0 Replies Latest reply on Feb 21, 2011 1:12 PM by gurkerl83
    CustomList extends ListBase bug !!! Serious !!!
    gurkerl83
      hi, listbase changed in sdk build 19786,
      19786 + post like not released 20135 which is included in the prerelease flashbuilder
      override protected function partAdded(partName:String, instance:Object):void
              super.partAdded(partName, instance);
              if (instance == dataGroup)
                  // Not your typical delegation, see 'set useVirtualLayout'
                  if (_useVirtualLayout && dataGroup.layout && dataGroup.layout.virtualLayoutSupported)
                      dataGroup.layout.useVirtualLayout = true;
                  dataGroup.addEventListener(
                      RendererExistenceEvent.RENDERER_ADD, dataGroup_rendererAddHandler);
                      RendererExistenceEvent.RENDERER_REMOVE, dataGroup_rendererRemoveHandler);
      so, on  RendererExistenceEvent.RENDERER_ADD and REMOVE the handler functions are called.
      Previously to that version eg. in
      there is no internal handling when a item is added to the datagroup.
      pre 19786
                  if (_useVirtualLayout && dataGroup.layout)
      Some libs exists eg. the expander Toolkit or a Flex 4 Tabbar http://examples.flashdan.net/blog/posts/Flex%204%20TabBar/srcview/index.html
      that rely on the RendererExistenceEvent.RENDERER_ADD, RendererExistenceEvent.RENDERER_REMOVE Event to trigger a different behaviour.
      In the above tabbar CustomTabBar Class which extends TabBar extends TabbarBase extends ListBase;  the following partAdded method is included:
      It runs greate in pre versions of sdk 19786 but breaks completly in 19786!!!
      Custom tabbar part added:
      protected override function partAdded(partName:String, instance:Object):void {
                  if(instance == dataGroup){
                      dataGroup.addEventListener(RendererExistenceEvent.RENDERER_ADD, dataGroup_rendererAddHandler);
                      dataGroup.addEventListener(RendererExistenceEvent.RENDERER_REMOVE, dataGroup_rendererRemoveHandler);
                      dataGroup.addEventListener(CustomTabBarCloseEvent.CLOSE_TAB, closeHandler);
