                    this.addEventListener(MouseEvent.MOUSE_WHEEL,onMouseNavigate);
                                    page_number.text = myBook.currentPage + ' / ' + myBook.pages.length;
                                private function onPageTorn(e:BookEvent):void{
                                    Debug.log('PAGE_TORN');
                                private function onPageTorned(e:BookEvent):void{
                                    page_number.text = (myBook.currentPage+1) + ' / ' + myBook.pages.length;
                                protected function onPageStatus(event:Event):void
                                protected function onMouseNavigate(event:MouseEvent):void
                                    if(event.delta > 0){
                                        myBook.prevPage();
                                    }else{
                                        myBook.nextPage()
                        </fx:Script>
                        <!-- book w:h >> 800:590  -->
                        <rs:Book id="myBook" bottom="91" width="820" height="700" hardCover="false" horizontalCenter="-10"
                                 layoutDirection="right" regionSize="30" sideFlip="true" liveBitmapping="true">
                                <rs:Page id="page01" >
                                    <mx:Image source="@Embed('assets/pages/page01.swf')" />
                                </rs:Page>
                                <rs:Page id="page02" >
                                    <mx:Image source="@Embed('assets/pages/page02.swf')" />
                                </rs:Page>
                                <rs:Page id="page03" >
                                    <mx:Image source="@Embed('assets/pages/page03.swf')" />
                                </rs:Page>
                                <rs:Page id="page04" >
                                    <mx:Image source="@Embed('assets/pages/page04.swf')" />
                                </rs:Page>
                                <rs:Page id="page05" >
                                    <mx:Image source="@Embed('assets/pages/page05.swf')" />
                                </rs:Page>
                                <rs:Page id="page06" >
                                    <mx:Image source="@Embed('assets/pages/page06.swf')" />
                                </rs:Page>
                                <rs:Page id="page07" >
                                </rs:Page>
                                <rs:Page id="page08" >
                                </rs:Page>
                        </rs:Book>
                    </s:Application>
                    but i have a new problem , please help me
                    i want to access page content (i have a textfield in each page i want access text in any textfield),How do i can ?
                    sorry for weak my english language
                    • 7. Re: Flip Book Example not working in flex 4
                      Harpalsinh Rana Level 1
                      ITs easy..
                      you can do it this way.
                      for ( var i:int=0; i< book.content.length; i++ )
                               var txt:string =    (book.content[i] as Page ).textField.text ;
                                trace( txt );
                      you can do this same for cover and back cover.
                      Message was edited by: Harpalsinh Rana
                      • 8. Re: Flip Book Example not working in flex 4
                        Vahid Arjmand Level 1
                        Harpalsinh Rana wrote:
                        ITs easy..
                                  trace( txt );
                        thank friend
                        but your code have a two problem.
                        there are no propery with name content in book class (i guess your target is page  proprty in book class)
                        and another problem is direct access a textfield in page content , If you have carefully too page class , each page have a child with Image type and can not access content in page continer
                        if you have any idea this idea please help
                        • 9. Re: Flip Book Example not working in flex 4
                          I have sent u a message here. check it.
                          • 10. Re: Flip Book Example not working in flex 4
                            StardusterII Level 1
                            While this is now running in 4.6, has anyone been able to get it to run in a mobile environment with Flex?   I've created a moible project with the code but it flags the following function with an error, "1020: Method marked override must override another method"
                            override public function getElements():Array {
                               return this._pages.source;
                            Anyone know what that means!
                            • 11. Re: Flip Book Example not working in flex 4
                              SanjayJangid
                              Hello monika
                                   your post use full
                                 it also working fine with flex 4.6
                                 But i also need information about flip book lienceing it is free or paid.
                              Sanjay
