4 Replies Latest reply on Feb 24, 2011 3:06 PM by Flex harUI
    Combobox change event...
    Ananth Flex
      My problem is, in my datagrid there is a combobox in 2'nd column 1'st row and if i change the selected index means the value in next cell (that is 3'rd column
      1's row ) want to get changed......
      i'm using action script...
      please Help me....
      Thanks in advance....
        • 1. Re: Combobox change event...
          miguel8312 Level 3
          can you post the code or an example im willing to help you but i would need to look at what you are doing.
          Miguel
          • 2. Re: Combobox change event...
            Ananth Flex Level 1
            <mx:DataGrid
            id="DG_Folder_Curtain" visible="false" width="940"
            dataProvider="
            {getCurtainPatterns}" rowCount="{getCurtainPatterns.length}"
            verticalGridLines="
            false" alternatingItemColors="[#FFFFFF,#A9A9A9]" includeInLayout="false">
            <mx:columns>
            <mx:DataGridColumn id="col1" headerText="Depth" dataField="document_folder_depth" width="90">
            <mx:itemRenderer>
            <fx:Component>
            <mx:HBox>
            <fx:Script>
            <![CDATA[
            override public function set data(value:Object):void
            super.data = value;
            lbl_doc_folder_depth.text=data.document_folder_depth;
            img_doc_folder_depth.toolTip=
            "Delete this Curtain pattern from the System";
            </fx:Script>
            <mx:Image id="img_doc_folder_depth" source="/IST_Shared/IST_images/IST_icons/Modern/gif/16/normal/trash_16.gif" click="outerDocument.delete_Floder(data)"/>
            <mx:Label id="lbl_doc_folder_depth"/>
            </mx:HBox>
            </fx:Component>
            </mx:itemRenderer>
            </mx:DataGridColumn>
            <mx:DataGridColumn headerText="Parent Folder" id="col2" dataField="document_folder_name" width="200">
            <mx:itemRenderer>
            <fx:Component>
            <mx:HBox>
            <fx:Script>
            <![CDATA[
            super.data = value;
            lbl_doc_folder.text=data.document_folder_name;
            lbl_doc_folder.toolTip=
            "ID: "+data.dfcp_document_folder_id+" PATH: "+data.storage_location_path+"";
            </fx:Script>
            <mx:Image toolTip="Select Starting Folder." source="/ist_shared/ist_images/ist_icons/Modern/gif/16/normal/edit_16.gif"/>
            <mx:Label id="lbl_doc_folder"/>
            </mx:HBox>
            </fx:Component>
            </mx:itemRenderer>
            <mx:DataGridColumn headerText="Pattern Type" id="col3" width="120">
            <mx:itemRenderer>
            <fx:Component>
            <mx:HBox>
            <fx:Script>
            <![CDATA[
            import mx.collections.ArrayCollection;
            super.data = value;
            if(data.dfcp_name_pattern_type=="EQ")
            cbox_pattern_type.selectedIndex=1;
            else if(data.dfcp_name_pattern_type=="B")
            cbox_pattern_type.selectedIndex=2;
            else if(data.dfcp_name_pattern_type=="E")
            cbox_pattern_type.selectedIndex=3;
            else
            cbox_pattern_type.selectedIndex=0;
            </fx:Script>
            <mx:ComboBox id="cbox_pattern_type" dataProvider="{outerDocument.source_pattern_type}" labelField="data" change="outerDocument.change_Pattern_type(event,data)"/>
            </mx:HBox>
            </fx:Component>
            </mx:itemRenderer>
            <mx:DataGridColumn headerText="Folder Pattern" id="col4" dataField="dfcp_name_pattern" width="300">
            <mx:itemRenderer>
            <fx:Component>
            <mx:HBox>
            <fx:Script>
            <![CDATA[
            import mx.utils.StringUtil;
            public var before_change:String;
            super.data = value;
            lbl_dnp.text=data.dfcp_name_pattern;
            lbl_dnp.toolTip=
            "To Curtain the Parent Folder use the Keyword SELF.";
            public function on_click():void
            before_change=lbl_dnp.text;
            lbl_dnp.includeInLayout=
            false;
            lbl_dnp.visible=
            false;
            txt_pattern.includeInLayout=
            true;
            txt_pattern.visible=
            true;
            txt_pattern.text=lbl_dnp.text;
            txt_pattern.setFocus();
            public function txt_focuse_out(e:FocusEvent,data:Object):void
            var temp:TextInput=TextInput(e.currentTarget);
            var after_change:String=temp.text;
            e.currentTarget.visible=
            false;
            lbl_dnp.text=StringUtil.trim(temp.text);
            true;
            lbl_dnp.visible=
            true;
            if(after_change!=before_change)
            //outerDocument.flag=1;
            outerDocument.onclick_Folder_patern(e,data,after_change)
            lbl_dnp.text=after_change;
            else
            </fx:Script>
            <mx:Image source="/ist_shared/ist_images/ist_icons/Modern/gif/16/normal/edit_16.gif" toolTip="Edit The Folder Pattern." click="on_click()"/>
            <mx:Label id="lbl_dnp" visible="true" includeInLayout="true"/>
            <s:TextInput id="txt_pattern" visible="false" includeInLayout="false" focusOut="txt_focuse_out(event,data)"/>
            </mx:HBox>
            </fx:Component>
            </mx:itemRenderer>
            <mx:DataGridColumn headerText="Right Level" id="col5" width="120">
            <mx:itemRenderer>
            <fx:Component>
            <mx:HBox>
            <fx:Script>
            <![CDATA[
            super.data = value;
            if(data.dfcp_sec_rights_level==1)
            cbox_right_level.selectedIndex=2;
            else if(data.dfcp_sec_rights_level==10)
            cbox_right_level.selectedIndex=3;
            else if(data.dfcp_sec_rights_level==50)
            cbox_right_level.selectedIndex=4;
            else if(data.dfcp_sec_rights_level==0)
            cbox_right_level.selectedIndex=1;
            else
            cbox_right_level.selectedIndex=0;
            //var selected_index:int=cbox_level.selectedIndex;
            </fx:Script>
            <mx:ComboBox id="cbox_right_level" dataProvider="{data.source_pattern_type}" labelField="sec_rights_level" change="outerDocument.onchange_cbox_level(event,data)"/>
            </mx:HBox>
            </fx:Component>
            </mx:itemRenderer>
            <mx:DataGridColumn headerText="Effective" id="col6" dataField="dfcp_sec_rights_level" width="150">
            <mx:itemRenderer>
            <fx:Component>
            <mx:HBox>
            <fx:Script>
            <![CDATA[
            super.data = value;
            if(data.df_sec_rights_level <= data.dfcp_sec_rights_level)
            lbl_sec_right_level.text=data.dfcp_sec_rights_level;
            else
            lbl_sec_right_level.text=data.df_sec_rights_level;
            lbl_sec_right_level.toolTip=
            "The Effective User Right Level required.";
            </fx:Script>
            <mx:Label id="lbl_sec_right_level"/>
            <mx:HBox paddingLeft="90">
            <mx:Image source="/ist_shared/ist_images/ist_icons/Modern/gif/16/normal/filesys_refresh_16.gif" toolTip="Refresh the Folder Curtains." click="outerDocument.onclick_Refresh(data)"/>
            </mx:HBox>
            </mx:HBox>
            </fx:Component>
            </mx:itemRenderer>
            </mx:columns>
            </mx:DataGrid>
            Hi... Here i explain u.... For my datagrid i'm getting data from remote object... note that in "col5"(column id) there is a combobox, if the selected index of combobox get changed means, the text for label in "col6"(column id) in the same row (but next column) wann to be"?".... i dont know how to do this... help me buddy......
            • 3. Re: Combobox change event...
              Ananth Flex Level 1
              hi all.... plese help tp solve the above probl
              me please.....
              my problem is...
              • 4. Re: Combobox change event...
                Flex harUI Adobe Employee
                When the combobox changes, you should update the dataprovider item
                immediately.  The other column should be bound to the appropriate field in
                the dataprovider item.
