6 Replies Latest reply on Feb 24, 2011 11:28 AM by Pablo Souza
    s:ComboBox Vrs mx:ComboBox
    PaddyMc2010 Level 1
      Hi, i am currenly facing a problem when trying to create a combobox on a s:titlewindow.  When i use the spark combo box it will not display anything however the mx Combobox will display as expeted.  Could someone advise me on what i am doing wrong or how i might be able to get around this?
      I have the below XMLList via a HTTP Service
      [Bindable] public var testSourceData:XMLList
      private function rGettestData(evt:ResultEvent):void {
      testSourceData = evt.result.r;}
      mx:HTTPService
      id="hsSourceData" method="GET" resultFormat="e4x"
      result="rGettestData(event)"
      fault="fault(event)"
      useProxy="false"
      </mx:HTTPService>
      <mx:ComboBox id="cbSource" width="150" dataProvider="{testSourceData}"   labelField="description"/>  ----Works Fine
      <s:ComboBox id="cbSource" width="150" dataProvider="{xmlGetSourceData}" labelField="description"/>  ----Does not display
        • 1. Re: s:ComboBox Vrs mx:ComboBox
          Pablo Souza Level 3
          Have you typed wrong or the Spark combobox has a different provider?
          Regards,
          Pablo Souza
          • 2. Re: s:ComboBox Vrs mx:ComboBox
            Pablo Souza Level 3
            I'm not sure if I fully understood your problem but take a look at this code, I believe it can help you:
                           xmlns:mx="library://ns.adobe.com/flex/mx"
                           creationComplete="srv.send();">
                <fx:Declarations>
                    <mx:HTTPService
                        id="srv"
                        rl="http://aspexamples.adobe.com/chart_examples/expenses-xml.aspx"/>
                </fx:Declarations>
                <s:VGroup width="100%" height="100%" horizontalAlign="center">
                    <mx:ComboBox width="150" dataProvider="{srv.lastResult.data.result}"
                                labelField="month"/>
                    <s:ComboBox width="150" dataProvider="{srv.lastResult.data.result}"
                </s:VGroup>
            </s:Application>
            Best regards,
            Pablo Souza
            • 3. Re: s:ComboBox Vrs mx:ComboBox
              PaddyMc2010 Level 1
              Paulo thanks for your response.
              Essentially my problem is when i use
              <s
              :ComboBox id="cbSourceName" width="150" dataProvider="{testData}" labelField="description" />
              My Combo box is blank with nothing in the dropdown.
              However
              When i use below mx:ComboBox this is fine and all is populated as expected.  Same XML List, same dataprovider, same httpe service etc.
              <mx:ComboBox id="cbSourceName" width="150" dataProvider="{testData}" labelField="description" />
              I am at a loss as to why this is not working.  I am thinking it must be some sort of XML issue perhaps although i dont no.  I guess i will just have to use the mx:ComboBOx for now until i can figure out why no data is populating.
              • 4. Re: s:ComboBox Vrs mx:ComboBox
                Pablo Souza Level 3
                If you are only listing the data from dataprovider, you can use the Spark DropDownList control instead of the ComboBox control.
                Regards,
                Pablo Souza
                • 5. Re: s:ComboBox Vrs mx:ComboBox
                  PaddyMc2010 Level 1
                  Pablo many thanks for your responses.
                  It turns out this issue was due to fact as i had my xml in xmlList not xmlListCollection.
                  Again
                  • 6. Re: s:ComboBox Vrs mx:ComboBox
                    Pablo Souza Level 3
                    Ok, great!
