5 Replies Latest reply on Feb 21, 2011 8:08 AM by BeriliaTubul
    [js] select the previous word
    BeriliaTubul
      I have a xml like this (well... this is just a part of my xml):
      "<p>This is some text<note>This will be a footnote</note></p>"
      I made a xml rules who find the "note" to make a footnote with it.
      So, I need the word before "note" to apply the footnote to it (in the case, "text")
      this.xpath = "//note";
      this.apply = function(myElement, myRuleProcessor){
        var myStory =  myElement.insertionPoints[0].parentStory.contents;
      how can i know which item (of words in myStory) is myElement?
      I tried to use index but I don't know how :
      myElement.words.item(0).index;
      Please help me this is so much frustrating!
        • 1. Re: [js] select the previous word
          Harbs. Level 6
          Try someting like this:
           var myStory =  myElement.insertionPoints[0].parentStory;
          var myInsertionPoint = myStory.insertionPoints.item(myElement.insertionPoints[0].index-1);
          //add the footnote to myInsertionPoint...
          Harbs
          • 2. Re: [js] select the previous word
            BeriliaTubul Level 1
            It doesn't work : myInsertionPoint is the number of the character (at least it's what I understood) but I need the number of the word :
            myWord = myTextFrame.parentStory.words.item(myInsertionPoint);
            var myFootnote = myWord.insertionPoints.item(-1).footnotes.add();
            myFootnote.insertionPoints.item(-1).contents = myElement.contents;
            Maybe I can do otherwise but I don't know how.
            • 3. Re: [js] select the previous word
              Harbs. Level 6
              That's not right...
              I don't know why you don't just use the insertionPoint, but it should be something like this:
              myWord = myTextFrame.parentStory.characters.item(myInsertionPoint).words.item(0);
              Harbs
              • 4. Re: [js] select the previous word
                When I do that I have an error in Indesign something like "incorrect parameter" (my messages are in french). It appends when I declare myWord
                var myTextFrame = myElement.insertionPoints[0].parentTextFrames[0]; var myStory =  myElement.insertionPoints[0].parentStory; var myInsertionPoint = myStory.insertionPoints.item(myElement.insertionPoints[0].index-1); var myWord = myTextFrame.parentStory.characters.item(myInsertionPoint).words.item(0);
                When I do
                alert(myInsertionPoint.contents);
                the alert is empty.
                • 5. Re: [js] select the previous word
                  That's ok with this code :
                  var myTextFrame = myElement.insertionPoints[0].parentTextFrames[0]; var myStory =  myElement.insertionPoints[0].parentStory; var myInsertionPoint = myStory.insertionPoints.item(myElement.insertionPoints[0].index-3); var myWord = myTextFrame.parentStory.characters.item(myElement.insertionPoints[0].index-3).words.item( 0);
                  I forgot that I have a return to line. This explain why I couldn't find any word at index-1.
                  Thank you very much Harbs
