2 Replies Latest reply on Feb 22, 2011 9:47 AM by Saha_Amitava
    Dynamically add some elements in WebService operation request
    Saha_Amitava
      I have a WebService element defined in my mxml which use to make soap calls.
      I need to dynamically add some repeating groups for action (dependent on action) in the following example.
      How can I add this in Action Script section? Can I access the WebService  by id userRequest and specify "
      userRequest.operations.DoAction.request.DoItemActionRequest.action.requiresAdditionItems.n ameValuePair.name = "SomeName";
      userRequest.operations.DoAction.request.DoItemActionRequest.action.requiresAdditionItems.n ameValuePair.name = "SomeValue";
      <mx:WebService  id="userRequest" wsdl="{Application.application.wsdl}" >
           <mx:operation name="DoAction" resultFormat="object"
            fault="faultHandler(event)"
            result="DoActionHandler(evnt)">
              <mx:request>
                <DoActionRequest>
                   <userId>{Application.application.userID}</userId>
                    <action>
                       <actionId>{selectedItem.actionId}</actionId>
                   </action>
                </DoActionRequest>
               </mx:request>
             </mx:operation>
      </mx:WebService>
      Amitava
        • 1. Re: Dynamically add some elements in WebService operation request
          miguel8312 Level 3
          ok well what you can do is something like this.
          <mx:WebService id="ws" wsdl="http://localhost:3960/WebSite6/Service.asmx?WSDL" fault="fault(event)">
          <mx:operation
           name="Process_Upload"
           result="Process_Upload(event)"/>
          then in actionscript you can reference like this.
          ws.process_upload();
          then you will also need a result handler for the xml coming back from the webservice.
          in my case.
          public function Process_Upload(event:ResultEvent):void{
          then optionally you can have a function to handle errors like such.
          // need to make these alert boxes better looking.
                  private function fault(event:FaultEvent):void {
                         // Oppps some error occured
                         Alert.show(event.toString(), "upload webservice failed.");
          • 2. Re: Dynamically add some elements in WebService operation request
            Saha_Amitava Level 1
            Hi miguel8312,
            Thanks for your suggestion. I understand the steps you explained for defining, calling and processing the result from a webservice from a MXML body.
            My query is specifically, can I modify the webservice request defination from AS function before making the call?
            In my example, if I need to dynamically add a name value pair for <action> tag (e.g. actionParam ), how do I do that?
            Amitava
