2 Replies Latest reply on Feb 23, 2011 4:22 PM by eye_j
    Problem with dispatching events, TypeError #1034
    eye_j
      Hi guys,
      I`m trying to develop a multitier Flex app and i have one problem with events. Maybe its simple but i`m bumping my head and cannot find an answer.
      My application will use AMFPHP to exchange data with the server. Since, i will have a lot of PHP services, i decided to create one RemoteService class, which will handle communication to the server (create and manage AMF channels, introspects error messages from the server..). RemoteService class will be the base class for the Service classes (SecurityService, UserService...) which will implement specific logic but the communication part will inherit from the base class.
      So, my problem is this: On mxml form, i create UserService and call its method GetUsers(). UserService initiate the call to the server through its base class. When i get the response in UserService class, i want to dispach a custom RemoteServiceEvent which will transfer a list of users wrapped in one value object (named AsVO).
      So, when i try to dispatch the event from UserService class to the mxml form like this:
      protected function onUserListResult(event:ResultEvent):void
         var result:AsVO = ClassConverter.AmfToAsConverter(event.result as AmfVO);
         dispatchEvent(new RemoteServiceEvent(result, RemoteServiceEvent.RESULT));
      i get the following error:
      TypeError: Error #1034: Type Coercion failed: cannot convert my.domain.events::RemoteServiceEvent@95b6ac1 to mx.rpc.events.ResultEvent.
      On the form, i have the following code:
      userService = new UserService();
      userService.addEventListener(RemoteServiceEvent.RESULT, handleResult);
      userService.getUserList();
      If i comment the line
      i dont get an error.
      Any help would be appreciated.
        • 1. Re: Problem with dispatching events, TypeError #1034
          robglobal
          You should be able to fix it pretty simply by changing this:
          to this:
          protected function onUserListResult(event:RemoteServiceEvent):void
          • 2. Re: Problem with dispatching events, TypeError #1034
            eye_j Level 1
            Now i see i`ve made  a confusing explanation. Sorry for that.
            because this function is event handler of RemoteObject defined in RemoteService class. Like i already said, i defined one superclass to maintain communication related stuff, and when the subclasses initiate the call to the remote methods, they use RemoteObject. So, in UserService, i have:
            public function getUserList():void
               remoteObject.getUserList.addEventListener(ResultEvent.RESULT, onUserListResult);
               remoteObject.getUserList();
            Since here is ResultEvent type of event,
            is ok. As the matter of fact, i do get the list of users, and i wrap it successfully in AsVO, UserService code is ok. I get the error when i try to forward this object to the mxml form, by dispatching the custom event.
            Thanks!
