1. Re: Ghosting
JJLAPIN Feb 23, 2011 11:19 AM (in response to Gualala Barbara)Did you try resaving the jpg as a psd or tiff and place that?
2. Re: Ghosting
Gualala Barbara Feb 23, 2011 11:29 AM (in response to JJLAPIN)Yes, I made it into a tif, placed it but it still ghosts.
3. Re: Ghosting
cblack412 Feb 23, 2011 1:37 PM (in response to Gualala Barbara)Sounds like the image is too big for the frame. Try one of the fitting commands. Select the object and then use: Object -> Fitting. This will fit your image properly in the frame. Try each on to see which one works best for your design.
4. Re: Ghosting
Gualala Barbara Feb 23, 2011 2:07 PM (in response to cblack412)Tried all the fitting choices and it still ghosts.
Just changed the tif into a gif and now it works. Oh, the mysteries....
.....barbara
5. Re: Ghosting
Gualala Barbara Feb 23, 2011 2:07 PM (in response to Gualala Barbara)Changed the gif into a tif and now it works....
6. Re: Ghosting
cblack412 Feb 24, 2011 7:55 AM (in response to Gualala Barbara)I think it might have been the transparency setting of the image. Try re-importing the TIFF image and see if it ghosts again. If so, check the opacity setting on the object.
7. Re: Ghosting
Gualala Barbara Feb 25, 2011 10:32 AM (in response to cblack412)When I import the tif image into InDesign, it is importing as 100%
opacity. I checked this Objects>Effects>Transparency>Opacity 100%.
When I view it in PhotoShop I can see the entire image as one layer. The
person who sent the file sent it as a one layer tif. Keep wondering if
perhaps when they flattened their file they did something different?
I've solved my immediate problem by making the file a gif. It worked
for this image because it was a line drawing, but am curious as to why
this image isn't showing up in InDesign. I often receive images to use
as part of our forms and this is the first time this has happened.
....barbara
