3 Replies Latest reply on Feb 21, 2011 6:35 AM by try67
    JS and PDF generation
    kUr4m4 Level 1
      Lets say I want to share a pdf but I want whoever is visioning it to have JS enabled, otherwise i don't want to display the pdf. Can I share a 'blank' pdf with only JS code in it that will generate a new pdf with all the text I want in it? Will this just provide a blank pdf if JS is disabled?
      thank you for your help
        • 1. Re: JS and PDF generation
          It's possible to generate a PDF using JavaScript (not in Reader, though),
          but it's very limited and cumbersome.
          A better option is to use an "envelope" to show a blank PDF that can only be
          opened when JavaScript is enabled. I know some people have been developing
          such a tool, perhaps they could shed more light on this technique.
          • 2. Re: JS and PDF generation
            kUr4m4 Level 1
            thank you for the quick reply!
            Following that line of thought, I could probably even display an alternative version, asking for JS to be enabled if the user wishes to view the content of the pdf?
            • 3. Re: JS and PDF generation
              Yes, you can use layers to do that and then create a small script that shows
              the layer with the actual content. However, I think this can also be
              manually done with JS disabled, so it's not 100% fool-proof.
