7 Replies Latest reply on Feb 28, 2011 7:26 AM by pbesi
    How to set selectedIndex of a DropDownList bound to a DataGrid
    pbesi
      Hello I'm a newbie.
      Here my problem:
      I've two kind of objects, named Persona and Email. Persona has a one to many  relation with Email object.
      Persona is displayed in a DataGrid.
      Cliccking a row (a Persona item), I need to display all related emails in a  DropDownList. I also want to display the first email automatically  (selectIndex=0).
      It works for the first row.
      Then, after the first row, I click the second row. It loads the related  emails correctly but doesn't not display the first email automatically, I have  to click on the dropdwonlist and choose it. If I want to see the first email  automatically, I need to click the second row twice. But now, going back to the  first row, it loads the related emails, but doesn't display the first one  automatically.
      Can anyone suggest me where is the problem?
      Follows my code:
      <s:Application
      xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:mx="library://ns.adobe.com/flex/mx"  minWidth="955" minHeight="600"  applicationComplete="ps.getPersonas()">
      <fx:Script>
      <![CDATA[
      import mx.collections.ArrayCollection;
      import mx.controls.Alert;
      import mx.rpc.events.ResultEvent;
      import spark.events.IndexChangeEvent;
      [Bindable]
      private var persone:ArrayCollection = new ArrayCollection();
      private function getPersonas_resultHandler(event:ResultEvent):void
      persone = event.result
      as ArrayCollection;
      private function aggiornaDropDown(event:MouseEvent):void
      Alert.show(dd.selectedIndex.toString());
      dd.selectedIndex=0;
      dd.dataProvider = dg.selectedItem.emails;
      dd.labelField=
      "address";
      </fx:Script>
      <fx:Declarations>
      <s:RemoteObject id="ps" destination="provaService"  endpoint="http://localhost:8400/FlexSpringServer/messagebroker/amf">
      <s:method name="getPersonas" result="getPersonas_resultHandler(event)" />
      </s:RemoteObject>
      </fx:Declarations>
      <mx:DataGrid x="138" y="126" id="dg" dataProvider="{persone}"  click="aggiornaDropDown(event)">
      <mx:columns>
      <mx:DataGridColumn headerText="ID" dataField="id"/>
      <mx:DataGridColumn headerText="Nome" dataField="nome"/>
      <mx:DataGridColumn headerText="Cognome" dataField="cognome"/>
      </mx:columns>
      </mx:DataGrid>
      <s:DropDownList x="545" y="201" id="dd"/>
      </s:Application>
      I also tried to set the selectIndex attribute to 0 inside the DroipDownList  tag, but I couldn't solve the problem.
      Thank you
      Paolo
        • 1. Re: How to set selectedIndex of a DropDownList bound to a DataGrid
          saisri2k2 Level 4
          Instead do, selectedItem = [first Object in the Email list].
          how to get the first element in the list ? Ans: ArrayCollection.getItemAt(0)
          • 2. Re: How to set selectedIndex of a DropDownList bound to a DataGrid
            pbesi Level 1
            Thank you saisri2k2,
            the problem was not solved. The same behavior described above.
            Is it possible that the problem arise from the fact that I change the dataprovider after each row click? Perhaps something is resetted?
            Any other suggestion please?
            Thank you
            Paolo
            • 3. Re: How to set selectedIndex of a DropDownList bound to a DataGrid
              pbesi Level 1
              Hello.
              any other suggestion?
              I try to summarize:
              Given a datagrid, click on a row.
              A dropdownlist load data related to the cliccked object, and display the first item.
              Cliccking a second row, dropdownlist loads the new data but doesn't display the first item, also setting selectedIndex=0 via AS or as MXML attribute.
              Why?
              thank you
              Paolo
              • 4. Re: How to set selectedIndex of a DropDownList bound to a DataGrid
                chris_t10 Level 1
                Try setting the index after you set the dataProvider.
                dd.selectedIndex=0;
                dd.labelField="address";
                Chris
                • 5. Re: How to set selectedIndex of a DropDownList bound to a DataGrid
                  Flex harUI Adobe Employee
                  What does the code for your renderer look like?
                  • 6. Re: How to set selectedIndex of a DropDownList bound to a DataGrid
                    pbesi Level 1
                    Hello.
                    I'm sorry but because I'm a newbie your question is not clear.
                    I wrote the code already included above and two AS valueobjects related to Persona and Email objects.
                    No more else.
                    Do I have to write a "renderer". Could you please clarify your question?
                    I attach new updates to my code but the problem is not solved.
                    Thank you
                    Paolo
                    <s:Application
                    xmlns:s="
                    xmlns:mx="
                    library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" applicationComplete="ps.getPersonas()" backgroundColor="#F4F384">
                    <fx:Script>
                    <![CDATA[
                    import mx.events.ListEvent;
                    Bindable]
                    Bindable]
                    private var emails:ArrayCollection = new ArrayCollection();
                    private function aggiornaDropDown(event:Event):void
                    var persona:Persona = new Persona();
                    persona = dg.selectedItem
                    as Persona;
                    ps.getPersonaEmails(persona);
                    private function getEmails_Handler(event:ResultEvent):void
                    emails = event.result
                    as ArrayCollection;
                    dd.selectedItem = emails.getItemAt(0); //dd.selectedIndex = 0 also doesn't work
                    </fx:Script>
                    <fx:Declarations>
                    <s:RemoteObject id="ps" destination="ProvaService" endpoint="http://localhost:8400/FlexSpringServer/messagebroker/amf">
                    <s:method name="getPersonas"/>
                    <s:method name="getPersonaEmails" result="getEmails_Handler(event)"/>
                    </s:RemoteObject>
                    </fx:Declarations>
                    <s:Panel x="23" y="42" width="505" height="263" title="Contatti">
                    <s:controlBarContent>
                    </s:controlBarContent>
                    <mx:DataGrid x="42" y="26" id="dg" dataProvider="{ps.getPersonas.lastResult}" click="aggiornaDropDown(event)">
                    <mx:columns>
                    </mx:columns>
                    </mx:DataGrid>
                    </s:Panel>
                    <s:Panel x="27" y="321" width="501" height="269" title="Dettagli contatti">
                    <s:VGroup x="45" y="10" width="200" height="200">
                    <s:HGroup width="150" height="20">
                    <s:Label text="Nome:"/>
                    <s:Label text="{dg.selectedItem.nome}" paddingLeft="23"/>
                    </s:HGroup>
                    <s:HGroup x="45" y="36" width="150" height="22">
                    <s:Label text="Cognome:"/>
                    <s:Label text="{dg.selectedItem.cognome}"/>
                    </s:HGroup>
                    <s:HGroup x="45" y="70" width="200" height="118">
                    <s:Label text="Emails:" paddingTop="5"/>
                    <s:DropDownList id="dd" dataProvider="{emails}" labelField="address"/>
                    </s:HGroup>
                    </s:VGroup>
                    </s:Panel>
                    <s:Label x="65" y="10" text="Rubrica" fontSize="33" fontWeight="bold" color="#162ABF"/>
                    </s:Application>
                    • 7. Re: How to set selectedIndex of a DropDownList bound to a DataGrid
                      pbesi Level 1
                      now it works putting a very strange code:
                      <s:DropDownList
                      id="dd" dataProvider="{emails}" labelField="address" selectedItem="whatever_you_want_to_write_here{dd.dataProvider}"/>
                      Anyone knows what happens? Instead of "whatever_you_want_to_write_here" you can write a word you prefer!!
                      thank you
                      Paolo
