4 Replies Latest reply on Feb 23, 2011 7:06 AM by robglobal
    The Skin doesn't update display
    Maximist Level 1
      Hallo. I have my list with my itemRenderer. Inside my itemRenderer i have a label and a button :
      <s:states>
      <s:State name="normal"/>
      <s:State name="hovered"/>
      <s:State name="selected"/>
      </s:states>
      <s:Label id="dataOrdine"
      x="2"
      maxWidth="70"
      maxDisplayedLines="1"
      verticalCenter="0"
      color.selected="#FFFFFF"
      fontSize="12"
      paddingTop="2"/>
      <ns:mioPulsante id="dettagliTransazione_btn" x="685" label="Dettagli" width="70" skinClass="skins.pulsanteSemplice_skin" click="dettagliTransazioneClickHandler(event)"
      coloreSfondoPulsanteComune="{data.coloreSfondoPulsanteComune}" coloreEtichettaPulsanteComune="{data.coloreSfondoEtichettaPulsanteComune}"/>
      </s:ItemRenderer>
      mioPulsante is a custom button and inside of it there are 2 property (coloreSfondoPulsanteComune and coloreEtichettaPulsanteComune). If inside my itemRenderer i trace data.coloreSfondoPulsanteComune the value is right, anyway on display i don't see the right color... Maybe i should do something to update display.. I don't know what to do...
      Pls help..
      Max
        • 1. Re: The Skin doesn't update display
          saisri2k2 Level 4
          </s:ItemRenderer>
          The above properties when set, would they call invalidateDisplayList() in the component? if so, in the updateDisplayList() do you set thse colors to the corresponding components?  Also, instead of using { }  (bindable tags) override the data and set thse properties from the data like this
          override public function set data(value:Object):void{// this method in the itemrender
                  dettagliTransazione_btn.coloreSfondoPulsanteComune = data.coloreSfondoPulsanteComune;
          in the ns:mioPulsante override the updateDisplayList
          override protected function updatedisplayList(xxxx):void{
          super.updatedisplaylist();
          this.setStyle("xx",coloreSfondoPulsanteComune);
          • 2. Re: The Skin doesn't update display
            Maximist Level 1
            Hallo. Thx for the help but my structure is a little different. I have a skin.. Ok i will be more clear:
            My itemRenderer:
            <s:states>
            </s:states>
            x="2"
            maxWidth="70"
            verticalCenter="0"
            fontSize="12"
            paddingTop="2"/>
            </s:ItemRenderer>
            My mioPulsante :
            <s:Button xmlns:fx="http://ns.adobe.com/mxml/2009"
              xmlns:mx="library://ns.adobe.com/flex/mx">
            <fx:Declarations>
            <!-- Place non-visual elements (e.g., services, value objects) here -->
            </fx:Declarations>
            <fx:Script>
            <![CDATA[
            public var coloreSfondoPulsanteComune:String;
            public var coloreEtichettaPulsanteComune:String;
            public var coloreSfondoPulsanteCancellaSelezione:String;
            public var coloreEtichettaPulsanteCancellaSelezione:String;
            </fx:Script>
            </s:Button>
            And then i have my pulsanteSemplice_skin:
            <s:SparkSkin xmlns:s="library://ns.adobe.com/flex/spark" xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:d="http://ns.adobe.com/fxg/2008/dt" xmlns:flm="http://ns.adobe.com/flame/2008" xmlns:ai="http://ns.adobe.com/ai/2009" height="21" width="200" initialize="aInizializzazioneCompleta(event)">
            <s:states>
            <s:State name="up"/>
            <s:State name="over"/>
            <s:State name="down"/>
            <s:State name="disabled"/>
            </s:states>
            <fx:Metadata>
            [HostComponent("componenti.Componenti_Condivisi.mioPulsante")]
            </fx:Metadata>
            <fx:Script>
            <![CDATA[
            import componenti.Componenti_Condivisi.mioPulsante;
            import mx.collections.ArrayList;
            import mx.events.FlexEvent;
            protected function aInizializzazioneCompleta(event:FlexEvent):void
            (hostComponent.coloreSfondoPulsanteComune != null) ? (this.coloreSfondoPulsanteComune.color = parseInt(hostComponent.coloreSfondoPulsanteComune) as uint) : (this.coloreSfondoPulsanteComune.color = this.coloreSfondoPulsanteComune.color);
            (hostComponent.coloreEtichettaPulsanteComune != null) ? (this.labelDisplay.setStyle('color', (parseInt(hostComponent.coloreEtichettaPulsanteComune) as uint))) : (this.labelDisplay.setStyle('color', this.labelDisplay.getStyle('color')));
            </fx:Script>
            <s:Group height="100%" width="100%" buttonMode.over="true" alpha.disabled="0.5">
            <s:Rect height="100%" width="100%" x="0" y="0" radiusX="3" radiusY="3">
            <s:fill>
            <s:SolidColor id="coloreSfondoPulsanteComune" color="#000000"/>
            </s:fill>
            </s:Rect>
            </s:Group>
            <s:RichText id="labelDisplay" color="#FFFFFF" alpha.disabled="0.5" columnCount="1" fontSize="16" textDecoration="underline" horizontalCenter="0" verticalCenter="0" textDecoration.up="none" color.over="#FF0000" buttonMode.over="true"/>
            </s:SparkSkin>
            As you can see what i am tryng to change is the color of the rect in my skin and that is what i can't do... I hope now you can help me better.
            Thx for all
            Max
            • 3. Re: The Skin doesn't update display
              saisri2k2 Level 4
              Probably use states in the skin? Add a couple of more states to the skin and change the colrs. How to change the state in the skin? seel the
              example below.
              http://saturnboy.com/2009/09/flex4-component-states-skin-states/
              • 4. Re: The Skin doesn't update display
                robglobal Level 1
                That's right. Something like this should do the trick:
                     color.over="#cc0000"/>
                Just add the .over state to the color node.
