0 Replies Latest reply on Feb 21, 2011 3:35 PM by StylusPilot
    Strange layers issue when printing
    StylusPilot
      Hi Guys,
      I am having a strange issue which is probably easy to fix however I am not a heavy adobe user and dont know where to start.
      This is the rough process to explain my point but a summary is - when printing PDF files they do not appear as they do on screen.
      A picture/document is created in Adobe Illustrator, an outline PDF is then created and saved
      I can open the outline PDF successfully, in newer versions of PDF Reader (v8+) the PDF displays on screen correctly. In older versions the PDF is missing lines or various things.
      If I print this PDF all these lines etc still missing. I know this sounds vague but I will try and explain.
      An example is this - the document is a black box with a silver smaller box on top in the centre. On the screen it shows correctly. When I print, the black box is printed with no silver box.
      I have just discovered that the silver box is actually printed however its printed in the background so I think its got to do with layers? If I make the black box to be white, and then print I can see my silver box, so its clear it has been printed in the wrong order.
      Oh another thing I have found is the default format for saving PDF files is v1.5 if I choose an older version, the layers are printed correctly
      I have both Adobe reader installed on Mac's and PC and the issue happens on both
      Surely all the printers I have can't be all in-compatible
      Printers:
      Kyocera KM-4050
      Kyocera FSC5200
      Canon MX850
      Lanier MP2500
      Lanier MP2800
