1 Reply Latest reply on Jun 27, 2007 10:03 PM by raghunathrao
    VideoDisplay control issue
    Shiv_Kumar
      I'm simply trying to play an .flv file using the VideoDisplay control.
      This .flv file works just fine in Flash.
      When I play the file I see the following error in the debugger:
      Error: 1000: UNo bitrate match
      at mx.controls.videoClasses::VideoPlayer/play()[E:\dev\flex_3_beta1\sdk\frameworks\projects\ framework\src\mx\controls\videoClasses\VideoPlayer.as:1297]
      at mx.controls::VideoDisplay/play()[E:\dev\flex_3_beta1\sdk\frameworks\projects\framework\sr c\mx\controls\VideoDisplay.as:1413]
      at Flex3Test/___Flex3Test_Button1_click()[C:\inetpub\wwwroot\ResolveTest\Flex3Test\Flex3Test .mxml:10]
      I can't understand the error message. Can someone else verify this issue? Why would the video play fine in Flash CS 3 but in Flex 2.01 or 3.0?
        • 1. Re: VideoDisplay control issue
          raghunathrao Level 1
          This RTE (Run Time Error) usually occurs when the VideoDisplay has no source set to it. I have verified that the VideoDisplay works well, otherwise in Flex3Beta and Flex2.0.1.
          If that is what you are seeing, then it is a valid exception. Can you post your code? We can take a look
          Raghu
