2 Replies Latest reply on Feb 21, 2011 9:27 PM by Ananth Flex
    Checkbox change Event...
    Ananth Flex Level 1
      My problem is, in my datagrid I'm having a checkbox, if the checkbox is selected means the value in the next consecutive(same row but different column) cell want to get changed.....
      is it possible to change the value of a cell in same row as a result of changes in another cell in same row but different column in FLEX 4........
      please Help me....
      Thanks in advance....
        • 1. Re: Checkbox change Event...
          miguel8312 Level 3
          this sounds very possible but again.do you have any sample code?
          Miguel
          • 2. Re: Checkbox change Event...
            Ananth Flex Level 1
            <mx:DataGrid
            id="dg_profile_groups" dataProvider="{first}" width="940" color="#000000"
            [#FFFFFF,#A9A9A9]" verticalScrollPolicy="on" itemClick="item_click(event)">
            <mx:columns>
            <mx:DataGridColumn id="col1" headerText="Label" width="200" dataField="spk_name"/>
            <mx:DataGridColumn id="col2" headerText="Key" width="180" dataField="spk_key"/>
            <mx:DataGridColumn id="col3" headerText="Defaule Value" width="150" dataField="lbl_spk_default_value">
            <mx:itemRenderer>
            <fx:Component>
            <mx:HBox horizontalScrollPolicy="off">
            <fx:Script>
            override public function set data(value:Object):void
            super.data = value;
            </fx:Script>
            <mx:LinkButton id="lkbtn_menu" textDecoration="underline" click="outerDocument.click_Setting(event)"/>
            </mx:HBox>
            </fx:Component>
            </mx:itemRenderer>
            </mx:DataGridColumn>
            <mx:DataGridColumn id="col4" headerText="Active" width="45">
            <mx:itemRenderer>
            <fx:Component>
            <mx:HBox>
            <fx:Script>
            import mx.collections.ArrayCollection;
            super.data = value;
            if(data.isActive==1)
            true;
            else
            false;
            </fx:Script>
            <mx:CheckBox id="chkbox_active"/>
            </mx:HBox>
            </fx:Component>
            </mx:itemRenderer>
            <mx:DataGridColumn id="col5" headerText="Indexed" width="55">
            <mx:itemRenderer>
            <fx:Component>
            <mx:HBox>
            <fx:Script>
            <![CDATA[
            super.data = value;
            if(data.isIndexed==1)
            true;
            else
            false;
            </fx:Script>
            <mx:CheckBox id="chkbox_active1" click="outerDocument.change_check(event,data)"/>
            </mx:HBox>
            </fx:Component>
            </mx:itemRenderer>
            <mx:DataGridColumn id="col6" headerText="Data Type" width="70">
            <mx:itemRenderer>
            <fx:Component>
            <mx:HBox>
            <fx:Script>
            <![CDATA[
            Bindable]
            super.data = value;
            if(data.default_datatype==4)
            else if(data.default_datatype==12)
            else
            true;
            true;
            else
            false;
            false;
            </fx:Script>
            <mx:ComboBox id="cbox_check" dataProvider="{outerDocument.cbox_array}" labelField="data"
            false" includeInLayout="false" width="70" change="outerDocument.cbox_change_event(event)"/>
            </mx:HBox>
            </fx:Component>
            </mx:itemRenderer>
            <mx:DataGridColumn id="col7" headerText="Width" width="100">
            <mx:itemRenderer>
            <fx:Component>
            <mx:HBox>
            <fx:Script>
            <![CDATA[
            super.data = value;
            if(data.default_datatype==4 || data.default_datatype==0)
            false;
            false;
            "50";
            true;
            true;
            else
            false;
            false;
            </fx:Script>
            <mx:Label id="lbl_max" text="Max Length"/>
            <mx:TextInput id="txt_length" width="30"/>
            </mx:HBox>
            </fx:Component>
            </mx:itemRenderer>
            </mx:columns>
            </mx:DataGrid>
            i think this is quite large.... i explain that wat i need nw..... there is a checkbox in the "col5"(this is column id), when the checkbox is checked--> the combox in "col6" and  label , textinput in "col7" in the same row want to get displayed..... And if it is uncheck the checkbox means both want to get dis appeared......
            thanks fr u help dude....
