0 Replies Latest reply on Feb 21, 2011 9:08 PM by Ananth Flex
    Here is the code....
    Ananth Flex Level 1
      <mx:DataGrid
      id="dg_profile_groups" dataProvider="{first}" width="940" color="#000000"
      alternatingItemColors="
      [#FFFFFF,#A9A9A9]" verticalScrollPolicy="on" itemClick="item_click(event)">
      <mx:columns>
      <mx:DataGridColumn id="col1" headerText="Label" width="200" dataField="spk_name"/>
      <mx:DataGridColumn id="col2" headerText="Key" width="180" dataField="spk_key"/>
      <mx:DataGridColumn id="col3" headerText="Defaule Value" width="150" dataField="lbl_spk_default_value">
      <mx:itemRenderer>
      <fx:Component>
      <mx:HBox horizontalScrollPolicy="off">
      <fx:Script>
      <![CDATA[
      override public function set data(value:Object):void
      super.data = value;
      var str_search:String="#";
      var str_app:String=data.app_spk_default_value;
      var str_spk:String=data.spk_default_value;
      var title_spk_default_value:String;
      var lbl_spk_default_value:String;
      if(outerDocument.Get_all_keys.length>0)
      if(str_app!=null && str_app!="")
      if(str_app.search(str_search)>=0)
      try
      lbl_spk_defaultvalue=
      "[1A]"+data.app_spk_default_value;
      catch(e:Error)
      "Error";
      else
      try
      "[2A]"+data.app_spk_default_value;
      catch(e:Error)
      "Error";
      title_spk_defaultvalue=data.app_spk_default_value;
      else
      if(str_spk!=null)
      if(str_spk.search(str_search)>=0)
      try
      "[1]"+data.spk_default_value;
      catch(e:Error)
      "Error";
      else
      try
      "[2]"+data.spk_default_value;
      catch(e:Error)
      "Error";
      title_spk_defaultvalue=data.spk_default_value;
      if(outerDocument.My_mpf_level>=200)
      var title_x:String=title_spk_default_value;
      else
      var title_x:String="";
      if(lbl_spk_defaultvalue==null)
      "N/A";
      lkbtn_menu.label=lbl_spk_default_value;
      lkbtn_menu.toolTip=
      "[1]Variable [2]Static [nA]App Specific "+title_x+"";
      </fx:Script>
      <mx:LinkButton id="lkbtn_menu" textDecoration="underline" click="outerDocument.click_Setting(event)"/>
      </mx:HBox>
      </fx:Component>
      </mx:itemRenderer>
      </mx:DataGridColumn>
      <mx:DataGridColumn id="col4" headerText="Active" width="45">
      <mx:itemRenderer>
      <fx:Component>
      <mx:HBox>
      <fx:Script>
      <![CDATA[
      import mx.collections.ArrayCollection;
      super.data = value;
      if(data.isActive==1)
      chkbox_active.selected=
      true;
      else
      false;
      </fx:Script>
      <mx:CheckBox id="chkbox_active"/>
      </mx:HBox>
      </fx:Component>
      </mx:itemRenderer>
      <mx:DataGridColumn id="col5" headerText="Indexed" width="55">
      <mx:itemRenderer>
      <fx:Component>
      <mx:HBox>
      <fx:Script>
      <![CDATA[
      super.data = value;
      outerDocument.chk_active=chkbox_active1;
      if(data.isIndexed==1)
      chkbox_active1.selected=
      true;
      else
      false;
      </fx:Script>
      <mx:CheckBox id="chkbox_active1" click="outerDocument.change_check(event,data)"/>
      </mx:HBox>
      </fx:Component>
      </mx:itemRenderer>
      <mx:DataGridColumn id="col6" headerText="Data Type" width="70">
      <mx:itemRenderer>
      <fx:Component>
      <mx:HBox>
      <fx:Script>
      <![CDATA[
      Bindable]
      outerDocument.cbox_change=cbox_check;
      super.data = value;
      if(data.default_datatype==4)
      cbox_check.selectedIndex=1;
      else if(data.default_datatype==12)
      cbox_check.selectedIndex=2;
      else
      cbox_check.selectedIndex=0;
      cbox_check.visible=
      true;
      cbox_check.includeInLayout=
      true;
      else
      false;
      cbox_check.visible=
      false;
      </fx:Script>
      <mx:ComboBox id="cbox_check" dataProvider="{outerDocument.cbox_array}" labelField="data"
      visible="
      false" includeInLayout="false" width="70" change="outerDocument.cbox_change_event(event)"/>
      </mx:HBox>
      </fx:Component>
      </mx:itemRenderer>
      <mx:DataGridColumn id="col7" headerText="Width" width="100">
      <mx:itemRenderer>
      <fx:Component>
      <mx:HBox>
      <fx:Script>
      <![CDATA[
      outerDocument.txt_max=txt_length;
      outerDocument.lbl_length=lbl_max;
      super.data = value;
      if(data.default_datatype==4 || data.default_datatype==0)
      txt_length.text=
      lbl_max.visible=
      false;
      txt_length.visible=
      false;
      txt_length.text=
      "50";
      txt_length.visible=
      true;
      lbl_max.visible=
      true;
      else
      lbl_max.visible=
      false;
      txt_length.visible=
      false;
      </fx:Script>
      <mx:Label id="lbl_max" text="Max Length"/>
      <mx:TextInput id="txt_length" width="30"/>
      </mx:HBox>
      </fx:Component>
      </mx:itemRenderer>
      </mx:columns>
      </mx:DataGrid>
      i think this is quite large.... i explain that wat i need nw..... there is a checkbox in the "col5"(this is column id), when the checkbox is checked--> the combox in "col6" and  label , textinput in "col7" in the same row want to get displayed..... And if it is uncheck the checkbox means both want to get dis appeared......
      thanks fr u help dude....
