10 Replies Latest reply on Feb 19, 2011 9:44 PM by AttaBoy2
    preloader problem
    AttaBoy2 Level 4
      I have a simple slide show that just used timeline tweening(no actionscript) named slideShow.swf
      I have another swf named loadSS.swf that I load slideShow.swf into this file has a preloader in it.
      I have a 3'rd swf named loadLoadSS.swf that simply loads loadSS.swf.
      The preloader in loadSS.swf works fine when I run it standalone.
      When I run loadLoadSS.swf the slideshow runs but the preloader doesn't.
      I don't want the preloader to run on the final destination because it's a website with a long timeline and many levels and the slideshow will be shown in many places and it just gets complicated.  If the slideshow can just provide it's own preloader life will be much simpler.
      slideShow.swf has no AS
      loadSS.swf has this AS:
      var mcLoader:MovieClipLoader = new MovieClipLoader();
      var listener:Object = new Object();
      var preloadPercent:Number;
      mcLoader.addListener(listener);
      listener.onLoadProgress = function(target_mc:MovieClip, loadedBytes:Number, totalBytes:Number) {
          preloadPercent = Math.round((loadedBytes/totalBytes) * 100);
          _root.preloader.preload_bar._xscale = preloadPercent;
          if(preloadPercent > 99){_root.preloader._visible = false;}
      //     trace("preloadPercent "+preloadPercent);
      mcLoader.loadClip("slideShow.swf", 2);
      loadLoadSS has this AS:
      mcLoader.loadClip("loadSS.swf", 2);
      links:
      slideShow.swf
      loadSS.swf
      loadLoadSS.swf
        • 1. Re: preloader problem
          in loadSS, add
          this._lockroot=true;
          • 2. Re: preloader problem
            AttaBoy2 Level 4
            nope tried that already and tried again just to be sure, no luck
            • 3. Re: preloader problem
              copy and paste your loadSS code
              • 4. Re: preloader problem
                AttaBoy2 Level 4
                I did it's on this page.
                • 5. Re: preloader problem
                  there's no _lockroot property assigned.
                  • 6. Re: preloader problem
                    AttaBoy2 Level 4
                    I posted this after I took it out and before I put it back in this is how it looks currently:
                        if(preloadPercent > 99){preloader._visible = false;}
                    • 7. Re: preloader problem
                      AttaBoy2 Level 4
                      I think I understand your concern with this._lockroot=true; now earlier I'd prefeced preloader with _root in an attempt to control a graphic on the top level swf.
                      That attempt failed and I forgot to remove the _root, oddly enough it made no difference.  Anyway what you see now is what is online.
                      • 8. Re: preloader problem
                        that code doesn't need _lockroot.  what's the following trace show:
                        trace(preloader+" "+preloader.preload_bar)
                        • 9. Re: preloader problem
                          AttaBoy2 Level 4
                          _level0.preloader _level0.preloader.preload_bar
                          when running loadSS.swf
                          nothing displays when nunning  loadLoadSS.swf
                          when I run the trace I commented out in the example it traces out the load percentage with both swfs
                          • 10. Re: preloader problem
                            AttaBoy2 Level 4
                            I got it working with your help ..thanks!
                            this.createEmptyMovieClip("holder", this.getNextHighestDepth());
                            trace(preloader+" "+preloader.preload_bar);
                            //this.swapDepths(_root.getNextHighestDepth());
                            mcLoader.loadClip("slideShow.swf", holder);
