1. Re: installing cs5 with laptop 1366x768 resolution
John T Smith Feb 19, 2011 9:25 PM (in response to @mikehedge)http://www.adobe.com/products/premiere/systemreqs/
- 1280x900 display with OpenGL 2.0–compatible graphics card
2. Re: installing cs5 with laptop 1366x768 resolution
@mikehedge Feb 19, 2011 9:34 PM (in response to John T Smith)I know what the system requirements are. my question is if I have an external monitor Dell 24" 1920x1080 when I do the install, will that work?
after CS5 is installed and I launch premiere with out the external monitor, will Premiere work?
appreciate the help. any ideas?
Mike
3. Re: installing cs5 with laptop 1366x768 resolution
Harm Millaard Feb 19, 2011 11:36 PM (in response to @mikehedge)It will work, but you have to work partly in the blind, not seeing the complete user interface.
Generally, laptops with such a below minimum requirement monitor are also lacking on a number of other requirements.
4. Re: installing cs5 with laptop 1366x768 resolution
@mikehedge Feb 20, 2011 12:21 AM (in response to Harm Millaard)ok so you are saying that it will install fine without an external monitor?
or are you saying that I need the external monitor (1920x1080) to get cs5 installed...
then once it's installed and I use Premiere CS5 without the external monitor, I will not have access to some user controls?
5. Re: installing cs5 with laptop 1366x768 resolution
Harm Millaard Feb 20, 2011 12:58 AM (in response to @mikehedge)It will install when you trick the installer to believe that your monitor resulution is sufficient. If you then remove the second monitor, you will have a working installation of CS5, but you can't access parts of the user interface. What parts of the interface will remain hidden from you, I don't know.
Generally those kind of laptops are dead slow and if you have to fiddle with the user interface all the time for you to access a command you need, it will be like having a blind as the driver of your car. Not very reassuring and pretty unsafe, even if the speed is nothing more than a crawl.
6. Re: installing cs5 with laptop 1366x768 resolution
Todd_Kopriva Feb 20, 2011 9:13 AM (in response to Harm Millaard)> What parts of the interface will remain hidden from you, I don't know.
There are several dialog boxes that are taller than 768 pixels, so you won't be able to use several controls within them. I've tried it, and I wasn't able to use footage interpretation controls, including those for RED settings.
Also, as Harm said, any laptop with such a small screen is probably also underpowered in other ways. I can imagine using such a laptop for a quick emergency task, but I certainly wouldn't want to try to get work done on it regularly.
7. Re: installing cs5 with laptop 1366x768 resolution
@mikehedge Feb 20, 2011 1:56 PM (in response to Todd_Kopriva)thank you! exact answer I was looking for thank you!!!!!
cheers!
Mike
