9 Replies Latest reply on Nov 27, 2011 11:36 PM by electroteque1
    Getting 503 errors for f4f httpstreaming files
    electroteque1 Level 1
      I am testing out the f4f apache module, two issues have come up but no fix. I have tested packaging up the demo files found with FMS. Every file ive tested obtains a 503 error when it tries to load
      something like this
      sample1_700kbpsSeg1-Frag1
      No proper debug error in the apache logs at all which isn't helpful.
      the config is setup right because i know its being activated
      <Location /videos/vod>
          HttpStreamingEnabled true
          HttpStreamingContentPath "/var/www/httpstreaming.electrocode.net/web/videos/vod/f4f"
          Options -Indexes FollowSymLinks
      </Location>
      I inspected the files and this is what it shows when i run this /opt/adobe/f4fpackager/f4fpackager --input-file=sample1_700kbpsSeg1.f4f --inspect-fragments
      It's very wierd, no debug messages at all !
      Prepackaged f4f files would be nice to know that the module is actually working correctly.
      Let me know.
        • 1. Re: Getting 503 errors for f4f httpstreaming files
          I'm unsure why some people get it and other people don't . i was even using the demo FMS files to package with. Any ideas ?  Bug report is my next option.
          • 2. Re: Getting 503 errors for f4f httpstreaming files
            AbhishekSinha
            The output on inspect-fragment looks correct and it seems file has been packaged correctly. It seems like your F4F module is not installed correctly. Can you verify your logs and see if you get an idea.
            Abhishek
            • 3. Re: Getting 503 errors for f4f httpstreaming files
              Hi thanks for your response, appreciate it. No generally an apache module would log a stacktrace, this plugin doesn't log anything which doesnt help. Is there a development binary module with logging enabled I could try out ? I am running this on ubuntu 64bit linux.
              My next steps is to try strace debugging apache.
              • 4. Re: Getting 503 errors for f4f httpstreaming files
                Hi there FYI.
                I used strace to figure out the issue. Your module does not log file not found errors correctly.
                Here was the original config
                </Location>
                http://httpstreaming.electrocode.net/videos/vod/f4f/sample1_700kbpsSeg1-Frag1
                And I was requesting it like this therefore in the stacktrace I saw there was filesystem errors saying the file cannot be found. it was requesting it like
                /var/www/httpstreaming.electrocode.net/web/videos/vod/f4f/f4f/sample1_700kbps.f4v
                I suggest put some logging in the module as a feature request perhaps, to prevent others having to strace their apache servers to figure what the module is doing wrong !
                • 5. Re: Getting 503 errors for f4f httpstreaming files
                  Nikhil Pavan Kalyan Level 4
                  I do not think the inspect-fragments dump is entirely correct. I have fragmented the same file (the demo file from FMS) with default fragmentation values and was able to playback. I am copying here the first few lines from the inspect fragments dump:
                  fragment: 1, 74912
                  afra:
                  long ids: true
                  long offsets: true
                  entries:
                  time = 0, offset = 16511
                  time = 3003, offset = 275611
                  global entries:
                  bootstrap:
                  version: 1
                  is update: false
                  is live: false
                  movie id:
                  timescale: 1000
                  current media time: 6006
                  smpte timecode offset: 0
                  servers:
                  qualities:
                  segments:
                  segment run table:
                  is update: false
                  qualities:
                  entries:
                  segment = 1, fragments = 1
                  fragments:
                  fragment run table:
                  is update: false
                  qualities:
                  entries:
                  fragment = 1, timestamp = 0, duration = 6000
                  fragment: 2, 600951
                  afra:
                  long ids: true
                  long offsets: true
                  entries:
                  time = 6006, offset = 8367
                  global entries:
                  bootstrap:
                  version: 2
                  is update: false
                  is live: false
                  movie id:
                  timescale: 1000
                  current media time: 9009
                  servers:
                  qualities:
                  segments:
                  segment run table:
                  is update: false
                  qualities:
                  entries:
                  segment = 1, fragments = 2
                  fragments:
                  fragment run table:
                  is update: false
                  qualities:
                  entries:
                  fragment = 2, timestamp = 6006, duration = 3000
                  fragment: 3, 833788
                  afra:
                  long ids: true
                  long offsets: true
                  entries:
                  time = 9009, offset = 8419
                  global entries:
                  bootstrap:
                  version: 2
                  is update: false
                  is live: false
                  movie id:
                  timescale: 1000
                  current media time: 12012
                  servers:
                  qualities:
                  segments:
                  segment run table:
                  is update: false
                  qualities:
                  entries:
                  segment = 1, fragments = 3
                  If you compare this part with that of what you have, you can observe that under fragment 2, you have the entry segment= 1 and fragments = 3 which is wrong. (my output has segment=1 and fragments =2 , which is correct).
                  So, can you confirm whats the command you used for packaging ? Or probably, try with the default packaging and see if you still get the mismatched entries in inspect fragments.
                  What build of FMS/File packager are you using ? Probably if thats old, you may want to switch to the most recent release.
                  Thank you !
                  • 6. Re: Getting 503 errors for f4f httpstreaming files
                    I tried a various amount of things after researching constantly, tried f4fpackager --input-file= , and with framerate and fragement duration flags and still didn't help. The problem was a bad apache location configuration, see above. It should be returning 404 errors and logging the problem instead of returning 503 errors and not logging at all. Can this be fixed in another version ?
                    Im using the standalone f4fpackager btw and FMS 4 Developer version, and a standalone apache.
                    My test stream works now.
                    • 7. Re: Getting 503 errors for f4f httpstreaming files
                      Good to know that you have the issue resolved !
                      I am little not sure about getting the wrong response code (503 instead of 404) because the f4f module does nothing but to redirect the status (error or otherwise) to apache which makes the response. Almost all the times when the configuration was wrong and when we had path related mismatches, 404 is what is recieved. Do post your observations as you try more and we can nail down the real issue
                      But, can you please send me the exact f4fpackager command that you used while packaging for which you got the inspect fragments that you attached? I would like to reproduce and get the same inspect fragments ouput (with errors) and see what's causing that.
                      Thank you !
                      • 8. Re: Getting 503 errors for f4f httpstreaming files
                        nick.doyle Level 1
                        electroteque I'm having the same issue
                        Can you tell me how you changed your configuration to work around it?
                        I'm also wondering why the player is even asking for non-existent fragments ... I guess I need to get code to read the f4x for me ....
                        • 9. Re: Getting 503 errors for f4f httpstreaming files
                          Just the wrong path set when referencing the file because it was already included in the apache config. The other issues now is switching bitrates and the audio glitching but there is a bug report for this.
