1 Reply Latest reply on Feb 21, 2011 8:14 PM by Saumitra Bhave
    StageWebView close event
    BarakHarel Level 1
      is there a way to catch/listen to a window close event from javascript inside the view? (such as window.close() or self.close()).
      I'm trying to add a simple "share in facebook" button using a StageWebView, which works fine until it needs to close itself (the window, after the user login and actual post, the window should close [facebook is using "self.close()"]).
      any thoughts?
        • 1. Re: StageWebView close event
          Saumitra Bhave Level 3
          I don't think you get something like close on SWV, But there are many
          solutions to the problems you are facing.
          1. Handle the location change event. And check the URL's where you get
          redirected.  And set stage = null whenever you get the appropriate URL.
          2. You can use the swc provided by adobe for Facebook. (Google -  Facebook
          for AIR/Flash)
          3. You can use HTMLLoader(Desktop Only) and call JS functions inside page.
          (and use JS SDK of Facebook as well as any event handlers you want to listen
          to)
          Hope This Helps!!
          Saumitra R. Bhave
          AIR-Linux
