0 Replies Latest reply on Feb 20, 2011 6:41 AM by Envirographics
    CS5 save as CS4 makes Large File and sees virtual memory issue
    Envirographics Level 1
      Two CS5 flash files. FileSource 27Mb  File Destination 21.8Mb
      They open in 80 seconds for each.
      FileSource has 15 MovieClips, 5 show areas of the map in a variety of colours, shape intensive one could say ! These are made into one movie clip and copy pasted to the FileDestination. In CS5 it then crashes.
      I turned these instead into CS4 files, they open in 10 seconds ! WOW !!!  I needed to adjust the text which had become two lines from one though.
      I try again for the CopyPaste of the movie Clip from library to library, this time I get a message Flash is out of  memory. To increase virtual memory, quit Flash and allocate more virtual memory in the Systems Properties dialog box.
      In there I see
      Initial   2046Mb
      Max size 4092Mb
      Recommended 4605Mb
      I alter this to:
      Initial  3800Mb
      Max    4600Mb
      Reboot PC (Win XP SP2 wih 4Gb ram, purpose built video editing suite) and try again, but again get the memory message. Such a powerful PC should handle Flash. PC at work also crashing with CS5.
      I thought I was winning with the quick handling of the files in CS4 but File size is now alarmingly FileSource  76.1Mb  and FileDestination 58.4Mb   WHY ? and why does it open them so quick but fall over on the copy paste ?
      CS4 opens these in 8 not 80 secs, but that save as CS4 has bloated their file size, quick to open but causing virtual memory failure.
      I am defeated
      Does CS5 have some way of keeping size down ? I can’t use CS5 as it crashes when pasting the MovieClip from the source file to destination.
      Can I get Flash to simplify the layers perhaps ? There are many shapes of the same colour which perhaps could be fused into one, lessening the number of vector edges. How is that done ? I am making an swf file for a clients powerpoint slide show.
      Envirographics
