1 Reply Latest reply on Feb 22, 2011 10:59 AM by _durin_
    Is it possible to use the sounds of loopology in Audition for Mac?
    Rolegisonoro
      I try to use the different loops of loopology with adobe audition for mac, but it didn´t recognize the files.
      Is there a way that I can use those loops?
        • 1. Re: Is it possible to use the sounds of loopology in Audition for Mac?
          _durin_ Adobe Employee
          I believe that all Loopology content will be available to Audition for the Mac at release.  Older editions of Loopology should be compatible as well, though pre-Audition 2.0 versions used .CEL files which are only partially supported at this time.  Loopology content from Audition 2.0 or higher, or downloaded from Adobe.com should be fully compatible .WAV files.  Can you describe what happened when you tried to access the content?
