6 Replies Latest reply on Feb 19, 2011 5:48 AM by Ned Murphy
    Need some help with simple flash buttons
    Aiguchi
      So I need either some direct tutorial help or for someone to point me in the direction of something helpful.
      What I am trying to do is create 3 clickable flash buttons which all link to a small box. I want these buttons to make some text appear in the box once clicked. I want the box to be blank until one button is clicked.
      EXAMPLE
      _______________
      | TEXT HERE       |
      |_______________|
      ___     ___     ___
      |__|     |__|     |___|
      Thanks a lot in advance.
        • 1. Re: Need some help with simple flash buttons
          What version of actionscript are you using?
          • 2. Re: Need some help with simple flash buttons
            Aiguchi Level 1
            I am using 3.0
            Just to let you know I am very new to all of this, I have almost finished the script now I just need some help touching it up.
            Basicly , I have imported 3 buttons made in photoshop, all turned into buttons and named.
            BTN1 , BTN2 , BTN3
            Frame 1 shows these 3 buttons on their own.
            Frame 2 shows the 3 buttons and the text for BTN1
            Frame 3 shows the 3 buttons and the text for  BTN2
            Frame 4 shows the 3 buttons and the text for BTN3
            However I just need some help coding them. Currently it doesn't really work.
            If you could tell me the coding that would work for each frame it would really help!!!!
            Heres what I have so far. Only for frame 1 I need it touching up and help for the other frames.
            stop();
            BTN1.addEventListener(MouseEvent.CLICK,mouseClick);
            function mouseClick(event:MouseEvent):void
            gotoAndStop(2);
            BTN2.addEventListener(MouseEvent.CLICK,mouseClick);
            gotoAndStop(3);
            BTN3.addEventListener(MouseEvent.CLICK,mouseClick);
            gotoAndStop(4);
            • 3. Re: Need some help with simple flash buttons
              What you described you have hints that you didn't set it up efficiently.
              Your buttons should be in their own layer and should only have a keyframe in frame 1.  Just extend them thru frame 4 by inserting a regular frame in frame 4 of that layer.  So you should only see a filled dot in frame 1 of that layer with shading thru frame 4.  The buttons in frame 1 will then be available in all those frames.  Each button should have its instance name assigned in the Properties panel--if those are just their library names, that won't work.
              Similarly, your code should only go in frame 1 and that layer can be similarly extended to frame 4.
              You could easily do this n just one frame if the only thing changing is the text in the textfield.  If you make the textfield a dynamic textfield you can have each button assign its text to the textfield when clicked.  Suppose you name the textfield tField...
              BTN1.addEventListener(MouseEvent.CLICK,mouseClick1);
                   tField.text = "text for btn 1";
              BTN2.addEventListener(MouseEvent.CLICK,mouseClick2);
              function mouseClick2(event:MouseEvent):void
                   tField.text = "text for btn 2";
              BTN3.addEventListener(MouseEvent.CLICK,mouseClick3);
              function mouseClick3(event:MouseEvent):void
                   tField.text = "text for btn 3";
              Message was edited by: Ned Murphy - revised to correct code example (I hope)
              • 4. Re: Need some help with simple flash buttons
                Strike what I said regarding the code being fine.  It isn't (my eyes just woke up).  Below is a proper coding for the way you had it.  To have the button share the same event handler function you need a different approach that tests for which button is clicked.  INstead of that approach, below I am showing each button having its own handler function...
                stop();
                function mouseClick1(event:MouseEvent):void
                gotoAndStop(2);
                gotoAndStop(3);
                gotoAndStop(4);
                • 5. Re: Need some help with simple flash buttons
                  Aiguchi Level 1
                  Thanks a lot got it working perfectly now
                  • 6. Re: Need some help with simple flash buttons
                    You're welcome
